CCleaner Community Forums
Winapp2.ini additions
The seccond part of Lunascape:
[Lunascape Temp*]
LangSecRef=3022
Detect=HKLM\Software\Lunascape Corporation
Default=False
FileKey1=%AppData%\Lunascape\Lunascape6\plugins|*.*|RECURSE
I could also delete the history, but when I start Luna it comes an alert, that it doesn't find the history database. This is irritating :/
My English is not verry good, but I hope I can help. =)
Link to post
I've seen that winapp2.ini adds a "Visual Studio Backup" entry.
Could you add an entry to clean the Visual Studio Search History?
You have to look at
HKEY_CURRENT_USER\Software\Microsoft\VisualStudio\<Visual Studio version>\Find
Where <Visual Studio version> can be 10.0, 9.0 etc.
Inside this key there are values called
  • Find
  • Find0
  • Find1
  • Find2
  • Find3
  • etc.
You should delete them.
Here is a sample entry. Please test this and see what you get. Which Search button are you using that creates these? Using the Quick Find I don't create these entries.
[MS Visual Stuido Serch History *]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\VisualStudio\7.1
Detect2=HKCU\Software\Microsoft\VisualStudio\8.0
Detect3=HKCU\Software\Microsoft\VisualStudio\9.0
Detect4=HKCU\Software\Microsoft\VisualStudio\10.0
Default=False
Regkey1=HKCU\Software\Microsoft\VisualStudio\7.1\Find
Regkey2=HKCU\Software\Microsoft\VisualStudio\8.0\Find
Regkey3=HKCU\Software\Microsoft\VisualStudio\9.0\Find
Regkey4=HKCU\Software\Microsoft\VisualStudio\10.0\Find
Link to post
  • Moderators
First things first the name of it seriously needs spelling corrections. :P
Link to post
What does deleting the plugins folder do?
This delete Cache, Cookies, (maybe) saved passwords and search results. Everything is saved in this folder.
The browser history is saved in an other file, but when I delete it, Lunascape show me a warning at next start up that it doesn't find the history file. =/
Edit:
Full list of Lunascape enrtys (I modified them):
Delete Backups, Cache, Cookies, extensions (I'll try to fix this), temp files, favicon cache, startup cache & history (but Lunascape will show you a warning next start up, I can't fix this).
[Lunascape6 Backups*]
LangSecRef=3022
Default=False
FileKey1=%AppData%\Lunascape\Lunascape6\backup|*.*|RECURSE
[Lunascape6 data*]
LangSecRef=3022
warning=This will also remove your extensions
Default=False
[Lunascape6 Temp files*]
LangSecRef=3022
Default=False
FileKey1=%AppData%\lunascape\Lunascape6\ApplicationData\Temp|*.*|RECURSE
[Lunascape6 icon cache*]
LangSecRef=3022
Default=False
FileKey1=%AppData%\lunascape\Lunascape6\ApplicationData\icons|*.*|RECURSE
[Lunascape6 startup cache*]
LangSecRef=3022
Default=False
[Lunascape6 history*]
LangSecRef=3022
warning=Note: Lunascape will show you a warning next start up.
Default=False
FileKey1=%AppData%\lunascape\Lunascape6\ApplicationData|history.ld2
FileKey2=%ProgramFiles%\Lunascape\Lunascape6\applicationdata|history.ld2
Edited by update
Link to post
Quick Find :lol:
Visual Studio 2010 Ultimate
LangSecRef=3021
Default=False
This is not ok.
HKCU\Software\Microsoft\VisualStudio\10.0\Find is the "folder" (I would ban myself for calling it "folder" :mellow: ).
Inside the Find "folder" there are values like
Find -> search string value
Find 0 -> search string value
Find 1 -> search string value
Find 2 -> search string value
Find 3 -> search string value
etc.
and - I've just seen -
Replace
Replace 0
Replace 1
Replace 2
etc.
Please note the space before the number... I erroneously wrote "Find0" instead of "Find 0" in my first message.
The rule you posted deletes the whole Find "folder" (which also contains other values), while we should only delete the values inside the Find "folder" with the "Find<space>" and "Replace<space>" prefixes (please note the <space> as there's also a FindTextFromEditor value).
Link to post
Unless I am wrong there is no way to use the wildcard character in the registry ( a good safety design I am sure).So you couldn't look for Find *. Have you actually removed these entries (manually) to see what happens? I don't think there would be an easy way to remove these without knowing the exact keys you wanted and if there could be potentially be a lot of them its seems kind of inefficient to write a hundred Regkey statements and potentially cause more issues without getting them at all once. If you need to save things under the Find key like other values then I don't think there is a way to easily remove those without getting them all.
Link to post
I understand the general desire to keep the number of entries to a minimum for multiple reasons, but would someone mind sharing the reasoning behind removing separations of entirely different types of data, like cache and logs? I pick those because they exemplify replaceable and irreplaceable data, which, depending on a user's reason for using CCleaner, they may well want to treat differently on an app-by-app basis.
