Winapp2.ini additions
Winapp2.ini
MODIFIED ENTRY
[iTunes Logs*]
LangSecRef=3023
DetectFile=%ProgramFiles%\iTunes\iTunes.exe
Default=False
FileKey1=%AppData%\Apple Computer\Logs|*.log|RECURSE
FileKey2=%WinDir%\system32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log
Link to comment
NEW ENTRY
[Google Update*]
LangSecRef=3024
DetectFile=%LocalAppData%\Google\Update\GoogleUpdate.exe
Default=False
FileKey1=%LocalAppData%\Google\Update\Download|*.*|RECURSE
FileKey1=%LocalAppData%\Google\Update\Offline|*.*|RECURSE
Warning=Not while Google Update is updating things.
Not sure if this can be / needs to be expanded to detect Google Update installed in %PF%. Not clear how to install Google Update nor Chrome SxS--what I use--for all users to begin with. In fact, I wouldn't mind a pointer, if you can give one... ?
Link to comment
  • Moderators
[Audio/Video (Stats)*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%LocalAppData%|DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
To my knowledge this may only clean the offending .INI file on Windows XP systems.
What it is:
It's like a cache of what Windows XP displays for the properties of videos you've highlighted to see the properties of in Explorer, or played such as .AVI videos. It seems each video that Windows XP is capable of displaying the properties of adds about 4KB to the offending .INI file, and over time it can grow to a large size.
Link to comment
MODIFIED ENTRIES
[MS Office Temp Files*]
LangSecRef=3021
DetectFile=%AppData%\Microsoft\Office
Default=False
RegKey1=HKCU\Software\Microsoft\Office\Common|FontBmpCache
FileKey1=%AppData%\Microsoft\Office|*.tmp|RECURSE
Added: RegKey1=HKCU\Software\Microsoft\Office\Common|FontBmpCache
Office .tmp files MRU being stored here.
[snagit 9 More*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\9
Default=False
RegKey1=HKCU\Software\TechSmith\SnagIt\9|StampCustomFolder
FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf
FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.*
FileKey3=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.*
FileKey4=%LocalAppData%\TechSmith\SnagIt\Thumbnails|*.*
[snagit 10 More*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\10
Default=False
RegKey1=HKCU\Software\TechSmith\SnagIt\10|StampCustomFolder
Removed: FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.*
Added; FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf
Deleting all the files from DataStore deletes Snagit Capture Library.
Link to comment
Hello everyone, I've read these forums (especially this thread) alot and for a long time and now I've finally registered and this is my first post. I've used CCleaner since.. don't even remember anymore but for many years. :)
I had problems updating Comodo Firewall on one PC, it got stuck in the same section while installing the update. I got it fixed by removing update temps from Comodo's folders, so I thought I'd add the entry to winapp2.ini also and post it here. This entry has been tested (on Windows 7 64bit).
NEW ENTRY
[Comodo Update Temps*]
LangSecRef=3024
DetectFile=%ProgramFiles%\COMODO\COMODO Internet Security
Default=False
FileKey1=%ProgramFiles%\COMODO\COMODO Internet Security|*.tmp
FileKey2=%LocalAppData%\Temp\Comodo\Firewall Pro\Data\TempFiles|*.*
Link to comment
LangSecRef=3025
Default=False
What it is:
Regrading DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini. -- it looks like this is the Windows Media Player (version 10, 11, 12) history.
Link to comment
Register a new account
Sign in
Important Information
