CSGalloway Posted August 21, 2011 Share Posted August 21, 2011 A general comment. Since winapp2.ini is getting huge now and many people just use the file and not extracting the entries they need, it would be very beneficial if DETECTFILE entries were replaced with DETECT ones, as reading from the Registry is always quicker than from the hard drive. Link to comment Share on other sites More sharing options...
SMalik Posted August 22, 2011 Share Posted August 22, 2011 MODIFIED ENTRIES [iTunes Logs*] LangSecRef=3023 DetectFile=%ProgramFiles%\iTunes\iTunes.exe Default=False FileKey1=%AppData%\Apple Computer\Logs|*.log FileKey2=%WinDir%\system32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log [iTunes Temp Files*] LangSecRef=3023 DetectFile=%ProgramFiles%\iTunes\iTunes.exe Default=False FileKey1=%Music%\iTunes|*.tmp|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 22, 2011 Author Share Posted August 22, 2011 I have slowly over time switched to Detect= for some entries, but I don't have all of the programs. I will make greater strides towards this soon. There were ideas floating around for a batch script that would search your drive and place all of the entries that would return true into the file for you, so you'd only have the entries relevant to your drive, but it never happened. If anyone wants to submit Detect= Paths to replace DetectFiles, I'll gladly replace it. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted August 22, 2011 Share Posted August 22, 2011 Can I suggest RegKey6 is removed from: [*Internet Explorer More] LangSecRef=3022 DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe Default=False RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached FileKey1=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey4=%LocalAppData%\Microsoft\Internet Explorer|brndlog.* FileKey5=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat FileKey6=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF It causes Windows Update site to prompt for permission for its active x every time you run it if this key is cleaned. Link to comment Share on other sites More sharing options...
back_track Posted August 23, 2011 Share Posted August 23, 2011 Update for Kies [samsung Kies*] LangSecRef=3023 Detect=HKCU\Software\Samsung\Kies2.0 Default=False FileKey1=%AppData%\Samsung\Kies|UpdateLog.txt FileKey2=%AppData%\Samsung\Kies|UpdateList.txt FileKey3=%AppData%\Samsung\Kies|*.mlca FileKey4=%AppData%\Samsung\Kies|*.mlme FileKey5=%AppData%\Samsung\Kies|*.mlpb FileKey6=%AppData%\Samsung\Kies|*.mlpgb FileKey7=%AppData%\Samsung\Kies\UpdateTemp|*.*|RECURSE FileKey8=%ProgramData%\Samsung\Kies|ConnectionManager.log Link to comment Share on other sites More sharing options...
Guest Keatah Posted August 24, 2011 Share Posted August 24, 2011 Just everyone be aware that the entries in post 677 will kill your itunes library and custom playlists. A real shocker unless you have a backup or are wanting to do that. All is well here, i didn't blow up anything here. Link to comment Share on other sites More sharing options...
kevinoid Posted August 24, 2011 Share Posted August 24, 2011 Hi all, Below is a winapp2.ini entry that I wrote for the Lenovo (formerly IBM) ThinkVantage System Update program. This is a software/driver update program installed on many late IBM and Lenovo desktop and laptop systems. The winapp2.ini entry cleans out the session directory, which holds all downloaded installers and temporary files and can easily grow to multiple GB in size (see many complaints about this across the web). I have tested the entry on ThinkVantage System Update version 4.01 running on Windows 7 and partially tested on ThinkVantage System Update version 3.15 on Windows XP (in a VM, which prevented full testing). [ThinkVantage System Update*] LangSecRef=3024 DetectFile=%ProgramFiles%\Lenovo\System Update\tvsu.exe Default=False FileKey1=%ProgramFiles%\Lenovo\System Update\session|*.*|RECURSE ; Must exclude system dir or program will not launch ExcludeKey1=FILE|%ProgramFiles%\Lenovo\System Update\session\system|*.* ; Need to exclude tvsutemp dir and updates.ser file to preserve hidden updates ExcludeKey2=FILE|%ProgramFiles%\Lenovo\System Update\session\tvsutemp|*.