Winapp2.ini additions
Winapp2.ini
  • Moderators
learned a new trick for DetectOS
if you place a pipe (|) infront of the OS number it'll only cover that OS version (and I believe lower)
e.g.
[Windows XP Error Reporting*]
LangSecRef=3003
LangRef=3149
Default=False
DetectOS=|5.2
FileKey1=%windir%\pchealth\ERRORREP\|*.*|RECURSE
only shows on windows XP and lower
Link to comment
Hi,
There are:
: occurances of "RECURSE|REMOVESELF" which can just have "RECURSE"
: some lines end in "|" which is not necessary
: Entry [AOL 9.1*] does not work.
I have WinXP and I have AOL 9.1 but it does not show up.
Narrowed down to the Detectfile entry -
C:\Documents and Settings\Charles\Application Data\AOL\C_AOL 9.1
so the problem is the "_" between L and 9 should be a space.
"C:\Documents and Settings\All Users\Application Data\AOL\C_AOL 9.1\bart"
should be "*.*|RECURSE" ....
: Some entries have "*" before product name like "[*BreezeBrowser Pro]" where
most are after product name.
: [Free Download Manager*]
The RegKey lines have some stuff at EndOfLine that doesn't make sense
: Some FileKeys have "\|" while most have "|"; Be nice to just have one
or the other...
: Please add:
[AOL AIM Messenger*]
Default=False
DetectFile=%appdata%\acccore\caches\bart
FileKey1=%appdata%\acccore\caches\bart|*.*|RECURSE
FileKey2=%LocalAppData%\AIM\Settings\aolbartcache|*.*|RECURSE
LangSecRef=3022
Link to comment
I also tried this a while ago, while running ?Torrent, however I only use analyze when testing new entries, and that was enough for me to see it doesn't work. I wonder why ?Torrent doesn't lock its "in use" torrent files.
That is odd. I also wonder why, they wouldn't.
I put in a request on the uTorrent forums: http://forum.utorrent.com/viewtopic.php?id=91974
Link to comment
Internet Download Accelerator (IDA)
[internet Download Accelerator*]
LangSecRef=3022
Detect=HKCU\Software\2VG\Internet Download Accelerator
Default=True
FileKey1=%AppData%\Internet Download Accelerator|history.xml
FileKey2=%AppData%\Internet Download Accelerator|nodelist.xmlc
FileKey3=%AppData%\Internet Download Accelerator\temp|*.hnt
FileKey4=%AppData%\Internet Download Accelerator\temp|lastnews.*
FileKey5=%AppData%\Internet Download Accelerator\temp|playflv.html
Beyond Compare 3
[beyond Compare 3*]
LangSecRef=3021
Detect=HKLM\Software\Scooter Software\Beyond Compare 3
Default=True
FileKey1=%AppData%\Scooter Software\Beyond Compare 3|*.bak
FileKey2=%AppData%\Scooter Software\Beyond Compare 3|BCCommands.xml
FileKey3=%AppData%\Scooter Software\Beyond Compare 3|BCSessions.xml
Link to comment
Good idea !
but K-meleon has already this option ( automatic cleaning ) :)
This functionality in K-Meleon is provided by a "Privacy plugin" that, unfortunately, doesn't always work as expected. In version 1.6beta 2 for example, it is bugged and the history cleaning on it doesn't work at all (you have to go to the preferences window to clean history).
Please, help add K-Meleon to the Winapp2.ini File!
Link to comment
It works fine (even with the beta) on my K-Meleon :)
Link to comment
Restorator 2007
[Restorator 2007*]
LangSecRef=3021
Detect=HKCU\Software\Bomers\Restorator
Default=False
RegKey1=HKCU\Software\Bomers\Restorator\Restorator\Current|LastSearchString
RegKey2=HKCU\Software\Bomers\Restorator\Restorator\FindDialog
RegKey3=HKCU\Software\Bomers\Restorator\Restorator\GrabDialog
RegKey4=HKCU\Software\Bomers\Restorator\Restorator\LastFoundFiles
RegKey5=HKCU\Software\Bomers\Restorator\Restorator\MRUList
BTW is there a way to edit .INI file sections?
Link to comment
  • Moderators
I don't understand the question. can you expand what you mean?
Link to comment
Anyway of NOT deleting the .INI file to preserve settings, only editing it to remove MRU stuff example
UniExtract.ini
[uniExtract Preferences]
globalprefs=1
history=1
appendext=1
removetemp=1
removedupe=1
warnexecute=1
debugdir=%temp%
[File History]
0=C:\Users\Ricardo\Desktop\wpi.msi
3=F:\Microsoft\Drivers\Se7en\INF_allOS_9.1.1.1014_PV.exe
5=F:\Microsoft\Drivers\Se7en\INF_allOS_9.1.2.1008_PV.exe
6=C:\Users\Ricardo\Downloads\wintv7setup.exe
7=C:\Users\Ricardo\Documents\Projects\dotNETMaker\dotNETfx\DNF11\netfx.msi
8=C:\Users\Ricardo\Desktop\Seven Remix XP 2.41.exe
9=C:\Users\Ricardo\Downloads\EP0000156866.exe
2=F:\Microsoft\Drivers\Se7en\INF_allOS_9.2.0.1021_PV.exe
1=F:\wpi\Install\SkypeSetup.msi
4=F:\Microsoft\Drivers\Se7en\INF_allOS_9.1.2.1007_PV.exe
[Directory History]
Code could go something like
[universal Extractor*]
LangSecRef=3021
DetectFile=%ProgramFiles%\Universal Extractor\UniExtract.exe
Default=False
; This will delete all that is present under a ini section
FileKey1=%ProgramFiles%\Universal Extractor|UniExtract.ini|File History,*
; This will delete only a specified value (8=*)
FileKey2=%ProgramFiles%\Universal Extractor|UniExtract.ini|Directory History,8
Its just a rough example to show you what I mean, you guys may know better how to code winapp2.ini
Link to comment
  • Moderators
We are working on adding support to clean various types of document/content. INI files will be one of them! Coming soon! :)
That's awesome news. :)
Link to comment
Happy to hear, cant wait :)
OH and please dont forget to add the 3 new program cleaning entries of mine (Restorator 2007, IDA and Beyond Compare 3) to Winapp2.ini, I use and have tested them and they all work gr8
Link to comment
Wildcard support would be nice too! (For folders!)
Yea, I saw that in the Web Platform Installer thread and thought it would be cool...this program that I did would benefit from it, making it work for all versions of the app and not just the one
[beyond Compare 3*]
LangSecRef=3021
Default=True
To make compatible with all versions it would go like this (would also be nice to add wildcard support for reg)
[beyond Compare*]
LangSecRef=3021
Detect=HKLM\Software\Scooter Software\Beyond Compare*
Default=True
FileKey1=%AppData%\Scooter Software\Beyond Compare*|*.bak
FileKey2=%AppData%\Scooter Software\Beyond Compare*|BCCommands.xml
FileKey3=%AppData%\Scooter Software\Beyond Compare*|BCSessions.xml
Link to comment
Well that wasn't quite how I was using it there, but you seem to have gotten the point! Another advantage of this would be
%AppData%\Scooter Software\*|*.bak
which is admittedly the same as \Scooter Software|*.bak|Recurse but the idea is essentially what you said, where it could be affixed to the end of a folder name to make it cross version compatible.
Link to comment
Register a new account
Sign in
Important Information
