Winapp2.ini additions
Winapp2.ini
Windows XP MUI cache is already in winapp2. Are the BagMRUs the same as the 'Window size/location cache' that CCleaner already cleans?
hi
sorry for delay, was pretty busy with life ;)
i can not exactly say what's ccleaner already doing there, because everything is internal. so i can not compare. have to do some regshots first. may take one or two days. bbl
Link to comment
[internet Explorer More*]
LangSecRef=3022
DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe
Default=False
RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache
RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache
RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU
RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup
RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore
RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats
RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached
FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.*
FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat
FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF
FileKey4=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE
FileKey5=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.*
FileKey6=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey7=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE
FileKey8=%AppData%\Microsoft\Windows\PrivacIE|*.*|RECURSE
Please remove: FileKey8=%AppData%\Microsoft\Windows\PrivacIE|*.*|RECURSE
Now it is included in CCleaner v3.10
Link to comment
I guess FileKey paths are not correct.
[Windows System Profile*]
LangSecRef=3025
DetectFile=%WinDir%\system32\config\systemprofile
Default=False
FileKey1=%WinDir%\system32\config\systemprofile\Local Settings\Temp|*.*|RECURSE
FileKey2=%WinDir%\system32\config\systemprofile\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey3=%WinDir%\system32\config\systemprofile\Cookies|*.*|RECURSE
Link to comment
MODIFIED ENTRIES
[Reg Organizer (Backups)*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Reg Organizer\RegOrganizer.exe
Default=False
FileKey1=%LocalAppData%\ChemTable Software\Reg Organizer\BackupHives|*.*|RECURSE
FileKey2=%LocalAppData%\ChemTable Software\Reg Organizer\backups|*.*|RECURSE
FileKey3=%LocalAppData%\ChemTable Software\Reg Organizer\RegHives|*.*|RECURSE
FileKey4=%Appdata%\ChemTable Software\Reg Organizer|ListsHistory.bin
[Tipard Total Media Converter*]
LangSecRef=3023
Detect=HKCU\Software\Tipard Studio\Tipard Total Media Converter
Default=False
RegKey1=HKCU\Software\Tipard Studio\Tipard Total Media Converter\Edit|LastVideoFilePath
FileKey1=%LocalAppData%\Tipard Studio\Tipard Total Media Converter|*.*
NEW ENTRY
[Glary Utilities (Backups)*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Glary Utilities\Integrator.exe
Default=False
FileKey1=%AppData%\GlarySoft\Glary Utilities\Backups|*.*
FileKey2=%UserProfile%|*.gbck
FileKey3=%LocalAppData%\Microsoft\Windows|*.gbck
FileKey4=%WinDir%\System32\config|*.gbck
Link to comment
Wiping the prefetch has been show (AFAIK) to have a negative impact on performance.
That may be true under most circumstances, unless there are items loaded into prefetch that a user deletes (malware, etc?) during a currently logged in session, causing Windows to attempt to load some of those now non-existent entries on re-boot.
Guess it can go both ways.
I personally, would love a prefetch cleaner, as it would be more of a privacy concern to me. I would love to know that were I to choose to do so, I could zap all those entries.
Even more troubling, I have no way of knowing, if Windows tries to create a prefetch entry, how well it does when a program is updated.
Example:
I install Defraggler. Windows creates a prefetch entry for it. Later, I download a newer version that drastically changes the way the program operates, rendering the old pre-fetch entry invalid.
How likely is Windows to update with a "newer" prefetch entry to update to the newer version changes? Not very!
Link to comment
Example:
No, it'll just create a new prefetch file for the new version and delete the old one when its not been used for a set time. No problem caused. And windows won't try to load anything if the related program (or malware) has been removed and its pf file will also be removed after a certain time.
There is NO purpose for cleaning pf data at all, windows does a perfectly adequate job of that itself.
Link to comment
Suggested to add for cleaning XBMC cachefiles (it does it by itself most of the time, not all however)
Also suggested to add cleaning of the packages directory, (storage location for all addons with all updates can get real big)
[XBMC cache*]
LangSecRef=3023
DetectFile=%AppData%\xbmc\cache
FileKey1=%AppData%\Xbmc\cache|*.*|RECURSE
[XBMC packages*]
LangSecRef=3023
Default=False
DetectFile=%AppData%\xbmc\addons\packages
FileKey1=%AppData%\Xbmc\addons\packages|*.*|RECURSE
Link to comment
Hi everyone, I'm pretty new here, but I would like to propose a couple of new entries.
