Winapp2.ini additions
Winapp2.ini
  • Moderators
btw have you seen/read this http://thewebatom.ne...are/ccenhancer/ (CCEnchancer) and it's forums http://thewebatom.ne...er-discussions/ ?
The above app is not generally discussed on these forums.
Thanks.
Support contact
https://support.piriform.com/hc/en-us/requests/new
support@ccleaner.com
Link to comment
I have provided this entry and one of the paths is missing in the latest Winapp2.ini. I have highlighted that path.
[internet Explorer More*]
LangSecRef=3022
DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe
Default=False
RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache
RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache
RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU
RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup
RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore
RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats
RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached
FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.*
FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat
FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF
FileKey4=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE
FileKey5=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.*
FileKey6=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey7=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE
Ext Stats or Browser Extensions Using Statistics: Internet Explorer can store information about using its add-ons such as ActiveX Controls, browser extensions, browser helper objects , or toolbars.
Link to comment
NEW ENTRY
[ArcSoft MediaConverter 7*]
LangSecRef=3023
DetectFile=%ProgramFiles%\ArcSoft\MediaConverter 7\MediaConverter.exe
Default=False
FileKey1=%AppData%\ArcSoft\ArcSoft MediaConverter\7.1|saved.proj
FileKey2=%AppData%\ArcSoft\log|*.log
Link to comment
To reflect the release of TrojanHunter V5.5
[TrojanHunter (Scan Logs)*]
LangSecRef=3024
Detect=HKCU\Software\TrojanHunter
Default=False
FileKey1=%ProgramFiles%\TrojanHunter 5.3\Scan Reports|*.*
FileKey2=%ProgramFiles%\TrojanHunter 5.5\Scan Reports|*.*
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD21, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
Changes to TuneUp Utilities Registry Defrag Cleanup (FileKey25, FileKey29/30/31)
[TuneUp Utilities 2011/2012 Reg Defrag Cleanup*]
LangSecRef=3024
Detect=HKCU\Software\TuneUp\Utilities\10.0
Detect2=HKCU\Software\TuneUp\Utilities\12.0
Default=False
FileKey1=%WinDir%\System32\config|SECURITY_tureg_old
FileKey2=%WinDir%\System32\config|SOFTWARE_tureg_old
FileKey3=%WinDir%\System32\config|SYSTEM_tureg_old
FileKey4=%WinDir%\System32\config|DEFAULT_tureg_new.LOG1
FileKey5=%WinDir%\System32\config|DEFAULT_tureg_new.LOG2
FileKey6=%WinDir%\System32\config|SAM_tureg_new.LOG1
FileKey7=%WinDir%\System32\config|SAM_tureg_new.LOG2
FileKey8=%WinDir%\System32\config|SECURITY_tureg_new.LOG1
FileKey9=%WinDir%\System32\config|SECURITY_tureg_new.LOG2
FileKey10=%WinDir%\System32\config|SOFTWARE_tureg_new.LOG1
FileKey11=%WinDir%\System32\config|SOFTWARE_tureg_new.LOG2
FileKey12=%WinDir%\System32\config|SYSTEM_tureg_new.LOG1
FileKey13=%WinDir%\System32\config|SYSTEM_tureg_new.LOG2
FileKey14=%WinDir%\System32\config|DEFAULT_tureg_old
FileKey15=%WinDir%\System32\config|SAM_tureg_old
FileKey16=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_old
FileKey17=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG1
FileKey18=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG2
FileKey19=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_old
FileKey20=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG1
FileKey21=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG2
Filekey22=%WinDir%\System32\config|COMPONENTS_tureg_old
Filekey23=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG1
Filekey24=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG2
FileKey25=%USERPROFILE%\AppData\Local\Microsoft\Windows\|USRCLASS.DAT_tureg_old
FileKey26=%UserProfile%|NTUSER.DAT_tureg_new.LOG1
FileKey27=%UserProfile%|NTUSER.DAT_tureg_new.LOG2
FileKey28=%UserProfile%|NTUSER.DAT_tureg_old
FileKey29=%SystemDrive%\Boot\|BCD_tureg_new.LOG1
FileKey30=%SystemDrive%\Boot\|BCD_tureg_new.LOG2
FileKey31=%SystemDrive%\Boot\|BCD_tureg_old
Link to comment
Thanks!
