212eta 0 Posted October 25, 2010 Share Posted October 25, 2010 The Eraser 5.5 Rules: [Eraser (Log)*] LangSecRef=3024 Detect=HKCU\Software\Heidi Computers Ltd\Eraser\5.5 Default=False FileKey1=%ProgramFiles%\Eraser|schedlog.txt FileKey2=%ProgramFiles(x86)%\Eraser|schedlog.txt are No Longer Valid for the Eraser 6! For example, instead of the HKCU\Software\Heidi Computers Ltd\Eraser\5.5 , there is HKCU\Software\Eraser\Eraser 6\ Can someone, PLEASE, write NEW Rules for Eraser 6? Link to post Share on other sites
Moderators Andavari 1 Posted October 25, 2010 Moderators Share Posted October 25, 2010 [NVIDIA (Play On My TV)] ; Removes the NVIDIA "Play On My TV" shell extension for .AVI, .MPG, .MPEG, and .WMV ; video files. The shell extension isn't necessary if you don't output to a TV! LangSecRef=3023 Detect=HKLM\Software\NVIDIA Corporation Default=False RegKey1=HKCR\AVIFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey2=HKCR\mpegfile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey3=HKCR\WMVFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey4=HKLM\SOFTWARE\Classes\AVIFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey5=HKLM\SOFTWARE\Classes\mpegfile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey6=HKLM\SOFTWARE\Classes\WMVFile\shellex\ContextMenuHandlers\NvPlayOnMyTV The only change is that all instances of "PlayOnMyTV" become "NvPlayOnMyTV". I'm not sure if the former key name is found on other systems with older ForceWare drivers or not, as I have not done further investigation. The older key is required for older versions of the NVIDIA software, therefore the keys you've found would need to be an addition instead of completely removing the older keys, i.e.; just like this: [NVIDIA (Play On My TV)*] ; Removes the NVIDIA "Play On My TV" shell extension for .AVI, .MPG, .MPEG, and .WMV ; video files. The shell extension isn't necessary if you don't output to a TV! LangSecRef=3023 Detect=HKLM\Software\NVIDIA Corporation Default=False RegKey1=HKCR\AVIFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey2=HKCR\mpegfile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey3=HKCR\WMVFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey4=HKLM\SOFTWARE\Classes\AVIFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey5=HKLM\SOFTWARE\Classes\mpegfile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey6=HKLM\SOFTWARE\Classes\WMVFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey7=HKCR\AVIFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey8=HKCR\mpegfile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey9=HKCR\WMVFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey10=HKLM\SOFTWARE\Classes\AVIFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey11=HKLM\SOFTWARE\Classes\mpegfile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey12=HKLM\SOFTWARE\Classes\WMVFile\shellex\ContextMenuHandlers\NvPlayOnMyTV Link to post Share on other sites
Winapp2.ini 0 Posted October 27, 2010 Author Share Posted October 27, 2010 http://ompldr.org/vNXh1eQ/winapp2.ini Link to post Share on other sites
Winapp2.ini 0 Posted October 29, 2010 Author Share Posted October 29, 2010 (edited) http://ompldr.org/vNXlscw/winapp2.ini updated to reflect the changes in CCv3.0 updated a second time, whoops. Grabi t again. (10:31 EST 10/28/10) Edited October 29, 2010 by Winapp2.ini Link to post Share on other sites
randompages 0 Posted October 29, 2010 Share Posted October 29, 2010 i just curious that winapp2.ini can solve my problems here.. http://forum.piriform.com/index.php?showuser=40711 Link to post Share on other sites
Tristan Wolf 0 Posted October 30, 2010 Share Posted October 30, 2010 Thank you VERY much for your hard work Winapp2. I will do my best to look over it and suggest anything that I can. One random thought: Have you considered making this a project on GitHub or SourceForge or some other open-source project source host? This could bring a few benefits: - You would have version control. Users would be directed to download the latest copy by default. Assuming you'd be interested, you could also release test versions, which would include new entries that you can't test locally (lack of owning the software or whatnot) that you could ask to be tested before release. - Track updates easily. Particularly helpful if a new method of entries is used, such as wildcards or OS detection, that could then