I use SlimDrivers to keep my computer's drivers updated. It doesn't always work, but it does leave behind a fair amount of crap on my C drive.
I propose we split the current SlimDrivers entry into three separate entries as follows:
[slimDrivers Backups*]
LangSecRef=3024
DetectFile=%LocalAppData%\Slimware Utilities Inc\SlimDrivers\
Default=false
FileKey1=%LocalAppData%\SlimWare Utilities Inc\SlimDrivers\Backups|*.*|RECURSE
[slimDrivers Downloads*]
LangSecRef=3024
Default=false
FileKey1=%LocalAppData%\SlimWare Utilities Inc\SlimDrivers\Downloads|*.*|RECURSE
FileKey2=%LocalAppData%\SlimWare Utilities Inc\SlimDrivers\Images|*.*|RECURSE
[slimDrivers Logs*]
LangSecRef=3024
Default=false
FileKey1=%LocalAppData%\SlimWare Utilities Inc\SlimDrivers\Logs|*.*|RECURSE
Also, I use the Vizzed Retro Game Room and its required browser plugin to play video games online.
I propose the following new entry to clean after this plugin:
[Vizzed Retro Game Room*]
LangSecRef=3023
DetectFile=%LocalLowAppData%\VizzedRgr\
Default=False
FileKey1=%LocalLowAppData%\VizzedRgr\Downloads|*.*|RECURSE
FileKey2=%LocalLowAppData%\VizzedRgr\Roms|*.*|RECURSE
"When people are free to do as they please, they usually imitate each other."
--Eric Hoffer
Link to comment
I know this is kind of a n00b question, but....
...can anyone tell me what the environment variables are of the browser profiles for the major non-MSIE web browsers (Firefox, Opera, and Chrome/Chromium)?
--Eric Hoffer
Link to comment
For the older, but still functional clipboard extension "ClipX" (tested with the 2008 x64 beta version and on Win7x64); it removes temp files which appear over time due to a bug, I guess (e.g. over 1 GB when I deleted the files today):
[ClipX*]
LangSecRef=3024
DetectFile=%LocalAppData%\ClipX\
Default=False
FileKey1=%LocalAppData%\ClipX\Storage|*.*
Link to comment
  • 2 weeks later...
new update of ccleaner doesn't have the updated entries for AVG2012
so here they are.
[AVG AntiVirus 2012*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\AVG\AVG2012
Default=False
FileKey1=%CommonAppData%\AVG2012\Log|*.log
FileKey2=%CommonAppData%\AVG2012\scanlogs|*.log
FileKey3=%CommonAppData%\AVG2012\Log|*.xml
FileKey4=%CommonAppData%\AVG2012\update\backup|*.*
FileKey5=%CommonAppData%\AVG2012\Emc\Log|*.log
FileKey6=%CommonAppData%\AVG2012\IDS\config|*List.zip.bak
FileKey7=%CommonAppData%\AVG2012\IDS\profile|globalLoadable.bak
FileKey8=%CommonAppData%\AVG2012\Temp|*.tmp
Link to comment
  • Moderators
A new entry:
[Freemake Audio Converter (Logs)*]
LangSecRef=3023
Detect=HKCU\Software\Freemake\FreemakeAudioConverter
Detect2=HKLM\Software\Freemake\FreemakeAudioConverter
DetectFile=%ProgramFiles%\Freemake\Freemake Audio Converter\FreemakeAudioConverter.exe
Default=False
FileKey1=%CommonAppData%\Freemake\FreemakeAudioConverter|*.txt
Link to comment
I added the COMPONENTS element to this code for cleanup of TuneUp Utilities defrag.
