Moderators Nergal 0 Posted June 27, 2012 Moderators Share Posted June 27, 2012 are all those DetectFiles necessary for Flash Player More*? why not use a DetectFile for the flash folder itself? Because Chrome doesn't use the normal flash locations that's why it was changed (see http://forum.pirifor...ndpost&p=216247 ) however I'm starting to wonder if that doesn't still work for flash in chrome ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
CSGalloway 0 Posted June 28, 2012 Share Posted June 28, 2012 I just ran the compress registry part of jv16 powertools and it created the following files. Can I suggest the winapp2 entry for all of the jv16 versions also check for these and similar named files in the other folders? C:\Documents and Settings\LocalService\NTUSER.DAT.tmp C:\Documents and Settings\NetworkService\NTUSER.DAT.tmp Link to post Share on other sites
2nd base 0 Posted June 28, 2012 Share Posted June 28, 2012 I was just wondering about this installshield installation information in the utilities section. If I check that and run CCleaner will it remove the log files needed to uninstall software? I don't want to check that and then go to uninstall something and not be able to. I know I ask some relatively noob questions here once in a while but I just want to be sure i don't fudge up things. Link to post Share on other sites
ricktendo64 0 Posted June 28, 2012 Share Posted June 28, 2012 I just ran the compress registry part of jv16 powertools and it created the following files. Can I suggest the winapp2 entry for all of the jv16 versions also check for these and similar named files in the other folders? C:\Documents and Settings\LocalService\NTUSER.DAT.tmp C:\Documents and Settings\NetworkService\NTUSER.DAT.tmp You need to make sure they are NOT temp files set to replace the current DAT file on next boot (I suspect they could be) Link to post Share on other sites
nodles 0 Posted June 28, 2012 Share Posted June 28, 2012 I was just wondering about this installshield installation information in the utilities section. If I check that and run CCleaner will it remove the log files needed to uninstall software? I don't want to check that and then go to uninstall something and not be able to. I know I ask some relatively noob questions here once in a while but I just want to be sure i don't fudge up things. It removes only .log files which shouldn't affect the uninstallation. I've had no problems with this entry using Win7 64bit. At the moment I'm using XP which doesn't have any .log files in that directory so nothing to clean. Link to post Share on other sites
APMichael 0 Posted June 28, 2012 Share Posted June 28, 2012 My settings.sol does not contain the domain information because I have the following settings selected (for security reasons) via the Flash control panel applet: - Block all sites from storing information on this computer. - Block all sites from using the camera and microphone. - Block all sites from using peer-assisted networking. I use the same settings. That's why I wrote this previous post: 1711. But I think that most users never change the settings, so maybe the new and more "aggressive" entry could be better. But because we don't know what the majority wants, your suggestion for a separate entry would be a fair solution. Link to post Share on other sites
APMichael 0 Posted June 28, 2012 Share Posted June 28, 2012 are all those DetectFiles necessary for Flash Player More*? why not use a DetectFile for the flash folder itself? DetectFile1=%AppData%\Adobe\Flash Player\ You are absolutely right! We can use the path of a FileKey line also for a DetectFile line. Sometimes you don't see the obvious. Link to post Share on other sites
Moderators Andavari 1 Posted June 28, 2012 Moderators Share Posted June 28, 2012 We can use the path of a FileKey line also for a DetectFile line. You can also do the same with registry detections/cleaning. Link to post Share on other sites
CSGalloway 0 Posted June 28, 2012 Share Posted June 28, 2012 You need to make sure they are NOT temp files set to replace the current DAT file on next boot (I suspect they could be) They are not replacement registry files so they are ok to remove. Link to post Share on other sites
siliconman01 0 Posted June 29, 2012 Share Posted June 29, 2012 Winapp2.ini- What change, if any, are you planning for the Adobe Flash Player More* on the next update (based on all the discussion recently here on the forum)? ? Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
Winapp2.ini 0 Posted June 29, 2012 Author Share Posted June 29, 2012 What do you guys think would be best? The DetectFile for flash or the DetectFile for Chome(s) winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
siliconman01 0 Posted June 29, 2012 Share Posted June 29, 2012 What do you guys think would be best? The DetectFile for flash or the DetectFile for Chome(s) The DetectFile for Flash Player Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
APMichael 0 Posted June 29, 2012 Share Posted June 29, 2012 What do you guys think would be best? The DetectFile for flash or the DetectFile for Chome(s) Also with Chrome the temp folders for Flash are still the same, so the DetectFile for Flash should be enough. Based on the recent discussion, here is my suggestion for the Flash entries: [Adobe Flash Player More*] LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer DetectFile=%AppData%\Adobe\Flash Player\ Default=False FileKey1=%AppData%\Adobe\Flash Player\AssetCache|*.*|RECURSE FileKey2=%WinDir%\System32\Macromed\Flash|FlashInstall.log FileKey3=%WinDir%\SysWOW64\Macromed\Flash|FlashInstall.log [Adobe Flash Player Settings*] LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer DetectFile=%AppData%\Adobe\Flash Player\ Warning=This will delete all your settings, including saved data from flash games! Default=False FileKey1=%AppData%\Adobe\Flash Player|*.*|RECURSE FileKey2=%AppData%\Macromedia\Flash Player|*.*|RECURSE Link to post Share on other sites
