Winapp2.ini additions
Winapp2.ini
I have never heard of a subkey. do you mean a value ?
I for one would prefer that CCleaner maintain its reputation as being safer than the common herd of registry cleaners and boosters.
It would be harmful if Piriform developers incorporated a rudimentary REG.EXE so that Winapp2.ini users have enhanced unsupervised super-killer capabilities.
I normally run CCleaner from a BAT script launched from a desktop short-cut.
The script first wipes out all the foreign language subdirectories that come with every Xmarks update in Firefox profile.
This script could also easily cause the merge of a previously exported and edited REG file with chosen non-zero default values.
All under user control and user responsibility.
Definition: A key in the Windows Registry can be thought of like a file folder. A key that sits within another key is called a "subkey". Source: http://pcsupport.about.com/od/termss/g/registy_subkey.htm
Microsoft recognize the term 'Subkey'. http://support.microsoft.com/kb/310516
You deserve a promotion from Power Member to some other higher grades.
Link to comment
  • Moderators
Titles like that can be edited by members themselves in their profiles after so many posts, although I don't remember how many it takes.
Link to comment
  • Moderators
http://forum.piriform.com/index.php?showtopic=11018
(sorry for off-topic)
Link to comment
Definition: A key in the Windows Registry can be thought of like a file folder. A key that sits within another key is called a "subkey."
Yes, I am happy with the definition that a key is "like a file folder".
Not so happy about a subkey.
I prefer Child-key because all keys are descendent of a hive, and each key can have a parent and also its own set of children.
I believe I can do what I like to any key regardless of its position in a family tree, subject only to access restrictions.
I asked because I was confused by these two statements :-
"The paths listed above have diff. subkeys each time. I didn't want to delete the CpMRU, PageSetup, PropertyStore and Stats keys but, there is no option to delete subkeys."
and
"I didn't want to delete the Cached key itself I wanted to delete all the values on pane but, there was no option to do that."
I have not tried to get CCleaner to delete registry values and will accept that CCleaner cannot.
So far as I am concerned it is possible to delete any subkey.
Been there, Done that.
My experience is that CCleaner also has that capability where write/delete access is allowed,
hence I wondered if you were referring to the same thing when saying "there is no option to delete subkeys" and "wanted to delete all the values".
N.B.
I quite fancy the title "Registry Death Dealer"
When I needed to update Comodo Firewall with a clean install the initial uninstall left a family of 2000 registry keys behind.
Totally inaccessible and unremoveable, and blocking the intended upgrade.
RegEdit could not touch them.
They never saw me coming - zapped in 5 minutes (including making ERUNT backups just in-case).
I could tell you how I did that - but I fear a moderator would take me out ! !
Link to comment
MODIFIED ENTRIES
[Cached WPF Fonts*]
LangSecRef=3025
DetectFile=%windir%\ServiceProfiles\LocalService\AppData\Local
Default=False
FileKey1=%windir%\ServiceProfiles\LocalService\AppData\Local|*.dat
[CleanMyPC Registry Cleaner (Backups)*]
LangSecRef=3024
DetectFile=%ProgramFiles%\CleanMyPC\Registry Cleaner\rcleaner.exe
Default=False
FileKey1=%AppData%\CleanMyPC Software\CleanMyPC Registry Cleaner\UndoCenter|*.*
FileKey2=%AppData%\CleanMyPC Software\CleanMyPC Registry Cleaner|fixlog.ini
FileKey3=%WinDir%\$regcmp$|*.*|REMOVESELF
[iTunes Logs*]
LangSecRef=3023
DetectFile=%AppData%\Apple Computer\iTunes
Default=False
FileKey1=%AppData%\Apple Computer\Logs|*.log
FileKey2=%WinDir%\system32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log
[skype More*]
LangSecRef=3022
DetectFile=%AppData%\Skype
Default=False
FileKey1=%AppData%\Skype|*.lck
FileKey2=%AppData%\Skype\*\chatsync|*.*|RECURSE
FileKey3=%AppData%\Skype\*|main.db
[snagit 9 More*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\9
Default=False
FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.*
FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.*
FileKey3=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.*
FileKey4=%LocalAppData%\TechSmith\SnagIt\Thumbnails|*.*
[snagit 10 More*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\10
Default=False
NEW ENTRIES
[Acrobat Distiller 10*]
LangSecRef=3021
DetectFile=%AppData%\Adobe\Acrobat\Distiller 10
Default=False
FileKey1=%AppData%\Adobe\Acrobat\Distiller 10|messages.log
[Diagnostics Logs*]
LangSecRef=3025
DetectFile=%WinDir%\debug
Default=False
FileKey1=%WinDir%\debug\WIA|wiatrace.log
FileKey2=%WinDir%\debug|PASSWD.log
[setup Logs*]
LangSecRef=3025
DetectFile=%WinDir%
Default=False
FileKey1=%WinDir%\inf|setupapi.app.log
FileKey2=%WinDir%\inf|setupapi.dev.log
FileKey3=%WinDir%\Panther\UnattendGC|setupact.log
FileKey4=%WinDir%\Panther\UnattendGC|setuperr.log
FileKey5=%WinDir%\Panther|setupact.log
FileKey6=%WinDir%\Panther|setuperr.log
Can we replace [eHome Logs*] and [eHome Playlist Cache*] entries with the entry listed here?
