TheWebAtom 0 Posted January 25, 2011 Share Posted January 25, 2011 I would suggest a simple batch script that detects the most recent folder and trashes all the other folders. If one of the old folders is accessed by another program, it could cause the script to delete the newer version instead. Obviously, that would have devastating side effects. ___ Edit: Whipped this up in 20 minutes after dinner I'm Shane. Link to post Share on other sites
Alan_B 0 Posted January 25, 2011 Share Posted January 25, 2011 Not a problem. Use the /T option. i.e. /T:C not the default /T:W or the always now /T:A Example from my Local Settings :- C:\Documents and Settings\Dad>DIR LOC* /A:D | find "/" 06/01/2011 20:48 <DIR> Local Settings C:\Documents and Settings\Dad>DIR LOC* /A:D /T:W | find "/" 06/01/2011 20:48 <DIR> Local Settings C:\Documents and Settings\Dad>DIR LOC* /A:D /T:A | find "/" 25/01/2011 20:19 <DIR> Local Settings C:\Documents and Settings\Dad>DIR LOC* /A:D /T:C | find "/" 21/10/2006 22:40 <DIR> Local Settings C:\Documents and Settings\Dad> That shows a Read Access at 20:19 which is when the Event Log started (i.e. start-up before log on) It shows something got written in there on 6 Jan 2011. It shows the folder was created in 2006 and nothing will change that date unless the folder is deleted and then created anew. The date shown by DIR in default mode (no /T option) is NOT affected by Read ACCESS, but could be affected by a write operation within the folder. So long as the /T:C option is used there can be no problem. To see all the options try "DIR /?" Regards Alan Link to post Share on other sites
Winapp2.ini 0 Posted January 26, 2011 Author Share Posted January 26, 2011 updated for 3.03 winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Nergal 0 Posted January 26, 2011 Moderators Share Posted January 26, 2011 Drop box link still downloads previous version (v1.0.110115) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Winapp2.ini 0 Posted January 26, 2011 Author Share Posted January 26, 2011 Whoops dropped the file in the wrong folder. It's fixed now winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
siliconman01 0 Posted January 28, 2011 Share Posted January 28, 2011 Winapp2, Are you considering adding some the latest suggested additions....such as the one for LightScribe and the modified PDF_Xchange code? Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
Winapp2.ini 0 Posted January 28, 2011 Author Share Posted January 28, 2011 Slipped my mind completely sorry about that.. I'll add them now winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
ricktendo64 0 Posted January 28, 2011 Share Posted January 28, 2011 Found one more location for cleaning for Internet Download Accelerator, please add "%AppData%\Internet Download Accelerator\temp\Preview" for cleaning all the files within this folder (do not delete folder with REMOVESELF, if folder is deleted preview stop working until the program is restarted and the dir is recreated) here is the new code with the location added [internet Download Accelerator*] LangSecRef=3022 Detect=HKCU\Software\2VG\Internet Download Accelerator Default=True FileKey1=%AppData%\Internet Download Accelerator|history.xml FileKey2=%AppData%\Internet Download Accelerator|nodelist.xmlc FileKey3=%AppData%\Internet Download Accelerator\temp|*.hnt FileKey4=%AppData%\Internet Download Accelerator\temp|lastnews.* FileKey5=%AppData%\Internet Download Accelerator\temp|playflv.html FileKey6=%AppData%\Internet Download Accelerator\temp\Preview|*.* Thank you for maintaining this great file Link to post Share on other sites
