Miroku4444 0 Posted December 5, 2010 Share Posted December 5, 2010 Want to request a program be added? Register and post on the offical piriform forums ( this thread http://tinyurl.com/Winapp2-Thread ) Shouldn't this be: http://forum.piriform.com/index.php?showtopic=29438&st=0 Link to post Share on other sites
Winapp2.ini 0 Posted December 5, 2010 Author Share Posted December 5, 2010 Shouldn't this be: http://forum.pirifor...opic=29438&st=0 I tinyurl'd it because the topic link is very long Link to post Share on other sites
Winapp2.ini 0 Posted December 5, 2010 Author Share Posted December 5, 2010 [Downloaded Installations*] LangSecRef=3025 DetectFile=%LocalAppData%\Downloaded Installations Default=False FileKey1=%LocalAppData%\Downloaded Installations|*.*|RECURSE I'm not so sure its safe to clean the Downloaded Installations folder, but I really don't know, can anyone confirm/deny? Link to post Share on other sites
Miroku4444 0 Posted December 5, 2010 Share Posted December 5, 2010 I tinyurl'd it because the topic link is very long Oh, a re-direct link. Ok, I got it. Link to post Share on other sites
Miroku4444 0 Posted December 5, 2010 Share Posted December 5, 2010 I'm not so sure its safe to clean the Downloaded Installations folder, but I really don't know, can anyone confirm/deny? Some programs use this folder for a copy of the install file. When you decide to update the program it may use this to update. If you delete this folder, the update won't install. Link to post Share on other sites
Moderators Nergal 0 Posted December 5, 2010 Moderators Share Posted December 5, 2010 I'm not so sure its safe to clean the Downloaded Installations folder, but I really don't know, can anyone confirm/deny? Confirmed ; Valid commands:; LangSecRef - The section under applications (see below) ; Detect - Location in the registry to activate an entry ; DetectFile - Location on a disk to activate an entry ; Default - Default on/off value (all false in this file) ; FileKey(x) - Files to be deleted ; RegKey(x) - Registry Values to be deleted ; ExcludeKey(x) - Files to NOT be deleted (used in tandum with a |*.* FileKey frequently ; Section - Sets a specific (new) section ;Warning - Pops up a Warning when the checkmark is ticked Link to post Share on other sites
siliconman01 0 Posted December 8, 2010 Share Posted December 8, 2010 I recommend that you combine the jv16 PowerTools 2009 and 2010 code with the following code which also includes 2011 currently in Beta testing. The registry compact files are the same irrespective of which version of jv16 being used. [jv16 PowerTools 2009/10/11**] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2009\jv16PT.exe DetectFile=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exe DetectFile=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe Default=False FileKey1=%userprofile%\|NTUSER.DAT.jv16pt_bak FileKey2=%userprofile%\|NTUSER.DAT.jv16pt_bak2 FileKey3=%userprofile%\|NTUSER.DAT.jv16pt_bak.LOG1 FileKey4=%userprofile%\|NTUSER.DAT.jv16pt_bak.LOG2 FileKey5=%LocalAppData%\Microsoft\Windows\|UsrClass.dat.jv16pt_bak FileKey6=%LocalAppData%\Microsoft\Windows\|UsrClass.dat.jv16pt_bak2 FileKey7=%LocalAppData%\Microsoft\Windows\|UsrClass.dat.jv16pt_bak.LOG1 FileKey8=%LocalAppData%\Microsoft\Windows\|UsrClass.dat.jv16pt_bak.LOG2 FileKey9=%windir%\system32\config\|Default.jv16pt_bak FileKey10=%windir%\system32\config\|Default.jv16pt_bak2 FileKey11=%windir%\system32\config\|Default.jv16pt_bak.LOG1 FileKey12=%windir%\system32\config\|Default.jv16pt_bak.LOG2 FileKey13=%windir%\system32\config\|software.jv16pt_bak.LOG1 FileKey14=%windir%\system32\config\|software.jv16pt_bak.LOG2 