[Windows Media Center*]
LangSecRef=3023
DetectFile=%CommonAppData%\Microsoft\eHome
Default=False
FileKey1=%CommonAppData%\Microsoft\eHome\logs|*.*
FileKey2=%LocalAppData%\Microsoft\eHome|playlistcache.db
Link to comment
I see [adobe flashplayer more*] was removed from Winapp2. Shouldn't these be removed anymore?:
C:\Documents and Settings\Kerry Kastelic\Application Data\Macromedia\Flash Player\#SharedObjects
C:\Documents and Settings\Kerry Kastelic\Application Data\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys
Also right after [Opera More*] in Winapp2.ini, it gets out of order chronologically. Goes from O's back to C listings.
Link to comment
[Cached Fonts*]
LangSecRef=3025
Default=False
FileKey1=%WinDir%\System32|FNTCACHE.DAT
[Cached GDI+ Fonts*]
LangSecRef=3025
Default=False
FileKey1=%LocalAppData%|GDIPFONTCACHEV1.DAT
[Cached WPF Fonts*]
LangSecRef=3025
Default=False
FileKey1=%windir%\ServiceProfiles\LocalService\AppData\Local|FontCache3.0.0.0.dat
ARE out of place, you're right!
[Crash Reports*]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\FireFox\Crash Reports\
Default=False
FileKey1=%AppData%\Mozilla\FireFox\Crash Reports\pending|*.*
FileKey2=%AppData%\Mozilla\FireFox\Crash Reports\submitted|*.*
FileKey3=%AppData%\Mozilla\FireFox\Crash Reports|*.*
[Dump Files*]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\Firefox
Default=False
FileKey1=%AppData%\Mozilla|*.dmp|RECURSE
[Firefox Updates*]
LangSecRef=3026
DetectFile=%LocalAppData%\Mozilla\Firefox
Default=False
FileKey1=%LocalAppData%\Mozilla\Firefox\updates|*.log
[Minefield Updates*]
LangSecRef=3026
DetectFile=%LocalAppData%\Mozilla\Firefox\minefield
Default=False
FileKey1=%LocalAppData%\Mozilla\Firefox\minefield\updates|*.log
[TestPilot Error Logs*]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\FireFox\Profiles
Default=False
FileKey1=%AppData%\Mozilla\FireFox\Profiles|TestPilotErrorLog.*|RECURSE
are not out of place, they're all there with an imaginary "Mozilla" prefixed before each of them. No use actually putting it there since they're under LangSecRef 3026
Link to comment
Oh, ok. I know they're under LangSecRef 3026, but for a better flow for all the entrys before and after, if Mozilla Firefox was added to the names? (i.e. Mozilla Firefox Crash Reports, Mozilla Firefox Dump Files)
Also, shouldn't Octoshape and Opera More* be with the O's?
[Octoshape*]
LangSecRef=3023
DetectFile=%LocalAppData%\Octoshape\Octoshape Streaming Services
Default=False
FileKey1=%LocalAppData%\Octoshape\Octoshape Streaming Services\temp|*.*
[Opera More*]
LangSecRef=3027
Detect=HKLM\SOFTWARE\Opera Software
Default=False
FileKey1=%LocalAppData%\Opera\Opera\icons|*.*|REMOVESELF
FileKey2=%LocalAppData%\Opera\Opera\thumbnails|*.*|REMOVESELF
FileKey3=%LocalAppData%\Opera\Opera\vps|*.*|REMOVESELF
FileKey4=%LocalAppData%\Opera\Opera\temporary_downloads|*.*|REMOVESELF
[Cached Fonts*]
LangSecRef=3025
Default=False
LangSecRef=3025
Default=False
[Cached WPF Fonts*]
LangSecRef=3025
Default=False
[Crash Reports*]
LangSecRef=3026
Default=False
[Dump Files*]
LangSecRef=3026
Default=False
[Firefox Updates*]
LangSecRef=3026
Default=False
LangSecRef=3026
Default=False
Link to comment
re: [Windows Live Messenger More*]
FileKey8=%ProgramFiles%\Common Files\Windows Live\.cache|*.*|RECURSE
FileKey9=%LocalLowAppData%\Microsoft\Windows Live\Setup|*.*|RECURSE
These two lines cause Windows Live Messenger and WLMAil not to be able to be removed. At least for the WinXP version.