be noted as such and subsequently applied to other applicable entries. Also helpful to remember if/why an entry was removed or changed. - Users could very easily submit suggested changes/additions by simply editing the file and uploading the changes. The source control system would then allow you to easily see the suggestions, and modify the versions as needed with little difficulty. - Could consider, if you were so inclined, creating a simple Java program (or whatever language you're comfortable with) to assist in automatically updating the Winapp2.ini file for anyone that would like to do that. Just an idea. Thanks again for everything. Please let me know if there's anything that I can do to help. Link to post Share on other sites
back_track 0 Posted October 30, 2010 Share Posted October 30, 2010 Can you edit this code to your list: [sRWare Iron\Chromium - Cache] Section=SRWare Iron LangRef=Cache Detect=HKCU\Software\Chromium Default=True FileKey1=%LocalAppData%\Chromium\User Data\Default\Cache|*.* [sRWare Iron\Chromium - Cookies] Section=SRWare Iron LangRef=Cookies Detect=HKCU\Software\Chromium Default=True FileKey1=%LocalAppData%\Chromium\User Data\Default|Cookies [sRWare Iron\Chromium - History] Section=SRWare Iron LangRef=History Detect=HKCU\Software\Chromium Default=True FileKey1=%LocalAppData%\Chromium\User Data\Default|*History* FileKey2=%LocalAppData%\Chromium\User Data\Default|Thumbnails FileKey3=%LocalAppData%\Chromium\User Data\Default|Visited Links [sRWare Iron\Chromium - Form Data] Section=SRWare Iron LangRef=Form Data Detect=HKCU\Software\Chromium Default=True FileKey1=%LocalAppData%\Chromium\User Data\Default|Web Data [sRWare Iron\Chromium - Session Restore] Section=SRWare Iron LangRef=Session Restore Detect=HKCU\Software\Chromium Default=True FileKey1=%LocalAppData%\Chromium\User Data\Default|Current* FileKey2=%LocalAppData%\Chromium\User Data\Default|Last* [XnView - Database*] Section=Xnview LangSecRef=3023 Detect=HKCU\Software\XnView Default=True FileKey1=%appdata%\XnView|XnView.db FileKey2=%appdata%\XnView|category.bak [XnView - All*] Section=Xnview LangSecRef=3023 Detect=HKCU\Software\XnView Default=False FileKey1=%appdata%\XnView|*.*|REMOVESELF" [streamripper Winamp*] Section=Streamripper LangSecRef=3023 Detect=HKCU\Software\Streamripper Default=False FileKey1=%appdata%\Streamripper|*.*|REMOVESELF" [Teeworlds*] Section=Teeworlds LangSecRef=3021 DetectFile=%appdata%\Teeworlds Default=False FileKey1=%appdata%\Teeworlds\demos|*.*|REMOVESELF" FileKey1=%appdata%\Teeworlds\downloadedmaps|*.*|REMOVESELF" FileKey1=%appdata%\Teeworlds\maps|*.*|REMOVESELF" FileKey1=%appdata%\Teeworlds\screenshots|*.*|REMOVESELF" [Teeworlds - All*] Section=Teeworlds LangSecRef=3021 DetectFile=%appdata%\Teeworlds Default=False FileKey1=%appdata%\Teeworlds|*.*|REMOVESELF" Link to post Share on other sites
MVE 0 Posted October 30, 2010 Share Posted October 30, 2010 Add this please: [iISExpress Logs*] LangSecRef=3022 DetectFile=%userprofile%\Documents\IISExpress Default=False FileKey1=%userprofile%\Documents\IISExpress\Logs\|*.* FileKey2=%userprofile%\Documents\IISExpress\TraceLogFiles\|*.*|RECURSE Link to post Share on other sites
Miroku4444 0 Posted October 30, 2010 Share Posted October 30, 2010 I don't know how to write the code for it, could you update: Gimp, JV16 Power Tools, OpenOffice.org, and Ultra ISO. It's in the Winapp2.ini File, but the version is outdated. Link to post Share on other sites
back_track 0 Posted October 30, 2010 Share Posted October 30, 2010 [GIMP 2.6*] LangSecRef=3021 Default=False DetectFile=%userprofile%\.gimp-2.6 filekey1=%userprofile%\.thumbnails\normal|*.* filekey2=%userprofile%\.gimp-2.6|documents filekey3=%userprofile%\.gegl-0.0|documents [GIMP 2.4*] LangSecRef=3021 Default=False DetectFile=%userprofile%\.gimp-2.4 filekey1=%userprofile%\.thumbnails\normal|*.* filekey2=%userprofile%\.gimp-2.4|documents I have only updated the old code [CustomBrushesMini Paint.Net-Plunging*] Section=CustomBrushes Paint.Net-Plunging LangSecRef=3021 DetectFile=%appdata%\CustomBrushesMini Default=False FileKey1=%appdata%\CustomBrushesMini\ThumbCache|*.*|REMOVESELF" FileKey2=%appdata%\CustomBrushesMini|*.*|REMOVESELF" Link to post Share on other sites