Alan_B 0 Posted January 29, 2011 Share Posted January 29, 2011 Here is 50 MB of junk. I found these 2 years ago after running NTREGOPT, and believe these backups are only needed if the computer fails to boot after compacting the registry. They recently reappeared for some other unknown reason, possibly when I used regseeker to rebuild my iconcache, and then had to restore an ERUNT backup to put the desktop shortcuts back where they belong. There may be other reasons why these files are spontaneously created, in which case detection based on NTREGOPT/ERUNT might be inappropriate. PROCESSING "\Documents and Settings\Dad" 10/01/2011 21:38 9,490,432 ntuser.bak 10/01/2011 21:38 20,480 ntuser.tmp.LOG PROCESSING "\Documents and Settings\Dad"\LOCALS~1\APPLIC~1\MICROS~1\Windows 07/01/2011 12:35 180,224 UsrClass.bak 05/01/2011 21:17 0 UsrClass.tmp.LOG PROCESSING \DOCUME~1\LocalService 10/01/2011 21:38 233,472 NTUSER.bak 10/01/2011 21:38 8,192 NTUSER.tmp.LOG PROCESSING \DOCUME~1\LOCALS~1\LOCALS~1\APPLIC~1\MICROS~1\Windows 07/01/2011 12:35 8,192 UsrClass.bak 05/01/2011 21:17 0 UsrClass.tmp.LOG PROCESSING \DOCUME~1\NetworkService 10/01/2011 21:38 237,568 NTUSER.bak 10/01/2011 21:38 8,192 NTUSER.tmp.LOG PROCESSING \DOCUME~1\NETWOR~1\LOCALS~1\APPLIC~1\MICROS~1\Windows 07/01/2011 12:35 8,192 UsrClass.bak 05/01/2011 21:17 0 UsrClass.tmp.LOG PROCESSING \WINDOWS\system32\config 10/01/2011 21:38 21,815,296 SOFTWARE.bak 10/01/2011 21:38 18,350,080 SYSTEM.bak 10/01/2011 21:38 303,104 DEFAULT.bak 10/01/2011 21:38 57,344 SECURITY.bak 10/01/2011 21:38 32,768 SOFTWARE.tmp.LOG 10/01/2011 21:38 24,576 SAM.bak 10/01/2011 21:38 8,192 SECURITY.tmp.LOG 10/01/2011 21:38 1,024 SYSTEM.tmp.LOG 05/01/2011 21:17 0 DEFAULT.tmp.LOG 05/01/2011 21:17 0 SAM.tmp.LOG Alan Link to post Share on other sites
DalGond 0 Posted January 30, 2011 Share Posted January 30, 2011 I was manually deleting some files and find about 700Mb(!) of temporary installation files. When updating Apple Software, every installation packet is temporary cached. These temporary installation packets will remain there undefinedly... and according with Apple's support, they're safe to delete! Sources: http://discussions.apple.com/thread.jspa?threadID=1513820 http://discussions.info.apple.com/message.jspa?messageID=11635634 CCleaner .ini suggestion: [Apple Installer Cache] LangSecRef=3021 DetectFile1=%ProgramData%\Apple\Installer Cache DetectFile2=%ProgramData%\Apple Computer\Installer Cache Default=False FileKey1=%ProgramData%\Apple\Installer Cache|*.*|RECURSE FileKey2=%ProgramData%\Apple Computer\Installer Cache|*.*|RECURSE Link to post Share on other sites
Alan_B 0 Posted January 31, 2011 Share Posted January 31, 2011 Sources: http://discussions.apple.com/thread.jspa?threadID=1513820 http://discussions.info.apple.com/message.jspa?messageID=11635634 CCleaner .ini suggestion: [Apple Installer Cache] LangSecRef=3021 DetectFile1=%ProgramData%\Apple\Installer Cache DetectFile2=%ProgramData%\Apple Computer\Installer Cache Default=False FileKey1=%ProgramData%\Apple\Installer Cache|*.*|RECURSE FileKey2=%ProgramData%\Apple Computer\Installer Cache|*.*|RECURSE These do NOT work on XP. I note that both the links refer to queries raised in mid 2008 and only cited XP paths, i.e. C:\Documents and Settings\All Users\Application Data\ and not %ProgramData% XP by default does NOT understand %ProgramData%, neither does it understand %LocalAppdata% Somehow CCleaner under XP DOES understand %LocalAppdata% but it still does NOT understand %ProgramData% The code suggested failed to work until I launched CCLEANER via a batch file which included the code SET ProgramData=C:\Documents and Settings\All Users\Application Data\ CCLEANER NB The BAT script is in the same folder as CCleaner.exe and WinApp2.ini That found and removed 60+ MB of two Apple installers that have been lurking since 2008. Regards Alan Link to post Share on other sites
Alan_B 0 Posted February 2, 2011 Share Posted February 2, 2011 That found and removed 60+ MB of two Apple installers that have been lurking since 2008. CORRECTION - IT ONLY RELOCATED THEM. I found that upon deletion Windows automatically MOVED these *.MSI into the current system Restore Point, so free space was not improved until I created a new R.P. and cleaned the older R.P. Perhaps an advisory comment would be in order when this is cleaned. N.B. - not sure, but I think perhaps using CCleaner in SAFE mode might avoid this effect, but probably not advisable when "cleaning to the bone". Regards Alan Link to post Share on other sites
