siliconman01 Posted July 4, 2012 Share Posted July 4, 2012 Added FileKey3 [ThumbsPlus 8/9*] LangSecRef=3023 Detect=HKCU\Software\Cerious Software Inc. Default=False FileKey1=%AppData%\Thumbsplus|*.log FileKey2=%AppData%\Thumbsplus|*.bak FileKey3=%AppData%\Thumbsplus|*.dmp Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 4, 2012 Author Share Posted July 4, 2012 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 6, 2012 Author Share Posted July 6, 2012 [Mention*] LangSecRef=3022 Detect=HKCU\Software\Mention Default=False FileKey1=%LocalAppData%\Mention\Cache|*.*|RECURSE FileKey2=%LocalAppData%\Mention|WebpageIcons.db [blueGriffon*] LangSecRef=3021 DetectFile=%LocalAppData%\Disruptive Innovations SARL\BlueGriffon Default=False FileKey1=%LocalAppData%\Disruptive Innovations SARL\BlueGriffon\Profiles\*\Cache|*.*|RECURSE winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted July 6, 2012 Share Posted July 6, 2012 Thanks! ( ) Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 6, 2012 Author Share Posted July 6, 2012 Just keeping myself organized I sometimes forget to add things I write / put things I write in the changelog. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
TheWebAtom Posted July 6, 2012 Share Posted July 6, 2012 I love Mention, but the size of that cache folder is crazy. That cleaning rule is much appreciated. I'm Shane. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 6, 2012 Author Share Posted July 6, 2012 Not like I downloaded it and tried it out after seeing it on your desktop or anything winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 11, 2012 Moderators Share Posted July 11, 2012 Updated - Only added in a warning dialog for this cleaner: [NVIDIA (Play On My TV)*] LangSecRef=3023 Detect=HKLM\Software\NVIDIA Corporation Default=False Warning=If you output to multiple displays such as an HDTV or another monitor don't enable this! RegKey1=HKCR\AVIFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey2=HKCR\mpegfile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey3=HKCR\WMVFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey4=HKLM\SOFTWARE\Classes\AVIFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey5=HKLM\SOFTWARE\Classes\mpegfile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey6=HKLM\SOFTWARE\Classes\WMVFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey7=HKCR\AVIFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey8=HKCR\mpegfile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey9=HKCR\WMVFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey10=HKLM\SOFTWARE\Classes\AVIFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey11=HKLM\SOFTWARE\Classes\mpegfile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey12=HKLM\SOFTWARE\Classes\WMVFile\shellex\ContextMenuHandlers\NvPlayOnMyTV Link to comment Share on other sites More sharing options...
Guest Keatah Posted July 11, 2012 Share Posted July 11, 2012 A little out of the train of thought currently rolling here. I remember a while back there was an entry or something to do with deleting recycle-bin logs. Why was this taken out? Was there a specific problem it caused? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 11, 2012 Author Share Posted July 11, 2012 I don't recall such an entry, though I cannot deny its existence. The reason most entries are removed is because they've been added to CCleaner and are no longer needed as an extension. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 11, 2012 Moderators Share Posted July 11, 2012 recycle-bin logs? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Guest Keatah Posted July 11, 2012 Share Posted July 11, 2012 [Recycle Bin Logs (Drive C:)*] LangSecRef=3025 Default=True DetectFile=C:\RECYCLER\ FileKey1=C:\RECYCLER\|*.