SMalik Posted August 12, 2011 Share Posted August 12, 2011 Thanks saad You're welcome Winapp2.ini. How about if we merge [inPrivate Filtering Saved Addresses*] into [internet Explorer More*]? [internet Explorer More*] LangSecRef=3022 DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe Default=False RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.* FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF FileKey4=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey5=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey6=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey7=%AppData%\Microsoft\Windows\PrivacIE|*.*|RECURSE I am removing the paths listed below as they are already included in the program's 'index.dat files' entry. I am sorry about that. %AppData%\Microsoft\Windows\IECompatCache|*.*|RECURSE %AppData%\Microsoft\Windows\IETldCache|*.*|RECURSE I think [inPrivate Filtering Saved Addresses*] (%AppData%\Microsoft\Windows\PrivacIE|*.*|RECURSE) should be added into CCleaner. Also they should correct the index.dat files entry as it does not detect all the index.dat files the ones should be removed. For example index.dat files from the locations listed here: %AppData%\Microsoft\Internet Explorer\UserData %AppData%\Microsoft\Windows\PrivacIE\Low Link to comment Share on other sites More sharing options...
SMalik Posted August 12, 2011 Share Posted August 12, 2011 I am listing all the modified and new entries here that I posted after Winapp2.ini Version: v1.0.110809. MODIFIED ENTRIES Please replace this one with [Acrobat Distiller 10*] [Adobe Acrobat Distiller 10*] LangSecRef=3021 DetectFile=%AppData%\Adobe\Acrobat\Distiller 10 Default=False RegKey1=HKCU\Software\Adobe\Acrobat Distiller\10.0|InPath FileKey1=%AppData%\Adobe\Acrobat\Distiller 10|messages.log [internet Explorer More*] LangSecRef=3022 DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe Default=False RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.* FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF FileKey4=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey5=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey6=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey7=%AppData%\Microsoft\Windows\PrivacIE|*.*|RECURSE NEW ENTRIES [Adobe Acrobat Distiller Cache*] LangSecRef=3021 DetectFile=%AppData%\Adobe\Acrobat\Distiller 10 Default=False FileKey1=%AppData%\Adobe\Acrobat\Distiller 10\Cache|*.*|RECURSE [Malicious Software Removal Tool*] LangSecRef=3025 DetectFile=%WinDir%\debug Default=False FileKey1=%WinDir%\debug|mrt.log [Paltalk Messenger*] LangSecRef=3022 DetectFile=%ProgramFiles%\Paltalk Messenger\paltalk.exe Default=False FileKey1=%AppData%\Paltalk|*.*|RECURSE [stored Application Descriptions*] LangSecRef=3025 Detect=HKCU\Software\Classes\Local Settings Default=False RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache [unity Web Player Cache*] LangSecRef=3023 DetectFile=%LocalLowAppData%\Unity Default=False FileKey1=%LocalLowAppData%\Unity\Web Player\Cache|*.*|RECURSE FileKey2=%LocalLowAppData%\Unity\WebPlayer\Cache|*.*|RECURSE Link to comment Share on other sites More sharing options...
aladoro Posted August 12, 2011 Share Posted August 12, 2011 thanks for explaining! >By deleting/wiping main.db does not effect contact list. deleting main.db DOES affect display of contacts + display of online status: contacts are gone, online status is ONLINE, my real name + contact pic are gone until >login back to Skype, you will get your contact list back. you're right, I didn't wait long enough last time. >by deleting 'config.xml' from the location listed here will delete the contact list right, but I didn't delete this file. >If you remove the whole Skype account folder from the location listed here: %AppData%\Skype\ understandable, but I didn't remove it for myself, I don't consider it save to remove main.db + hence will keep unchecked SkypeMore. but I DO appreciate your enhancing of winapp2.ini! cheers, andreas Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 12, 2011 Author Share Posted August 12, 2011 Hm, I noticed the the contacts list does repopulate, so I'm not certain whether or not the main.db file should be excluded so as not to convince people CCleaner broke their skype. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted August 13, 2011 Share Posted August 13, 2011 Hm, I noticed the the contacts list does repopulate, so I'm not certain whether or not the main.db file should be excluded so as not to convince people CCleaner broke their skype. Yes you could remove that line. Let me work on it. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 13, 2011 Author Share Posted August 13, 2011 Yeah, it seems like it may be a good idea to remove the main.db filekey. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted August 13, 2011 Share Posted August 13, 2011 Yeah, it seems like it may be a good idea to remove the main.db filekey. [skype More*] LangSecRef=3022 DetectFile=%AppData%\Skype Default=False FileKey1=%AppData%\Skype\*\chatsync|*.*|RECURSE FileKey2=%AppData%\Skype\*\httpfe|cookies.dat Main CCleaner entry for Skype does not delete Skype Cookies. Thats is why I have added this line in this entry and removed *.lck line as there is no need to delete it. Link to comment Share on other sites More sharing options...
