Winapp2.ini additions
Winapp2.ini
  • Moderators
I added a nice little "How-To" to the first post... thoughts? :)
love it, it's funny cause I was thinking about some sort of "how-to win*2.ini" only yesterday.
Only one suggestion adding that a submittor should indicate what OS(or multitude of OS) the entry was tested on (as well as that they did test it).
Link to comment
CORRECTED ENTRY
[Corel PaintShop Photo Pro X3*]
LangSecRef=3023
DetectFile=%ProgramFiles%\Corel\Corel PaintShop Photo Pro\X3\PSPClassic\Corel Paint Shop Pro Photo.exe
Default=False
FileKey1=%LocalAppData%\Corel\Thumbs|*.*|RECURSE
FileKey2=%LocalAppData%\Corel|*.PspCache
Link to comment
NEW ENTRIES
[Windows Compatibility Assistant*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant
Default=False
RegKey1=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted
[Windows Tracing*]
LangSecRef=3025
Detect=HKLM\SOFTWARE\Microsoft\Tracing
Default=False
RegKey1=HKLM\SOFTWARE\Microsoft\Tracing
Link to comment
Fixing an entry I had submitted correctly but didn't end up in the file correctly.
[AOL 9.6*]
Default=False
DetectFile=%CommonAppData%\AOL\C_AOL Desktop 9.6
LangSecRef=3022
FileKey1=%CommonAppData%\AOL\C_AOL Desktop 9.6\spool|*.tmp
FileKey2=%CommonAppData%\AOL\C_AOL Desktop 9.6\bart|*.*|RECURSE
The problem is there was no \ after the ending % on the DetectFile line...
Link to comment
@CSGalloway
I found your previous post painfully obscure.
It was NOT immediately obvious what you were on about.
A little dash of larger size, colour, and boldness would have helped, e.g.
[AOL 9.6*]
Default=False
DetectFile=%CommonAppData%AOL\C_AOL Desktop 9.6
LangSecRef=3022
FileKey1=%CommonAppData%AOL\C_AOL Desktop 9.6\spool|*.tmp
FileKey2=%CommonAppData%AOL\C_AOL Desktop 9.6\bart|*.*|RECURSE
should be
[AOL 9.6*]
Default=False
LangSecRef=3022
Link to comment
@Hazel
I was responding to a criticism implied by the introduction
"Fixing an entry I had submitted correctly but didn't end up in the file correctly."
@ricktendo64
Glad you can hear me speak even if you can see the writing with colour ! !
Link to comment
MODIFIED ENTRIES
LangSecRef=3023
Default=False
FileKey3=%AppData%\Corel\PaintShop Photo Pro\13\Cache|*.*|RECURSE
RegKey1=HKCU\Software\Corel\PhotoDownloader\2\PhotoDownloader\DownloadFolder
RegKey2=HKCU\Software\Corel\PhotoDownloader\2\PhotoDownloader\DefaultDownloadFolder
[MS Clip Organizer*]
LangSecRef=3025
DetectFile=%AppData%\Microsoft\Clip Organizer
Default=False
FileKey1=%AppData%\Microsoft\Clip Organizer|mstore14.mgc
NEW ENTRIES
[FastStone Image Viewer*]
LangSecRef=3023
DetectFile=%ProgramFiles%\FastStone Image Viewer\FSViewer.exe
Default=False
FileKey1=%AppData%\FastStone\FSIV|HisFolderList.db
FileKey2=%AppData%\FastStone\FSIV|FSViewer.db
[MS Picture Manager*]
LangSecRef=3025
DetectFile=%LocalAppData%\Microsoft\OIS
Default=False
FileKey1=%LocalAppData%\Microsoft\OIS\OIScatalog.cag
[RealPlayer Converter*]
LangSecRef=3023
DetectFile=%ProgramFiles%\Real\RealPlayer\realconverter.exe
Default=False
RegKey1=HKCU\Software\RealNetworks\RealJukebox\1.0\Preferences\WatchFolders
RegKey2=HKCU\Software\RealNetworks\RealConverter\12.0\Preferences\BrowsePath
RegKey3=HKCU\Software\RealNetworks\RealConverter\12.0\Preferences\DestinationPath
[RealPlayer Trimmer*]
LangSecRef=3023
DetectFile=%ProgramFiles%\Real\RealPlayer\realtrimmer.exe
Default=False
RegKey1=HKCU\Software\RealNetworks\RealTrimmer\12.0\Preferences\BrowsePath
Please look into this entry. It is not working.
[Windows DVD Maker*]
LangSecRef=3023
DetectFile=HKCU\Software\Microsoft\Microsoft DVD Wizard Settings
Default=False
RegKey1=HKCU\Software\Microsoft\Microsoft DVD Wizard Settings\Browse 128
RegKey2=HKCU\Software\Microsoft\Microsoft DVD Wizard Settings\Browse 2
RegKey3=HKCU\Software\Microsoft\Microsoft DVD Wizard Settings\Browse 5
RegKey4=HKCU\Software\Microsoft\Microsoft DVD Wizard Settings\Browse 7
RegKey5=HKCU\Software\Microsoft\Microsoft DVD Wizard Settings\MRU0
RegKey6=HKCU\Software\Microsoft\Microsoft DVD Wizard Settings\MRU1
RegKey7=HKCU\Software\Microsoft\Microsoft DVD Wizard Settings\MRU2
RegKey8=HKCU\Software\Microsoft\Microsoft DVD Wizard Settings\MRU3
Link to comment
oh yes :)
Thank you.
Thanks Saad!
Try changing
to
Detect=HKCU\Software\Microsoft\Microsoft DVD Wizard Settings
since it is a registry path :)
Link to comment
  • Moderators
How about adding Media Player Homecinema recent history list?
Please read the first post in this thread as to how to submit entries.
Link to comment
[MAL Updater Image Cache*]
LangSecRef=3023
DetectFile=%ProgramFiles%\Mal Updater 2\MalUpdater.exe
Default=False
FileKey1=%AppData%\Mal Updater\AnimePics|*.*
FileKey2=%AppData%\Mal Updater\MangaPics|*.*
FileKey3=%AppData%\Mal Updater\SeasonData|*.*
[MAL Updater Logs*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\Mal Updater\Users|*.log|RECURSE
The logs rule was a bit tricky, because the logs actually are in %AppData%\Mal Updater\Users\USERNAME\ (for example: Users\rctgamer3\AnimeLogNotes.log).
Is using RECURSE the best way to do it? No other files should be deleted other than the .log files.
Link to comment
LangSecRef=3023
Default=False
[MAL Updater Logs*]
LangSecRef=3023
Default=False
Try it with %username% variable
Link to comment
MODIFIED ENTRY
[Auslogics Registry Cleaner*]
LangSecRef=3024
Detect=HKCU\Software\Auslogics\Registry Cleaner
Default=False
FileKey1=%AppData%\Auslogics\Registry Cleaner\User Reports|*.*
FileKey2=%AppData%\Auslogics\Rescue\Auslogics Registry Cleaner|*.*
Link to comment
Register a new account
Sign in
Important Information
