nodles 0 Posted June 25, 2012 Share Posted June 25, 2012 Updated! Thanks! Link to post Share on other sites
Coffee4Joe 0 Posted June 25, 2012 Share Posted June 25, 2012 Thanks winapp! Shouldn't this be posted on CCleaner Bug Reporting? I just posted it in Bug Reporting Link to post Share on other sites
siliconman01 0 Posted June 25, 2012 Share Posted June 25, 2012 Shouldn't this be posted on CCleaner Bug Reporting? I posted it in CCleaner Bug Reporting Link to post Share on other sites
Coffee4Joe 0 Posted June 25, 2012 Share Posted June 25, 2012 I posted it in CCleaner Bug Reporting LOL oops. I did too. edit: thanks to the mod that fixed/removed my topic Link to post Share on other sites
siliconman01 0 Posted June 25, 2012 Share Posted June 25, 2012 We need a different Detect or DetectFile for Thumbnails* that definitively shows that Firefox is installed on a system. Norton Internet Security and Norton 360 create the HKLM\Software\Mozilla\Firefox registry key even if Firefox is not installed on the system. I assume that Norton products do this so that it will recognize the installation of Firefox if a user installs Firefox after installing Norton. Link to post Share on other sites
ricktendo64 0 Posted June 25, 2012 Share Posted June 25, 2012 Fix [innoExtractor*] LangSecRef=3021 DetectFile=%LocalAppData%\InnoExtractor\InnoExtractor.exe Default=False FileKey1=%LocalAppData%\InnoExtractor|Historial.dat Added EXE because CCleaner might still show the option after uninstall (because the directory may not be deleted by uninstaller) Link to post Share on other sites
Winapp2.ini 0 Posted June 25, 2012 Author Share Posted June 25, 2012 Norton Okay Rick! Link to post Share on other sites
Winapp2.ini 0 Posted June 25, 2012 Author Share Posted June 25, 2012 Fixed those up, you can grab the file again if you wish. Link to post Share on other sites
Moderators Andavari 1 Posted June 25, 2012 Moderators Share Posted June 25, 2012 Norton Internet Security and Norton 360 create the HKLM\Software\Mozilla\Firefox registry key even if Firefox is not installed on the system.. Other software does that too. Link to post Share on other sites
AmelieTavie 0 Posted June 25, 2012 Share Posted June 25, 2012 You just missed this entry in Adobe Flash Player More* : FileKey2=%AppData%\Macromedia\Flash Player|*.*|RECURSE I know people want to keep settings, but not every setting for each website they visit. This kind of setting is stored in : %AppData%\Macromedia\Flash Player Link to post Share on other sites
Moderators Nergal 0 Posted June 26, 2012 Moderators Share Posted June 26, 2012 You just missed this entry in Adobe Flash Player More* : FileKey2=%AppData%\Macromedia\Flash Player|*.*|RECURSE I know people want to keep settings, but not every setting for each website they visit. This kind of setting is stored in : %AppData%\Macromedia\Flash Player you mean the files that are already cleaned by the internal ccleaner flash player clean (sol files other than the overreaching setting.sol which (while yes contains a list of every flash including the naughty ones) holds your flash settings)? or is there something else that is not removed from that folder? Link to post Share on other sites
Guest Keatah Posted June 26, 2012 Share Posted June 26, 2012 Is the TRIM.BAT file shown in the first post of this thread the latest version? I seem to have one that is dated later -- ECHO FILE CREATION 13:52 08/03/2012 -- and titled TRIM_12.bat Suggestions please! thx Link to post Share on other sites
AmelieTavie 0 Posted June 26, 2012 Share Posted June 26, 2012 you mean the files that are already cleaned by the internal ccleaner flash player clean (sol files other than the overreaching setting.sol which (while yes contains a list of every flash including the naughty ones) holds your flash settings)? or is there something else that is not removed from that folder? Yes I mean the settings.sol files stored in folders like : %AppData%\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#website\ and they're never removed. This is the same for SWF files in %AppData%\Roaming\Macromedia\Flash Player\#SharedObjects\'code'\#website\swf\ etc... Could you clean everything in %AppData%\Roaming\Macromedia\Flash Player\ ? Link to post Share on other sites