* ExcludeKey3=FILE|%ProgramFiles%\Lenovo\System Update\session\updates.ser ; To preserve in-program installation history, uncomment ExcludeKey4 (@ ~4KB/update) ;ExcludeKey4=FILE|%ProgramFiles%\Lenovo\System Update\session\|*.xml Warning=This option will clear the ThinkVantage System Update in-program installation history. However, this will not result prompting/installing updates again. I hope you find it useful. Edit: Further investigation showed that the in-program installation history is cleared unless the XML file for each update is retained. These updates have no well-defined naming scheme and are approximately 3KB in size (often with about 1KB of unrelated XML files each). Since I've not found any value to the installation history, I don't think it is worth the disk space, but since others may disagree I have added a warning and the option to exclude the necessary file. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 24, 2011 Author Share Posted August 24, 2011 I just noticed that yesterday was this thread's first birthday winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nikki605 Posted August 24, 2011 Share Posted August 24, 2011 Hi all, Below is a winapp2.ini entry that I wrote for the Lenovo (formerly IBM) ThinkVantage System Update program. This is a software/driver update program installed on many late IBM and Lenovo desktop and laptop systems. The winapp2.ini entry cleans out the session directory, which holds all downloaded installers and temporary files and can easily grow to multiple GB in size (see many complaints about this across the web). I have tested the entry on ThinkVantage System Update version 4.01 running on Windows 7 and partially tested on ThinkVantage System Update version 3.15 on Windows XP (in a VM, which prevented full testing). [ThinkVantage System Update*] LangSecRef=3024 DetectFile=%ProgramFiles%\Lenovo\System Update\tvsu.exe Default=False FileKey1=%ProgramFiles%\Lenovo\System Update\session|*.*|RECURSE ; Must exclude system dir or program will not launch ExcludeKey1=FILE|%ProgramFiles%\Lenovo\System Update\session\system|*.* ; Need to exclude tvsutemp dir and updates.ser file to preserve hidden updates ExcludeKey2=FILE|%ProgramFiles%\Lenovo\System Update\session\tvsutemp|*.* ExcludeKey3=FILE|%ProgramFiles%\Lenovo\System Update\session\updates.ser I hope you find it useful. Owning a T410 myself, I find this intriguing. Are you really sure it is safe to clean the session folder? Mine is 5GB with over 8,300 files & 1,200 folders. Is the installation history retained? Would you still have the ability to uninstall an update, if needed? Is there any other "downside?" Win10 Pro x64 Desktop (Speccy) - Win10 Pro x64 Laptop (Speccy) Link to comment Share on other sites More sharing options...
kevinoid Posted August 24, 2011 Share Posted August 24, 2011 Owning a T410 myself, I find this intriguing. Are you really sure it is safe to clean the session folder? Mine is 5GB with over 8,300 files & 1,200 folders. Is the installation history retained? Would you still have the ability to uninstall an update, if needed? Is there any other "downside?" I've been clearing out the session folder for years on my computers and haven't seen any problems. The updates are still uninstallable via Add/Remove Programs (TVSU really just downloads the exe/msi and runs it with a set of pre-programmed command-line switches). The one downside that I am aware of is that reinstalling an update requires re-downloading the update, since the installer is removed. Also, now that you mentioned it, I just found that the in-program installation history is also cleared. This doesn't cause updates to be re-installed (since each update has a detection signature which looks for registry keys and/or files installed by the update), but the list of installed updates in TVSU is now empty. I haven't found a way to avoid this yet... I'll add a warning if I can't find one soon. I haven't tested what would happen with deferred updates (since I have never used them before), but I will test that shortly. Edit: To amend the downsides: The in-program banner advertisements are re-downloaded (as they are when the ads change) and the updates list is re-downloaded (as it is when new updates are added by Lenovo). They don't strike me as significant, but I thought I should mention them for completeness. Edit2: Deferred updates are unaffected by cleaning (they are stored in tvsutemp which is already excluded). Link to comment Share on other sites More sharing options...
nikki605 Posted August 24, 2011 Share Posted August 24, 2011 Thanks for the follow-up & additional testing, kevinoid. I guess I could always backup the session folder before using the cleaner... just until I'm sure everything is still working properly. Win10 Pro x64 Desktop (Speccy) - Win10 Pro x64 Laptop (Speccy) Link to comment Share on other sites More sharing options...
