Winapp2.ini 0 Posted May 15, 2012 Author Share Posted May 15, 2012 I'm switching the file hosting to winapp2.com, so I'm going to modify the file to link there instead of ccleaner.de I'll fix up the links in the top post as well. Nico has informed me he is taking down the site, so I'd like to publically thank him for allowing me to host the file there for the past year. Thanks a lot, Nico! winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Nergal 0 Posted May 15, 2012 Moderators Share Posted May 15, 2012 NIco, I too would like to thank you for your server. Winapp congrats to you for the new domain ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Winapp2.ini 0 Posted May 15, 2012 Author Share Posted May 15, 2012 I've had it for a while, but have just been incredibly lazy in setting it up! winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
nodles 0 Posted May 15, 2012 Share Posted May 15, 2012 I'm switching the file hosting to winapp2.com, so I'm going to modify the file to link there instead of ccleaner.de Any changes in the actual Winapp2.ini file? MERGED ENTRY: [Kaspersky*] LangSecRef=3021 DetectFile=%CommonAppData%\Kaspersky Lab Warning=Make sure to disable “Self Defence” before cleaning. Default=False FileKey1=%CommonAppData%\Kaspersky Lab\AVP*\Temp|*.* FileKey2=%CommonAppData%\Kaspersky Lab\AVP*\Bases\Cache|*.*|RECURSE FileKey3=%CommonAppData%\Kaspersky Lab\AVP*\Data\Updater\Temporary Files|*.*|RECURSE From: [Kaspersky 2010*] LangSecRef=3021 DetectFile=%CommonAppData%\Kaspersky Lab Warning=Make sure to disable “Self Defence” before cleaning. Default=False FileKey1=%CommonAppData%\Kaspersky Lab\AVP9\Temp|*.* FileKey2=%CommonAppData%\Kaspersky Lab\AVP9\Bases\Cache|*.tmp FileKey3=%CommonAppData%\Kaspersky Lab\AVP9\Data\Updater\Temporary Files|*.*|RECURSE [Kaspersky 2011*] LangSecRef=3021 DetectFile=%CommonAppData%\Kaspersky Lab Default=False FileKey1=%CommonAppData%\Kaspersky Lab\AVP11\Temp|*.* FileKey2=%CommonAppData%\Kaspersky Lab\AVP11\Bases\Cache|*.*|RECURSE FileKey3=%CommonAppData%\Kaspersky Lab\AVP11\Data\Updater\Temporary Files|*.*|RECURSE MODIFIED ENTRY: [Diablo III Logs*] LangSecRef=3021 Detect=HKCU\Software\Blizzard Entertainment\D3 Default=False FileKey1=%CommonAppData%\Battle.net\Setup\diablo3_engb\Log FileKey2=%ProgramFiles%\Diablo III\Logs FileKey3=%ProgramFiles%\Diablo III Beta\Logs|*.* <-Added FK1 & FK2. Link to post Share on other sites
Winapp2.ini 0 Posted May 15, 2012 Author Share Posted May 15, 2012 Nope, I'll push all the modifications to the entries in the next version. I've been kind of slow on it the last three months as I've been busy with school work. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
pook1y7985 0 Posted May 16, 2012 Share Posted May 16, 2012 [MySpaceIM Dump Files*] LangSecRef=3022 Detect=HKCU\Software\Myspace\IM Default=False FileKey1=%AppData%\MySpace\IM\Dump|*.* [MySpaceIM Images*] LangSecRef=3022 Detect=HKCU\Software\MySpace\IM Default=False FileKey1=%AppData%\MySpace\IM\Images|*.* Merged Entries Above (Assuming anyone uses Myspace) [MySpaceIM Dump Files/Images*] LangSecRef=3022 Detect=HKCU\Software\Myspace\IM Default=False FileKey1=%AppData%\MySpace\IM\Dump|*.* FileKey2=%AppData%\MySpace\IM\Images|*.* [OpenOffice 2.3*] LangSecRef=3021 Detect=HKLM\SOFTWARE\OpenOffice.org\OpenOffice.org\2.3 Default=False FileKey1=%AppData%\OpenOffice.org2\user\registry\data\org\openoffice\Office|Common.xcu [OpenOffice.org 3*] LangSecRef=3021 Detect=HKCU\Software\OpenOffice.org Default=False FileKey1=%AppData%\OpenOffice.org\*\user\config\imagecache|*.* FileKey2=%AppData%\OpenOffice.org\*\user\registry\cache|*.* FileKey3=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Common.xcu FileKey4=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Views.xcu FileKey5=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Writer.xcu FileKey6=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu FileKey7=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Store.xcu Merged Entries above to include wipe for OpenOffice 2.3 Entry [OpenOffice.org 2.3 and 3*] LangSecRef=3021 Detect=HKCU\Software\OpenOffice.org Default=False FileKey1=%AppData%\OpenOffice.org\*\user\config\imagecache|*.* FileKey2=%AppData%\OpenOffice.org\*\user\registry\cache|*.