FileKey15=%windir%\system32\config\|software.jv16pt_bak FileKey16=%windir%\system32\config\|software.jv16pt_bak2 FileKey17=%windir%\system32\config\|system.jv16pt_bak FileKey18=%windir%\system32\config\|system.jv16pt_bak2 FileKey19=%windir%\system32\config\|system.jv16pt_bak.LOG1 FileKey20=%windir%\system32\config\|system.jv16pt_bak.LOG2 FileKey21=%windir%\System32\config\|SAM.jv16pt_bak FileKey22=%windir%\System32\config\|SAM.jv16pt_bak2 FileKey23=%windir%\System32\config\|SAM.jv16pt_bak.LOG1 FileKey24=%windir%\System32\config\|SAM.jv16pt_bak.LOG2 FileKey25=%windir%\System32\config\|COMPONENTS.jv16pt_bak FileKey26=%windir%\System32\config\|COMPONENTS.jv16pt_bak2 FileKey27=%windir%\System32\config\|COMPONENTS.jv16pt_bak.LOG1 FileKey28=%windir%\System32\config\|COMPONENTS.jv16pt_bak.LOG2 FileKey29=%windir%\ServiceProfiles\NetworkService\|NTUSER.DAT.jv16pt_bak FileKey30=%windir%\ServiceProfiles\NetworkService\|NTUSER.DAT.jv16pt_bak2 FileKey31=%windir%\ServiceProfiles\NetworkService\|NTUSER.DAT.jv16pt_bak.LOG1 FileKey32=%windir%\ServiceProfiles\NetworkService\|NTUSER.DAT.jv16pt_bak.LOG2 FileKey33=%windir%\ServiceProfiles\LocalService\|NTUSER.DAT.jv16pt_bak FileKey34=%windir%\ServiceProfiles\LocalService\|NTUSER.DAT.jv16pt_bak2 FileKey35=%windir%\ServiceProfiles\LocalService\|NTUSER.DAT.jv16pt_bak.LOG1 FileKey36=%windir%\ServiceProfiles\LocalService\|NTUSER.DAT.jv16pt_bak.LOG2 Link to post Share on other sites
RCMorey11 0 Posted December 8, 2010 Share Posted December 8, 2010 Has it ever been suggested to add include the latest WinApp2.ini file with each new CCleaner release and then have an option to select if it is included or not? Then those of us who like the extra options but don't necessary need all the updates inbetween CCleaner releases can still at least get periodic WinApp2.ini updates. Link to post Share on other sites
Aethec 0 Posted December 8, 2010 Share Posted December 8, 2010 Has it ever been suggested to add include the latest WinApp2.ini file with each new CCleaner release and then have an option to select if it is included or not? Then those of us who like the extra options but don't necessary need all the updates inbetween CCleaner releases can still at least get periodic WinApp2.ini updates. I don't think Piriform wants to test all entries in Winapp2.ini. A single bad entry could do a lot of harm. Link to post Share on other sites
RCMorey11 0 Posted December 8, 2010 Share Posted December 8, 2010 I don't think Piriform wants to test all entries in Winapp2.ini. A single bad entry could do a lot of harm. That's why it would be an option, maybe a checkbox to include/exclude the WinApp2.ini file. Then you could include the file the same way you can now without having to download it, or you could choose not to and use CCleaner with the normal configuration (this would be default). Then maybe even add another option to be able to automatically check and download updated WinApp2.ini files. It may be to much effort to impliment for the small benefit. Link to post Share on other sites
Moderators Nergal 0 Posted December 9, 2010 Moderators Share Posted December 9, 2010 Well basically the easy answer to this would be that it would be redundant. Why would they include winapp2.ini when they would just as easily intigrate it into the program. There is nothing different in the embedded from the way winapp2 does things, winapp2 is just extra entries that haven't been included in the program. Aside from that, this Winapp2 is an unofficial version that has been maintained by community members. The Point of the ability to do a Win*2.ini file is so a user