SMalik Posted August 13, 2011 Share Posted August 13, 2011 RE-MODIFIED ENTRY Added: FileKey4=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE [internet Explorer More*] LangSecRef=3022 DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe Default=False RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.* FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF FileKey4=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE FileKey5=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey6=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey7=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey8=%AppData%\Microsoft\Windows\PrivacIE|*.*|RECURSE MODIFIED ENTRIES [Corel PaintShop Photo Pro X3*] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel PaintShop Photo Pro\X3\PSPClassic\Corel Paint Shop Pro Photo.exe Default=False RegKey1=HKCU\Software\Corel\PhotoDownloader\2\PhotoDownloader\DownloadFolder RegKey2=HKCU\Software\Corel\PhotoDownloader\2\PhotoDownloader\DefaultDownloadFolder FileKey1=%LocalAppData%\Corel\Thumbs|*.*|RECURSE FileKey2=%LocalAppData%\Corel|*.db FileKey3=%LocalAppData%\Corel|*.PspCache FileKey4=%AppData%\Corel\PaintShop Photo Pro\13\Cache|*.*|RECURSE [MS Clip Organizer*] LangSecRef=3025 DetectFile=%AppData%\Microsoft\Clip Organizer Default=False RegKey1=HKCU\Software\Microsoft\Office\12.0\Clip Organizer\Search\Last Query RegKey2=HKCU\Software\Microsoft\Office\14.0\Clip Organizer\Search\Last Query FileKey1=%AppData%\Microsoft\Clip Organizer|mstore12.mgc FileKey2=%AppData%\Microsoft\Clip Organizer|mstore14.mgc Link to comment Share on other sites More sharing options...
aladoro Posted August 14, 2011 Share Posted August 14, 2011 [skype More*] thanks for revising this entry! Link to comment Share on other sites More sharing options...
SMalik Posted August 15, 2011 Share Posted August 15, 2011 thanks for revising this entry! You're welcome. Link to comment Share on other sites More sharing options...
SMalik Posted August 15, 2011 Share Posted August 15, 2011 Please remove the [setup Logs*] and [Diagnostics Logs*] from Winapp2.ini. I forgot that CCleaner does not remove locked items. Could you pls rename to [html Help*]. It looks more professional. CCleaner entries Paint Shop Pro X3, Paint.NET and Nero Burning ROM 10 are useless. Pls advise them to remove these entries. Also Real Player SP entry name needs to be corrected. It is RealPlayer. I have left messages in CCleaner Suggestions forum in past but, they haven't fixed these yet. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 15, 2011 Author Share Posted August 15, 2011 CCleaner cleaned those two entries just fine for me. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted August 15, 2011 Share Posted August 15, 2011 CCleaner cleaned those two entries just fine for me. You mean [setup Logs*] and [Diagnostics Logs*]? Link to comment Share on other sites More sharing options...
SMalik Posted August 15, 2011 Share Posted August 15, 2011 Please remove [MS Picture Manager*] as CCleaner's [MS Office Picture Manager*] is same. MODIFIED ENTRY [MS Clip Organizer*] LangSecRef=3025 DetectFile=%AppData%\Microsoft\Clip Organizer Default=False RegKey1=HKCU\Software\Microsoft\Office\12.0\Clip Organizer\Search\Last Query RegKey2=HKCU\Software\Microsoft\Office\14.0\Clip Organizer\Search\Last Query FileKey1=%AppData%\Microsoft\Clip Organizer|mstore12.mgc FileKey2=%AppData%\Microsoft\Clip Organizer|mstore14.mgc Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 15, 2011 Author Share Posted August 15, 2011 You mean [setup Logs*] and [Diagnostics Logs*]? Yes winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
back_track Posted August 16, 2011 Share Posted August 16, 2011 [MS Robocopy Gui*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Microsoft Robocopy GUI Default=False FileKey1=%AppData%\Microsoft Robocopy GUI\Logs|*.* FileKey2=%ProgramFiles%\Microsoft\Microsoft Robocopy GUI\Logs|*.* [GameSave Manager 2*] LangSecRef=3021 DetectFile1=%WinDir%\GameSave Manager_2.0\uninstall.exe DetectFile2=%AppData%\GameSave Manager 2\ Detect1=HKCR\GSM_gsba Detect2=HKCR\GSM_gsdu Detect3=HKCR\GSM_gsms Default=False FileKey1=%AppData%\GameSave Manager 2\TaskLogs|*.* FileKey2=%AppData%\GameSave Manager 2\TaskCache|*.* FileKey3=%AppData%\GameSave Manager 2\GameCache|*.* Link to comment Share on other sites More sharing options...
