Ronny. Posted June 28, 2011 Share Posted June 28, 2011 That's fairly likely. Unfortunately I don't know if that should be HKCU or HKLM because it was a user submitted entry. Glad to see one of the BleachBit crowd here though Try this: I just removed it, as I don't have that App. I'll post a request on the bleachbit board to make sure the app verifies the root hives while it reads the file so it doesn't have to crash on a failure in it. Kind regards, Ronny Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 28, 2011 Author Share Posted June 28, 2011 Thank you for your time and pointing out that error! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted June 28, 2011 Share Posted June 28, 2011 Thank you. Yes it was a typo. OK, good to know. I just like it to look exactly like the folder in the appdata. I think it was probably a typo? Link to comment Share on other sites More sharing options...
Miroku4444 Posted June 28, 2011 Share Posted June 28, 2011 Thank you. Yes it was a typo. Ok, cool. It was no big deal. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 29, 2011 Author Share Posted June 29, 2011 I'd really suggest removing these because I have to delete this file to get Netflix working C:\ProgramData\Microsoft\PlayReady\mspr.hds I know I can uncheck DRM but I'd leave it up to you to determine whether it's a good thing but I never like cleaner apps that have unintended consequences. I did some testing on another machine and ran into this problem as well, however it was solved by deleting that file as you said so I added FileKey2=%CommonAppData%\Microsoft\PlayReady|*.hds which seems to solve the problem. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted June 30, 2011 Share Posted June 30, 2011 It removes only last played. [WMP Playlists*] LangSecRef=3023 Detect=HKCU\Software\Microsoft\MediaPlayer\Player Default=False FileKey1=%LocalAppData%\Microsoft\Media Player|lastplayed.wpl Link to comment Share on other sites More sharing options...
siliconman01 Posted July 1, 2011 Share Posted July 1, 2011 A file naming change in jv16 PT 2011 registry compactor makes the following change necessary (bak_jv16pt changed to jv16pt_bak) [jv16 PowerTools 2011*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe Default=False FileKey1=%UserProfile%|NTUSER.DAT.jv16pt_bak2 FileKey2=%UserProfile%|NTUSER.DAT.jv16pt_bak FileKey3=%UserProfile%|NTUSER.DAT.jv16pt_bak.LOG1 FileKey4=%UserProfile%|NTUSER.DAT.jv16pt_bak.LOG2 FileKey5=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak2 FileKey6=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak FileKey7=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak.LOG1 FileKey8=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak.LOG2 FileKey9=%windir%\system32\config|Default.jv16pt_bak FileKey10=%windir%\system32\config|Default.jv16pt_bak2 FileKey11=%windir%\system32\config|Default.jv16pt_bak.LOG1 FileKey12=%windir%\system32\config|Default.jv16pt_bak.LOG2 FileKey13=%windir%\system32\config|software.jv16pt_bak.LOG1 FileKey14=%windir%\system32\config|software.jv16pt_bak.LOG2 FileKey15=%windir%\system32\config|software.jv16pt_bak2 FileKey16=%windir%\system32\config|software.jv16pt_bak FileKey17=%windir%\system32\config|system.jv16pt_bak2 FileKey18=%windir%\system32\config|system.jv16pt_bak FileKey19=%windir%\system32\config|system.jv16pt_bak.LOG1 FileKey20=%windir%\system32\config|system.jv16pt_bak.LOG2 FileKey21=%windir%\System32\config|SAM.jv16pt_bak FileKey22=%windir%\System32\config|SAM.jv16pt_bak2 FileKey23=%windir%\System32\config|SAM.jv16pt_bak.LOG1 FileKey24=%windir%\System32\config|SAM.jv16pt_bak.LOG2 FileKey25=%windir%\System32\config|COMPONENTS.jv16pt_bak FileKey26=%windir%\System32\config|COMPONENTS.jv16pt_bak2 FileKey27=%windir%\System32\config|COMPONENTS.jv16pt_bak.LOG1 FileKey28=%windir%\System32\config|COMPONENTS.jv16pt_bak.LOG2 FileKey29=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak FileKey30=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak2 FileKey31=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak.LOG1 FileKey32=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak.LOG2 FileKey33=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak FileKey34=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak2 FileKey35=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak.LOG1 FileKey36=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak.LOG2 Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
CallMeTheArrow Posted July 3, 2011 Share Posted July 3, 2011 Hello, The latest winapp2.ini is not clearing Star Trek Online for me. I have the Steam-installed version of it. Logs: C:\Program Files (x86)\Steam\steamapps\common\star trek online\Star Trek Online\Live\logs\GameClient C:\Program Files (x86)\Steam\steamapps\common\star trek online\Star Trek Online\Playtest\logs\GameClient Cache: C:\Program Files (x86)\Steam\steamapps\common\star trek online\Star Trek Online\Live\cache C:\Program Files (x86)\Steam\steamapps\common\star trek online\Star Trek Online\Playtest\cache Same problem with Champions Online. Logs: C:\Program Files (x86)\Steam\steamapps\common\champions online\Champions Online\Live\logs\GameClient C:\Program Files (x86)\Steam\steamapps\common\champions online\Champions Online\Playtest\logs\GameClient Cache: C:\Program Files (x86)\Steam\steamapps\common\champions online\Champions Online\Live\cache C:\Program Files (x86)\Steam\steamapps\common\champions online\Champions Online\Playtest\cache Thank you. Link to comment Share on other sites More sharing options...
