Moderators Nergal Posted July 29, 2011 Moderators Share Posted July 29, 2011 For easy access here is the entry for Foxit Version 5 [*Foxit Reader 5.0] LangSecRef=3021 Detect=HKCU\Software\Foxit Software\Foxit Reader 5.0 Default=True RegKey1=HKCU\Software\Foxit Software\Foxit Reader 5.0\Recent File List RegKey2=HKCU\Software\Foxit Software\Foxit Reader 5.0\RecentFiles RegKey3=HKCU\Software\Foxit Software\Foxit Reader 5.0\Preferences\History\LastOpen RegKey4=HKCU\Software\Foxit Software\Foxit Reader 5.0\Preferences\Others|csInitialOpenDir As I stated in the thread about this, it seems the last key does remove the last directory opened from the registry but Foxit still managed to remember the location (still at least the plain text loction is removed) (Tested XP sp3 but as it is reg entries should work across all OS versions) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
ricktendo64 Posted July 29, 2011 Share Posted July 29, 2011 I hope they add registry wildcard next Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 29, 2011 Moderators Share Posted July 29, 2011 In 1.0.110727 I noticed [Adobe Updater Logs*] LangSecRef=3021 Detect=HKCU\Software\Adobe Default=False FileKey1=%LocalAppData%\Adobe\AAMUpdater|*.Log|RECURSE FileKey2=%LocalAppData%\Adobe\Updater6|*.log|RECURSE FileKey1=%AppData%\Adobe\LogTransport2\Logs|ulog_*.tmp two FileKey1 [FastStone Image Viewer More*] LangSecRef=3023 DetectFile=%ProgramFiles%\FastStone Image Viewer\FSViewer.exe Default=False FileKey2=%AppData%\FastStone\FSIV|FSViewer.db no FileKey1 ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 30, 2011 Author Share Posted July 30, 2011 Ah, small errors, I'll fix those up winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted July 30, 2011 Share Posted July 30, 2011 I need help to create an entry for Winapp2.ini. I am listing a reg path here where "CaptureCount" is a DWORD value. I like to reset the value data to 00000000. Is there a way to do that? I don't want to delete the value. HKEY_CURRENT_USER\Software\TechSmith\SnagIt\10 "CaptureCount"=dword:00000011 Link to comment Share on other sites More sharing options...
SMalik Posted July 30, 2011 Share Posted July 30, 2011 MODIFIED ENTRIES [Corel PaintShop Photo Pro X3*] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel PaintShop Photo Pro\X3\PSPClassic\Corel Paint Shop Pro Photo.exe Default=False RegKey1=HKCU\Software\Corel\PhotoDownloader\2\PhotoDownloader\DownloadFolder RegKey2=HKCU\Software\Corel\PhotoDownloader\2\PhotoDownloader\DefaultDownloadFolder FileKey1=%LocalAppData%\Corel\Thumbs|*.*|RECURSE FileKey2=%LocalAppData%\Corel|*.PspCache FileKey3=%AppData%\Corel\PaintShop Photo Pro\13\Cache|*.*|RECURSE [jv16 PowerTools 2011*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe Default=False FileKey1=%ProgramFiles%\jv16 PowerTools 2011\Backups|*.*|RECURSE FileKey2=%ProgramFiles%\jv16 PowerTools 2011\Settings|UserActionLog.txt FileKey3=%UserProfile%|NTUSER.DAT.jv16pt_bak2 FileKey4=%UserProfile%|NTUSER.DAT.jv16pt_bak FileKey5=%UserProfile%|NTUSER.DAT.jv16pt_bak.LOG1 FileKey6=%UserProfile%|NTUSER.DAT.jv16pt_bak.LOG2 FileKey7=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak2 FileKey8=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak FileKey9=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak.LOG1 FileKey10=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt_bak.LOG2 FileKey11=%windir%\system32\config|Default.jv16pt_bak FileKey12=%windir%\system32\config|Default.jv16pt_bak2 FileKey13=%windir%\system32\config|Default.jv16pt_bak.LOG1 FileKey14=%windir%\system32\config|Default.jv16pt_bak.LOG2 