* FileKey3=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Common.xcu FileKey4=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Views.xcu FileKey5=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Writer.xcu FileKey6=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu FileKey7=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Store.xcu FileKey8=%AppData%\OpenOffice.org2\user\registry\data\org\openoffice\Office|Common.xcu Updated to Include newer versions of Nitro PDF Reader and Update entry name to indicate what your removing [Nitro PDF Reader Recent Files*] LangSecRef=3024 Detect=HKCU\Software\Nitro PDF\Reader\ Default=False RegKey1=HKCU\Software\Nitro PDF\Reader\1.0\Recent File List RegKey2=HKCU\Software\Nitro PDF\Reader\2.0\Recent File List Combined all Perfect Disk Entries into one that should account for any future releases. We have several PerfectDisk Entries all only to see new versions. I tested this without issues [PerfectDisk More*] LangSecRef=3024 Detect=HKCU\Software\Raxco\PerfectDisk\ Default=False FileKey1=%CommonAppData%\Raxco\PerfectDisk\*.0|*.log FileKey2=%CommonAppData%\Raxco\PerfectDisk\*.5|*.log Link to post Share on other sites
siliconman01 0 Posted May 16, 2012 Share Posted May 16, 2012 I recommend that the name of the code below be changed to: [Adobe Flash More*] LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer Default=False FileKey1=%AppData%\Adobe\Flash Player\AssetCache|*.*|RECURSE FileKey2=%WinDir%\System32\Macromed\Flash|FlashInstall.log FileKey3=%WinDir%\SysWOW64\Macromed\Flash|FlashInstall.log changed to: [Adobe Flash Player More*] Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
natsumerio 0 Posted May 22, 2012 Share Posted May 22, 2012 My OS = Windows 7 home premium, 32-bit version, english language USA version. I have been using CCleaner & CCEnhancer & Winapp2.ini for several years now. It had been a few months since I last updated any of them, so on May 21, 2012, I downloaded & installed the very latest versions of all of them. I also downloaded & used "trim.bat". After running & configuring everything (& no, I didn't RUN CCleaner when "trim.bat" told me not to), I used CCleaner's primary function. So far, so good. Then I opened up a folder in my pictures section, one that only has 15 pictures in it, for a total of 82.9 MBs. After letting Windows render them as thumbnails, I went up one folder, then back into that very same folder a half second later. Instead of the thumbnails either being already rendered or only taking a half second (give or take) to re-render, all of their thumbnails were blank, & I had to wait for Windows to render them as if it was the first time that I had ever been to that folder. This is the very FIRST time that this has ever happened to me before. My question is, was this problem caused by either the new CCleaner, the new CCEnhancer, the new Winapp2.ini, or the "trim.bat", & if so, then what can I do about it? Link to post Share on other sites
pook1y7985 0 Posted May 23, 2012 Share Posted May 23, 2012 This is the entry in Winsys.ini [Thumbnail Cache] ID=1029 LangSecRef=3002 LangRef=3131 DetectOS=6.0 Default=true SpecialKey1=N_EX_THUMBNAIL_CACHE FileKey1=%LocalAppData%\Microsoft\Windows\Explorer|thumbcache_*.db FileKey2=%LocalAppData%\Microsoft\Windows\Explorer\ThumbCacheToDelete|thm*.tmp Link to post Share on other sites
CSGalloway 0 Posted May 23, 2012 Share Posted May 23, 2012 Winapp2.ini: Is http://winapp2.com/Winapp2.ini accessiable by FTP and if so what is the address please? Link to post Share on other sites
ekerazha 0 Posted May 23, 2012 Share Posted May 23, 2012 I've seen that winapp2.ini adds a "Visual Studio Backup" entry. Could you add an entry to clean the Visual Studio Search History? You have to look at HKEY_CURRENT_USER\Software\Microsoft\VisualStudio\<Visual Studio version>\Find Where <Visual Studio version> can be 10.0, 9.0 etc. Inside this key there are values called Find Find0 Find1 Find2 Find3 etc. You should delete them. Link to post Share on other sites
Winapp2.ini 0 Posted May 25, 2012 Author Share Posted May 25, 2012 Update on its way winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Tr3bg0D 0 Posted May 25, 2012 Share Posted May 25, 2012 Update on its way Are we there yet? Please verify the posted INI. File INI: ; Version: v1.0.120515 ; Application Cleaning files Posted Info: Link to download Winapp2.ini Version: v1.0.120425 Link to post Share on other sites
Winapp2.ini 0 Posted May 25, 2012 Author Share Posted May 25, 2012 Yeah, sorry. This update fell between my finals (and packing up to go home), so I've been a bit occupied. It's on its way shortly. edit: updated the file winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
nodles 0 Posted May 25, 2012 Share Posted May 25, 2012 Yeah, sorry. This update fell between my finals (and packing up to go home), so I've been a bit occupied. It's on its way shortly. edit: updated the file Thanks! I'll check it when I come back from Prague (2.6.). Link to post Share on other sites
