Hav0c 0 Posted July 21, 2012 Share Posted July 21, 2012 What other application? Those entries aren't even in the winapp2.ini file that's in this thread. Applications is called Tracks Eraser Pro, it has a lot of plug-ins as well to use. Yes the enties is not in winapp2.ini. I was in the process of making them but as seen in the above post it seems that they are files being used. CCleaner can't delete files in use, also make sure you've unchecked only clean temp files older than 24 hours. Makes sence as Tracks Eraser Pro is a bit on the aggressive side Does anyone know if its in the pipeline to use the registry keys as paths ? I know it was mentioned somewhere here but it was a while back. Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to post Share on other sites
Moderators Nergal 0 Posted July 21, 2012 Moderators Share Posted July 21, 2012 what do you mean registry keys as paths? Your replies really seem little to do with this thread, please start your own if your going to ask outside of the winapp2 questions. Also please run the export command line and look through the inbuilt rules ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Winapp2.ini 0 Posted July 21, 2012 Author Share Posted July 21, 2012 He means transferring from DetectFiles to Detects, and I still try to. If you have any changes, they're appreciated. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Nergal 0 Posted July 21, 2012 Moderators Share Posted July 21, 2012 thanks for the explain I were ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Winapp2.ini 0 Posted July 21, 2012 Author Share Posted July 21, 2012 unsure and confused? winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Winapp2.ini 0 Posted July 22, 2012 Author Share Posted July 22, 2012 More than 50 75 entries in the next version will be converted from DetectFile to Detect winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Andavari 1 Posted July 22, 2012 Moderators Share Posted July 22, 2012 Just random thinking, but too bad we can't change in winapp2.ini the asterick * to this: ² Example: [Greenfish Icon Editor Pro (MRU)²] But then again it may not show up properly for some languages. Link to post Share on other sites
Moderators Andavari 1 Posted July 22, 2012 Moderators Share Posted July 22, 2012 New: [ctfmon.exe (Disable Startup)*] LangSecRef=3021 Detect=HKCU\Software\Microsoft\Office Detect2=HKLM\Software\Microsoft\Office Default=False Warning=This will only temporarily disable the Microsoft Office installed file ctfmon.exe from starting with Windows. ctfmon.exe is known to cause severe system slow downs and can be permanently disabled using the free CTFMON-Remover: http://www.gerhard-schlager.at/en/projects/ctfmonremover/ RegKey1=HKLM\Software\Microsoft\Windows\CurrentVersion\Run|ctfmon.exe RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Run|ctfmon.exe RegKey3=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run|ctfmon.exe New: [DVDFab (Logs)*] LangSecRef=3023 Detect=HKLM\Software\DVDFab Default=False FileKey1=%userprofile%\My Documents\DVDFab|*.log|RECURSE New: [DVDFab Passkey (Logs)*] LangSecRef=3023 Detect=HKCU\Software\DVDFab Passkey Detect2=HKLM\Software\DVDFab Passkey Default=False FileKey1=%userprofile%\My Documents\DVDFab Passkey|*.log|RECURSE New: [DVD Flick (Logs)*] LangSecRef=3023 DetectFile=%ProgramFiles%\DVD Flick\dvdflick.exe Default=False FileKey1=%AppData%\DVD Flick|dvdflick.log FileKey2=%AppData%\DVD Flick|report.txt New: [Kodak AiO Software (Disable Startup)*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Kodak\Kodak AiO Software Detect2=HKLM\SOFTWARE\Eastman Kodak Company\KODAK AiO Home Center Default=False Warning=Disables the Kodak AiO Software from automatically starting with Windows. Note: Everytime you print the Kodak AiO Software will automatically re-enable itself to start with Windows. RegKey1=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run|EKAIO2StatusMonitor New: [Kodak AiO Software (Logs)*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Kodak\Kodak AiO Software Detect2=HKLM\SOFTWARE\Eastman Kodak Company\KODAK AiO Home Center Default=False FileKey1=%CommonAppData%\Kodak\Inkjet Logging|*.bak|RECURSE FileKey2=%CommonAppData%\Kodak\Inkjet Logging|*.html|RECURSE FileKey3=%CommonAppData%\Kodak\Inkjet Logging|*.log|RECURSE FileKey4=%CommonAppData%\Kodak\Inkjet Logging|Format.css FileKey5=%CommonAppData%\Kodak\Inkjet Logging\Twain\kds_aio2esp\twain|*.txt|RECURSE FileKey6=%CommonAppData%\Kodak\Inkjet Logging\Twain\kds_aio2esp\twain|*.xml|RECURSE New: [Macrium Reflect (Logs)*] LangSecRef=3024 Detect=HKCU\Software\Macrium\Reflect Default=False FileKey1=%CommonAppData%\Macrium\Reflect|*.html New: [VirtualDubMod (MRU)*] LangSecRef=3023 Default=False Detect=HKCU\Software\Freeware\VirtualDubMod RegKey1=HKCU\Software\Freeware\VirtualDubMod\MRU List New: [Windows Movie Maker (XP)*] LangSecRef=3023 Detect=HKCR\Windows.Movie.Maker Default=False FileKey1=%localappdata%\Microsoft\Movie Maker|MEDIATAB.DAT ---------------------------------------------------- Recommend changing the name of one of the cleaners I made before Original Name: [Audio/Video (Stats)*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%|DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini New Name: [Windows Audio/Video (Stats)*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%|DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini Link to post Share on other sites