Winapp2.ini 0 Posted October 30, 2010 Author Share Posted October 30, 2010 Thank you for the additions, just a few things to note for the future: Section= is not needed, just LangSecRef the ' " ' at the end of some of the entries may break them (I don't know) As a general rule, I try to separate things into individual options such as Teeworld ALL being inclusive of 4 different things, some may want the demos but not the screen shots, for example. Again, thank you for your submissions, they'll be in the next version Link to post Share on other sites
Miroku4444 0 Posted October 30, 2010 Share Posted October 30, 2010 Yeah thanks back_track. Did you test them? Now if i can only get JV16 Power Tools and Ultra ISO updated. Link to post Share on other sites
Winapp2.ini 0 Posted October 30, 2010 Author Share Posted October 30, 2010 I'm really happy to announce this update. I've finally resolved this issue (I don't know how many people have seen it) http://ompldr.org/vNXpiZQ Note here that because of the multiple same paths for compatibility, the "analyze" results are incorrect (as the same files are detected twice) This did not affect "Clean" because the files were gone and couldn't be cleaned twice. HOWEVER, I have fixed this (see here -> http://ompldr.org/vNXpiZg ) This version (along with a bunch of new entries and revised entries) deals mainly with this issue, which was easily corrected by making any instance of 2 identical paths (but not identically written) the same filekey number. Other than that, a bunch of revisions involving the path %allusersappdata% have been made for compatibly reasons, as many were written improperly, or just not compatible with all three systems this file is designed for. This will be copied to the first post as usual, heres the file! http://ompldr.org/vNXpicQ/winapp2.ini Link to post Share on other sites
Winapp2.ini 0 Posted October 30, 2010 Author Share Posted October 30, 2010 Yeah thanks back_track. Did you test them? Now if i can only get JV16 Power Tools and Ultra ISO updated. I noticed that entry is malformed, is this better, or completely wrong? [jv16 PowerTools 2009*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2009\jv16PT.exe DetectFile=%ProgramFiles(x86)%\jv16 PowerTools 2009\jv16PT.exe Default=False FileKey1=%userprofile%\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey1=%localappdata%\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey2=%userprofile%|NTUSER.DAT.bak_jv16pt FileKey3=%systemdrive%\documents and settings\LocalService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey4=%systemdrive%\documents and settings\LocalService|NTUSER.DAT.bak_jv16pt FileKey5=%systemdrive%\documents and settings\NetworkService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey6=%systemdrive%\documents and settings\NetworkService|NTUSER.DAT.bak_jv16pt FileKey3=%systemdrive%\users\LocalService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey4=%systemdrive%\users\LocalService|NTUSER.DAT.bak_jv16pt FileKey5=%systemdrive%\users\NetworkService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey6=%systemdrive%\users\NetworkService|NTUSER.DAT.bak_jv16pt FileKey7=%windir%\system32\config|SAM.bak_jv16pt FileKey8=%windir%\system32\config|SECURITY.bak_jv16pt FileKey9=%windir%\system32\config|default.bak_jv16pt FileKey10=%windir%\system32\config|software.bak_jv16pt FileKey11=%windir%\system32\config|system.bak_jv16pt I dont have UltraISO, what needs to be changed/removed/added from that entry? or does a whole new entry need to be created? Link to post Share on other sites
Miroku4444 0 Posted October 30, 2010 Share Posted October 30, 2010 I dont have UltraISO, what needs to be changed/removed/added from that entry? or does a whole new entry need to be created? It says the version is 5 in the Winapp2.ini. UltraISO is on version 9. I saw the JV16 power Tools in the Winapp2.ini also, but the currant version of JV16 power Tools is 2010, not 2009. http://www.macecraft.com/ Link to post Share on other sites
