Winapp2.ini additions
Winapp2.ini
Probably, but the only one I can think of that doesn't use the default profile location is Pale Moon. What is it, %AppData%\Moonchild Productions\Pale Moon\Profiles?
I am using PaleMoon v 12
(it has abandoned the rat race towards infinity)
It is however receiving security updates plus improvements designed for the benefit of Palemoon users.
I have two paths in use for my profile
C:\Users\Alan\AppData\Roaming\Moonchild Productions\PaleMoon\Profiles\4qbu47br.default
and
C:\Users\Alan\AppData\Local\Moonchild Productions\PaleMoon\Profiles\4qbu47br.default
The non-admin general user account also has
C:\Users\User\AppData\Roaming\Moonchild Productions\PaleMoon\Profiles\s1t2a4mk.default
and
C:\Users\User\AppData\Local\Moonchild Productions\PaleMoon\Profiles\s1t2a4mk.default
I cannot find any trace of a Palemoon Thumbnail.
Link to comment
If you don't use firefox 13+'s new 9 tab display page feature, I found out from somebody how to stop firefox from making them in the first place.
1) Start firefox.
2) In firefox's address bar, type "about:config".
3) Right click somewhere, click "new > boolean".
4) Name this "browser.pagethumbnails.capturing_disabled".
5) Set it's value as "true".
6) Close that tab.
Link to comment
1) Start firefox.
6) Close that tab.
Or just disable the new tab feature altogether (very first thing I did upon upgrading to FF13).
Link to comment
AH! found it in winapp.ini
I think it has an error
[Font Cache]
ID=1040
LangSecRef=3003
LangRef=3152
FileKey1=%WinDir%\System32|FNTCACHE.DAT
FileKey2=%LocalAppData%|GDIPFONTCACHEV1.DAT
FileKey2=%windir%\ServiceProfiles\LocalService\AppData\Local|FontCache*.dat
Shouldn't it be FileKey3?
Link to comment
ANALYSIS COMPLETE - (0.067 secs)
0.32 MB to be removed. (Approximate size)
Details of files to be deleted (Note: No files have been deleted yet)
System - Font Cache    325 KB    2 files
C:\Windows\System32\FNTCACHE.DAT    268 KB
C:\Users\Rob\AppData\Local\GDIPFONTCACHEV1.DAT    57 KB
Seems to work just as well
Link to comment
Mine cleans the same two you showed but skips the second FileKey2.
changing the second FileKey2 to FileKey3 It'll clean
2 files
C:\Windows\ServiceProfiles\LocalService\AppData\Local\FontCache-S-1-5-21-3736337810-901014033-4281033208-1000-12288.dat 3,868 KB
C:\Windows\ServiceProfiles\LocalService\AppData\Local\FontCache-System.dat 226 KB
Link to comment
  • Moderators
Why why would you page them for a winapp2 entry that has two filekey2? why not change the second to filekey3 as stated. LOL
Link to comment
  • Moderators
LOL I figured since it was in this thread . . . well you know what they say about assuming (though I never understood how the Ming dynasty fit into the whole thing :D )
Link to comment
Please change the name of [ThumbsPlus 8*] to [ThumbsPlus 8/9*]. ThumbsPlus 9 is in the final testing stage and is about to be released as gold.
ThumbsPlus 8/9*]
LangSecRef=3023
Detect=HKCU\Software\Cerious Software Inc.
Default=False
FileKey1=%AppData%\Thumbsplus|*.log
FileKey2=%AppData%\Thumbsplus|*.bak
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
Howdy folks, after a lengthy absence I return with a question.
I have recently started using qBittorrent on my computer. It is a free/open source torrent client. I was wondering if any of you folks were familiar with it and what files (if any) can be deleted in its %appdata% folders.
It isn't a huge big deal because I really don't use it that frequently, I was just wondering if there is anything in qBittorrent to add to winapp2.ini.
Edited by Nergal
removal of unneeded program link, people can search if you need
"When people are free to do as they please, they usually imitate each other."
--Eric Hoffer
Link to comment
MODIFIED ENTRIES:
As of Version: v1.0.120611 this hasnt been changed.
[Alcohol 120% Log*]
LangSecRef=3023
Detect=HKCU\Software\Alcohol Soft\Alcohol 120%\
Default=False
FileKey1=%ProgramFiles%\Alcohol Soft\Alcohol 120|alcohol.log
--Change DetectFile to Detect
--Rename from More* to Log* seeing that only the log file is removed
Every line of code written by man can be undone by man
"A loser in the real world is still a loser in the net!" - .hack//SIGN
Getting old is inevitable,  growing up is optional !!
Link to comment
OK I think I came up with one thing we can put for qBittorrent:
[qBittorrent*]
LangSecRef=3022
DetectFile=%LocalAppData%\qBittorrent\
Default=False
FileKey1=%LocalAppData%\qBittorrent\torrents|*.torrent
Note that this would only be necessary if you choose to check off Options > Downloads > Copy .torrent files to... and then specify that folder, so maybe some of you might have some objection to including this. Let me know what you think.
--Eric Hoffer
Link to comment
MODIFIED ENTRIES:
As of Version: v1.0.120611 this hasn't been changed.
[TeamSpeak 3 Logs*]
LangSecRef=3022
Detect=HKCU\Software\TeamSpeak 3 Client\
Default=False
FileKey1=%LocalAppData%\TeamSpeak 3 Client\config\logs|*.*
FileKey2=%AppData%\TS3Client\logs|*.log
--Changed DetectFile to Detect.
--Added FileKey2 seeing some logs was missed to be removed.
Can someone verify Filekey1 as it seems to me I don’t have that config folder that is in the Winapp2.ini.
[Acoustica CD Label Maker*]
LangSecRef=3024
Detect=HKCU\Software\Acoustica\CD Label Maker\
Default=False
FileKey1=%ProgramFiles%\Acoustica CD Label Maker\thumbs|*.*|RECURSE
FileKey2=%AppData%\Acoustica\CD Label Maker\cache|*.*|RECURSE
FileKey3=%AppData%\Acoustica\CD Label Maker\backgrounds\cache|*.*|RECURSE
FileKey4=%AppData%\Acoustica\CD Label Maker\layouts\cache|*.*|RECURSE
FileKey5=%AppData%\Acoustica\CD Label Maker\shapes|*.*
FileKey5=%AppData%\Acoustica\CD Label Maker\themes\cache|*.*|RECURSE
[AIM More*]
LangSecRef=3022
Detect=HKCU\America Online\AOL Diagnostics\
Default=False
FileKey1=%AppData%\acccore\caches\bart|*.*|RECURSE
Link to comment
[Font Cache]
ID=1040
LangSecRef=3003
LangRef=3152
The above error does not appear to be fixed in the latest V3.20 Ccleaner
Link to comment
Register a new account
Sign in
Important Information