can add entries for apps they use to the program. TwistedMetal, and now Winapp2.ini (the person), just happen to have collected a number of entires for programs from throughout this forum and made a file that is easily accessable to a user of ccleaner. I've said it before and I'll say it again. The inclusion of these files as a whole into the base installer will never happen, it would bloat the installer and (again) defeat the purpose of even having a win*2.ini (I keep many of the entries listed from the winapp2.ini shared here in my winsys2.ini) Link to post Share on other sites
sdratsaB_hsurC_ot_ekiL_I 0 Posted December 10, 2010 Share Posted December 10, 2010 Already included in Winapp2.ini is Eusing Free Registry Cleaner. Perhaps Eusing Free Registry Defrag will be added soon. Setting up a Request For Eusing Free Registry Defrag entry or assistance in creating one. Link to post Share on other sites
aqua 0 Posted December 10, 2010 Share Posted December 10, 2010 can you add "gBurner" program please.. thanks Link to post Share on other sites
Moderators Nergal 0 Posted December 10, 2010 Moderators Share Posted December 10, 2010 Already included in Winapp2.ini is Eusing Free Registry Cleaner. Perhaps Eusing Free Registry Defrag will be added soon. Setting up a Request For Eusing Free Registry Defrag entry or assistance in creating one. There seems nothing to clean for this program. If I am incorrect, please provide the location of the files you feel should be cleaned (tested on windows XP sp3) it doesn't even seem to have a registry entry in the computer's registry. can you add "gBurner" program please.. thanks On this one, too, I could not find any thing to clean though my test was cut short as I could not burn using my Virtual PC. The Default Temporary location for burned files is window's temp folder which is already cleaned by cleaner. There were MRU Registry entrys if that is what you wish cleaned Here is an entry [gBurner*] LangSecRef=3021 Detect=HKCU\Software\gBurner Default=False RegKey1=HKCU\Software\gBurner|Reopen0 RegKey2=HKCU\Software\gBurner|Reopen1 RegKey3=HKCU\Software\gBurner|Reopen2 RegKey4=HKCU\Software\gBurner|Reopen3 Link to post Share on other sites
sdratsaB_hsurC_ot_ekiL_I 0 Posted December 11, 2010 Share Posted December 11, 2010 You may be correct Nergal. You may be able to clear something up for me. If you scan with Index.dat Analyzer after cleaning with CCleaner apparently index.dat traces remain for example from cnn live windows media player and possibly others. Also, is there a possibility the index.dat locations change and and thats why CCleaner is not picking up? Upon an Index.dat Analyzer scan the locations shown for dat files in the Index.dat Analyzer program window are the following. C:\Documents and Settings\user name\Local Settings\Temporary Internet Files\Content.IE5\index.dat C:\Documents and Settings\user name\Local Settings\History\History.IE5\index.dat C:\Documents and Settings\user name\Cookies\index.dat C:\Documents and Settings\user name\Local Settings\History\History.IE5\MSHist(numbers that would be here without quotations vary each scan).ini The apparent random numbers in last entry may be the reason its not deleting fron CCleaner this particulat entry but the other locations stay consistent shouldn't they be removed. Again if you can create an entry for me or instruct me on how to create one to add to Winapp2.ini file. Appreciate all the assistance. Link to post Share on other sites