2nd base Posted August 25, 2011 Share Posted August 25, 2011 I should probably know the answer to this but right this second it's bed time and have a bit of a brain freeze. c:\users\[username]\appdata\local\ virtualstore is hard to maintain, it seems. I have a bunch of junk that's not even on this particular computer anymore sitting in that folder, including what looks like a bunch of different Winapp2.ini (partial downloads?). I guess it's best to just pick through them and figure out what's what and whats not? Thanks. Link to comment Share on other sites More sharing options...
back_track Posted August 25, 2011 Share Posted August 25, 2011 I should probably know the answer to this but right this second it's bed time and have a bit of a brain freeze. c:\users\[username]\appdata\local\ virtualstore is hard to maintain, it seems. I have a bunch of junk that's not even on this particular computer anymore sitting in that folder, including what looks like a bunch of different Winapp2.ini (partial downloads?). I guess it's best to just pick through them and figure out what's what and whats not? Thanks. Ok I start: Delt: C:\Users\Admin\AppData\Local\VirtualStore\Program Files\Java\jre6\launch4j-tmp I would suggest to have a serperat fiel/area for the virtualStore with under option for diffrent programms because every programm put there other things. Link to comment Share on other sites More sharing options...
ricktendo64 Posted August 25, 2011 Share Posted August 25, 2011 New version of cc is out hopefully we will get a update to the ini with the skype db fix that erroneously deletes contacts list BTW what happened to my post about the use of "%programfiles%\common files" instead of "%commonprogramfiles%", it seems to have been deleted [Windows Live Messenger More*] ... FileKey8=%ProgramFiles%\Common Files\Windows Live\.cache|*.*|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 25, 2011 Author Share Posted August 25, 2011 The forums had to be rolled back and many posts were lost. Also, weird, but I have heard a lot about the virtual store folder, but I never have anything in it myself. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
randomcore Posted August 25, 2011 Share Posted August 25, 2011 Hi This erases the ShellBags and MRU list - a list of visited folders and individual settings for each of these folders. A goodie for paranoid people who won't leave traces. [Windows XP ShellBags*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags Default=False RegKey1=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey2=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags [Windows XP MUICache*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\ShellNoRoam\MUICache Default=False RegKey1=HKCU\Software\Microsoft\Windows\ShellNoRoam\MUICache [Windows 7 ShellBags*] LangSecRef=3025 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\ Default=False RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags [Windows 7 MUICache*] LangSecRef=3025 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache\ Default=False RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache EDIT: removed and separated the 7 MUICache from ShellBags. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted August 25, 2011 Moderators Share Posted August 25, 2011 I just noticed that yesterday was this thread's first birthday And may you and it have many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 25, 2011 Author Share Posted August 25, 2011 I think this thread is old enough to start picking up some of the chores around the house, you know? With age comes responsibility. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted August 26, 2011 Share Posted August 26, 2011 Hi This erases the ShellBags and MRU list - a list of visited folders and individual settings for each of these folders. A goodie for paranoid people who won't leave traces. [Windows XP ShellBags*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags Default=False RegKey1=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey2=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags [Windows XP MUICache*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\ShellNoRoam\MUICache Default=False RegKey1=HKCU\Software\Microsoft\Windows\ShellNoRoam\MUICache [Windows 7 ShellBags*] LangSecRef=3025 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\ Default=False RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags [Windows 7 MUICache*] LangSecRef=3025 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache\ Default=False RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache EDIT: removed and separated the 7 MUICache from ShellBags. Windows XP MUI cache is already in winapp2. Are the BagMRUs the same as the 'Window size/location cache' that CCleaner already cleans? Link to comment Share on other sites More sharing options...
