Winapp2.ini additions
Winapp2.ini
  • Moderators
New addition:
[Roadkil's Unstoppable Copier*]
LangSecRef=3024
Detect=HKCU\Software\Roadkil
Default=False
RegKey1=HKCU\Software\Roadkil|Source_Unstp
RegKey2=HKCU\Software\Roadkil|Target_Unstp
Updated addition, someone else also needs to test this first before it's put into the winapp2.ini file! I used the pre-release SAS v5.0 when making this.
[sUPERAntiSpyware (Logs)*]
; Supports v4 and v5
LangSecRef=3024
Detect=HKCU\SOFTWARE\SUPERAntiSpyware.com\SUPERAntiSpyware
Detect2=HKLM\SOFTWARE\SUPERAntiSpyware.com\SUPERAntiSpyware
DetectFile=%ProgramFiles%\SUPERAntiSpyware\SUPERAntiSpyware.exe
Default=False
FileKey1=%CommonAppData%\!SASCORE\AppLogs|*.dmp
FileKey2=%CommonAppData%\!SASCORE\AppLogs|*.SDB
FileKey3=%AppData%\SUPERAntiSpyware.com\SUPERAntiSpyware\AppLogs|*.dmp
FileKey4=%AppData%\SUPERAntiSpyware.com\SUPERAntiSpyware\AppLogs|*.SDB
FileKey5=%AppData%\SUPERAntiSpyware.com\SUPERAntiSpyware\Logs|*.log
Link to comment
  • Moderators
Original:
[*Avidemux 2.5 log]
LangSecRef=3023
DetectFile=%ProgramFiles%\Avidemux 2.5\avidemux2.exe
Default=False
FileKey1=%AppData%\avidemux|admlog.txt
Thank you for that original cleaning routine, I didn't realize that admlog.txt would be so huge! Unfortunately getting rid of the version numbers won't work if doing a standard installation using the recommended settings from the setup file, also it wouldn't make any difference because even the registry settings use the version number so no way to change those at all.
Updated, now includes the registry key location as detection as well :)
...and to answer Winapp2.ini I've tested it on Windows XP and it works:
[Avidemux 2.5 (Log)*]
LangSecRef=3023
Detect=HKLM\Software\Avidemux 2.5
Default=False
Link to comment
Hello,
I moved the cache of firefox to another location.
I can not find how to change the winapp2 to allow cleaning.
Can anyone help me.
Thanks
Go to options and select include. Click on add and use the drive or folder option. Hit browse and find your new location of the cache folder and select it. Where it says options select "include files and subfolders". Then hit ok. If you haven't done so already check mark "custom files and folders" in the advanced section.
Link to comment
Removing all the RecentMovie that was used in the Flashplayer.
I don't know how to only remove RecentMovie1,2,3,4 and so on inside the register.
But it works to clear the whole FlashPlayer registry too.
[Macromedia Flashplayer*]
LangSecRef=3023
Detect=HKCU\Software\Macromedia\FlashPlayer
Default=False
RegKey1=HKCU\Software\Macromedia\FlashPlayer
Tested with Windows 7. Should work in other Windows versions i guess.
Link to comment
Try
LangSecRef=3023
Default=False
RegKey1=HKCU\Software\Macromedia\FlashPlayer|RecentMovie1
RegKey2=HKCU\Software\Macromedia\FlashPlayer|RecentMovie2
RegKey3=HKCU\Software\Macromedia\FlashPlayer|RecentMovie3
RegKey4=HKCU\Software\Macromedia\FlashPlayer|RecentMovie4
Link to comment
[Toshiba BluetoothStack*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Toshiba\BluetoothStack
Default=False
FileKey1=C:\Users\Admin\AppData\Local\Toshiba\BluetoothStack\V1.0\tosOBEX\Temp|*.*
I know that the filekey is to long but i can't shorten it. xD
wow you are fast xD
Link to comment
[Downloaded Installations*]
LangSecRef=3025
DetectFile=C:\Users\Admin\AppData\Local\Downloaded Installations
Default=False
FileKey1=C:\Users\Admin\AppData\Local\Downloaded Installations|*.*|REMOVESELF
[samsung Kies*]
LangSecRef=3023
Detect=HKCU\Software\Samsung\Kies2.0
Default=False
FileKey1=C:\Users\Admin\AppData\Roaming\Samsung\Kies\UpdateLog.txt
Would it be better with |*.txt ?
Link to comment
LangSecRef=3025
DetectFile=%LocalAppData%\Downloaded Installations
Default=False
FileKey1=%LocalAppData%\Downloaded Installations|*.*|REMOVESELF
fixed
[samsung Kies*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\Samsung\Kies|UpdateLog.txt
Will work fine if UpdateLog.txt is the only text file that needs to be deleted.
Link to comment
[PDF-XChange Viewer*]
LangSecRef=3021
Detect=HKCU\Software\Tracker Software\PDFViewer
Default=False
RegKey1=HKCU\Software\Tracker Software\PDFViewer\Documents\LastOpened
RegKey2=HKCU\Software\Tracker Software\PDFViewer\Documents\LatestView\Bars
RegKey3=HKCU\Software\Tracker Software\PDFViewer\Documents\LatestView\Panes
FileKey1=%LocalAppData%\Tracker Software\LiveUpdate\Updates\|*.*
Found old downloaded update in Updates folder, thus the addition of FileKey1 is needed.
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
  • Moderators
New entries, fully tested and works on Windows XP.