Alan_B 0 Posted June 29, 2012 Share Posted June 29, 2012 I just ran the compress registry part of jv16 powertools and it created the following files. Can I suggest the winapp2 entry for all of the jv16 versions also check for these and similar named files in the other folders? C:\Documents and Settings\LocalService\NTUSER.DAT.tmp C:\Documents and Settings\NetworkService\NTUSER.DAT.tmp Are you sure that you found all it did ? I found the above, and much more, when I used NTREGOPT to compress my Registry on my Laptop running XP. These are the locations which I found to clean after using NTREGOPT :- \DOCUME~1\Dad \DOCUME~1\Dad\LOCALS~1\APPLIC~1\MICROS~1\Windows \DOCUME~1\LocalService \DOCUME~1\LOCALS~1\LOCALS~1\APPLIC~1\MICROS~1\Windows \DOCUME~1\NetworkService \DOCUME~1\NETWOR~1\LOCALS~1\APPLIC~1\MICROS~1\Windows \WINDOWS\system32\config I believe every original NTUSER.DAT is renamed NTUSER.DAT.tmp and then the compressed version is created as NTUSER.DAT ready for a reboot. Hopefully if the compression is defective and kills the registry it might be feasible to delete the new and replace the old, either because Windows recognizes a disaster and reverts to "Last Good", or possibly via a Linux Boot CD and skills I hope never to need I was happy to zap all those *.DAT.TMP files after a successful reboot which "proved" no damage was done, but only because I was confident that yesterday's image backup would rescue me from the jaws of death. I do not know if, when, or how, these *.DAT.tmp files may ever be needed by normal users whose only recovery strategy is to reinstall Windows Link to post Share on other sites
Moderators Andavari 1 Posted June 29, 2012 Moderators Share Posted June 29, 2012 I was happy to zap all those *.DAT.TMP files after a successful reboot which "proved" no damage was done, but only because I was confident that yesterday's image backup would rescue me from the jaws of death. I do not know if, when, or how, these *.DAT.tmp files may ever be needed by normal users whose only recovery strategy is to reinstall Windows If an ERUNT backup was made it can restore the registry outside of Windows, without the lengthy process of needing to use an image restore. Link to post Share on other sites
Alan_B 0 Posted June 29, 2012 Share Posted June 29, 2012 If an ERUNT backup was made it can restore the registry outside of Windows, without the lengthy process of needing to use an image restore. Agreed. But many users of CCleaner do not use ERUNT - especially if they use jv16 powertools and an unaware of NTREGOPT. Link to post Share on other sites
siliconman01 0 Posted June 29, 2012 Share Posted June 29, 2012 Also with Chrome the temp folders for Flash are still the same, so the DetectFile for Flash should be enough. Based on the recent discussion, here is my suggestion for the Flash entries: [Adobe Flash Player More*] LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer DetectFile=%AppData%\Adobe\Flash Player\ Default=False FileKey1=%AppData%\Adobe\Flash Player\AssetCache|*.*|RECURSE FileKey2=%WinDir%\System32\Macromed\Flash|FlashInstall.log FileKey3=%WinDir%\SysWOW64\Macromed\Flash|FlashInstall.log [Adobe Flash Player Settings*] LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer DetectFile=%AppData%\Adobe\Flash Player\ Warning=This will delete all your settings, including saved data from flash games! Default=False FileKey1=%AppData%\Adobe\Flash Player|*.*|RECURSE FileKey2=%AppData%\Macromedia\Flash Player|*.*|RECURSE I agree. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
Moderators Nergal 0 Posted June 29, 2012 Moderators Share Posted June 29, 2012 Also with Chrome the temp folders for Flash are still the same, so the DetectFile for Flash should be enough. Based on the recent discussion, here is my suggestion for the Flash entries: Works for me ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Winapp2.ini 0 Posted June 29, 2012 Author Share Posted June 29, 2012 Alright, I'll change it to a DetectFile for flash winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
JDPower 0 Posted July 1, 2012 Share Posted July 1, 2012 Just noticed the winapp2 file has a Bit Torrent entry which is already in CCleaner. Link to post Share on other sites
Winapp2.ini 0 Posted July 2, 2012 Author Share Posted July 2, 2012 I noticed that too, I keep making a mental note to fix it but alas, my head needs some more RAM winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
SMalik 0 Posted July 2, 2012 Share Posted July 2, 2012 MODIFIED ENTRY [Auslogics BoostSpeed 5*] LangSecRef=3024 DetectFile=%ProgramFiles%\Auslogics\Auslogics BoostSpeed\boostspeed.exe Default=False FileKey1=%AppData%\Auslogics|*.htm|RECURSE FileKey2=%AppData%\Auslogics|*.log|RECURSE FileKey3=%AppData%\Auslogics|*.xml|RECURSE RegKey1=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.ErrorsFailed RegKey2=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.ErrorsFound RegKey3=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.ErrorsRemoved RegKey4=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.LastScan RegKey5=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.ErrorsFailed RegKey6=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.ErrorsFound RegKey7=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.ErrorsRemoved RegKey8=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.LastScan RegKey9=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.DateTimeLo RegKey10=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.FailedToRemove RegKey11=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.Found RegKey12=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.Removed -Changed the name from [Auslogics BoostSpeed*] to [Auslogics BoostSpeed 5*] -Removed the FileKey3=%AppData%\Auslogics|*.rsc|RECURSE (.rsc are important rollback files for Auslogics Internet Optimizer, Registry cleaner and Startup items) -Added RegKey paths to remove the unnecessary MRU's Link to post Share on other sites
SMalik 0 Posted July 2, 2012 Share Posted July 2, 2012 I think the entry listed below should be removed. I use Eclipse and I know this is a very dangerous entry. It could remove all the work from Eclipse. [Eclipse - Workspace*] Link to post Share on other sites
Winapp2.ini 0 Posted July 2, 2012 Author Share Posted July 2, 2012 You know what, I've used Eclipse too and I can't believe I overlooked that. I'll remove that one. (what was I thinking o.O) winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Nergal 0 Posted July 2, 2012 Moderators Share Posted July 2, 2012 thanks I've been commenting this out each release ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