Winapp2.ini 0 Posted July 22, 2012 Author Share Posted July 22, 2012 Just random thinking, but too bad we can't change in winapp2.ini the asterick * to this: ² Example: [Greenfish Icon Editor Pro (MRU)²] But then again it may not show up properly for some languages. I actually like that idea, i do wonder about the language barrier though Edit: It'd also drive poor shane up a wall winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Winapp2.ini 0 Posted July 22, 2012 Author Share Posted July 22, 2012 as of this post, the next update contains 51 New Entries 115 Modified Entries 3 Removed Entires (this is before applying changes from the next version of CCleaner, so that may change.) winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Andavari 1 Posted July 22, 2012 Moderators Share Posted July 22, 2012 I actually like that idea, i do wonder about the language barrier though Edit: It'd also drive poor shane up a wall You can tell I currently have nothing to do, been playing with this and tried it another way: [Greenfish Icon Editor Pro (MRU)|²|] Have a quick preview by modifying one of your locally installed winapp2.ini entries and see how it sticks out so obvious that it's a winapp2.ini cleaner. Link to post Share on other sites
Hav0c 0 Posted July 22, 2012 Share Posted July 22, 2012 what do you mean registry keys as paths? Your replies really seem little to do with this thread, please start your own if your going to ask outside of the winapp2 questions. Also please run the export command line and look through the inbuilt rules Actually it does have to does with winapp2.ini. Okay, I have to admit my post was a bit unclear regarding the registry keys as paths. What I meant was for FileKey to use the registry keys to get the path of the application that is installed to be cleaned. Example: FileKey1=(registry key path) \ Files to be cleaned Currently I have to change a lot of winapp2.ini entries manually to point to my applications paths every time a update is available. He means transferring from DetectFiles to Detects, and I still try to. If you have any changes, they're appreciated. . Will wait for the new version to see what has been updated to Detect and see if I can help with the remaining DetectFiles. Maybe add some new once later on. Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to post Share on other sites
Moderators Andavari 1 Posted July 22, 2012 Moderators Share Posted July 22, 2012 Example: FileKey1=(registry key path) \ Files to be cleaned Could this be why you're having problems? Because this is how CCleaner removes things: FileKey1=Files or folders path to be cleaned FileKey2=Files or folders path to be cleaned (continuing on to FileKey3, 4, etc.,) RegKey1=Registry key path to be cleaned RegKey2=Registry key path to be cleaned (continuing on to RegKey3, 4, etc.,) As for software that beyond very annoyingly uses version numbers in its install path; If the setup program allows modifying the install path I usually do so for the sake of only making one winapp2.ini cleaner for it instead of having to constantly update the winapp2.ini cleaner, and I'll usually attempt to contact the software publisher to ask if they'd stop using version numbers in the install path. Link to post Share on other sites
Winapp2.ini 0 Posted July 22, 2012 Author Share Posted July 22, 2012 It's okay if they use version numbers, so long as it looks like HKCU\Software\Company\Software\Version or Program Files\Company\Software\Version since that doesn't mess with detection, and wildcards can be used to clean the various versions (except for the registry one, please note the MS Visual Studio Search History entry, which has 200 regkeys - though ccleaner doesn't allow for wildcard usage in the registry) winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Nergal 0 Posted July 22, 2012 Moderators Share Posted July 22, 2012 Example: FileKey1=(registry key path) \ Files to be cleanedCurrently I have to change a lot of winapp2.ini entries manually to point to my applications paths every time a update is available. see that's what I thought you meant, and not detect file vs reg, which is why I asked. to take what you want would require quite a re-write