Is there a Windows XP user who has WL Mail installed who wouldn't mind uploading the contents of the two folders to a website so I can uninstall mine? There will be no privacy issues here.....
Link to comment
I have WLM installed on WinXP... what do you need? :)
AppData\LocalLow doesn't exist on WinXP. But I see it on my Win7 laptop - The Setup folder is empty and so is the tmp subfolder.
I've got the contents of the .cache folder zipped - a little over 23MB. The msi's don't compact much. Let me know if that is what you want.
Win10 Pro x64 Desktop (Speccy) - Win10 Pro x64 Laptop (Speccy)
Link to comment
So whats the scoop guys?? Delete or not delete?
Link to comment
I found http://www.vistapcguy.net/?p=173 which says that locallowappdatya is valid for vista so it would be nice if %LocalLowAppData% was docuents in the first post of this thread.
I did find a zapmessenger.exe that removed WLMessenger so was hoping to find someone who could send me compressed copies of the follwing folders on their system:
FileKey9=%LocalAppData%\Microsoft\Windows Live\Setup|*.*|RECURSE
call the first one PF.zip and the 2nd one LAD.zip - then tell me the web addresses of =where they are stored. I'll download them and go from there.
Link to comment
I made some entry's for some AnvSoft Products.
[AnvSoft*]
LangSecRef=3023
Detect=HKCU\Software\AnvSoft
Default=False
FileKey1=%AppData%\AnvSoft\Any Audio Converter|*.*
FileKey2=%AppData%\AnvSoft\Any DVD Converter Professional|*.*
FileKey3=%AppData%\AnvSoft\Any Video Converter|*.*
[AnvSoft(Logs)*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\AnvSoft\Any Audio Converter|*.log
FileKey2=%AppData%\AnvSoft\Any DVD Converter Professional|*.log
FileKey3=%AppData%\AnvSoft\Any Video Converter|*.log
[AnvSoft(Database)*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\AnvSoft\Any Audio Converter|*.db
FileKey2=%AppData%\AnvSoft\Any DVD Converter Professional|*.db
FileKey3=%AppData%\AnvSoft\Any Video Converter|*.db
The first one deletes everything, the second one deletes just the logs, and the lasts gets rid of the database. ***Warning*** deleting the database slows the programs(adds a few seconds) load time, as it has to rebuild the database.
Link to comment
Here's the link for the .cache PF.zip: http://www.sendspace.com/file/resisw
I couldn't find the Setup location on WinXP.
Link to comment
Do you have a:
%userprofile%\Local Settings\Application Data\Microsoft\Windows Live\Setup
folder? If so that is what I will also need. and a HUGE thank you for PF.ZIP too
Link to comment
Do you have a:
No Setup subfolder. The only thing there is:
%userprofile%\Local Settings\Application Data\Microsoft\Windows Live\SqmApi
The SqmApi folder is empty.
Link to comment
This code cleans up after a registry defrag via TuneUp Utilities 2011.