Link to post
MODIFIED ENTRIES
[MS Office Help Cache*]
LangSecRef=3021
Detect1=HKCU\Software\Microsoft\Office\12.0
Detect2=HKCU\Software\Microsoft\Office\14.0
Default=False
FileKey1=%LocalAppData%\Microsoft Help|*.*
[MS Office Saved CEIP Data*]
LangSecRef=3021
Default=False
FileKey1=%AppData%\Microsoft\UProof|*.bin
FileKey2=%AppData%\Microsoft\UProof|*.XML
[MS Office Temp Files*]
LangSecRef=3021
Default=False
RegKey1=HKCU\Software\Microsoft\Office\Common|FontBmpCache
FileKey1=%AppData%\Microsoft\Office|*.tmp|RECURSE
[MS Office UnsavedFiles*]
LangSecRef=3021
Default=False
FileKey1=%LocalAppData%\Microsoft\Office\UnsavedFiles|*.*
[MS Office Word More*]
LangSecRef=3021
Default=False
FileKey1=%AppData%\Microsoft\Word|*.*|RECURSE
FileKey2=%Documents%|~*.doc|RECURSE
ExcludeKey1=FILE|%AppData%\Microsoft\Word\STARTUP|*.*
ExcludeKey2=FILE|%AppData%\Microsoft\Word|listgal.dat
Changed the detect paths.
The entries above are for Office 2007 and 2010. These entries are checked in CCleaner even on the system that never had office on it because the registry path [HKEY_CURRENT_USER\Software\Microsoft\Office] is present on that system as outlook creates it.
I am listing the registry data here from a system that never had office on it.
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook]
[HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\Addins]
[OpenOffice.org*]
LangSecRef=3021
Detect1=HKLM\SOFTWARE\OpenOffice.org
Detect2=HKLM\SOFTWARE\Wow6432Node\OpenOffice.org
Default=False
FileKey1=%AppData%\OpenOffice.org\*\user\config\imagecache|*.*
FileKey2=%AppData%\OpenOffice.org\*\user\registry\cache|*.*
FileKey3=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Common.xcu
FileKey4=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Views.xcu
FileKey5=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Writer.xcu
FileKey6=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu
FileKey7=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Store.xcu
FileKey8=%AppData%\OpenOffice.org2\user\registry\data\org\openoffice\Office|Common.xcu
Changed the detect paths as the current detect path does not work on Windows with more than one User account. OpenOffice.org doesn't create reg path in HKEY_CURRENT_USER for each user account.
[snagit 11 More*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\11
Default=False
Warning=This will delete the backups of the captures that you have performed with SnagIt 11.
FileKey1=%LocalAppData%\TechSmith\Snagit|*.bin
FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf
FileKey3=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAG
FileKey4=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAGundo
RegKey1=HKCU\Software\TechSmith\Snagit\11|CaptureCount
Changed the entry name from [snagit 11*] to [snagit 11 More*]
Link to post
This entry could be removed from winapp2.ini because CC includes it already.
LangSecRef=3021
Default=False
Link to post
Is there a maximum number that the find and replace keys will reach before pruning the old ones?
Find
Find 0
Find 1
Find 2
Find 3
Find 19
Find (without number) is the "current value". "Find 0" is the first and "Find 19" is the last (so 20 values).
I didn't test "Replace" but I believe it's the same.
Link to post
How come you can't download the winapp.ini file anymore? All you get is a text file. What am I supposed to do with that?
the link in the text file to download it leads nowhere, btw.
Right click and save the download link, don't just click it
Link to post
Go figger. Thanks. I did actually try that the first time but it only offered a html link. Weird. Anyhow, thanks for what you all do here.
Link to post
Here's a new entry for JavaRa
[JavaRa (Log)*]
LangSecRef=3022
DetectFile1=%ProgramFiles%\JavaRa\JavaRa.exe
DetectFile2=%ProgramFiles%\JavaRa 2.0\JavaRa.exe
Default=False
Filekey1=%SystemDrive%\|JavaRa.log
Filekey2=%ProgramFiles%\JavaRa 2.0\|version-output.log
Add
Filekey3=%ProgramFiles%\JavaRa 2.0\|*.log|RECURSE
In version 2.0; the program logs are named based on date, so wildcard scanning is needed.
I'm Shane.
Link to post
Java produces junk that has to be removed by JavaRa
JavaRa produces junk that has to be removed by CCleaner
Is CCleaner safe at one end of the food chain or will something come along to purge CCleaner :rolleyes:
http://en.wikipedia....ki/Ad_infinitum
"Great fleas have little fleas upon their backs to bite 'em,
And little fleas have lesser fleas, and so ad infinitum.
And the great fleas themselves, in turn, have greater fleas to go on,
While these again have greater still, and greater still, and so on."
Link to post
Register a new account
Sign in
