Winapp2.ini Posted August 23, 2010 Share Posted August 23, 2010 (edited) Welcome! ***Please Read*** The entries contained in winapp2.ini are not endorsed or supported in any way by the developers of CCleaner. This file is very large in its complete form and can cause significant delays when launching CCleaner. You can tailor the file to your system configuration and optimize CCleaner's launch time using winapp2ool's Trim module. While we do our best to ensure that submitted entries are not harmful, it is possible that some entries can impact the normal functionality of your system or applications. Winapp2.ini is provided "as is" and as such, neither I nor Piriform hold any liability for damage done to your machine in the event of an issue. If you have any questions, comments, concerns, or issues, please either file an issue on GitHub or make a post in this thread. *** Thank you ***GitHub Direct Download Winapp2ool releases Latest winapp2ool beta build (stability not guaranteed) winapp2ool beta commit log (aggregate changes between the most recent release version and the most recent beta version) ReadMe for creating entries Enjoy! Looking for old content? Our litany of old scripts/programs have been replaced with functions in winapp2ool. Check it out! You can also file bug reports on GitHub (this link may include open entry requests - feel free to fulfill them either here or on GitHub :)) Edited September 28, 2020 by Winapp2.ini winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
amckern Posted August 24, 2010 Share Posted August 24, 2010 Thanks! Link to comment Share on other sites More sharing options...
login123 Posted August 24, 2010 Share Posted August 24, 2010 Thank you, Winapp2.ini. The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to comment Share on other sites More sharing options...
eL_PuSHeR Posted August 24, 2010 Share Posted August 24, 2010 Thanks. I will test it when I return back from work. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 25, 2010 Moderators Share Posted August 25, 2010 woo hoo hurrah for new winapp2.ini from winapp2. . . uh .ini LOL downloading saving and merging with my already made personal entries one thing of note though winapp2 I think [**Quicktime Player more for vista and 7 users]ID=2035 LangSecRef=3023 Detectfile=%locallowappdata%\Apple Computer\quicktime Default=True FileKey1=%localappdata%\Apple Computer\QuickTime|QTPlayerSession.xml is better because it then will not show for any computer that has quicktime but is not 7 or vista (with the detect=hkey as you had it has it show on xp and lower as well ) and it also catches both instance of QTplayersession.XML plus the one that you have listed in there is now already intigrated into winapp.ini From Winapp1 [Quicktime Player] ID=2035 LangSecRef=3023 Detect=HKLM\Software\Apple Computer, Inc.\QuickTime Default=True RegKey1=HKLM\Software\Apple Computer, Inc.\QuickTime\Recent Movies FileKey1=%userprofile%|QTPlayerSession.xml FileKey2=%appdata%\Apple Computer\QuickTime|QTPlayerSession.xml [Quicktime Player Cache] ID=2036 LangSecRef=3023 Detect=HKLM\Software\Apple Computer, Inc.\QuickTime Default=True FileKey1=%localappdata%\Apple Computer\QuickTime\downloads|*.*|RECURSE FileKey2=%locallowappdata%\Apple Computer\quicktime\downloads|*.*|RECURSE Also (and this is just an opinion) I moved the *(as in [* ) to the end (as in *] ) this keeps the programs in alphabetical (i.e. all the quicktimes are now grouped.) Again I realllllllllllllllllllllllllllllly appreciate all the work you do on winapp2 and without it I would be nowhere when helping out in this forum. . . in short you are my CCLeaner hero. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 26, 2010 Author Share Posted August 26, 2010 Thank you Nergal, I'm glad I'm your hero The quicktime entries weren't written by myself, but I see your point in that having a registry detect when it was designed for win vista/7 is sort of moot. Could I take it to mean that the quicktime entries are now obsolete and can be removed? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 26, 2010 Moderators Share Posted August 26, 2010 Thank you Nergal, I'm glad I'm your hero The quicktime entries weren't written by myself, but I see your point in that having a registry detect when it was designed for win vista/7 is sort of moot. Could I take it to mean that the quicktime entries are now obsolete and can be removed? Registry suggestion was so that XP and below didn't see the entry (as it shows up due to the same entry being detected on all systems) The Entry (as I typed it) is still valid as Piriform included the download cache for vista/7 but did not put in the quicktime entry highlighted in red in my entry (%localappdata%\Apple Computer\QuickTime|QTPlayerSession.xml) See http://forum.piriform.com/index.php?showtopic=27173&view=findpost&p=171890 Again I think what you have done, with this 32, 64, xp, vista, 7 winapp2 is awesome for people such as myself who use the same ccleaner on multiple machines as a tech support tool ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
212eta Posted August 26, 2010 Share Posted August 26, 2010 [icon Cache] LangSecRef=3002 Default=true FileKey1=%userprofile%\Local Settings\Application Data|IconCache.db FileKey2=%LocalAppData%|IconCache.db Can you, please, add the above entry to the winapp2.ini file? Link to comment Share on other sites More sharing options...