DalGond 0 Posted February 2, 2011 Share Posted February 2, 2011 These do NOT work on XP. I note that both the links refer to queries raised in mid 2008 and only cited XP paths, i.e. C:\Documents and Settings\All Users\Application Data\ and not %ProgramData% XP by default does NOT understand %ProgramData%, neither does it understand %LocalAppdata% Somehow CCleaner under XP DOES understand %LocalAppdata% but it still does NOT understand %ProgramData% The code suggested failed to work until I launched CCLEANER via a batch file which included the code SET ProgramData=C:\Documents and Settings\All Users\Application Data\ CCLEANER NB The BAT script is in the same folder as CCleaner.exe and WinApp2.ini That found and removed 60+ MB of two Apple installers that have been lurking since 2008. Regards Alan You're right! I forgot to say that tested only in Vista... sorry! For instance, sometimes the Apple Installer will keep files there for ages (in my case, since Safari launched 3.x version) It can help users freeing some bits, at least once. Thanks for corrections! Is it possible to be added to Winapp2.ini file? Chrs, Dalton Link to post Share on other sites
SMalik 0 Posted February 7, 2011 Share Posted February 7, 2011 New Erase Entries! Windows 7/Vista Files/Folders Wipe all the files and subfolders C:\Users\User\AppData\Local\CrashDumps\ Wipe the file C:\Users\User\AppData\Local\GDIPFONTCACHEV1.DAT Wipe the file C:\Users\User\AppData\Local\IconCache.db Wipe all the files and subfolder C:\Users\User\AppData\Local\Microsoft\Feeds Cache\ Wipe all the files and subfolder C:\Users\User\AppData\Local\Microsoft\Internet Explorer\DOMStore\ Wipe all the files C:\Users\User\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\ Wipe all the files C:\Users\User\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\ Wipe all the files and subfolder C:\Users\User\AppData\Roaming\Microsoft\Internet Explorer\UserData\ Windows 7/Vista Registry Delete all the subkeys and values [HKEY_CLASSES_ROOT\Local Settings] [HKEY_CURRENT_USER\Software\Classes\Local Settings] [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\DOMStorage] [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Low Rights] [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore] [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\PageSetup] [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Zoom] [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Action Center] [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\BitBucket] [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning] [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32]] [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Ext] [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached] [HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted] [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\DragDrop] [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy] [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\RunDLl32Policy] [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications] [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\RADAR\HeapLeakDetection\ReflectionApplications] [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Tracing] [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers] [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\AppCompatCache] Delete the value "AppCompatCache". Link to post Share on other sites
back_track 0 Posted February 7, 2011 Share Posted February 7, 2011 [Eclips - Workspace*] LangSecRef=3024 DetectFile=%UserProfile%\workspace\ Default=False FileKey1=%UserProfile%\workspace\|*.*|REMOVESELF Link to post Share on other sites