siliconman01 0 Posted May 25, 2012 Share Posted May 25, 2012 This revised Belarc did not make it in the latest update. [belarc*] LangSecRef=3024 Detect=HKCU\Software\Belarc Default=False FileKey1=%ProgramFiles%\Belarc\Advisor\|INSTALL.Log FileKey2=%ProgramFiles%\Belarc\Advisor\System\|Progress.Log FileKey3=%ProgramFiles%\Belarc\Advisor\System\Tmp\|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
siliconman01 0 Posted May 25, 2012 Share Posted May 25, 2012 This new entry for SpywareBlaster did not make the update either. [spywareBlaster Update File*] LangSecRef=3024 DetectFile=%ProgramFiles%\SpywareBlaster\sbautoupdate.exe Default=False Warning=This deletes SWB program updater file spywareblasterupgrade_latest.exe which is no longer needed once a SWB program version update occurs. FileKey1=%ProgramFiles%\SpywareBlaster\|spywareblasterupgrade_latest.exe Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
siliconman01 0 Posted May 25, 2012 Share Posted May 25, 2012 Here's a new entry for JavaRa [JavaRa (Log)*] LangSecRef=3022 DetectFile1=%ProgramFiles%\JavaRa\JavaRa.exe DetectFile2=%ProgramFiles%\JavaRa 2.0\JavaRa.exe Default=False Filekey1=%SystemDrive%\|JavaRa.log Filekey2=%ProgramFiles%\JavaRa 2.0\|version-output.log Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
Winapp2.ini 0 Posted May 25, 2012 Author Share Posted May 25, 2012 You posted the SpywareBlaster entry for JavaRA winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
siliconman01 0 Posted May 25, 2012 Share Posted May 25, 2012 You posted the SpywareBlaster entry for JavaRA Oops! Fixed Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
update 0 Posted May 25, 2012 Share Posted May 25, 2012 My first part of Lunascape support [Lunascape Backups*] LangSecRef=3022 Detect=HKLM\Software\Lunascape Corporation Default=False FileKey1=%AppData%\Lunascape\Lunascape6\backup|*.*|RECURSE And the Jagex cache support do not work fine. (Win XP, Official Jagex Client) "[Jagex Cache*] LangSecRef=3021 DetectFile1=%WinDir%\.jagex_cache_32 DetectFile2=%UserProfile%\jagexcache Default=False FileKey1=%WinDir%\.jagex_cache_32|*.*|RECURSE FileKey2=%UserProfile%\jagexcache*|*.*|RECURSE FileKey3=%UserProfile%|jagex__preferences*.dat FileKey4=%UserProfile%|jagex_cl_runescape_LIVE*.dat FileKey5=%UserProfile%|jagex_runescape_preferences*.dat" It's always C:\ (My system partition for windows is F but the cache file is on C (only document stuff)) This one reset all my settings! That's completly useless! My English is not verry good, but I hope I can help. =) Link to post Share on other sites
Winapp2.ini 0 Posted May 25, 2012 Author Share Posted May 25, 2012 I'll fix that entry up, thanks winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
nodles 0 Posted May 25, 2012 Share Posted May 25, 2012 My first part of Lunascape support [Lunascape Backups*] LangSecRef=3022 Detect=HKLM\Software\Lunascape Corporation Default=False FileKey1=%AppData%\Lunascape\Lunascape6\backup|*.*|RECURSE And the Jagex cache support do not work fine. (Win XP, Official Jagex Client) "[Jagex Cache*] LangSecRef=3021 DetectFile1=%WinDir%\.jagex_cache_32 DetectFile2=%UserProfile%\jagexcache Default=False FileKey1=%WinDir%\.jagex_cache_32|*.*|RECURSE FileKey2=%UserProfile%\jagexcache*|*.*|RECURSE FileKey3=%UserProfile%|jagex__preferences*.dat FileKey4=%UserProfile%|jagex_cl_runescape_LIVE*.dat FileKey5=%UserProfile%|jagex_runescape_preferences*.dat" It's always C:\ (My system partition for windows is F but the cache file is on C (only document stuff)) This one reset all my settings! That's completly useless! I'll fix that entry up, thanks There's nothing to fix. It's meant to clean all Jagex-files (I'd prefer folders, too), and you can exclude or untick these entries if needed. I don't think the %WinDir% should be changed either, you can include them if you have custom paths. Link to post Share on other sites
Winapp2.ini 0 Posted May 25, 2012 Author Share Posted May 25, 2012 I believe the second FileKey is deleting his settings though, no? winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
update 0 Posted May 25, 2012 Share Posted May 25, 2012 There's nothing to fix. It's meant to clean all Jagex-files (I'd prefer folders, too), and you can exclude or untick these entries if needed.I don't think the %WinDir% should be changed either, you can include them if you have custom paths. Try it if you don't believe: Download this: http://www.runescape.com/downloads/runescape.msi Itnstal it use CCleaner All settings are removed and sometimes the programm do not longer work => This make no sense... And everybody has the cache file on C:\ so why do you use %WinDir%? My English is not verry good, but I hope I can help. =) Link to post Share on other sites