Winapp2.ini 0 Posted October 31, 2010 Author Share Posted October 31, 2010 so would this suffice? [jv16 PowerTools 2009*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exe DetectFile=%ProgramFiles(x86)%\jv16 PowerTools 2010\jv16PT.exe Default=False FileKey1=%userprofile%\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey1=%localappdata%\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey2=%userprofile%|NTUSER.DAT.bak_jv16pt FileKey3=%systemdrive%\documents and settings\LocalService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey4=%systemdrive%\documents and settings\LocalService|NTUSER.DAT.bak_jv16pt FileKey5=%systemdrive%\documents and settings\NetworkService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey6=%systemdrive%\documents and settings\NetworkService|NTUSER.DAT.bak_jv16pt FileKey3=%systemdrive%\users\LocalService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey4=%systemdrive%\users\LocalService|NTUSER.DAT.bak_jv16pt FileKey5=%systemdrive%\users\NetworkService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey6=%systemdrive%\users\NetworkService|NTUSER.DAT.bak_jv16pt FileKey7=%windir%\system32\config|SAM.bak_jv16pt FileKey8=%windir%\system32\config|SECURITY.bak_jv16pt FileKey9=%windir%\system32\config|default.bak_jv16pt FileKey10=%windir%\system32\config|software.bak_jv16pt FileKey11=%windir%\system32\config|system.bak_jv16pt Link to post Share on other sites
Miroku4444 0 Posted October 31, 2010 Share Posted October 31, 2010 Seems to be right, but i dont have these files: FileKey1=%userprofile%\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey1=%localappdata%\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey2=%userprofile%|NTUSER.DAT.bak_jv16pt FileKey3=%systemdrive%\documents and settings\LocalService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey4=%systemdrive%\documents and settings\LocalService|NTUSER.DAT.bak_jv16pt FileKey5=%systemdrive%\documents and settings\NetworkService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey6=%systemdrive%\documents and settings\NetworkService|NTUSER.DAT.bak_jv16pt FileKey3=%systemdrive%\users\LocalService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey4=%systemdrive%\users\LocalService|NTUSER.DAT.bak_jv16pt FileKey5=%systemdrive%\users\NetworkService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey6=%systemdrive%\users\NetworkService|NTUSER.DAT.bak_jv16pt FileKey7=%windir%\system32\config|SAM.bak_jv16pt FileKey8=%windir%\system32\config|SECURITY.bak_jv16pt FileKey9=%windir%\system32\config|default.bak_jv16pt FileKey10=%windir%\system32\config|software.bak_jv16pt FileKey11=%windir%\system32\config|system.bak_jv16pt The program files directory is right, just can locate those files. Is it because i dont have vista or windows 7 or some feature of jv16 im not using? Link to post Share on other sites
Winapp2.ini 0 Posted October 31, 2010 Author Share Posted October 31, 2010 I really don't know, I will make an effort to revise this entry later, sorry. Link to post Share on other sites
Miroku4444 0 Posted October 31, 2010 Share Posted October 31, 2010 I really don't know, I will make an effort to revise this entry later, sorry. Ok, maybe someone else who also has JV16 can shed some light on it. Link to post Share on other sites
CSGalloway 0 Posted October 31, 2010 Share Posted October 31, 2010 I just ran the registry compactor in jv16 2010 and these are the files to delete: C:\Documents and Settings\Charles\NTUSER.DAT.jv16pt_bak.LOG C:\Documents and Settings\Charles\NTUSER.DAT.jv16pt_bak2 C:\Documents and Settings\Charles\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.jv16pt_bak C:\Documents and Settings\LocalService\NTUSER.DAT.jv16pt_bak C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.jv16pt_bak C:\Documents and Settings\NetworkService\NTUSER.DAT.jv16pt_bak C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.jv16pt_bak C:\WINDOWS\system32\config\default.jv16pt_bak C:\WINDOWS\system32\config\software.jv16pt_bak.LOG C:\WINDOWS\system32\config\software.jv16pt_bak2 C:\WINDOWS\system32\config\system.jv16pt_bak C:\WINDOWS\system32\config\system.jv16pt_bak.LOG Link to post Share on other sites
siliconman01 0 Posted October 31, 2010 Share Posted October 31, 2010 I just ran the registry compactor in jv16 2010 and these are the files to delete: C:\Documents and Settings\Charles\NTUSER.DAT.jv16pt_bak.LOG C:\Documents and Settings\Charles\NTUSER.DAT.jv16pt_bak2 C:\Documents and Settings\Charles\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.jv16pt_bak C:\Documents and Settings\LocalService\NTUSER.DAT.jv16pt_bak C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.jv16pt_bak C:\Documents and Settings\NetworkService\NTUSER.DAT.jv16pt_bak C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.jv16pt_bak C:\WINDOWS\system32\config\default.jv16pt_bak C:\WINDOWS\system32\config\software.jv16pt_bak.LOG C:\WINDOWS\system32\config\software.jv16pt_bak2 C:\WINDOWS\system32\config\system.jv16pt_bak C:\WINDOWS\system32\config\system.jv16pt_bak.LOG JFI, you can do this deletion within jv16 PT. Just open jv16, in the top menu go to Tools>Maintenance Program and select "Remove Registry Compactor Backups". It will locate all the registry compact backup files, display them and ask you if you want to delete them. These files vary based on Windows OS and what needs to be compacted. Link to post Share on other sites
