Winapp2.ini Posted May 8, 2011 Author Share Posted May 8, 2011 Updated! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
back_track Posted May 8, 2011 Share Posted May 8, 2011 And why would you want to remove saved games? After a removal they could stay there and i have too much time xD. PS: [Daemon Tools Image Catalog*] LangSecRef=3024 DetectFile=%AppData%\DAEMON Tools Lite\ DetectFile2=%AppData%\DAEMON Tools Pro\ DetectFile3=%AppData%\DAEMON Tools\ Default=False FileKey1=%AppData%\DAEMON Tools Lite|imagecatalog.xml FileKey2=%AppData%\DAEMON Tools|imagecatalog.xml FileKey3=%AppData%\DAEMON Tools Pro|imagecatalog.xml FileKey4=%AppData%\DAEMON Tools Pro\IconsCache|*.* FileKey5=%AppData%\DAEMON Tools Lite\IconsCache|*.* FileKey6=%AppData%\DAEMON Tools\IconsCache|*.* Update to Pro version ________________________________________ Path variablen for the info header: %WinDir% %LocalAppData% %ProgramFiles% %AppData% %Documents% %CommonAppData% %UserProfile% %SystemDrive% %Music% %LocalLowAppData% %Video% All??? give it %picture% ??? _____________________________________ [unigine Heaven DX11 Benchmark 2.5*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Unigine Heaven DX11 Benchmark 2.5_is1 Default=False FileKey1=%UserProfile%\Unigine Heaven\save|*.*|REMOVESELF FileKey2=%UserProfile%\Unigine Heaven|log.html FileKey3=%UserProfile%\Unigine Heaven|*.cache it'd be better the other delts the config.^^ [3DMark Vantage*] LangSecRef=3024 Detect=HKCU\Software\Futuremark\3DMarkVantage Default=False FileKey1=C:\ProgramData\Futuremark\3DMark Vantage\cache|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
Alan_B Posted May 8, 2011 Share Posted May 8, 2011 Posted Today, 08:19 AM View PostWinapp2.ini, on 07 May 2011 - 09:37 PM, said: And why would you want to remove saved games? After a removal they could stay there and i have too much time xD. ???????????????????????????????? Are you saying that the files remain after you have uninstalled the games, and you would like Winapp2.ini to complete the removal for you ? Perhaps you might remember to NOT check the box whilst you are still hooked on the habit, but other users of CC might think that checking the box would make the game run better. Link to comment Share on other sites More sharing options...
SMalik Posted May 8, 2011 Share Posted May 8, 2011 Modified Entry [PowerISO*] LangSecRef=3024 Detect=HKCU\Software\PowerISO Default=False RegKey1=HKCU\Software\PowerISO|Reopen0 RegKey2=HKCU\Software\PowerISO|Reopen1 RegKey3=HKCU\Software\PowerISO|Reopen2 RegKey4=HKCU\Software\PowerISO|Reopen3 RegKey5=HKCU\Software\PowerISO|ExtractPath0 RegKey6=HKCU\Software\PowerISO|ExtractPath1 RegKey7=HKCU\Software\PowerISO|ExtractPath2 RegKey8=HKCU\Software\PowerISO|ExtractPath3 RegKey9=HKCU\Software\PowerISO|ExtractPath4 RegKey10=HKCU\Software\PowerISO|ExtractPath5 RegKey11=HKCU\Software\PowerISO|ExtractPath6 RegKey12=HKCU\Software\PowerISO|ExtractPath7 Link to comment Share on other sites More sharing options...