Edit: oh wow, this topic is 40 pages long :blink:
Is your subconscious telling you the topic would be shorter and life easier if you avoided tidying up after other windows tools such as TuneUp Utilities :unsure:
Link to comment
The "MS Management Console More*" code causes (in Windows 7 x86) the Task Scheduler to issue an error message "Task BackgroundConfigSurveryor: The task image is corrupt or has been tampered with". This error occurs on opening the Task Scheduler following a CCleaner run. I recommend that this code be removed.
[MS Management Console More*]
LangSecRef=3025
DetectFile=%AppData%\Microsoft\MMC
Default=False
FileKey1=%AppData%\Microsoft\MMC|*.*
Link to comment
LangSecRef=3025
Default=False
The error has nothing to do with this entry.
For more info please look at this link:
http://www.sevenforums.com/general-discussion/75441-task-backgroundconfigsurveyor-task-image-corrupt.html
Link to comment
http://www.sevenforu...ge-corrupt.html
I stand corrected....thanks much!
Link to comment
NEW ENTRIES
[Windows SCM Logs*]
LangSecRef=3025
DetectFile1=%WinDir%\System32\LogFiles\Scm
Default=False
FileKey1=%WinDir%\System32\LogFiles\Scm|*.*
[Asus Logs*]
LangSecRef=3024
DetectFile1=%WinDir%log
Default=False
FileKey1=%WinDir%\log|*.log|*.txt
[Crayon Physics Deluxe Temps & Cache*]
LangSecRef=3023
DetectFile1=%ProgramFiles%\Steam\steamapps\common\crayon physics deluxe
Default=False
FileKey1=%ProgramFiles%\Steam\steamapps\common\crayon physics deluxe\data\recordings\temp|*.tmp
FileKey2=%ProgramFiles%\Steam\steamapps\common\crayon physics deluxe\cache|*.*
FileKey3=%AppData%\Crayon Physics Deluxe|log.txt
[League of Legends Logs & Cache*]
LangSecRef=3023
DetectFile1=%HomeDrive%\Riot Games\League of Legends\rads
Default=False
FileKey1=%HomeDrive%\Riot Games\League of Legends\rads|*.log|*.log1|*.log2|*.log3
FileKey2=%HomeDrive%\Riot Games\League of Legends\rads\solutions\lol_game_client_sln\releases\0.0.0.86\deploy|*.log|*.txt
FileKey3=%HomeDrive%\Riot Games\League of Legends\rads\projects\lol_air_client\releases\0.0.0.94\deploy\logs|*.log
FileKey4=%HomeDrive%\Riot Games\League of Legends\rads\projects\lol_launcher\releases\0.0.0.33\deploy|*.log
[borderlands Log*]
LangSecRef=3023
DetectFile1=%Documents%\My Games\Borderlands\WillowGame\Logs
Default=False
FileKey1=%Documents%\My Games\Borderlands\WillowGame\Logs|*.log
[Google Crash Reports*]
LangSecRef=3022
DetectFile1=%LocalAppData%\Google\CrashReports
Default=False
FileKey1=%LocalAppData%\Google\CrashReports|*.*
[Roxio Log Files*]
LangSecRef=3021
DetectFile1=%AppData%\Roxio
Default=False
FileKey1=%AppData%\Roxio Log Files|*.*|RECURSE
FileKey2=%AppData%\Roxio\Dragon\3.x\DeviceDetectionLogs|*.log
FileKey3=%AppData%\Roxio\Dragon\3.x\WriteLogs|*.log
FileKey4=%WinDir%\System32\config\systemprofile\AppData\Roaming\Roxio Log Files|*.*|RECURSE
[Heroes of Newerth Log*]
LangSecRef=3023
DetectFile1=%Documents%\Heroes of Newerth\game
Default=False
FileKey1=%Documents%\Heroes of Newerth\game|console.log
[Cisco HostScan Log*]
LangSecRef=3021
DetectFile1=%LocalAppData%\Cisco\Cisco HostScan\log
Default=False
FileKey1=%LocalAppData%\Cisco\Cisco HostScan\log|*.log