Winapp2.ini 0 Posted October 31, 2010 Author Share Posted October 31, 2010 so would this suffice? [jv16 PowerTools 2010*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exe DetectFile=%ProgramFiles(x86)%\jv16 PowerTools 2010\jv16PT.exe Default=False FileKey1=%userprofile%\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey1=%localappdata%\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey2=%userprofile%|NTUSER.DAT.bak_jv16pt FileKey3=%systemdrive%\documents and settings\LocalService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey4=%systemdrive%\documents and settings\LocalService|NTUSER.DAT.bak_jv16pt FileKey5=%systemdrive%\documents and settings\NetworkService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey6=%systemdrive%\documents and settings\NetworkService|NTUSER.DAT.bak_jv16pt FileKey3=%systemdrive%\users\LocalService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey4=%systemdrive%\users\LocalService|NTUSER.DAT.bak_jv16pt FileKey5=%systemdrive%\users\NetworkService\Local Settings\Application Data\Microsoft\Windows|UsrClass.dat.bak_jv16pt FileKey6=%systemdrive%\users\NetworkService|NTUSER.DAT.bak_jv16pt FileKey7=%windir%\system32\config|SAM.bak_jv16pt FileKey8=%windir%\system32\config|SECURITY.bak_jv16pt FileKey9=%windir%\system32\config|default.bak_jv16pt FileKey10=%windir%\system32\config|software.bak_jv16pt FileKey11=%windir%\system32\config|system.bak_jv16pt [jv16 PowerTools 2010*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exe DetectFile=%ProgramFiles(x86)%\jv16 PowerTools 2010\jv16PT.exe Default=False FileKey1=%userprofile%\|NTUSER.DAT.jv16pt_bak.LOG FileKey2=%userpfofile%\|NTUSER.DAT.jv16pt_bak2 FileKey3=%userprofile%\Local Settings\Application Data\Microsoft\Windows\|UsrClass.dat.jv16pt_bak FileKey4=%systemdrive%\documents and settings\LocalService\|NTUSER.DAT.jv16pt_bak FileKey5=%systemdrive%\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\|UsrClass.dat.jv16pt_bak FileKey6=%systemdrive%\Documents and Settings\NetworkService\|NTUSER.DAT.jv16pt_bak FileKey7=%systemdrive%\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\|UsrClass.dat.jv16pt_bak FileKey8=%windir%\system32\config\|default.jv16pt_bak FileKey9=%windir%\system32\config\|software.jv16pt_bak.LOG FileKey10=%windir%\system32\config\|software.jv16pt_bak2 FileKey11=%windir%\system32\config\|system.jv16pt_bak FileKey12=%windir%\system32\config\|system.jv16pt_bak.LOG Link to post Share on other sites
Miroku4444 0 Posted October 31, 2010 Share Posted October 31, 2010 I'm assuming the bottom one is the corrected one? [jv16 PowerTools 2010*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exe DetectFile=%ProgramFiles(x86)%\jv16 PowerTools 2010\jv16PT.exe Default=False FileKey1=%userprofile%\|NTUSER.DAT.jv16pt_bak.LOG FileKey2=%userpfofile%\|NTUSER.DAT.jv16pt_bak2 FileKey3=%userprofile%\Local Settings\Application Data\Microsoft\Windows\|UsrClass.dat.jv16pt_bak FileKey4=%systemdrive%\documents and settings\LocalService\|NTUSER.DAT.jv16pt_bak FileKey5=%systemdrive%\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\|UsrClass.dat.jv16pt_bak FileKey6=%systemdrive%\Documents and Settings\NetworkService\|NTUSER.DAT.jv16pt_bak FileKey7=%systemdrive%\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\|UsrClass.dat.jv16pt_bak FileKey8=%windir%\system32\config\|default.jv16pt_bak FileKey9=%windir%\system32\config\|software.jv16pt_bak.LOG FileKey10=%windir%\system32\config\|software.jv16pt_bak2 FileKey11=%windir%\system32\config\|system.jv16pt_bak FileKey12=%windir%\system32\config\|system.jv16pt_bak.LOG Link to post Share on other sites
Winapp2.ini 0 Posted October 31, 2010 Author Share Posted October 31, 2010 Yes, does that work? Link to post Share on other sites
Miroku4444 0 Posted October 31, 2010 Share Posted October 31, 2010 Ill test it in the morning, but thanks for all your help. Link to post Share on other sites