*|RECURSE Just curious that's all. When the file with the title like -- "S-1-5-21-1012598097-1492342706-15185329643-1002" -- which resides in the RECYCLER directory is deleted, it takes the preferences with it. The preference I'm talking about is found here: On Windows XP SP3 Desktop Right click on the Recycle Bin Select properties And configure drives independently The tick mark box for "Do not move deleted files to the Recycle Bin. Remove files immediately when deleted." becomes non-sticky and clears itself after running CCleaner + winapp2.ini + that entry. I don't remember where I got it from. Quite possibly right here. Ahh yes yes right here -- http://forum.pirifor...44 Somehow this got into my winapp2.ini file, how? I don't know and I don't care. For all I know I could have copy/pasted it in myself. Or used some updater or something. It was around the time when I first started using winapp2.ini about a year ago did some lengthy customization. Yes yes. I got to experimenting around and had a moment of insanity for some obscure reason and in a fit I seemingly forgot about it. It remained part of my cut-n-paste set of custom entries for a long time. I always wondered why this check box option for determining the fate of files dumped into the bin would would seemingly keep changing on its own. See.. Whenever a new winapp2.ini comes out. I go ahead and grab it. And I keep a text file of my own set of tried and true "specific-to-my-system" entries. I then merge the two together creating a SUPER winapp2.ini file, if you will.. And this got buried in there. Somehow. Anyways, after a quick search on Google I couldn't find anything remotely called a "Recycle Bin log" or similar. The closest thing would be the index.dat types of files and other areas of the system which are beyond the scope of this post. Teach me but good and dandy that I don't know more than other people is the wrong way to think! I typically review changes and I don't add things to my setups arbitrarily but this was one of those times I did. Frakk it! Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 11, 2012 Author Share Posted July 11, 2012 I don't think that one was ever included in the file, since we never fully understood what it did. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 12, 2012 Author Share Posted July 12, 2012 Updated! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 12, 2012 Moderators Share Posted July 12, 2012 wait that recycler thing seems dangerous and why would people want to delete that preference?!? and renew my second what logs there are no Recycle bin logsthird The Recycle bin (and yes that is everything in the hidden system files of C:\Recycler) is already cleaned by ccleaner in it's default state ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Guest Keatah Posted July 12, 2012 Share Posted July 12, 2012 Correct! You don't want this recycle bin thing in winapp2.ini at all! It could be a security issue because it changes how the recycle bin behaves on removable HDD's too! So do not include it! Sorry I ever brought attention to the entry. Link to comment Share on other sites More sharing options...
Guest Keatah Posted July 12, 2012 Share Posted July 12, 2012 The entry I showed seems to delete something that is related to protected storage provider and when the symbolic link is deleted parts of the registry change. I'm too busy now to fully research it. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 12, 2012 Author Share Posted July 12, 2012 It wasn't included anyway, fear not! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 12, 2012 Moderators Share Posted July 12, 2012 (edited) New: [Puran Defrag (Log)*] LangSecRef=3024 Detect=HKLM\Software\Puran Software\Puran Defrag Default=False FileKey1=%ProgramFiles%\Puran Defrag|PuranDefrag.html ----------------------------- Updated: * Includes a Warning dialog. [DVD Shrink (Analysis Results)*] LangSecRef=3023 Detect=HKCU\Software\DVD Shrink Warning=Each time you use this you'll have to agree to the DVD Shrink license. Default=False FileKey1=%CommonAppData%\DVD Shrink|*.