CSGalloway 0 Posted December 12, 2010 Share Posted December 12, 2010 The Detect line doesn't work here: [Yahoo Messenger (Logs/Cache)*] LangSecRef=3022 Detect=%ProgramFiles%\Yahoo!\Messenger|ypager.log Default=False FileKey1=%ProgramFiles%\Yahoo!\Messenger|ypager.log FileKey2=%ProgramFiles%\Yahoo!\Messenger\Profiles|*.*|RECURSE FileKey3=%ProgramFiles%\Yahoo!\Messenger\Cache|*.*|RECURSE FileKey4=%ProgramFiles%\Yahoo!\Messenger\IMVCache|*.*|RECURSE It need to be a DetectFile line for a file or a Detect for the registry. the best detect line would be: Detect=HKCU\Software\Yahoo\pager ======================================== The following entrities should be added.... [ACDSee 6.0 Standard*] Warning=This will remove the Database information, use with caution*** Default=False Detect=HKCU\Software\ACD Systems\ACDSee 6.0 FileKey1=%appdata%\ACD Systems\Catalogs\Default|*.* LangSecref=3023 Link to post Share on other sites
Winapp2.ini 0 Posted December 13, 2010 Author Share Posted December 13, 2010 http://ompldr.org/vNmpncg/winapp2.ini Updated, wait for the changes to CCEnhancer or grab it above! Link to post Share on other sites
Miroku4444 0 Posted December 15, 2010 Share Posted December 15, 2010 http://ompldr.org/vNmpncg/winapp2.ini Updated, wait for the changes to CCEnhancer or grab it above! Thanks!! Link to post Share on other sites
CSGalloway 0 Posted December 16, 2010 Share Posted December 16, 2010 These entries should be helpful to others. [680: MS Windows Wallpaper*] Default=False Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Wallpaper LangSecRef=3025 RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Wallpaper\MRU [690: Multi-Edit 9.0*] Default=False Detect=HKCU\Software\American Cybernetics\Multi-Edit\9.0 FileKey1=%ProgramFiles%\Multi-Edit 9\Config\Tmp|*.* LangSecref=3021 [695: MySpaceIM*] Default=False Detect=HKCU\Software\MySpace\IM FileKey1=%appdata%\MySpace\IM\Images|*.* FileKey2=%appdata%\MySpace\IM\Dump|*.* FileKey3=%appdata%\MySpace\IM\Logs|*.* FileKey4=%appdata%\MySpace\IM\Install|*.* LangSecref=3021 [1056: Windows Live Mail*] Default=False Detect=HKCU\Software\Microsoft\Windows Live Mail LangSecRef=3021 RegKey1=HKCU\Software\Microsoft\Windows Live Mail|SearchFolderVersion Warning=this will reset the read counts, which will be recaculated when WLMail is started. [1092: WMP Art Cache*] Default=False Detect=HKCU\Software\Microsoft\MediaPlayer\Player FileKey1=%LocalAppData%\Microsoft\Media Player\Art Cache\LocalMLS|*.*|RECURSE LangSecRef=3023 [1135: Yahoo! Autosync*] Default=False Detect=HKCU\Software\Yahoo!\Autosync for Yahoo! FileKey1=%ProgramFiles%\Yahoo!\Yahoo! Autosync\Logs LangSecRef=3022 [1137: Yahoo! Messenger (Cache/Chats/IMVCache/Log/Logs)*] Default=False Detect=HKCU\Software\Yahoo\pager FileKey1=%ProgramFiles%\Yahoo!\Messenger|ypager.log FileKey2=%ProgramFiles%\Yahoo!\Messenger\Cache|*.*|RECURSE FileKey3=%ProgramFiles%\Yahoo!\Messenger\IMVCache|*.*|RECURSE FileKey4=%ProgramFiles%\Yahoo!\Messenger\Profiles|*.*|RECURSE FileKey5=%ProgramFiles%\Yahoo!\Messenger\Logs|*.* LangSecRef=3022 [1139: Yahoo! Messenger (Cache/Chats/Log)*] Default=False Detect=HKCU\Software\Yahoo\pager FileKey1=%ProgramFiles%\Yahoo!\Messenger\Cache|*.*|RECURSE FileKey2=%ProgramFiles%\Yahoo!\Messenger\Profiles|*.*|RECURSE FileKey3=%ProgramFiles%\Yahoo!\Messenger|ypager.log LangSecRef=3022 [1140: Yahoo! Messenger (Cache/IMVCache/Chats/Log)*] Default=False Detect=HKCU\Software\Yahoo\pager FileKey1=%ProgramFiles%\Yahoo!\Messenger\Cache|*.*|RECURSE FileKey2=%ProgramFiles%\Yahoo!\Messenger\IMVCache|*.*|RECURSE FileKey3=%ProgramFiles%\Yahoo!\Messenger\Profiles|*.*|RECURSE FileKey4=%ProgramFiles%\Yahoo!\Messenger|ypager.log LangSecRef=3022 [1141: Yahoo! Messenger (Cache/IMVCache/Log)*] Default=False Detect=HKCU\Software\Yahoo\pager FileKey1=%ProgramFiles%\Yahoo!