LeppeRMessiaH Posted July 5, 2011 Share Posted July 5, 2011 The LibreOffice 3 filter also deletes program preferences so after running it they all revert to the default ones. I'm guessing it's because of FileKey5=%AppData%\LibreOffice\3\user|*.xcu but I'm not sure. Link to comment Share on other sites More sharing options...
mga Posted July 5, 2011 Share Posted July 5, 2011 There's a bug in v1.0.110627: [LogMeIN Hamatchi Backups*] ... FileKey3=%WindDir%\System32\config\systemprofile\AppData\Local\LogMeIn Hamachi|*.old Should be %WinDir% and the name should be "LogMeIn Hamachi". Thanks for your great work. Link to comment Share on other sites More sharing options...
MVE Posted July 6, 2011 Share Posted July 6, 2011 [WorldWide Telescope*] LangSecRef=3021 DetectFile=%ProgramFiles%\Microsoft Research\Microsoft WorldWide Telescope Default=False FileKey1=%LocalAppData%\Microsoft\WorldWideTelescope\dem|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\WorldWideTelescope\Imagery|*.*|RECURSE FileKey3=%LocalAppData%\Microsoft\WorldWideTelescope\tourcache|*.*|RECURSE Link to comment Share on other sites More sharing options...
siliconman01 Posted July 10, 2011 Share Posted July 10, 2011 Cache cleaning for ViewNX 2 software supplied with Nikon cameras [Nikon ViewNX 2 Pic Viewer (Cache)*] LangSecRef=3023 Detect=HKLM\Software\Nikon\MCA2\ViewNX 2 Default=False FileKey1=%USERPROFILE%\AppData\Local\Nikon\ViewNX 2\Cache|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 10, 2011 Author Share Posted July 10, 2011 Thanks guys winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SystemArray Posted July 11, 2011 Share Posted July 11, 2011 [Recycle Bin Logs] LangSecRef=3025 Default=True DetectFile=C:\RECYCLER\ FileKey1=C:\RECYCLER\|*.*|RECURSE Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 11, 2011 Moderators Share Posted July 11, 2011 [Recycle Bin Logs] LangSecRef=3025 Default=True DetectFile=C:\RECYCLER\ FileKey1=C:\RECYCLER\|*.*|RECURSE UHHHH first c:\recycler only exists in XP (at least it's not on my Win7) second what logs there are no Recycle bin logs third The Recycle bin (and yes that is everything in the hidden system files of C:\Recycler) is already cleaned by ccleaner in it's default state. So, since I'm confused, maybe you could expland on what you think you are cleaning with that. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 12, 2011 Author Share Posted July 12, 2011 I also have that directory in my Win7 but I don't see what it cleans over the default CCleaner. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
MVE Posted July 15, 2011 Share Posted July 15, 2011 Time for update. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 17, 2011 Moderators Share Posted July 17, 2011 why time for update did a new ccleanrr drop & I missed it? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 17, 2011 Author Share Posted July 17, 2011 I usually update it for the new release and once in between. I've just been quite busy recently. I'll update it today. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Omelqi Posted July 17, 2011 Share Posted July 17, 2011 Hello, Here is some more removeable crap : [*Migration Wizard logs] LangSecRef=3025 DetectFile=%WinDir%\System32\migwiz\migwiz.exe Default=False FileKey1=%LocalAppData%\MigWiz|*.*|REMOVESELF [*Avidemux 2.5 log] LangSecRef=3023 DetectFile=%ProgramFiles%\Avidemux 2.5\avidemux2.exe Default=False FileKey1=%AppData%\avidemux|admlog.txt [*Adobe Updater logs] LangSecRef=3022 DetectFile=%ProgramFiles%\Common Files\Adobe\Updater6\Adobe_Updater.exe Default=False FileKey1=%AppData%\Adobe\LogTransport2\Logs|ulog_*.tmp [*Norton Utilities 15 reports] LangSecRef=3024 DetectFile=%ProgramFiles%\Norton Utilities 15\nu.exe Default=False FileKey1=%AppData%\Norton Utilities\log|pgscan_*.html It doesn't really matters, but... Is there a way to get rid of those version numbers in the pathes above ? (disk or registry pathes, same problem) ++ Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 17, 2011 Moderators Share Posted July 17, 2011 have you tested the above entries? On which OS(es)? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 17, 2011 Author Share Posted July 17, 2011 Unfortunately entries have to remain version specific, unless CCleaner eventually supports wildcard folders. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
CSGalloway Posted July 18, 2011 Share Posted July 18, 2011 [secunia PSI*] : csg : correected DetectFile line below and commented it out, added Detect= line ..., correected FileKeys... LangSecRef=3021 : DetectFile=%ProgramFiles%\Secunia\PSI\psi.exe Detect=HKCU\Software\Secunia\PSI Default=False FileKey1=%ProgramFiles%\Secunia\PSI|sualog.txt FileKey2=%ProgramFiles%\Secunia\PSI|psialog.txt FileKey3=%ProgramFiles%\Secunia\PSI|psialog.txt2 Link to comment Share on other sites More sharing options...