FileKey15=%windir%\system32\config|software.jv16pt_bak.LOG1 FileKey16=%windir%\system32\config|software.jv16pt_bak.LOG2 FileKey17=%windir%\system32\config|software.jv16pt_bak2 FileKey18=%windir%\system32\config|software.jv16pt_bak FileKey19=%windir%\system32\config|system.jv16pt_bak2 FileKey20=%windir%\system32\config|system.jv16pt_bak FileKey21=%windir%\system32\config|system.jv16pt_bak.LOG1 FileKey22=%windir%\system32\config|system.jv16pt_bak.LOG2 FileKey23=%windir%\System32\config|SAM.jv16pt_bak FileKey24=%windir%\System32\config|SAM.jv16pt_bak2 FileKey25=%windir%\System32\config|SAM.jv16pt_bak.LOG1 FileKey26=%windir%\System32\config|SAM.jv16pt_bak.LOG2 FileKey27=%windir%\System32\config|COMPONENTS.jv16pt_bak FileKey28=%windir%\System32\config|COMPONENTS.jv16pt_bak2 FileKey29=%windir%\System32\config|COMPONENTS.jv16pt_bak.LOG1 FileKey30=%windir%\System32\config|COMPONENTS.jv16pt_bak.LOG2 FileKey31=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak FileKey32=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak2 FileKey33=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak.LOG1 FileKey34=%windir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt_bak.LOG2 FileKey35=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak FileKey36=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak2 FileKey37=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak.LOG1 FileKey38=%windir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt_bak.LOG2 Added lines FileKey1=%ProgramFiles%\jv16 PowerTools 2011\Backups|*.*|RECURSE FileKey2=%ProgramFiles%\jv16 PowerTools 2011\Settings|UserActionLog.txt Link to comment Share on other sites More sharing options...
siliconman01 Posted July 31, 2011 Share Posted July 31, 2011 Added linesFileKey1=%ProgramFiles%\jv16 PowerTools 2011\Backups|*.*|RECURSE FileKey2=%ProgramFiles%\jv16 PowerTools 2011\Settings|UserActionLog.txt I disagree with adding the above code to the current jv16 PowerTools 2011 registry compactor backup files removal code. FileKey1=%ProgramFiles%\jv16 PowerTools 2011\Backups|*.*|RECURSE removes the individual registry cleaning backup entries that jv16 stores when performing a registry cleaning. This is like removing quarantined items automatically along with logs on security programs which can be dangerous in the event of a false positive. I recommend a separate code block that users can leave unchecked. [jv16 PowerTools 2011 Backup Files*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe Default=False FileKey1=%ProgramFiles%\jv16 PowerTools 2011\Backups\|*.*|RECURSE| FileKey2=%ProgramFiles%\jv16 PowerTools 2011\Settings|UserActionLog.txt Excludekey1=FILE|%ProgramFiles%\jv16 PowerTools 2011\Backups\|License.xbin_backup Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
2nd base Posted July 31, 2011 Share Posted July 31, 2011 Folks should leave MSE well enough alone and let it do what it does. Otherwise you're defeating the purpose as well as fudging up processes required for practical future development of the software at the very least. Link to comment Share on other sites More sharing options...
Alan_B Posted July 31, 2011 Share Posted July 31, 2011 Folks should leave MSE well enough alone and let it do what it does. Otherwise you're defeating the purpose as well as fudging up processes required for practical future development of the software at the very least. You could be right, but which post does this refer to ? N.B. I cannot see "MSE" on page 31, and life is too short to search the 30 previous pages ! Link to comment Share on other sites More sharing options...