[Rigs of Rods 0.37 Crash Reports*]
LangSecRef=3023
DetectFile1=%LocalAppData%\CrashRpt\UnsentCrashReports\Rigs of Rods_0.37
Default=False
FileKey1=%LocalAppData%\CrashRpt\UnsentCrashReports\Rigs of Rods_0.37|*.*|RECURSE
[star Wars The Force Unleashed 2 Crash Logs*]
LangSecRef=3023
DetectFile1=%LocalAppData%\LucasArts\Star Wars The Force Unleashed 2
Default=False
FileKey1=%LocalAppData%\LucasArts\Star Wars The Force Unleashed 2|*.*
[TeamSpeak 3 Logs*]
LangSecRef=3022
DetectFile1=%LocalAppData%\TeamSpeak 3 Client\config\logs
Default=False
FileKey1=%LocalAppData%\TeamSpeak 3 Client\config\logs|*.*
[Jagex Cache*]
LangSecRef=3023
DetectFile1=%WinDir%\.jagex_cache_32
Default=False
FileKey1=%WinDir%\.jagex_cache_32|*.*|REMOVESELF
FileKey2=%UserProfile%\jagexcache|*.*|REMOVESELF
FileKey3=%UserProfile%\jagexcache1|*.*|REMOVESELF
FileKey4=%UserProfile%|jagex__preferences3.dat
FileKey5=%UserProfile%|jagex_cl_runescape_LIVE.dat
FileKey6=%UserProfile%|jagex_cl_runescape_LIVE1.dat
FileKey7=%UserProfile%|jagex_runescape_preferences.dat
FileKey8=%UserProfile%|jagex_runescape_preferences2.dat
[shattered Horizon Cache*]
LangSecRef=3023
DetectFile1=%LocalAppData%\Futuremark\Shattered Horizon\
Default=False
FileKey1=%LocalAppData%\Futuremark\Shattered Horizon\cache|*.*|REMOVESELF
Edited some entries.
Edited by nodles
Link to comment
@nodles
[Jagex Cache*]
LangSecRef=3023
DetectFile2=%UserProfile%\ (mhhh have you lost somthing ? :P when not, delt it)
Default=False
FileKey2=%UserProfile%\jagexcache1|*.*|REMOVESELF
FileKey3=%UserProfile%|jagex__preferences3.dat
FileKey4=%UserProfile%|jagex_cl_runescape_LIVE.dat
FileKey5=%UserProfile%|jagex_cl_runescape_LIVE1.dat
FileKey6=%UserProfile%|jagex_runescape_preferences.dat
FileKey7=%UserProfile%|jagex_runescape_preferences2.dat
Updated on time! :lol:
Changes now in a link in the first post (verbose)
why you havent inticlude my post?
http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=203495
Link to comment
  1. Please can the following entry's be added to Winapp2.ini.
  2. [AnyDVDHD*]
    LangSecRef=3024
    Detect=HKCU\Software\SlySoft\AnyDVD
    Default=False
    FileKey1=%userprofile%\Documents\AnyDVD_logs|*.*
  3. [Newsleecher*]
    LangSecRef=3021
    DetectFile=%userprofile%\Application Data\Newsleecher\Backups
    Default=False
    FileKey1=%userprofile%\Application Data\Newsleecher\Backups|*.*
Link to comment
@nodles
[Jagex Cache*]
What do you mean? Those files were in the root of the folder (User).
And new entry for the Jagex Cache (in red):
[Jagex Cache*]
LangSecRef=3023
DetectFile3=%UserProfile%\jagexcache
Default=False
FileKey8=%UserProfile%\jagexcache|*.*|REMOVESELF
Link to comment
[Jagex Cache*]
LangSecRef=3023
Default=False
I don't think you need three detect keys for one program's cleaning routine.
Link to comment
  • Moderators
[Auslogics Disk Defrag Portable*]
LangSecRef=3024
Detect=HKCU\Software\Auslogics\Disk Defrag Portable
Default=False
FileKey1=%appdata%\Auslogics\Disk Defrag\Reports|*.*
FileKey2=%appdata%\Auslogics\Disk Defrag\Logs|*.*
Link to comment
Register a new account
Sign in
Important Information