Moderators Nergal 0 Posted February 7, 2011 Moderators Share Posted February 7, 2011 New Erase Entries! <SNIP> Saad2011, all you provided is a request. This is a place for entries that are correctly made please read http://www.piriform.com/docs/ccleaner/advanced-usage/ccleaner-ini-files/how-to-add-your-own-program-for-ccleaner-to-clean and provide enties if you want else open a new topic with a request. Hey winapp2.ini to stave off replies like this one, can you place a warning that says something along the line of only correctly made entries will be considered. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Vidz99 0 Posted February 11, 2011 Share Posted February 11, 2011 Hi everyone How about adding the following entries: [Windows Update Downloads*] LangSecRef=3025 DetectFile=%WINDIR%\SoftwareDistribution\Download\ Default=False FileKey1=%WINDIR%\SoftwareDistribution\Download\|*.* FileKey2=%WINDIR%\SoftwareDistribution\DataStore\|DataStore.edb [More Windows Logs*] LangSecRef=3025 DetectFile=%WINDIR%\Logs\ Default=False FileKey1=%WINDIR%\Logs\|*.* [Windows Installer Cache*] LangSecRef=3025 DetectFile=%WINDIR%\Installer\$PatchCache$\ Default=False FileKey1=%WINDIR%\Installer\$PatchCache$\|*.* [More Windows Live Mail*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Live Mail Default=False FileKey1=%LOCALAPPDATA%\Microsoft\Windows Live Mail\Backup\|*.* FileKey2=%LOCALAPPDATA%\Microsoft\Windows Live Mail\|edb0*.log I have those in my include list and never experienced any troubles. Link to post Share on other sites
Moderators Nergal 0 Posted February 11, 2011 Moderators Share Posted February 11, 2011 Windows Updates downloads is NOT something that should be cleaned outside of the Hotfix removal ccleaner does for Windows XP. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Vidz99 0 Posted February 11, 2011 Share Posted February 11, 2011 Windows Updates downloads is NOT something that should be cleaned outside of the Hotfix removal ccleaner does for Windows XP. Could you please give me more information why this should not be deleted? Thanks Link to post Share on other sites
Moderators Nergal 0 Posted February 11, 2011 Moderators Share Posted February 11, 2011 Could you please give me more information why this should not be deleted? Thanks I don't know whether other users have experienced the same thing but every time I clean that folder, it seems the Windows autoupdate function kicks in and starts to re-examine my entire system. And as long as that re-examination continues, my system is very slow in its responses. However, I maybe confusing SoftwareDistribution folder removal being bad with some other location where windows stores hotfix uninstallers. Microsoft does not want hotfix installers removed in Vista/Windows7 because it uses those unistallers when it does patches later. (thus it was removed from ccleaner for anything newer than XP back in 2008 http://forum.piriform.com/index.php?showtopic=17728&st=0&p=114295&hl=+vista%20+hotfix%20+unistaller&fromsearch=1entry114295) Also Search Hotfix Vista on the Piriform forum and you'll find the history of this issue. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Alan_B 0 Posted February 12, 2011 Share Posted February 12, 2011 I see no problem with FileKey1=%WINDIR%\SoftwareDistribution\Download\|*.* For several years before I used Winapp2.ini, I have removed this via CCleaner.ini Include9=PATH|C:\WINDOWS\SoftwareDistribution\Download\|*.* The top 3 Google result for "DataStore.edb" show One person who deleted it and now wanted help to get it back, and one person who had a 40 MB instance that he deleted, and it was recreated as 33 MB. Seems to me a bad idea to zap that one. ALSO CONSIDER; If the 7 MB that are not recreated stipulate all the updates which cause damage, and which you have stipulated should not me offered again, you will get them all over again - just hope you recognise and block the rogues on the next update. Alan Link to post Share on other sites
Winapp2.ini 0 Posted February 19, 2011 Author Share Posted February 19, 2011 Updated winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Nergal 0 Posted February 19, 2011 Moderators Share Posted February 19, 2011 Updated ??? Last Update: January 26'th, 2011 ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Miroku4444 0 Posted February 20, 2011 Share Posted February 20, 2011 ??? Check again. Last Update: February 18'th 2011 # Entries in this version: 451 Link to post Share on other sites
JDPower 0 Posted February 20, 2011 Share Posted February 20, 2011 Updated Any chance of telling us what new entries are in it when updated? Link to post Share on other sites