[TuneUp Utilities 2011 Reg Defrag Cleanup**]
LangSecRef=3024
Detect=HKCU\Software\TuneUp\Utilities\10.0
Default=False
FileKey1=%WinDir%\System32\config\|SECURITY_tureg_old
FileKey2=%WinDir%\System32\config\|SOFTWARE_tureg_old
FileKey3=%WinDir%\System32\config\|SYSTEM_tureg_old
FileKey4=%WinDir%\System32\config\|DEFAULT_tureg_new.LOG1
FileKey5=%WinDir%\System32\config\|DEFAULT_tureg_new.LOG2
FileKey6=%WinDir%\System32\config\|SAM_tureg_new.LOG1
FileKey7=%WinDir%\System32\config\|SAM_tureg_new.LOG2
FileKey8=%WinDir%\System32\config\|SECURITY_tureg_new.LOG1
FileKey9=%WinDir%\System32\config\|SECURITY_tureg_new.LOG2
FileKey10=%WinDir%\System32\config\|SOFTWARE_tureg_new.LOG1
FileKey11=%WinDir%\System32\config\|SOFTWARE_tureg_new.LOG2
FileKey12=%WinDir%\System32\config\|SYSTEM_tureg_new.LOG1
FileKey13=%WinDir%\System32\config\|SYSTEM_tureg_new.LOG2
FileKey14=%WinDir%\System32\config\|DEFAULT_tureg_old
FileKey15=%WinDir%\System32\config\|SAM_tureg_old
FileKey16=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_old
FileKey17=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_new.LOG1
FileKey18=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_new.LOG2
FileKey19=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_old
FileKey20=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_new.LOG1
FileKey21=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_new.LOG2
Filekey22=%WinDir%\System32\config\|COMPONENTS_tureg_old
Filekey23=%WinDir%\System32\config\|COMPONENTS_tureg_new.LOG1
Filekey24=%WinDir%\System32\config\|COMPONENTS_tureg_new.LOG2
FileKey25=%USERPROFILE%\AppData\Local\Microsoft\Windows|USRCLASS.DAT_tureg_old
FileKey26=%USERPROFILE%\|NTUSER.DAT_tureg_new.LOG1
FileKey27=%USERPROFILE%\|NTUSER.DAT_tureg_new.LOG2
FileKey28=%USERPROFILE%\|NTUSER.DAT_tureg_old
FileKey29=C:\Boot\|BCD_tureg_new.LOG1
FileKey30=C:\Boot\|BCD_tureg_new.LOG2
FileKey31=C:\Boot\|BCD_tureg_old
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
MODIFIED ENTRY
LangSecRef=3025
Default=False
FileKey1=%WinDir%\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
FileKey2=%WinDir%\system32\config\systemprofile\AppData\Local\Temp|*.*|RECURSE
FileKey3=%WinDir%\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies|*.*|RECURSE
FileKey4=%WinDir%\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\IETldCache|*.*|RECURSE
Link to comment
  • Moderators
[Windows Explorer More*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StreamMRU
cleaned by ccleaner default via this entry in WinSYS.ini
[Window Size/Location Cache]
ID=1022
LangSecRef=3004
LangRef=3127
WarningRef=3205
RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Streams
____________________________________________________________________________________________________________________________
[secunia PSI*]
LangSecRef=3021
DetectFile=%ProgramFiles%\Secunia\PSIsua.exe
Detect=HKCU\Software\Secunia\PSI
Default=False
FileKey1=%ProgramFiles%SecuniaPSI|sualog.txt
FileKey2=%ProgramFiles%SecuniaPSI|psialog.txt
FileKey3=%ProgramFiles%\Secunia\PSI|psialog.txt2
FileKey1 and 2 are missing 2 \ (Each) should be
FileKey1=%ProgramFiles%\Secunia\PSI|sualog.txt
FileKey2=%ProgramFiles%\Secunia\PSI|psialog.txt
[Windows Defender More*]
LangSecRef=3024
DetectFile=%CommonAppData%\Microsoft\Windows Defender\
Default=False
FileKey1=%CommonAppData%\Microsoft\Windows Defender\Support|*.log [/Code]
is redundant now
Default Windows Defender entry cleans it
[Code][Windows Defender]
ID=2132
LangSecRef=3024
Detect=HKLM\SOFTWARE\Microsoft\Windows Defender
Default=True
FileKey1=%commonappdata%\Microsoft\Windows Defender\Scans\History\Results\Quick|*.*
FileKey2=%commonappdata%\Microsoft\Windows Defender\Scans\History\Results\Resource|*.*
FileKey3=%CommonAppData%\Microsoft\Windows Defender\Support|*.log
Link to comment
Register a new account
Sign in
Important Information