aqua Posted May 9, 2011 Share Posted May 9, 2011 ok have a question,, i use sandboxie and ie8,after downloading latest winapi i saw in ccleaner another option in applications section-internet explorer more* i check,,clean everything and open ie8,it idn't connect to the net,and then got a popout from sandboxie SBIE1308 program verclsid.exe cannot start due to restrictions" now when untickin this"internet explorer more...i get connection to the net..but the nag remain i have to close SB. and everytime i open ie8 i get this nag from SB... Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 9, 2011 Author Share Posted May 9, 2011 Perhaps this setting interferes with Sandboxie.. can anyone else confirm? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
aqua Posted May 9, 2011 Share Posted May 9, 2011 update..i thought ccleaner got corrupted..uninstall,reinstall...but this is not the problem avira,uninstall/reinstall...open ie8...no problem it opens fine.. but when cleaning using ccleaner and that option enable and also sandboxie container files...the problem is back [nag] now waiting for if someone else has the same problem. Link to comment Share on other sites More sharing options...
siliconman01 Posted May 9, 2011 Share Posted May 9, 2011 For the next release after Version: v1.0.110508 Please fix this error in [TrojanHunter (Scan Logs)*]. The error is preventing the scan logs from being deleted. [TrojanHunter (Scan Logs)*] LangSecRef=3024 Detect=HKCU\Software\TrojanHunter Default=False FileKey2=%ProgramFiles%\TrojanHunter 5.3\Scan Reports|*.* Corrected: [TrojanHunter (Scan Logs)*] LangSecRef=3024 Detect=HKCU\Software\TrojanHunter Default=False FileKey1=%ProgramFiles%\TrojanHunter 5.3\Scan Reports|*.* Please correct this [Microsoft Windows Game Statistics*] entry [Microsoft Windows Game Statistics*] LangSecRef=3025 DetectOS=6.0 DetectFile=%LocalAppData%\Microsoft Games\ Default=False FileKey1=%LocalAppData%\Microsoft Games\Chess Titans|ChessTitans.xml FileKey3=%LocalAppData%\Microsoft Games\FreeCell|FreeCellSettings.xml FileKey5=%LocalAppData%\Microsoft Games\Hearts|HeartsSettings.xml FileKey6=%LocalAppData%\Microsoft Games\Hearts|HearsSettings.xml FileKey7=%LocalAppData%\Microsoft Games\Mahjong Titans|MahjongTitans.xml FileKey8=%LocalAppData%\Microsoft Games\Mahjong Titans|MahJongTitansStats.xml FileKey10=%LocalAppData%\Microsoft Games\Minesweeper|MinesweeperSettings.xml FileKey12=%LocalAppData%\Microsoft Games\Purble Place|ComfyCakesScoresAndSettings.xml FileKey14=%LocalAppData%\Microsoft Games\Purble Place|ConcentrationScoresAndSettings.xml FileKey16=%LocalAppData%\Microsoft Games\Purble Place|PurblePlaceSettings.xml FileKey18=%LocalAppData%\Microsoft Games\Purble Place|PurbleShopScoresAndSettings.xml FileKey20=%LocalAppData%\Microsoft Games\Solitaire|SolitaireSettings.xml FileKey22=%LocalAppData%\Microsoft Games\Spider Solitaire|SpiderSolitaireSettings.xml Corrected: [Microsoft Windows Game Statistics*] LangSecRef=3025 DetectOS=6.0 DetectFile=%LocalAppData%\Microsoft Games\ Default=False FileKey1=%LocalAppData%\Microsoft Games\Chess Titans|ChessTitans.xml FileKey2=%LocalAppData%\Microsoft Games\FreeCell|FreeCellSettings.xml FileKey3=%LocalAppData%\Microsoft Games\Hearts|HeartsSettings.xml FileKey4=%LocalAppData%\Microsoft Games\Hearts|HearsSettings.xml FileKey5=%LocalAppData%\Microsoft Games\Mahjong Titans|MahjongTitans.xml FileKey6=%LocalAppData%\Microsoft Games\Mahjong Titans|MahJongTitansStats.xml