tempguest Posted March 17, 2011 Share Posted March 17, 2011 Oh, okay, I didn't know Sandboxie worked like that! Thanks! I just fixed it now! I made a mistake in the first edit (earlier today), so make sure you ad the entry as of this post. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 17, 2011 Author Share Posted March 17, 2011 Oh, I had corrected that on my end when I read it earlier, so it's all good winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
waltzing Posted March 21, 2011 Share Posted March 21, 2011 Oh, I had corrected that on my end when I read it earlier, so it's all good First, a quick thank you to all the good work you do. Will the next update include OpenOffice.org 3.3.0? Alternatively, can i simply edit the winapp2.ini file and change the OOo entry from "3.2" to "3.3" there? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 21, 2011 Author Share Posted March 21, 2011 You're quite welcome, though I can't take credit since it is fueled by the community. To answer your question, probably! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Sailback Posted March 24, 2011 Share Posted March 24, 2011 You're quite welcome, though I can't take credit since it is fueled by the community. To answer your question, probably! I too want to thank you for maintaining winapp2.ini. I was about to suggest Several sections including the OpenOffice 3.2 section be removed from winapp2.ini when I saw the above post. The OO 3 section in winapp2.ini actually won't work because the path is incorrect. And it goes after the wrong file, anyway. OO 3 cleaning has been discussed elswhere on the forum. I believe deleting custom.xcu gives people problems in OO 3. So you may want to review the "OpenOffice 3" section in winapp.ini before adding support for OpenOffice 3.3 in winapp2.ini. Anyway, Here are a few winapp2.ini sections that seem to be duplicated in Ccleaner. My apologies if you have addressed some of them already. Remove Sections That Are In CCleaner Already: ********* Already In Winsys.Ini [MS Direct Draw*] In [Other Explorer MRUs] [MS Windows Wallpaper*] In [Other Explorer MRUs] ********* Already In Winapp.Ini [Acronis True Image Home*] [Azureus*] As [Vuze] [Google Calendar Sync*] [Media Player Classic Recent Files List*] In [Media Player Classic] [MS Office Publisher 2003*] In [Office 2003] Section [OpenOffice 3.2*] In [OpenOffice 3] Section [Opera 9 (Classic)*] [Outlook 2003*] In [Office 2003] Section [WinRAR History*] In [WinRAR] ** Covered In Winreg.ini ** [MUICache*] Also, you've cleaned up quite a few errors but a few still remain. Search for the offending line listed and make the recommended change if you agree. Fix Misspellings & Other Errors: **** Remove Duplicate Line: RegKey5=HKCU\Software\Poikosoft\Easy CD-DA Extractor 8|k92 **** should be FileKey4= FileKey3=%AppData%\Everest Labs\Spydefense|Backups.ini **** should be %systemdrive% ( %rootdir% doesn't work) FileKey1=%rootdir%|SCANDISK.LOG **** should be RECURSE FileKey2=%Public%\games\World of Warcraft\Errors|*.lua.bak|RECUSE **** should be Software RegKey1=HKCU\Sofrware\Nico Mal Computing\WinZip\Mru **** should be simply DetectFile DetectFile1=%UserProfile%\My Documents\IISExpress **** should be LangSecRef= Section=3024 **** should be %UserProfile%\Music FileKey2=%UserProfile%\My Music\CDDB|*.txt **** should be %UserProfile%\Videos FileKey2=%UserProfile%\My Videos\DivX Movies|*.*|RECURSE Thanks again. Link to comment Share on other sites More sharing options...