Moderators Andavari 1 Posted June 26, 2012 Moderators Share Posted June 26, 2012 Could you clean everything in %AppData%\Roaming\Macromedia\Flash Player\ ? Yes! I always nuke everything in the Flash Player folder. Note that if you play any online games that save your score/level/settings you'll need to hang onto settings.sol. Link to post Share on other sites
AmelieTavie 0 Posted June 26, 2012 Share Posted June 26, 2012 Hope it'll be integrated one day in Winapp2.ini Link to post Share on other sites
Tr3bg0D 0 Posted June 26, 2012 Share Posted June 26, 2012 Is the TRIM.BAT file shown in the first post of this thread the latest version? I seem to have one that is dated later -- ECHO FILE CREATION 13:52 08/03/2012 -- and titled TRIM_12.bat Suggestions please! thx Trim_12 is the latest as far as I am aware http://forum.piriform.com/index.php?showtopic=34642&view=findpost&p=211682 Link to post Share on other sites
APMichael 0 Posted June 26, 2012 Share Posted June 26, 2012 Updated! Thanks for the updated file. You've missed few posts / entries: #1695 and #1690. Maybe you can modify the "Flash Player" entry and add a warning message: [Adobe Flash Player More*] LangSecRef=3023 Detect1=HKCU\Software\Macromedia\FlashPlayer Detect2=HKCU\Software\Chromium DetectFile1=%localappdata%\Google\Chrome\Application\chrome.exe DetectFile2=%ProgramFiles%\Google\Chrome\Application\chrome.exe DetectFile3=%localappdata%\Flock\Application\flock.exe DetectFile4=%ProgramFiles%\Flock\Application\flock.exe DetectFile5=%localappdata%\Google\Chrome SxS\Application\chrome.exe DetectFile6=%ProgramFiles%\Google\Chrome SxS\Application\chrome.exe DetectFile7=%localappdata%\SRWare Iron\iron.exe DetectFile8=%ProgramFiles%\SRWare Iron\iron.exe DetectFile9=%ProgramFiles%\Chromium\chrome.exe DetectFile10=%localappdata%\Chromium\chrome.exe DetectFile11=%ProgramFiles%\Chromium\Application\chrome.exe DetectFile12=%localappdata%\Chromium\Application\chrome.exe DetectFile13=%AppData%\ChromePlus\chrome.exe DetectFile14=%localappdata%\RockMelt\Application\rockmelt.exe DetectFile15=%ProgramFiles%\RockMelt\Application\rockmelt.exe DetectFile16=%LocalAppData%\Comodo\Dragon\dragon.exe DetectFile17=%ProgramFiles%\Comodo\Dragon\dragon.exe Warning=This will delete your settings, including saved data from flash games! Default=False FileKey1=%AppData%\Adobe\Flash Player|*.*|RECURSE FileKey2=%AppData%\Macromedia\Flash Player|*.*|RECURSE FileKey3=%WinDir%\System32\Macromed\Flash|FlashInstall.log FileKey4=%WinDir%\SysWOW64\Macromed\Flash|FlashInstall.log Link to post Share on other sites
AmelieTavie 0 Posted June 26, 2012 Share Posted June 26, 2012 This would be perfect, thanks APMichael Link to post Share on other sites
Winapp2.ini 0 Posted June 26, 2012 Author Share Posted June 26, 2012 Can do, and yes, as far as I am aware, Trim_12 is the latest and greatest from Alan_B Link to post Share on other sites
Alan_B 0 Posted June 26, 2012 Share Posted June 26, 2012 Trim_12.bat is indeed the last version I issued. Link to post Share on other sites
siliconman01 0 Posted June 26, 2012 Share Posted June 26, 2012 Thanks for the updated file. You've missed few posts / entries: #1695 and #1690. [Adobe Flash Player More*] LangSecRef=3023 Detect1=HKCU\Software\Macromedia\FlashPlayer Detect2=HKCU\Software\Chromium DetectFile1=%localappdata%\Google\Chrome\Application\chrome.exe DetectFile2=%ProgramFiles%\Google\Chrome\Application\chrome.exe DetectFile3=%localappdata%\Flock\Application\flock.exe DetectFile4=%ProgramFiles%\Flock\Application\flock.exe DetectFile5=%localappdata%\Google\Chrome SxS\Application\chrome.exe DetectFile6=%ProgramFiles%\Google\Chrome SxS\Application\chrome.exe DetectFile7=%localappdata%\SRWare Iron\iron.exe DetectFile8=%ProgramFiles%\SRWare Iron\iron.exe DetectFile9=%ProgramFiles%\Chromium\chrome.exe DetectFile10=%localappdata%\Chromium\chrome.exe DetectFile11=%ProgramFiles%\Chromium\Application\chrome.exe DetectFile12=%localappdata%\Chromium\Application\chrome.exe DetectFile13=%AppData%\ChromePlus\chrome.exe DetectFile14=%localappdata%\RockMelt\Application\rockmelt.exe DetectFile15=%ProgramFiles%\RockMelt\Application\rockmelt.exe DetectFile16=%LocalAppData%\Comodo\Dragon\dragon.exe DetectFile17=%ProgramFiles%\Comodo\Dragon\dragon.exe Warning=This will delete your settings, including saved data from flash games! Default=False FileKey1=%AppData%\Adobe\Flash Player|*.