FileKey7=%LocalAppData%\Microsoft Games\Minesweeper|MinesweeperSettings.xml FileKey8=%LocalAppData%\Microsoft Games\Purble Place|ComfyCakesScoresAndSettings.xml FileKey9=%LocalAppData%\Microsoft Games\Purble Place|ConcentrationScoresAndSettings.xml FileKey10=%LocalAppData%\Microsoft Games\Purble Place|PurblePlaceSettings.xml FileKey11=%LocalAppData%\Microsoft Games\Purble Place|PurbleShopScoresAndSettings.xml FileKey12=%LocalAppData%\Microsoft Games\Solitaire|SolitaireSettings.xml FileKey13=%LocalAppData%\Microsoft Games\Spider Solitaire|SpiderSolitaireSettings.xml [ultraISO*] appears to have an error as well. [ultraISO*] LangSecRef=3024 Detect=HKCU\Software\EasyBoot Systems\UltraISO\5.0 RegKey1=HKCU\Software\EasyBoot Systems\UltraISO\5.0|Reopen Default=False RegKey2=HKCU\Software\EasyBoot Systems\UltraISO\5.0|a RegKey3=HKCU\Software\EasyBoot Systems\UltraISO\5.0|b RegKey4=HKCU\Software\EasyBoot Systems\UltraISO\5.0|c RegKey5=HKCU\Software\EasyBoot Systems\UltraISO\5.0|d RegKey6=HKCU\Software\EasyBoot Systems\UltraISO\5.0|e RegKey7=HKCU\Software\EasyBoot Systems\UltraISO\5.0|f RegKey8=HKCU\Software\EasyBoot Systems\UltraISO\5.0|g RegKey9=HKCU\Software\EasyBoot Systems\UltraISO\5.0|h RegKey10=HKCU\Software\EasyBoot Systems\UltraISO\5.0|i Corrected: [ultraISO*] LangSecRef=3024 Detect=HKCU\Software\EasyBoot Systems\UltraISO\5.0 Default=False RegKey1=HKCU\Software\EasyBoot Systems\UltraISO\5.0|Reopen RegKey2=HKCU\Software\EasyBoot Systems\UltraISO\5.0|a RegKey3=HKCU\Software\EasyBoot Systems\UltraISO\5.0|b RegKey4=HKCU\Software\EasyBoot Systems\UltraISO\5.0|c RegKey5=HKCU\Software\EasyBoot Systems\UltraISO\5.0|d RegKey6=HKCU\Software\EasyBoot Systems\UltraISO\5.0|e RegKey7=HKCU\Software\EasyBoot Systems\UltraISO\5.0|f RegKey8=HKCU\Software\EasyBoot Systems\UltraISO\5.0|g RegKey9=HKCU\Software\EasyBoot Systems\UltraISO\5.0|h RegKey10=HKCU\Software\EasyBoot Systems\UltraISO\5.0|i The Warning message in [Windows Live Mail*] needs corrections [Windows Live Mail*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Live Mail Default=False Warning=this will reset the read counts, which will be recaculated when WLMail is started. RegKey1=HKCU\Software\Microsoft\Windows Live Mail|SearchFolderVersion FileKey1=%LocalAppData%\Microsoft\Windows Live Mail\Backup|*.*|REMOVESELF FileKey2=%LocalAppData%\Microsoft\Windows Live Mail|edb0*.log Corrected: [Windows Live Mail*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Live Mail Default=False Warning=This will reset the read counts, which will be recalculated when WLMail is started. RegKey1=HKCU\Software\Microsoft\Windows Live Mail|SearchFolderVersion FileKey1=%LocalAppData%\Microsoft\Windows Live Mail\Backup|*.*|REMOVESELF FileKey2=%LocalAppData%\Microsoft\Windows Live Mail|edb0*.log Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted May 9, 2011 Moderators Share Posted May 9, 2011 update..i thought ccleaner got corrupted..uninstall,reinstall...but this is not the problem avira,uninstall/reinstall...open ie8...no problem it opens fine.. but when cleaning using ccleaner and that option enable and also sandboxie container files...the problem is back [nag] now waiting for if someone else has the same problem. Does this help at all aqua? http://www.sandboxie.com/phpbb/viewtopic.php?t=7819&sid=498a72ebbe3ae17e4234e87121ba2112 Support contact https://support.piriform.com/hc/en-us/requests/new?ticket_form_id=86507 support@ccleaner.com Link to comment Share on other sites More sharing options...