Sailback Posted July 31, 2011 Share Posted July 31, 2011 I need help to create an entry for Winapp2.ini. I am listing a reg path here where "CaptureCount" is a DWORD value. I like to reset the value data to 00000000. Is there a way to do that? I don't want to delete the value. HKEY_CURRENT_USER\Software\TechSmith\SnagIt\10 "CaptureCount"=dword:00000011 Thank you. You can do that with VBScript and run it from Ccleaner like this: ' add a scriptkeyX entry to the SnagIt cleaner code '[snagIt 10...] 'Detect=HKCU\Software\TechSmith\SnagIt\10 'ScriptKey1=SNAGIT.VBS ' ' save the folowing code as SNAGIT.VBS ' ccleaner has already checked that SnagIt 10 is installed SET sh=CreateObject("WScript.Shell") sh.RegWrite "HKCU\Software\TechSmith\SnagIt\10\CaptureCount", 0, "REG_DWORD" SET sh=Nothing Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 31, 2011 Author Share Posted July 31, 2011 Very informative, Sailback winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted July 31, 2011 Share Posted July 31, 2011 I think this is better. BTW jv16 PowerTools does not create a backup file for License.xbin into Backup folder. I disagree with adding the above code to the current jv16 PowerTools 2011 registry compactor backup files removal code. FileKey1=%ProgramFiles%\jv16 PowerTools 2011\Backups|*.*|RECURSE removes the individual registry cleaning backup entries that jv16 stores when performing a registry cleaning. This is like removing quarantined items automatically along with logs on security programs which can be dangerous in the event of a false positive. I recommend a separate code block that users can leave unchecked. [jv16 PowerTools 2011 Backup Files*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe Default=False FileKey1=%ProgramFiles%\jv16 PowerTools 2011\Backups\|*.*|RECURSE| FileKey2=%ProgramFiles%\jv16 PowerTools 2011\Settings|UserActionLog.txt Excludekey1=FILE|%ProgramFiles%\jv16 PowerTools 2011\Backups\|License.xbin_backup Link to comment Share on other sites More sharing options...
SMalik Posted July 31, 2011 Share Posted July 31, 2011 Thank you. I think there should be an easy option to reset value data. For example: |RESET VB Script is not an easy option. You can do that with VBScript and run it from Ccleaner like this: ' add a scriptkeyX entry to the SnagIt cleaner code '[snagIt 10...] 'Detect=HKCU\Software\TechSmith\SnagIt\10 'ScriptKey1=SNAGIT.VBS ' ' save the folowing code as SNAGIT.VBS ' ccleaner has already checked that SnagIt 10 is installed SET sh=CreateObject("WScript.Shell") sh.RegWrite "HKCU\Software\TechSmith\SnagIt\10\CaptureCount", 0, "REG_DWORD" SET sh=Nothing Link to comment Share on other sites More sharing options...
SMalik Posted July 31, 2011 Share Posted July 31, 2011 MODIFIED ENTRIES [snagit 9 More*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\9 Default=False FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.* FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.* [snagit 10 More*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\10 Default=False FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.* FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.* Link to comment Share on other sites More sharing options...
back_track Posted July 31, 2011 Share Posted July 31, 2011 Update: for TeeWorlds you can delt the old entries and use this: [Teeworlds Others*] LangSecRef=3021 DetectFile=%AppData%\Teeworlds Default=False FileKey2=%AppData%\Teeworlds\ghosts|*.*|REMOVESELF FileKey3=%AppData%\Teeworlds\tmp|*.*|REMOVESELF FileKey4=%AppData%\Teeworlds\dumps|*.*|REMOVESELF FileKey5=%AppData%\Teeworlds\ghosts|*.*|REMOVESELF [Teeworlds Maps*] LangSecRef=3021 DetectFile=%AppData%\Teeworlds Default=False FileKey1=%AppData%\Teeworlds\downloadedmaps|*.*|REMOVESELF FileKey2=%AppData%\Teeworlds\maps|*.*|REMOVESELF FileKey3=%AppData%\Teeworlds\downloadedfiles|*.*|REMOVESELF [Teeworlds Screenshots,Demos*] LangSecRef=3021 DetectFile=%AppData%\Teeworlds Default=False FileKey1=%AppData%\Teewords\Screenshots|*.*|REMOVESELF FileKey2=%AppData%\Teeworlds\demos|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
Alan_B Posted August 1, 2011 Share Posted August 1, 2011 Thank you. I think there should be an easy option to reset value data. For example: |RESET VB Script is not an easy option. Even better how about |ASSERT"nnnn" where nnnn is any chosen value that could be zero Perhaps it should also stipulate what sort of value, e.g. DWORD; QWORD; Binary value; String Value; etc. I suggest it should be kept as a difficult option. It does not seem right that WinApp2.ini should be used as a click-n-go fixit for the registry by those who cannot safely use RegEdit. The hard part you have already done, you have identified what registry value you wish to change in which registry key. I have not learnt how to program in VB script, but have no difficulty in creating and executing a BAT script that incorporates a VB script and launches cscript. I suggest that an EASY OPTION would be MERGE{THIS.reg} Where THIS.reg is the path and name of an exported registry key, which has then been manually edited so that desired defaults will be imposed when it is merged. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 1, 2011 Moderators Share Posted August 1, 2011 It does not seem right that WinApp2.ini should be used as a click-n-go fixit for the registry by those who cannot safely use RegEdit.. +1 if the program doesn't recreate the entry at 0 then the isn't much ccleaner can (should) do. Ccleaner does not write/create/modify registry entries. Ccleaner is not the correct route to achieve this. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 1, 2011 Author Share Posted August 1, 2011 One treads upon dangerous ground, modifying the registry beyond RegKeys winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Miroku4444 Posted August 1, 2011 Share Posted August 1, 2011 BTW jv16 PowerTools does not create a backup file for License.xbin into Backup folder. It does on my system. A copy of the License.xbin is in the backup folder. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 2, 2011 Author Share Posted August 2, 2011 So the Backup folder is not safe to complete empty? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Miroku4444 Posted August 2, 2011 Share Posted August 2, 2011 So the Backup folder is not safe to complete empty? Why would you want to delete files in your back-up folders, that contain back-ups of your registry cleaning? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 2, 2011 Author Share Posted August 2, 2011 Well I wouldn't add it to the cleaning of JV16 by default, it'd definitely be a second option. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted August 2, 2011 Share Posted August 2, 2011 Even better how about |ASSERT"nnnn" where nnnn is any chosen value that could be zero Perhaps it should also stipulate what sort of value, e.g. DWORD; QWORD; Binary value; String Value; etc. I suggest it should be kept as a difficult option. It does not seem right that WinApp2.ini should be used as a click-n-go fixit for the registry by those who cannot safely use RegEdit. The hard part you have already done, you have identified what registry value you wish to change in which registry key. I have not learnt how to program in VB script, but have no difficulty in creating and executing a BAT script that incorporates a VB script and launches cscript. I suggest that an EASY OPTION would be MERGE{THIS.reg} Where THIS.reg is the path and name of an exported registry key, which has then been manually edited so that desired defaults will be imposed when it is merged. I have provided the entry listed here for Winapp2.ini. [internet Explorer More*] LangSecRef=3022 DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe Default=False RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached FileKey1=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE ================================= RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache The paths listed above should be reseted only but, there was no option to do that. RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats The paths listed above have diff. subkeys each time. I didn't want to delete the CpMRU, PageSetup, PropertyStore and Stats keys but, there is no option to delete subkeys. Another example: RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached I didn't want to delete the Cached key itself I wanted to delete all the values on pane but, there was no option to do that. I think there should be a cure for these when creating an entry for Winapp2.ini. I use Ace Utilities (http://www.acelogix.com/), East-Tec Eraser (http://www.east-tec.com/) and R-Wipe & Clean (http://www.r-wipe.com/). I have provided them these suggestions and they have included in their programs. All the options work the way they should. I feel CCleaner is a good program of its kind and this should be more professional. Link to comment Share on other sites More sharing options...
Alan_B Posted August 2, 2011 Share Posted August 2, 2011 The paths listed above have diff. subkeys each time. I didn't want to delete the CpMRU, PageSetup, PropertyStore and Stats keys but, there is no option to delete subkeys. Another example: RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached I didn't want to delete the Cached key itself I wanted to delete all the values on pane but, there was no option to do that. I have never heard of a subkey. do you mean a value ? I think there should be a cure for these when creating an entry for Winapp2.ini. I use Ace Utilities (http://www.acelogix.com/), East-Tec Eraser (http://www.east-tec.com/) and R-Wipe & Clean (http://www.r-wipe.com/). I have provided them these suggestions and they have included in their programs. All the options work the way they should. I feel CCleaner is a good program of its kind and this should be more professional. I for one would prefer that CCleaner maintain its reputation as being safer than the common herd of registry cleaners and boosters. It would be harmful if Piriform developers incorporated a rudimentary REG.EXE so that Winapp2.ini users have enhanced unsupervised super-killer capabilities. I normally run CCleaner from a BAT script launched from a desktop short-cut. The script first wipes out all the foreign language subdirectories that come with every Xmarks update in Firefox profile. This script could also easily cause the merge of a previously exported and edited REG file with chosen non-zero default values. All under user control and user responsibility. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 2, 2011 Author Share Posted August 2, 2011 I think modifying registry values is overstepping the ideas of CCleaner a bit winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