ricktendo64 Posted March 24, 2011 Share Posted March 24, 2011 FINALLY!!! - Added new environment variables for user documents. (i.e. %CommonDocuments%, %CommonMusic%, %CommonPictures%, %CommonVideo%, %MyDocuments%, %Documents%, %MyMusic%, %Music%, %MyPictures%, %Pictures%, %MyVideo%, %Video%) Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 24, 2011 Author Share Posted March 24, 2011 I'll be fixing up the file to reflect the changes in the new CCleaner version, and have it out soon. Thank you for all of that, Sailback! I really appreciate it! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
ricktendo64 Posted March 24, 2011 Share Posted March 24, 2011 I think I found a couple typo's in the new ini [CDex*] ... FileKey1=%Music%\My Music\CDDB|*.txt [iTunes Temp Files*] ... FileKey1=%Music%\My Music\iTunes|*.tmp|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 25, 2011 Author Share Posted March 25, 2011 D'aw shoot, I'll fix those right up winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
back_track Posted March 27, 2011 Share Posted March 27, 2011 [Eclips - Workspace*] LangSecRef=3024 DetectFile=%UserProfile%\workspace\ Default=False FileKey1=%UserProfile%\workspace\|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
SMalik Posted March 27, 2011 Share Posted March 27, 2011 Modified/new entries. [Adobe Shockwave Player*] LangSecRef=3023 DetectFile=%LocalLowAppData%\Adobe\Shockwave Player 11 Default=False FileKey1=%LocalLowAppData%\Adobe\Shockwave Player 11|Shockwave Log. [Auslogics BoostSpeed*] LangSecRef=3024 DetectFile=%ProgramFiles%\Auslogics\Auslogics BoostSpeed\boostspeed.exe Default=False FileKey1=%AppData%\Auslogics\BoostSpeed\User Reports|*.* FileKey2=%AppData%\Auslogics\Rescue\Boost Speed|*.* [Auslogics Disk Defrag*] LangSecRef=3024 Detect=HKCU\Software\Auslogics\Disk Defrag Default=False FileKey1=%AppData%\Auslogics\Disk Defrag\Reports|*.* [Auslogics Registry Cleaner*] LangSecRef=3024 Detect=HKCU\Software\Auslogics\Registry Cleaner Default=False FileKey1=%AppData%\Auslogics\Rescue\Auslogics Registry Cleaner|*.* [Auslogics Registry Defrag*] LangSecRef=3024 Detect=HKCU\Software\Auslogics\Registry Defrag Default=False FileKey1=%AppData%\Auslogics\Registry Defrag\Reports|*.* [Auslogics System Information*] LangSecRef=3024 Detect=HKCU\Software\Auslogics\System Information Default=False FileKey1=%AppData%\Auslogics\System Information|*.* [PowerISO*] LangSecRef=3024 Detect=HKCU\Software\PowerISO Default=False RegKey1=HKCU\Software\PowerISO|Reopen0 RegKey2=HKCU\Software\PowerISO|Reopen1 RegKey3=HKCU\Software\PowerISO|Reopen2 RegKey4=HKCU\Software\PowerISO|Reopen3 [snagit 9*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\9 Default=False FileKey1=%LocalAppData%\TechSmith\SnagIt\DataStore|*.* FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.* [snagit 10*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\10 Default=False FileKey1=%LocalAppData%\TechSmith\SnagIt\DataStore|*.* FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.* [ultraISO*] LangSecRef=3024 Detect=HKCU\Software\EasyBoot Systems\UltraISO\5.0 RegKey1=HKCU\Software\EasyBoot Systems\UltraISO\5.0|Reopen sDefault=False RegKey2=HKCU\Software\EasyBoot Systems\UltraISO\5.0|a RegKey3=HKCU\Software\EasyBoot Systems\UltraISO\5.0|b RegKey4=HKCU\Software\EasyBoot Systems\UltraISO\5.0|c RegKey5=HKCU\Software\EasyBoot Systems\UltraISO\5.0|d RegKey6=HKCU\Software\EasyBoot Systems\UltraISO\5.0|e RegKey7=HKCU\Software\EasyBoot Systems\UltraISO\5.0|f RegKey8=HKCU\Software\EasyBoot Systems\UltraISO\5.0|g RegKey9=HKCU\Software\EasyBoot Systems\UltraISO\5.0|h RegKey10=HKCU\Software\EasyBoot Systems\UltraISO\5.0|i Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 28, 2011 Moderators Share Posted March 28, 2011 Delete these entries from winapp2 Auslogics BoostSpeed Logs Wrong path Auslogics Free Utilities All the paths are wrong You've got to realize that some of the applications are old, and some people may actually still use the old versions. So any changes would possibly only add-in new paths where things have been moved for backwards compatibility versus just outright removing support for old versions. Link to comment Share on other sites More sharing options...
SMalik Posted March 28, 2011 Share Posted March 28, 2011 [snagit 9*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\9 Default=False RegKey1=HKCU\Software\TechSmith\SnagIt\9\Recent Captures RegKey2=HKCU\Software\TechSmith\SnagIt\9\SnagItEditor\Recent File List FileKey1=%LocalAppData%\TechSmith\SnagIt\DataStore|*.* FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.* [snagit 10*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\10 Default=False RegKey1=HKCU\Software\TechSmith\SnagIt\10\Recent Captures RegKey2=HKCU\Software\TechSmith\SnagIt\10\SnagItEditor\Recent File List FileKey1=%LocalAppData%\TechSmith\SnagIt\DataStore|*.* FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.* Link to comment Share on other sites More sharing options...