[Freemake Video Converter (Logs)*]
LangSecRef=3023
Detect=HKCU\Software\Freemake\FreemakeVideoConverter
Detect2=HKLM\Software\Freemake\FreemakeVideoConverter
DetectFile=%ProgramFiles%\Freemake\Freemake Video Converter\FreemakeVideoConverter.exe
Default=False
FileKey1=%CommonAppData%\Freemake\FreemakeVideoConverter|*.txt
[Freemake Video Downloader (Logs)*]
LangSecRef=3023
Detect=HKCU\Software\Freemake\FreemakeVideoDownloader
Detect2=HKLM\Software\Freemake\FreemakeVideoDownloader
DetectFile=%ProgramFiles%\Freemake\FreemakeVideoDownloader\FreemakeVideoDownloader.exe
Default=False
FileKey1=%CommonAppData%\Freemake\FreemakeVideoDownloader|*.txt
Link to comment
Try
LangSecRef=3023
Default=False
It's more then 4, i had 12 last time. I don't know how many RecentMovie you can have inside that registry.
Thats why i added the whole folder. Doesn't RecentMovie* work?
Link to comment
Add this please
[Microsoft Security Essentials*]
LangSecRef=3024
DetectFile=%ProgramData%\Microsoft\Microsoft Antimalware
Default=False
FileKey1=%ProgramData%\Microsoft\Microsoft Antimalware\LocalCopy|*.*|RECURSE
Link to comment
  • Moderators
Add this please
LangSecRef=3024
Default=False
what exactly is removed in this?
Link to comment
  • Moderators
Add this please
LangSecRef=3024
Default=False
You should probably PM the official Piriform bug fixer MrT with this addition since Microsoft AntiMalware is already included in CCleaner by default and can be updated if he deems it safe.
Also that location to clean in WinXP would need this added as a FileKey2 path (albeit that LocalCopy folder is empty on my system and I haven't a clue what it's for):
%CommonAppData%\Microsoft\Microsoft Antimalware\LocalCopy
Link to comment
In that folder located malware detected by MSE. I think only malware for transferring into Microsoft Malware Protection Center, cuz quarantine is located in %ProgramData%\Microsoft\Microsoft Antimalware\Quarantine. It's safe to delete.
Link to comment
  • Moderators
Here is what Local copy is
http://answers.microsoft.com/en-us/protect/forum/protect_scanning/what-are-the-contents-of-this-folder-of-mse/e3836026-ac4d-464a-a886-fae1544598af
The LocalCopy directory is a working directory that holds a local copy of detected threats. For instance when I downloaded the eicar.com test file, the detailed information for the detection specified:
file:C:\Documents and Settings\Greg\Desktop\eicar.com
filelocalcopy:C:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\LocalCopy\<GUID>-eicar.com
webfile:C:\Documents and Settings\All Users\Application Data\Microsoft\Microsoft Antimalware\LocalCopy\<GUID>-eicar.com|http://www.eicar.org/download/eicar.com
webfile:C:\Documents and Settings\Greg\Desktop\eicar.com|http://www.eicar.org/download/eicar.com
The file specified as the local copy was present in the LocalCopy folder after the detection, but was removed upon cleaning the eicar.com file on the desktop. To test whether the local copy was an active copy of the file, I saved it in another folder, and then scanned it after the desktop file had been cleaned. The local copy was detected as eicar.com. So in this case it looks like some glitch or bug prevented the local copies from being removed along with the originals as they should have been.
I have several other files in this directory that I suspect might be local copies of heuristic detections that were saved for submission to the Dynamic Signature Service, but that?s only speculation on my part. The only detection I?ve had in this folder was by the Kaspersky Online Scanner, when I did some double-checking for things that Security Essentials might have missed. That detection would also tend to confirm that the local copies are active.
Link to comment
re : ; Application Cleaning files
; Version: v1.0.110727
[secunia PSI*]
LangSecRef=3021
DetectFile=%ProgramFiles%\Secunia\PSIsua.exe
Detect=HKCU\Software\Secunia\PSI
Default=False
FileKey1=%ProgramFiles%SecuniaPSI|sualog.txt
FileKey2=%ProgramFiles%SecuniaPSI|psialog.txt
FileKey3=%ProgramFiles%\Secunia\PSI|psialog.txt2
should be:
[secunia PSI*]
LangSecRef=3021
Default=False
FileKey1=%ProgramFiles%\Secunia\PSI|sualog.txt
FileKey2=%ProgramFiles%\Secunia\PSI|psialog.txt
leaving out the "\" in the FileKeys...
Also what happens if the DetectFile= is false and the Detect= is true = will the File and Reg Keys be executed?
Link to comment
I use Windows XP and recently tried to remove Windows Live Essentials. The uninstall EXE could not be found. I usually run CCleaner with [Windows Live Messenger More*] selected. I looked in the registry and saw the pertinent files for the uninstall are in:
%ProgramFiles%\Common Files\Windows Live\.cache|*.*
%LocalLowAppData%\Microsoft\Windows Live\Setup|*.*
folders. Can a warning be added to he entry warning that if selected the user will no longer be able top remove any Windows Live Essential product? Or if not delete the two entries in the Winapp2.ini please?
Also can the revised file be posted soon - at least for4 the Secunia PSI modification I posted a few hours earlier? Thank you.
Link to comment
Add the following line to: [Windows Live Messenger More*]
ExcludeKey1=FILE|%ProgramFiles%\Common Files\Windows Live\.cache|*.msi|RECURSE
to correct the problem I was having and posted about a little while ago.
Link to comment
Register a new account
Sign in
Important Information