tux. Posted August 26, 2010 Share Posted August 26, 2010 Maybe unifying the entries' formats would be fine. Some with *, some with ~... wtf? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 26, 2010 Author Share Posted August 26, 2010 I updated the file to be inclusive of Nergal's quicktime suggestion, I also added the icon cache posted above, fixed some alphabetization and changed the entries marked with tilde (~) to have asterisks (*) http://omploader.org/vNWNsOQ/winapp2.ini ^ theres the new version, I'll be updating the first post with it too. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 26, 2010 Moderators Share Posted August 26, 2010 Good work Winapp2.ini! Now your chosen forum member name makes even more sense than ever now. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted August 26, 2010 Moderators Share Posted August 26, 2010 Nice job. And Pans Labyrinth is in the top ten of my most watched DVD's. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 27, 2010 Author Share Posted August 27, 2010 I only know one person who watched it and didn't like it Dennis. I think anyone who doesn't want to give it a chance just doesn't want to read the subtitles. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 31, 2010 Moderators Share Posted August 31, 2010 Winapp2.ini I figured out how to use Detectos in entries My Updated Quicktime Entry is [Quicktime Player more for vista and 7 users*]ID=2035 LangSecRef=3023 DetectOS=6.0 Default=True FileKey1=%localappdata%\Apple Computer\QuickTime|QTPlayerSession.xml My Java for Vista and 7 entry is [sun Java for Vista & 7**]ID=2094 LangSecRef=3022 DetectOS=6.0 Default=True FileKey1=%locallowappdata%\Sun\Java\Deployment\cache\|*.*|RECURSE FileKey2=%locallowappdata%\Sun\Java\Deployment\javaws\cache|*.*|RECURSE Also it seems the Realplayer SP entry is now intigrated into the builtin ini @moderators/Admins any objection to this topic being a sticky? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 31, 2010 Author Share Posted August 31, 2010 Edit: Removed my question as I answered it myself. New version inclusive of those two things from Nergal, also a few tweaks here and there and Mozilla FireFox Crash Reports http://omploader.org...lbA/winapp2.ini edit: I created this [*Microsoft Windows Game Statistics] LangSecRef=3025 DetectOS=6.0 DetectFile=%localappdata%\Microsoft Games\ Default=False FileKey1=%localappdata%\Microsoft Games\Chess Titans\|chesstitans.xml FileKey2=%localappdata%\Microsoft Games\Freecell\|freecell.xml FileKey3=%localappdata%\Microsoft Games\Hearts\|hearts.xml FileKey4=%localappdata%\Microsoft Games\Mahjong Titans\|mahjong titans.xml FileKey8=%localappdata%\Microsoft Games\Minesweeper\|minesweeper.xml FileKey5=%localappdata%\Microsoft Games\Purble Place\|purble place.xml FileKey6=%localappdata%\Microsoft Games\Solitaire\|solitaire.xml FileKey7=%localappdata%\Microsoft Games\Spider Solitaire\|spider solitaire.xml I don't know whether or not people would be interested in this, its an option in the windows disk cleanup that is not in ccleaner. I set it to be unticked by default and it is not in the current version I have posted on this page. Feedback? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