Miroku4444 Posted March 28, 2011 Share Posted March 28, 2011 [ultraISO*]LangSecRef=3024 Detect=HKCU\Software\EasyBoot Systems\UltraISO\5.0 RegKey1=HKCU\Software\EasyBoot Systems\UltraISO\5.0|Reopen sDefault=False RegKey2=HKCU\Software\EasyBoot Systems\UltraISO\5.0|a RegKey3=HKCU\Software\EasyBoot Systems\UltraISO\5.0|b RegKey4=HKCU\Software\EasyBoot Systems\UltraISO\5.0|c RegKey5=HKCU\Software\EasyBoot Systems\UltraISO\5.0|d RegKey6=HKCU\Software\EasyBoot Systems\UltraISO\5.0|e RegKey7=HKCU\Software\EasyBoot Systems\UltraISO\5.0|f RegKey8=HKCU\Software\EasyBoot Systems\UltraISO\5.0|g RegKey9=HKCU\Software\EasyBoot Systems\UltraISO\5.0|h RegKey10=HKCU\Software\EasyBoot Systems\UltraISO\5.0|i Is that s b4 the word detect an typo?? Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 28, 2011 Moderators Share Posted March 28, 2011 Is that s b4 the word detect an typo?? Looks like a typo indeed! sDefault=False should be: Default=False Link to comment Share on other sites More sharing options...
Miroku4444 Posted March 28, 2011 Share Posted March 28, 2011 [snagit 9*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\9 Default=False RegKey1=HKCU\Software\TechSmith\SnagIt\9\Recent Captures RegKey2=HKCU\Software\TechSmith\SnagIt\9\SnagItEditor\Recent File List FileKey1=%LocalAppData%\TechSmith\SnagIt\DataStore|*.* FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.* [snagit 10*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\10 Default=False RegKey1=HKCU\Software\TechSmith\SnagIt\10\Recent Captures RegKey2=HKCU\Software\TechSmith\SnagIt\10\SnagItEditor\Recent File List FileKey1=%LocalAppData%\TechSmith\SnagIt\DataStore|*.* FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.* Which versions of these is right? This one or the first one, or are they both right? FileKey1=%LocalLowAppData%\Adobe\Shockwave Player 11|Shockwave Log. Is that . after Shockwave Log a typo also?? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 29, 2011 Author Share Posted March 29, 2011 Ending in a . (or perhaps nothing at all) returns results for files with no extension (usually descibed as "file" in the status pane.) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Miroku4444 Posted March 29, 2011 Share Posted March 29, 2011 Ending in a . (or perhaps nothing at all) returns results for files with no extension (usually descibed as "file" in the status pane.) Ok, cool then its suppose to be there. Link to comment Share on other sites More sharing options...
Miroku4444 Posted March 29, 2011 Share Posted March 29, 2011 I have shockwave 11, which entry is right. This is saad2011's [Adobe Shockwave Player*] LangSecRef=3023 DetectFile=%LocalLowAppData%\Adobe\Shockwave Player 11 Default=False FileKey1=%LocalLowAppData%\Adobe\Shockwave Player 11|Shockwave Log. The One in Winapp2.ini already. [shockwave 11*] LangSecRef=3023 DetectFile=%LocalLowAppData%\Adobe\Shockwave Player 11 Default=False FileKey1=%LocalLowAppData%\Adobe\Shockwave Player 11|Shockwave Log. Or the built in one, whatever that does? Link to comment Share on other sites More sharing options...
SMalik Posted March 29, 2011 Share Posted March 29, 2011 MODIFIED ENTRIES [Adobe Shockwave 11*] LangSecRef=3023 Detect=HKCU\Software\AppDataLow\Software\Adobe\Shockwave 11 Default=False RegKey1=HKCU\Software\AppDataLow\Software\Adobe\Shockwave 11\statistics FileKey1=%LocalLowAppData%\Adobe\Shockwave Player 11|Shockwave Log [Macromedia Shockwave 10*] LangSecRef=3023 Detect=HKCU\Software\AppDataLow\Software\Macromedia\Shockwave 10 Default=False RegKey1=HKCU\Software\AppDataLow\Software\Macromedia\Shockwave 10\statistics FileKey1=%LocalLowAppData%\Macromedia\Shockwave Player|Shockwave Log [snagit 9*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\9 Default=False RegKey1=HKCU\Software\TechSmith\SnagIt\9\Recent Captures RegKey2=HKCU\Software\TechSmith\SnagIt\9\SnagItEditor\Recent File List FileKey1=%LocalAppData%\TechSmith\SnagIt\DataStore|*.* FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.* [snagit 10*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\10 Default=False RegKey1=HKCU\Software\TechSmith\SnagIt\10\Recent Captures RegKey2=HKCU\Software\TechSmith\SnagIt\10\SnagItEditor\Recent File List FileKey1=%LocalAppData%\TechSmith\SnagIt\DataStore|*.* FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.* [ultraISO*] LangSecRef=3024 Detect=HKCU\Software\EasyBoot Systems\UltraISO\5.0 RegKey1=HKCU\Software\EasyBoot Systems\UltraISO\5.0|Reopen Default=False RegKey2=HKCU\Software\EasyBoot Systems\UltraISO\5.0|a RegKey3=HKCU\Software\EasyBoot Systems\UltraISO\5.0|b RegKey4=HKCU\Software\EasyBoot Systems\UltraISO\5.0|c RegKey5=HKCU\Software\EasyBoot Systems\UltraISO\5.0|d RegKey6=HKCU\Software\EasyBoot Systems\UltraISO\5.0|e RegKey7=HKCU\Software\EasyBoot Systems\UltraISO\5.0|f RegKey8=HKCU\Software\EasyBoot Systems\UltraISO\5.0|g RegKey9=HKCU\Software\EasyBoot Systems\UltraISO\5.0|h RegKey10=HKCU\Software\EasyBoot Systems\UltraISO\5.0|i NOTE: UltraISO entry is for UltraISO version 5 through version 9. The paths for Shockwave 11 entry that is already in Winapp2.ini are wrong. Link to comment Share on other sites More sharing options...