*|RECURSE FileKey2=%AppData%\Macromedia\Flash Player|*.*|RECURSE FileKey3=%WinDir%\System32\Macromed\Flash|FlashInstall.log FileKey4=%WinDir%\SysWOW64\Macromed\Flash|FlashInstall.log I do not like the suggestion of this modification to Flash Player More*. Deleting settings.sol deletes the global settings of Flash Player as set up via the Flash Player Control Panel applet. How about a totally separate entry for those who want settings.sol removed....such as. [Adobe Flash Player (Remove Settings)*] LangSecRef=3023 Detect1=HKCU\Software\Macromedia\FlashPlayer Detect2=HKCU\Software\Chromium DetectFile1=%localappdata%\Google\Chrome\Application\chrome.exe DetectFile2=%ProgramFiles%\Google\Chrome\Application\chrome.exe DetectFile3=%localappdata%\Flock\Application\flock.exe DetectFile4=%ProgramFiles%\Flock\Application\flock.exe DetectFile5=%localappdata%\Google\Chrome SxS\Application\chrome.exe DetectFile6=%ProgramFiles%\Google\Chrome SxS\Application\chrome.exe DetectFile7=%localappdata%\SRWare Iron\iron.exe DetectFile8=%ProgramFiles%\SRWare Iron\iron.exe DetectFile9=%ProgramFiles%\Chromium\chrome.exe DetectFile10=%localappdata%\Chromium\chrome.exe DetectFile11=%ProgramFiles%\Chromium\Application\chrome.exe DetectFile12=%localappdata%\Chromium\Application\chrome.exe DetectFile13=%AppData%\ChromePlus\chrome.exe DetectFile14=%localappdata%\RockMelt\Application\rockmelt.exe DetectFile15=%ProgramFiles%\RockMelt\Application\rockmelt.exe DetectFile16=%LocalAppData%\Comodo\Dragon\dragon.exe DetectFile17=%ProgramFiles%\Comodo\Dragon\dragon.exe Warning=This will delete your settings, including saved data from flash games! Default=False FileKey1=%AppData%\Macromedia\Flash Player|*.*|RECURSE Link to post Share on other sites
APMichael 0 Posted June 27, 2012 Share Posted June 27, 2012 I do not like the suggestion of this modification to Flash Player More*. Deleting settings.sol deletes the global settings of Flash Player as set up via the Flash Player Control Panel applet. Yes, I know this. But as Nergal wrote already, a bad thing is that the "settings.sol" also contains a complete list of all visited domains using flash! I don't know what is more important here, settings or privacy? If you want to keep your settings you can add this line: ExcludeKey1=FILE|%AppData%\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys|settings.sol Link to post Share on other sites
siliconman01 0 Posted June 27, 2012 Share Posted June 27, 2012 Yes, I know this. But as Nergal wrote already, a bad thing is that the "settings.sol" also contains a complete list of all visited domains using flash! I don't know what is more important here, settings or privacy? If you want to keep your settings you can add this line: ExcludeKey1=FILE|%AppData%\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys|settings.sol My settings.sol does not contain the domain information because I have the following settings selected (for security reasons) via the Flash control panel applet: - Block all sites from storing information on this computer. - Block all sites from using the camera and microphone. - Block all sites from using peer-assisted networking. My settings.sol is only 1 kbyte in size and contains only the above settings. Link to post Share on other sites
Winapp2.ini 0 Posted June 27, 2012 Author Share Posted June 27, 2012 The important thing is, Flash needs to die. It'd be a "shame" if "Adobe Flash More*" accidentally were to delete flash from the system *innocent whistle* Link to post Share on other sites
Coffee4Joe 0 Posted June 27, 2012 Share Posted June 27, 2012 are all those DetectFiles necessary for Flash Player More*? why not use a DetectFile for the flash folder itself? [Adobe Flash Player More*] LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer DetectFile1=%AppData%\Adobe\Flash Player\ Default=False FileKey1=%AppData%\Adobe\Flash Player\AssetCache|*.*|RECURSE FileKey2=%AppData%\Macromedia\Flash Player|*.*|RECURSE FileKey3=%WinDir%\System32\Macromed\Flash|FlashInstall.log FileKey4=%WinDir%\SysWOW64\Macromed\Flash|FlashInstall.log Link to post Share on other sites