SMalik Posted August 16, 2011 Share Posted August 16, 2011 MODIFIED ENTRY [CrashDumps*] LangSecRef=3025 DetectFile=%LocalAppData%\CrashDumps Default=False FileKey1=%LocalAppData%\CrashDumps|*.dmp FileKey2=%WinDir%\system32\config\systemprofile\AppData\Local\CrashDumps|*.dmp Link to comment Share on other sites More sharing options...
back_track Posted August 16, 2011 Share Posted August 16, 2011 Ups I have make some mistakes xD I have 2 [Teeworlds Demos*] LangSecRef=3021 DetectFile=%AppData%\Teeworlds Default=False FileKey1=%AppData%\Teeworlds\dumps|*.*|REMOVESELF and [Teeworlds Demos*] LangSecRef=3021 DetectFile=%AppData%\Teeworlds Default=False FileKey1=%AppData%\Teeworlds\demos|*.*|REMOVESELF please delt both and put this: [Teeworlds Dumps*] LangSecRef=3021 DetectFile=%AppData%\Teeworlds Default=False FileKey1=%AppData%\Teeworlds\dumps|*.*|REMOVESELF [Teeworlds Demos*] LangSecRef=3021 DetectFile=%AppData%\Teeworlds Default=False FileKey1=%AppData%\Teeworlds\demos|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
SMalik Posted August 16, 2011 Share Posted August 16, 2011 NEW ENTRY [Reg Organizer*] LangSecRef=3024 DetectFile=%ProgramFiles%\Reg Organizer\RegOrganizer.exe Default=False FileKey1=%LocalAppData%\ChemTable Software\Reg Organizer\BackupHives|*.*|RECURSE FileKey2=%LocalAppData%\ChemTable Software\Reg Organizer\backups|*.*|RECURSE FileKey3=%LocalAppData%\ChemTable Software\Reg Organizer\RegHives|*.*|RECURSE FileKey4=%Appdata%\ChemTable Software\Reg Organizer|ListsHistory.bin Link to comment Share on other sites More sharing options...
SMalik Posted August 19, 2011 Share Posted August 19, 2011 I guess there was some problem with this forum. I feel some of the posts are gone from here. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 19, 2011 Moderators Share Posted August 19, 2011 I guess there was some problem with this forum. I feel some of the posts are gone from here. It's the whole forum actually, see here: http://forum.piriform.com/index.php?showtopic=33514 Link to comment Share on other sites More sharing options...
CSGalloway Posted August 19, 2011 Share Posted August 19, 2011 Does 3.09 support regkeys of the form: [HKEY_CURRENT_USER\Identities\{0A22DB1E-8412-4D38-9011-F2525F13D995}\Software\Microsoft\Outlook Express\5.0\Find History] where the \{whatever}\ can be anything? similar to the wildcard folder ability in this version? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 19, 2011 Author Share Posted August 19, 2011 I do not believe there is wildcard support for the registry. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted August 21, 2011 Share Posted August 21, 2011 [Windows CBS Logs*] entry should be removed from Winapp2.ini as it is already included in CCleaner's Windows Log Files. Link to comment Share on other sites More sharing options...
CSGalloway Posted August 21, 2011 Share Posted August 21, 2011 New entry please [AM-DeadLink*] Default=False Detect=HKCU\Software\aignes\deadlink LangSecRef=3022 FileKey1=%AppData%\aignes\AM-DeadLink|deadlink.log I think I have the correct LangSecRef, it checks browser favorites/bookmarks and downloads Fav-Icons, checks duplicates. Link to comment Share on other sites More sharing options...