* ----------------------------- Updated: * Now supports v2 also. [VSO Downloader (Logs)*] LangSecRef=3023 Detect=HKCU\Software\VSO\VSO Downloader Default=False FileKey1=%AppData%\VSO|*.log FileKey2=%AppData%\VSO\VSO Downloader\1\items\finished|*.item FileKey3=%AppData%\VSO\VSO Downloader\2\items\finished|*.item ----------------------------- Pale Moon cleaners: [Pale Moon (Adblock Plus Backups)*] LangSecRef=3026 Detect=HKLM\Software\Mozilla\Pale Moon Default=False FileKey1=%appdata%\Moonchild Productions\Pale Moon\Profiles\*\adblockplus|patterns-backup*.ini [Pale Moon (Bookmark Backups)*] LangSecRef=3026 Detect=HKLM\Software\Mozilla\Pale Moon Default=False FileKey1=%appdata%\Moonchild Productions\Pale Moon\Profiles\*\bookmarkbackups|*.json [Pale Moon (Corrupt SQLites)*] LangSecRef=3026 Detect=HKLM\Software\Mozilla\Pale Moon Default=False FileKey1=%appdata%\Moonchild Productions\Pale Moon\Profiles|*.corrupt|RECURSE [Pale Moon (Crash Reports)*] LangSecRef=3026 Detect=HKLM\Software\Mozilla\Pale Moon Default=False FileKey1=%appdata%\Moonchild Productions\Pale Moon\Crash Reports|*.*|RECURSE [Pale Moon (Extensions Log)*] LangSecRef=3026 Detect=HKLM\Software\Mozilla\Pale Moon Default=False FileKey1=%appdata%\Moonchild Productions\Pale Moon\Profiles\*|extensions.log [Pale Moon (Updates)*] LangSecRef=3026 Detect=HKLM\Software\Mozilla\Pale Moon Default=False FileKey1=%localappdata%\Moonchild Productions\Pale Moon\Pale Moon\updates|*.*|RECURSE [Pale Moon (WebAppsStore SQLite)*] LangSecRef=3026 Detect=HKLM\Software\Mozilla\Pale Moon Default=False FileKey1=%appdata%\Moonchild Productions\Pale Moon\Profiles|webappsstore.sqlite|RECURSE Edited July 12, 2012 by Andavari : Changed the Pale Moon cleaners to show under "Firefox/Mozilla" in CCleaner. Link to comment Share on other sites More sharing options...
APMichael Posted July 12, 2012 Share Posted July 12, 2012 Thanks for the update. Missed entries / suggestions: #1695 #1690 I found some typos: [Teamviewer Past Connections*] LangSecRef=3024 Detect=HKCU\Software\TeamViewer\ Default=False RegKey1=HKCU\Software\TeamViewer\Version5|Last_Machine_Connections RegKey2=HKCU\Software\TeamViewer\Version5.1|Last_Machine_Connections RegKey3=HKCU\Software\TeamViewer\Version6|Last_Machine_Connections RegKey4=HKCU\Software\TeamViewer\Version7\Last_Machine_Connections FileKey1=%AppData%\TeamViewer|*.* And does anybody know if the backslash before "Last_Machine_Connections" is correct on RegKey4? Shouldn't it be a pipe | symbol? [Ability Office*] LangSecRef=3021 Detect=HKCU\Software\Ability 6.0\ Default=False RegKey1=HKCU\Software\Ability 6.0\Ability Write\Files RegKey2=HKCU\Software\Ability 6.0\Ability Database\Recent File List RegKey3=HKCU\Software\Ability 6.0\Ability PhotoPaint\Recent File List RegKey4=HKCU\Software\Ability 6.0\Ability PhotoPaint Studio\Recent File List RegKey5=HKCU\Software\Ability 6.0\Ability Spreadsheet\Recent File List FileKey1=%Documents%\My Ability Files|*.*|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 12, 2012 Author Share Posted July 12, 2012 Whoops, I'll add/remove the entries above next version. I believe that should indeed be a pipe symbol. And yeah, 3 filekey3's is probably a no-no. Whoops! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 13, 2012 Moderators Share Posted July 13, 2012 New: [Greenfish Icon Editor Pro (MRU)*] LangSecRef=3021 DetectFile=%LocalAppData%\gfie\recent.txt Default=False FileKey1=%LocalAppData%\gfie|recent.txt Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 13, 2012 Author Share Posted July 13, 2012 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
TheWebAtom Posted July 14, 2012 Share Posted July 14, 2012 New: [Xmarks Sync Log*] LangSecRef=3024 Detect=HKCU\Software\Xmarks Default=False FileKey1=%LocalAppData%\Xmarks|xmarks.log [HTC Sync*] LangSecRef=3024 Detect=%ProgramFiles%\HTC\HTC Sync 3.0 Default=False FileKey1=%AppData%\HTC\Logs|*.log I'm Shane. Link to comment Share on other sites More sharing options...
APMichael Posted July 14, 2012 Share Posted July 14, 2012 Whoops, I'll add/remove the entries above next version. I believe that should indeed be a pipe symbol. And yeah, 3 filekey3's is probably a no-no. Whoops! Thanks! Link to comment Share on other sites More sharing options...