CSGalloway Posted August 26, 2011 Share Posted August 26, 2011 New Entries [AM-DeadLink*] Default=False Detect=HKCU\Software\aignes\deadlink LangSecRef=3022 FileKey1=%AppData%\aignes\AM-DeadLink|deadlink.log [KC Software SUMo*] Default=False Detect=HKCU\Software\KC Softwares\SUMo LangSecRef=3022 FileKey1=%AppData%\KC Softwares\SUMo|db.bak [Yahoo Messenger Chat Icons*] LangSecRef=3022 DetectFile=%ProgramFiles%\Yahoo!\Messenger\ Warning=This will delete all chat user-defined display pictures. Default=False FileKey1=%ProgramFiles%\Yahoo!\Messenger\Profiles\*\My Icons|*.* FileKey2=%AppData%\Local\VirtualStore\Program Files\Yahoo!\Messenger\Profiles\*\My Icons|*.* Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 26, 2011 Author Share Posted August 26, 2011 AM-Deadlink is currently included in winapp2.ini [AM-DeadLink*] Default=False Detect=HKCU\Software\aignes\deadlink LangSecRef=3022 FileKey1=%AppData%\aignes\AM-DeadLink|deadlink.log winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted August 27, 2011 Share Posted August 27, 2011 Code to clean up after a TuneUp Utilities 2011 registry compact/defrag. [TuneUp Utilities 2011 Reg Defrag Cleanup**] LangSecRef=3024 Detect=HKCU\Software\TuneUp\Utilities\10.0 Default=False FileKey1=%WinDir%\System32\config\|SECURITY_tureg_old FileKey2=%WinDir%\System32\config\|SOFTWARE_tureg_old FileKey3=%WinDir%\System32\config\|SYSTEM_tureg_old FileKey4=%WinDir%\System32\config\|DEFAULT_tureg_new.LOG1 FileKey5=%WinDir%\System32\config\|DEFAULT_tureg_new.LOG2 FileKey6=%WinDir%\System32\config\|SAM_tureg_new.LOG1 FileKey7=%WinDir%\System32\config\|SAM_tureg_new.LOG2 FileKey8=%WinDir%\System32\config\|SECURITY_tureg_new.LOG1 FileKey9=%WinDir%\System32\config\|SECURITY_tureg_new.LOG2 FileKey10=%WinDir%\System32\config\|SOFTWARE_tureg_new.LOG1 FileKey11=%WinDir%\System32\config\|SOFTWARE_tureg_new.LOG2 FileKey12=%WinDir%\System32\config\|SYSTEM_tureg_new.LOG1 FileKey13=%WinDir%\System32\config\|SYSTEM_tureg_new.LOG2 FileKey14=%WinDir%\System32\config\|DEFAULT_tureg_old FileKey15=%WinDir%\System32\config\|SAM_tureg_old FileKey16=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_old FileKey17=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_new.LOG1 FileKey18=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_new.LOG2 FileKey19=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_old FileKey20=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_new.LOG1 FileKey21=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_new.LOG2 FileKey22=%USERPROFILE%\AppData\Local\Microsoft\Windows|USRCLASS.DAT_tureg_old FileKey23=%USERPROFILE%\|NTUSER.DAT_tureg_new.LOG1 FileKey24=%USERPROFILE%\|NTUSER.DAT_tureg_new.LOG2 FileKey25=%USERPROFILE%\|NTUSER.DAT_tureg_old FileKey26=C:\Boot\|BCD_tureg_new.LOG1 FileKey27=C:\Boot\|BCD_tureg_new.LOG2 FileKey28=C:\Boot\|BCD_tureg_old Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
back_track Posted August 27, 2011 Share Posted August 27, 2011 Info over VirtualStore: http://answers.microsoft.com/en-us/windows/forum/windows_7-security/how-to-disable-virtualstore-in-windows-7/55dce284-0dcd-46af-892e-d2b9cf5bcff6 Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 27, 2011 Author Share Posted August 27, 2011 Ah, I have my UAC shut off, so that's probably why I never see files in Virtual Store winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
2nd base Posted August 28, 2011 Share Posted August 28, 2011 Info over VirtualStore: http://answers.microsoft.com/en-us/windows/forum/windows_7-security/how-to-disable-virtualstore-in-windows-7/55dce284-0dcd-46af-892e-d2b9cf5bcff6 Yeah, I did the same thing already. Thanks for that though. Serves as some confirmation that I was right in my own assessment. Link to comment Share on other sites More sharing options...