aqua Posted May 9, 2011 Share Posted May 9, 2011 ok i use xp pro sp3...and this is another update.. i run ccleaner with no winapp=no problems... i run ccleaner with winapp Version: v1.0.110428 entries 463 == no problems,all seens ok -the latest version seens to be the problem for me. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted May 9, 2011 Moderators Share Posted May 9, 2011 Have you thought about posting over on the sbie forum to ask which entry they think may be the problem in the winapp2.ini I gather from member Winapp that the entry is this one.. [internet Explorer More*] LangSecRef=3022 DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe Default=False RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached FileKey1=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey4=%LocalAppData%\Microsoft\Internet Explorer|brndlog.* FileKey5=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat FileKey6=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF Are you using the latest stable sbie 3.52 or a beta version? Support contact https://support.piriform.com/hc/en-us/requests/new?ticket_form_id=86507 support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 9, 2011 Author Share Posted May 9, 2011 I have a feeling that the problem is caused by one of these entries: FileKey4=%LocalAppData%\Microsoft\Internet Explorer|brndlog.* FileKey5=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat FileKey6=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
aqua Posted May 9, 2011 Share Posted May 9, 2011 was using the latest stable 3.54 build....and also i updated to the latest beta 3.55.06==same problem.. only when going back to the previous winapp version=all runs fine,no problem. Link to comment Share on other sites More sharing options...
Tom AZ Posted May 9, 2011 Share Posted May 9, 2011 Are there any negative effects of cleaning "WMP Databases" with winapp2.ini? I assume they're recreated as needed. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 9, 2011 Author Share Posted May 9, 2011 Not as far as I've seen, Tom. They seem to be rebuilt as needed, like you said. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Laktionov Ivan Posted May 10, 2011 Share Posted May 10, 2011 4 update EssentialPIM Desktop Logs clean: [EssentialPIM Desktop Logs*] LangSecRef=3021 Detect=HKCM\SOFTWARE\RegisteredApplications\EssentialPIM Default=False FileKey1=%AppData%\EssentialPIM\Logs|*.* [EssentialPIM Pro Desktop Logs*] LangSecRef=3021 Detect=HKCM\SOFTWARE\RegisteredApplications\EssentialPIM Pro Default=False FileKey1=%AppData%\EssentialPIM Pro\Logs|*.* Evernote clean: [Evernote Logs & Updates*] LangSecRef=3021 Detect=HKCU\Software\Evernote Default=False FileKey1=%LocalAppData%\Evernote\Evernote\AutoUpdate|*.exe FileKey2=%LocalAppData%\Evernote\Evernote\Logs|*.* FileKey3=%LocalAppData%\Evernote\Evernote\Updates|*.* Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 10, 2011 Moderators Share Posted May 10, 2011 Are there any negative effects of cleaning "WMP Databases" with winapp2.ini? I assume they're recreated as needed. You'll lose the following: Play count, Last played, Ratings and the such ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
HomiSite Posted May 11, 2011 Share Posted May 11, 2011 For the video player KoolPlaya: [KoolPlaya*]LangSecRef=3023 Detect=HKCU\Software\AKi-Software\ Default=False RegKey1=HKCU\Software\AKi-Software\Kool-Playa\VideoHistory RegKey2=HKCU\Software\AKi-Software\Kool-Playa\Videos RegKey3=HKCU\Software\AKi-Software\Kool-PlayaX64\VideoHistory RegKey4=HKCU\Software\AKi-Software\Kool-PlayaX64\Videos Hope everything is correct (combines x86 and x64 builds), at least it works here. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 12, 2011 Author Share Posted May 12, 2011 I made a list of programs affected by Winapp2.ini It's in the first post winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted May 12, 2011 Share Posted May 12, 2011 Please help me to chose 'Detect' path for the entries listed here. Thank you. BTW I have tried the both entries and they are working fine without 'Detect' path. [Windows Error Reporting More*] LangSecRef=3025 Detect= Default=False RegKey1=HKCU\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation RegKey2=HKLM\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation [Windows Session Manager*] LangSecRef=3025 Detect= Default=False RegKey1=HKLM\System\ControlSet001\Control\Session Manager|PendingFileRenameOperations RegKey2=HKLM\System\ControlSet001\Control\Session Manager\AppCompatCache|AppCompatCache RegKey3=HKLM\System\ControlSet002\Control\Session Manager|PendingFileRenameOperations RegKey4=HKLM\System\ControlSet002\Control\Session Manager\AppCompatCache|AppCompatCache Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 12, 2011 Author Share Posted May 12, 2011 Why not HKCU\Software\Microsoft\Windows\Windows Error Reporting\ and HKLM\System\ControlSet001\Control\Session Manager Respectively? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted May 12, 2011 Share Posted May 12, 2011 NEW ENTRIES [Cached Fonts*] LangSecRef=3025 Default=False FileKey1=%WinDir%\System32|FNTCACHE.DAT [Cached GDI+ Fonts*] LangSecRef=3025 Default=False FileKey1=%LocalAppData%|GDIPFONTCACHEV1.DAT [Cached Icons*] LangSecRef=3025 Default=False FileKey1=%LocalAppData%|IconCache.db Please replace current [icon Cache*] entry with [Cached Icons*] entry. [Windows Error Reporting More*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\Windows Error Reporting Default=False RegKey1=HKCU\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation RegKey2=HKLM\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation [Windows Session Manager*] LangSecRef=3025 Detect=HKLM\System\CurrentControlSet\Control\Session Manager Default=False RegKey1=HKLM\System\ControlSet001\Control\Session Manager|PendingFileRenameOperations RegKey2=HKLM\System\ControlSet001\Control\Session Manager\AppCompatCache|AppCompatCache RegKey3=HKLM\System\ControlSet002\Control\Session Manager|PendingFileRenameOperations RegKey4=HKLM\System\ControlSet002\Control\Session Manager\AppCompatCache|AppCompatCache Link to comment Share on other sites More sharing options...
SMalik Posted May 12, 2011 Share Posted May 12, 2011 Thank you. Why not HKCU\Software\Microsoft\Windows\Windows Error Reporting\ and HKLM\System\ControlSet001\Control\Session Manager Respectively? Link to comment Share on other sites More sharing options...
CSGalloway Posted May 15, 2011 Share Posted May 15, 2011 Please add: [Multi-Edit 2008 11.04*] LangSecref=3021 Detect=HKCU\Software\Multi Edit Software\Multi-Edit\11.0 Default=False FileKey1=%appdata%\Multi Edit Software\Multi-Edit\11\Config.04\Tmp\*.* Link to comment Share on other sites More sharing options...
SMalik Posted May 15, 2011 Share Posted May 15, 2011 MODIFIED ENTRIES [WMP Databases*] LangSecRef=3023 Detect=HKCU\Software\Microsoft\MediaPlayer\Player Default=False FileKey1=%LocalAppData%\Microsoft\Media Player|*.wmdb FileKey2=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Media Player|*.*|REMOVESELF [McAfee Logs*] LangSecRef=3021 DetectFile=%CommonAppData%\McAfee\MCLOGS Default=False FileKey1=%CommonAppData%\McAfee\MCLOGS|*.log|RECURSE FileKey2=%CommonAppData%\McAfee\MCLOGS\CoreTech|*.*|RECURSE I have tested this modified entry on Windows 7 32-bit and 64-bit systems. I have McAfee Internet Security 2011 on both the systems. For some reason so many uninstalled programs empty folders were residing in the location listed here: C:\ProgramData\McAfee\MCLOGS\CoreTech After removing all the subfolders from the location listed above, everything was fine. I restarted the systems and all the needed subfolders were recreated. Please help me to figure out Norton Quarantine files location. Link to comment Share on other sites More sharing options...