212eta Posted September 1, 2010 Share Posted September 1, 2010 [iMVU Cache] LangSecRef=3022 DectectFile=%appdata%\IMVUClient\IMVUClient.exe Default=False FileKey1=%appdata%\IMVU\cache\|*.*|REMOVESELF| FileKey2=%appdata%\IMVU\AssetCache\|*.*|REMOVESELF| FileKey3=%appdata%\IMVU\PixmapCache\|*.*|REMOVESELF| Can you, please, add the Above Entry to the winapp2.ini file? Thank you in advance! Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 1, 2010 Moderators Share Posted September 1, 2010 [iMVU Cache] [sNIP] Can you, please, add the Above Entry to the winapp2.ini file? Thank you in advance! Looks Like Winapp2.ini added it Line 1173 [iMVU Cache*]LangSecRef=3022 DetectFile=%appdata%\IMVUClient\IMVUClient.exe Default=False FileKey1=%appdata%\IMVU\cache\|*.*|REMOVESELF| FileKey2=%appdata%\IMVU\AssetCache\|*.*|REMOVESELF| FileKey3=%appdata%\IMVU\PixmapCache\|*.*|REMOVESELF| [iMVU Logs*] LangSecRef=3022 DetectFile=%appdata%\IMVUClient\Imvuclient.exe Default=Flase FileKey1=%appdata%\IMVU|*.log.* ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
aqua Posted September 1, 2010 Share Posted September 1, 2010 this thread is sticky right????...great.. and thanks a lot to Winapp2.ini ...great job Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 1, 2010 Author Share Posted September 1, 2010 Looks Like Winapp2.ini added it Line 1173 Those were in the original release too, I wonder why they wouldn't have shown up for 212eta. What do you think of the Microsoft game statistics entry? Y/N? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
tux. Posted September 1, 2010 Share Posted September 1, 2010 Would make sense indeed. The disk cleaner is an alternative, not a side-by-side add-on to CCleaner. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 1, 2010 Moderators Share Posted September 1, 2010 Would make sense indeed. The disk cleaner is an alternative, not a side-by-side add-on to CCleaner. Yeah, I agree with Tux there that ccleaner is great for making it so you never acutally need to run disk cleanup. so it would make sense to add that entry. I also like that it is false by default. question though, my Windows seven also makes a MinesweeperSettings.xml.bak so those would be left behind after the cleaning, is this by design? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 1, 2010 Author Share Posted September 1, 2010 Yes, the gameSetting.xml and gameSetting.xml.bak are for the games settings ie. for Minesweeper the game board size, ect. I could add them as a separate entry, but I don't see why anyone would want to clear their settings for games. Anyway here is a new file, added to it are some updated folders, auslogics boostspeed logs, last.fm client cache and the microsoft windows game stats updated: Removed SRWare Iron and fixed Microsoft Windows Games Stats http://omploader.org...ydw/winapp2.ini updating the first post with it too. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 1, 2010 Moderators Share Posted September 1, 2010 LOL I read your entry wrong . . or at least made an assumption I only have the settings files and the windowprefs.xml I don't have what you have listed yet, let me play one game of something so i have a stat file and then I get back to you LOL what weird though my minesweepersettings.xml does have stats written inside of it o_O EDIT: Yup doesn't look like windows 7 is creating those files and it doesn't even looks like the diskcleanup is even emptying the stats from the settings file. (note I only tested on Solitare and Minesweeper) Still I say yeah add it ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 1, 2010 Author Share Posted September 1, 2010 Edit: seems my assumption as to the behavior of the saving system was incorrect. I will amend the file to account for this. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
metalj Posted September 1, 2010 Share Posted September 1, 2010 You should remove SRWare Iron as it now has official support. Piriform Software User Guides Link to comment Share on other sites More sharing options...