\Messenger\Cache|*.*|RECURSE FileKey2=%ProgramFiles%\Yahoo!\Messenger\IMVCache|*.*|RECURSE FileKey3=%ProgramFiles%\Yahoo!\Messenger|ypager.log LangSecRef=3022 [1142: Yahoo! Messenger (Cache/IMVCache/Log)*] Default=False Detect=HKCU\Software\Yahoo\pager FileKey2=%ProgramFiles%\Yahoo!\Messenger\Cache|*.*|RECURSE FileKey3=%ProgramFiles%\Yahoo!\Messenger\IMVcache|*.*|RECURSE FileKey1=%ProgramFiles%\Yahoo!\Messenger|ypager.log FileKey4=%SystemDrive%|YServer.txt LangSecRef=3022 [1144: Yahoo! Messenger (Chats)*] Default=False Detect=HKCU\Software\Yahoo\pager FileKey1=%ProgramFiles%\Yahoo!\Messenger\Profiles|*.*|RECURSE LangSecRef=3022 [1145: Yahoo! Messenger (Chats/Log)*] Default=False Detect=HKCU\Software\Yahoo\pager FileKey1=%ProgramFiles%\Yahoo!\Messenger\Profiles|*.*|RECURSE FileKey2=%ProgramFiles%\Yahoo!\Messenger|ypager.log LangSecRef=3022 [1146: Yahoo! Messenger (Regi. Profiles)*] Default=False Detect=HKCU\Software\Yahoo\Profiles LangSecRef=3022 RegKey1=HKCU\Software\Yahoo\Profiles Link to post Share on other sites
Winapp2.ini 0 Posted December 19, 2010 Author Share Posted December 19, 2010 Grab it while its hot (new update) http://ompldr.org/vNm1nbw/winapp2.ini Changes and the download link in the first post as well Link to post Share on other sites
TheWebAtom 0 Posted December 19, 2010 Share Posted December 19, 2010 CCEnhancer will grab the new rules now Link to post Share on other sites
Moonbase 0 Posted December 19, 2010 Share Posted December 19, 2010 Cheers for taking the time and effort to always keep us up-to-date, Winapp2.ini! Happy holidays everyone! Link to post Share on other sites
CSGalloway 0 Posted December 22, 2010 Share Posted December 22, 2010 The followng errors were found in the [Version: v1.0 build 101218] of winapp2.ini Format is Line number : error found Follwing lines have: "= " 119 : Detect= HKCU\Software\Advanced Searchbar\Toolbar 1828 : Detect= HKCU\Software\Microsoft\Works\8.0 Should have DetectFile instead of Detect. 1105 : Detect=%ProgramFiles%\Go!Zilla 3155 : Detect=%ProgramFiles%\Yahoo!\Messenger\ 3148 : Detect=%ProgramFiles%\Yahoo!\Messenger\ 3163 : Detect=%ProgramFiles%\Yahoo!\Messenger\ Warning for [Yahoo Messenger Logs*] is wrong. Change Warning=This will also delete your saved chat histories. to Warning=This will also delete your useage loges. The RegKey1 for [Yahoo Messenger Profiles*] should be moved to it's own entirty. A statement for [Yahoo Messenger Profiles*] should be added, such as: Warning=This will also delete your saved chat histories. ================================================================================== Link to post Share on other sites
Winapp2.ini 0 Posted December 22, 2010 Author Share Posted December 22, 2010 Thank you for those amendments But why should the RegKey for Y!Messenger Profiles be moved to its own entry? Link to post Share on other sites
CSGalloway 0 Posted December 23, 2010 Share Posted December 23, 2010 The RegKey1 entry for Yahoo Profiles stores things like custom status messages. Has nothing to do with the messenger profiles folder tree. I know that some people will want to remove the HKCU...Yahoo\Profiles but keep the chat history. That is why I suggested spliting the one entry. Basically any thing after the "=" starts with HK is a registry key and hence needs Detect line. If what follows the "=" is a "%" or a drive letter then it needs DetectFile line. Does this make sense? with the changes I recommended - if you wanted to send me a revised winapp2.ini as a private message - I'd be glad to look at it ...... before you post it .... Link to post Share on other sites