Miroku4444 Posted March 29, 2011 Share Posted March 29, 2011 NOTE: UltraISO entry is for UltraISO version 5 through version 9. The paths for Shockwave 11 entry that is already in Winapp2.ini are wrong. What about the one built into the program? Link to comment Share on other sites More sharing options...
tempguest Posted March 30, 2011 Share Posted March 30, 2011 @tempguest yep, that's right. it's not an essential file and windows would recreate it everytime if it gets deleted. @winapp2.ini yep, it works. you can include it. %username% is the same as your windows username you are on. every windows user get it's own sandbox. eg. \Sandbox\tempguest\DefaultBox\ \Sandbox\Winapp2.ini\DefaultBox\ \Sandbox\randomcore\DefaultBox\ \Sandbox\%UserName%\DefaultBox\ Since you're the only other person on here that seems to use Sandboxie, I guess I'll ask for your opinion. Do you think it would be better off to modify the Sandboxie entry to erase the contents of all Sandboxes? Like this: [sandboxie Container Files*] LangSecRef=3024 DetectFile=%ProgramFiles%\Sandboxie\Start.exe Default=False ExcludeKey1=FILE|%SystemDrive%\Sandbox\%UserName%\DONT-USE.TXT FileKey1=%SystemDrive%\Sandbox\%UserName%|*.*|RECURSE Since I've only been using the default sandbox up until now, I just realized that no settings are contained in the above folder; just contents. So, if you have multiple Sandboxes, this will delete all the contents, but preserve your actual Sandboxes -- and their settings. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 31, 2011 Moderators Share Posted March 31, 2011 Latest Adobe Flash Player "superclean" complete with warning, correct file location and detect=false [Adobe Flash All Site History*] Warning=This will remove all sites from Flash Player's Settings (Trusted sites, Privacy, Storage and Peer Assisted Networking). There is no way to exclude sites. LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer Default=False FileKey1=%appdata%\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys|settings.sol Also this is now baked into CCleaner and can be removed from Winapp2 [Adobe Air*] LangSecRef=3024 DetectFile=%LocalAppData%\Adobe\Air\ Defualt=False FileKey1=%LocalAppData%\Adobe\Air\Logs|*.* ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
siliconman01 Posted April 1, 2011 Share Posted April 1, 2011 Latest Adobe Flash Player "superclean" complete with warning, correct file location and detect=false [Adobe Flash All Site History*] Warning=This will remove all sites from Flash Player's Settings (Trusted sites, Privacy, Storage and Peer Assisted Networking). There is no way to exclude sites. LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer Default=False FileKey1=%appdata%\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys|settings.sol Deleting settings.sol removes the user's total security settings for FlashPlayer, doesn't it (See link below)? It just doesn't remove "sites". This doesn't seem like a very good idea to me. http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager02.html Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
ricktendo64 Posted April 4, 2011 Share Posted April 4, 2011 Hey Winapp2.ini, you think you could request a feature where you could use strings/variables in winapp2.ini to translate certain entry names...Most programs wont need this, its only for expanded Windows cleaning. Here is an example of what I am talking about [%Remote_Desktop_Connection%*] LangSecRef=3025 DetectFile=%WinDir%\System32\mstsc.exe Default=False FileKey1=%Documents%\|*.rdp ; English (default or if language not supported) [strings] Remote_Desktop_Connection=Remote Desktop Connection ; 1034 is the language ID for Spanish [strings.1034] Remote_Desktop_Connection=Conexi?n a Escritorio remoto CCleaner will see %Remote_Desktop_Connection% and if you have it set to Spanish (1034) it will look under [strings.1034] and it will display "Conexi?n a Escritorio remoto", if its set to english or the language is not supported it will look under the default [strings] section Link to comment Share on other sites More sharing options...