of ccleaner. That's not a winapp2 thing it's a rewrite (one that honestly I don't think makes a whole lot of sense) where would ccleaner even know where to look in the registry? And it would take longer to find the registry entry then find where the key that says where the application is installed then find that location of the PC then enumerate the files to remove then to actually remove them. Currently ccleaner shortens that roadmap by at least two steps and allows the majority of rules to be plain text instead of specialkey and specialdetect (such as Mozilla entries use.) the plain text is what allows us members to be helpful to users and developers and to develop Win*2 files ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Hav0c 0 Posted July 22, 2012 Share Posted July 22, 2012 Okay when one looks at it in the time spend in getting the location of the application using the registry makes a lot of sense vs giving it the set path instead. Thanks for pointing that out Well then looks like I have to make 2 files, one with only my applications correct paths and only update as needed when a new winapp2.ini comes out. Going to take some work Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to post Share on other sites
Moderators Nergal 0 Posted July 22, 2012 Moderators Share Posted July 22, 2012 Pro-Tip: if you run command-line export and rename the files winapp1.ini etc you can use the inbuilt rules and just change the locations via that pro-tip 2: using a diff program, such as Winmerge, will make that task that you've set yourself much faster ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Moderators Andavari 1 Posted July 23, 2012 Moderators Share Posted July 23, 2012 It's okay if they use version numbers, so long as it looks like HKCU\Software\Company\Software\Version or Program Files\Company\Software\Version With it being in the registry isn't the issue I was eluding to. For software that doesn't use the registry to store settings, yet the publisher insists on having it installed into for example: C:\Program Files\Some Software v1.51 and then a future version C:\Program Files\Some Software v1.89 and so forth I've tried using the asterick wildcard on such things in detecting/cleaning but couldn't get it to work. Link to post Share on other sites
Winapp2.ini 0 Posted July 23, 2012 Author Share Posted July 23, 2012 Registry doesnt support wildcards, I don't think DetectFiles do either winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
CSGalloway 0 Posted July 24, 2012 Share Posted July 24, 2012 Modify the entry please.... [AI Roboform Search*] LangSecRef=3022 Detect=HKCU\Software\Siber Systems Default=False RegKey1=HKCU\Software\Siber Systems\RoboForm\Query-MRU ; clears the MRU data. Will be reset when RF is restarted. FileKey1=%Documents%\My RoboForm Data\**|mru.rfo|RECURSE Link to post Share on other sites
Winapp2.ini 0 Posted July 25, 2012 Author Share Posted July 25, 2012 Will do! winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Winapp2.ini 0 Posted July 25, 2012 Author Share Posted July 25, 2012 Updated winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Coffee4Joe 0 Posted July 25, 2012 Share Posted July 25, 2012 Thanks! The Detects that use "HKCU" don't seem to be detected I noticed this only because firefox went from really long to really short edit: Only the firefox entries. I did do a clean install of Firefox 14 when it was released, wonder if they changed? or did I goof the install Link to post Share on other sites
Winapp2.ini 0 Posted July 25, 2012 Author Share Posted July 25, 2012 Will change to HKLM for the next version. I appologize, I tend tweak entries based on how they appear on my computer, and I have several flavors of Firefox installed. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
APMichael 0 Posted July 26, 2012 Share Posted July 26, 2012 Thanks for the big update! Missed entries: #1824 Modified entry: [Apple Installer Cache*] LangSecRef=3023 Detect=HKCU\Software\Apple Computer, Inc. Warning=You have to reinstall iTunes after adding a new windows user account. Default=False FileKey1=%CommonAppData%\Apple Computer\Installer Cache\*|*.* FileKey2=%CommonAppData%\Apple\Installer Cache\*|*.* Entry with typo: [DivX Player*] LangSecRef=3023 Detect1=HKCU\Software\DivX\Settings Detect2=HKCU\Software\DivXNetworks\DivX Player Default=False RegKey1=HKCU\Software\DivX\Settings\Player\PlayerState|LastOpenFileLocation RegKey2=HKCU\Software\DivX\Settings\TransferWizard|LastBrwosedDir RegKey3=HKCU\Software\DivX\Settings\Converter|lastBrowseDir RegKey4=HKCU\Software\DivX\Settings\Converter|outputDir RegKey5=HKCU\Software\DivXNetworks\DivX Player|file I think you can remove the entry ;[Macromedia Flashplayer*], because it seems that the RegKey doesn't exist anymore. Link to post Share on other sites