[TuneUp Utilities 2011 Reg Defrag Cleanup*]
LangSecRef=3024
Detect=HKCU\Software\TuneUp\Utilities\10.0
Default=False
FileKey1=%WinDir%\System32\config\|SECURITY_tureg_old
FileKey2=%WinDir%\System32\config\|SOFTWARE_tureg_old
FileKey3=%WinDir%\System32\config\|SYSTEM_tureg_old
FileKey4=%WinDir%\System32\config\|DEFAULT_tureg_new.LOG1
FileKey5=%WinDir%\System32\config\|DEFAULT_tureg_new.LOG2
FileKey6=%WinDir%\System32\config\|SAM_tureg_new.LOG1
FileKey7=%WinDir%\System32\config\|SAM_tureg_new.LOG2
FileKey8=%WinDir%\System32\config\|SECURITY_tureg_new.LOG1
FileKey9=%WinDir%\System32\config\|SECURITY_tureg_new.LOG2
FileKey10=%WinDir%\System32\config\|SOFTWARE_tureg_new.LOG1
FileKey11=%WinDir%\System32\config\|SOFTWARE_tureg_new.LOG2
FileKey12=%WinDir%\System32\config\|SYSTEM_tureg_new.LOG1
FileKey13=%WinDir%\System32\config\|SYSTEM_tureg_new.LOG2
FileKey14=%WinDir%\System32\config\|DEFAULT_tureg_old
FileKey15=%WinDir%\System32\config\|SAM_tureg_old
FileKey16=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_old
FileKey17=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_new.LOG1
FileKey18=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_new.LOG2
FileKey19=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_old
FileKey20=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_new.LOG1
FileKey21=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_new.LOG2
FileKey22=%USERPROFILE%\AppData\Local\Microsoft\Windows|USRCLASS.DAT_tureg_old
FileKey23=%USERPROFILE%\|NTUSER.DAT_tureg_new.LOG1
FileKey24=%USERPROFILE%\|NTUSER.DAT_tureg_new.LOG2
FileKey25=%USERPROFILE%\|NTUSER.DAT_tureg_old
FileKey26=C:\Boot\|BCD_tureg_new.LOG1
FileKey27=C:\Boot\|BCD_tureg_new.LOG2
FileKey28=C:\Boot\|BCD_tureg_old
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
NEW ENTRIES
[Adobe Acrobat Distiller Cache*]
LangSecRef=3021
Default=False
FileKey1=%AppData%\Adobe\Acrobat\Distiller 10\Cache|*.*|RECURSE
[Paltalk Messenger*]
LangSecRef=3022
DetectFile=%ProgramFiles%\Paltalk Messenger\paltalk.exe
Default=False
FileKey1=%AppData%\Paltalk|*.*|RECURSE
[unity Web Player Cache*]
LangSecRef=3023
DetectFile=%LocalLowAppData%\Unity
Default=False
FileKey1=%LocalLowAppData%\Unity\Web Player\Cache|*.*|RECURSE
FileKey2=%LocalLowAppData%\Unity\WebPlayer\Cache|*.*|RECURSE
MODIFIED ENTRY
Please replace the entry listed here with [Acrobat Distiller 10*] if possible. I have corrected the name.
[Adobe Acrobat Distiller 10*]
LangSecRef=3021
Default=False
Link to comment
Winapp2.ini Version: v1.0.110809
this kills my contact list!? is/was this intended?
don't like; glad I had a recent backup ...
otherwise: great work, thanks!
By deleting/wiping main.db does not effect contact list. It wipes the things listed here ONLY:
Chat History
Call History
by deleting 'config.xml' from the location listed here will delete the contact list:
%AppData%\Skype\*
Where * is Skype user account.
In your case where your Skype contacts were gone. If you remove the whole Skype account folder from the location listed here: %AppData%\Skype\
And login back to Skype, you will get your contact list back.
Link to comment
MODIFIED ENTRY
LangSecRef=3021
Default=False
RegKey1=HKCU\Software\Adobe\Acrobat Distiller\10.0|InPath
NEW ENTRY
[stored Application Descriptions*]
LangSecRef=3025
Detect=HKCU\Software\Classes\Local Settings
Default=False
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache
Link to comment
NEW ENTRIES
This is for Internet Explorer 9.
[inPrivate Filtering Saved Addresses*]
LangSecRef=3022
DetectFile=%AppData%\Microsoft\Windows\PrivacIE
Default=False
FileKey1=%AppData%\Microsoft\Windows\PrivacIE|*.*|RECURSE
Many webpages use content such as advertisements, maps, or web analysis tools from websites other than the one you are visiting. InPrivate Filtering helps prevent website content providers from collecting information about sites you visit. In this index.dat file you can see web address of such content stored in your system.
Go to the location listed here and open index.dat file with notepad to look at youself that how much sensitive data this .dat file holds.
AppData\Roaming\Microsoft\Windows\PrivacIE\Low
[Malicious Software Removal Tool*]
LangSecRef=3025
Default=False
FileKey1=%WinDir%\debug|mrt.log
MODIFIED ENTRY
[internet Explorer More*]
LangSecRef=3022
DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe
Default=False
RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache
RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache
RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU
RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup
RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore
RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats
RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached
FileKey1=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE
FileKey4=%AppData%\Microsoft\Windows\IECompatCache|*.*|RECURSE
FileKey5=%AppData%\Microsoft\Windows\IETldCache|*.*|RECURSE
FileKey6=%LocalAppData%\Microsoft\Internet Explorer|brndlog.*
FileKey7=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat
FileKey8=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF
In this entry I have added 2 more sensitive areas.
Link to comment
Register a new account
Sign in
Important Information