Omelqi Posted July 18, 2011 Share Posted July 18, 2011 have you tested the above entries? On which OS(es)? Yes, Win7 x64 HP SP1 with CCleaner x64 3.07. It doesn't mean I advise to blindly delete those logs/reports. Unfortunately entries have to remain version specific, unless CCleaner eventually supports wildcard folders. Wildcards ? Ummh... no, thanks. Here is another one for Seagate GoFlex drives owners : [*Seagate Dashboard logs] LangSecRef=3024 Detect=HKLM\SOFTWARE\Seagate\Seagate Dashboard\CurrentVersion Default=False FileKey1=%AppData%\Seagate\Seagate Dashboard\logs|MemeoLauncher.exe.log FileKey2=%AppData%\Seagate\Seagate Dashboard\logs|MemeoLauncher.exe.log-*.log FileKey3=%AppData%\Seagate\Seagate Dashboard\logs|MemeoUpdater.exe.log FileKey4=%AppData%\Seagate\Seagate Dashboard\logs|MemeoUpdater.exe.log-*.log FileKey5=%AppData%\Seagate\Seagate Dashboard\logs|SeagateDashboard-*.log FileKey6=%windir%\System32\config\systemprofile\AppData\Roaming\Seagate\Seagate Dashboard\logs|SeagateDashboardService FileKey7=%windir%\System32\config\systemprofile\AppData\Roaming\Seagate\Seagate Dashboard\logs|SeagateDashboardService-*.log FileKey8=%windir%\SysWOW64\config\systemprofile\AppData\Roaming\Seagate\Seagate Dashboard\logs|SeagateDashboardService FileKey9=%windir%\SysWOW64\config\systemprofile\AppData\Roaming\Seagate\Seagate Dashboard\logs|SeagateDashboardService-*.log Are those duplicated entries at the bottom the good way to make the entry 32bit- and 64bit-compatible ? The strange thing is that the Detect= line correctly checks HKLM\SOFTWARE\Wow6432Node\Seagate\..., but this doesn't automagically works with FileKeyX= lines. ++ Link to comment Share on other sites More sharing options...
siliconman01 Posted July 18, 2011 Share Posted July 18, 2011 As stated earlier, jv16 PowerTools 2011 needs to be changed to the code below: [jv16 PowerTools 2011*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe Default=False FileKey1=%UserProfile%|NTUSER.DAT.jv16pt_bak2 FileKey2=%UserProfile%|NTUSER.DAT.jv16pt_bak FileKey3=%UserProfile%|NTUSER.DAT.jv16pt_bak.LOG1 FileKey4=%UserProfile%|NTUSER.DAT.jv16pt_bak.LOG2 FileKey5=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak2 FileKey6=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak FileKey7=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak.LOG1 FileKey8=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak.LOG2 FileKey9=%windir%\system32\config|Default.jv16pt_bak FileKey10=%windir%\system32\config|Default.jv16pt_bak2 FileKey11=%windir%\system32\config|Default.jv16pt_bak.LOG1 FileKey12=%windir%\system32\config|Default.jv16pt_bak.LOG2 FileKey13=%windir%\system32\config|software.jv16pt_bak.LOG1 FileKey14=%windir%\system32\config|software.jv16pt_bak.LOG2 FileKey15=%windir%\system32\config|software.jv16pt_bak2 FileKey16=%windir%\system32\config|software.jv16pt_bak FileKey17=%windir%\system32\config|system.jv16pt_bak2 FileKey18=%windir%\system32\config|system.jv16pt_bak FileKey19=%windir%\system32\config|system.jv16pt_bak.LOG1 FileKey20=%windir%\system32\config|system.jv16pt_bak.LOG2 FileKey21=%windir%\System32\config|SAM.jv16pt_bak FileKey22=%windir%\System32\config|SAM.jv16pt_bak2 FileKey23=%windir%\System32\config|SAM.jv16pt_bak.LOG1 FileKey24=%windir%\System32\config|SAM.jv16pt_bak.LOG2 FileKey25=%windir%\System32\config|COMPONENTS.jv16pt_bak FileKey26=%windir%\System32\config|COMPONENTS.jv16pt_bak2 FileKey27=%windir%\System32\config|COMPONENTS.jv16pt_bak.LOG1 FileKey28=%windir%\System32\config|COMPONENTS.jv16pt_bak.LOG2 FileKey29=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak FileKey30=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak2 FileKey31=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak.LOG1 FileKey32=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak.LOG2 FileKey33=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak FileKey34=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak2 FileKey35=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak.LOG1 FileKey36=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak.LOG2 Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
