Winapp2.ini additions
Winapp2.ini
The following code of [TuneUp Utilities 2011 Reg Defrag Cleanup**] in Winapp2.ini Version: v1.0.110928
needs to be updated to the following:
[TuneUp Utilities 2011 Reg Defrag Cleanup*]
LangSecRef=3024
Detect=HKCU\Software\TuneUp\Utilities\10.0
Default=False
FileKey1=%WinDir%\System32\config\|SECURITY_tureg_old
FileKey2=%WinDir%\System32\config\|SOFTWARE_tureg_old
FileKey3=%WinDir%\System32\config\|SYSTEM_tureg_old
FileKey4=%WinDir%\System32\config\|DEFAULT_tureg_new.LOG1
FileKey5=%WinDir%\System32\config\|DEFAULT_tureg_new.LOG2
FileKey6=%WinDir%\System32\config\|SAM_tureg_new.LOG1
FileKey7=%WinDir%\System32\config\|SAM_tureg_new.LOG2
FileKey8=%WinDir%\System32\config\|SECURITY_tureg_new.LOG1
FileKey9=%WinDir%\System32\config\|SECURITY_tureg_new.LOG2
FileKey10=%WinDir%\System32\config\|SOFTWARE_tureg_new.LOG1
FileKey11=%WinDir%\System32\config\|SOFTWARE_tureg_new.LOG2
FileKey12=%WinDir%\System32\config\|SYSTEM_tureg_new.LOG1
FileKey13=%WinDir%\System32\config\|SYSTEM_tureg_new.LOG2
FileKey14=%WinDir%\System32\config\|DEFAULT_tureg_old
FileKey15=%WinDir%\System32\config\|SAM_tureg_old
FileKey16=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_old
FileKey17=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_new.LOG1
FileKey18=%WinDir%\ServiceProfiles\LocalService\|NTUSER.DAT_tureg_new.LOG2
FileKey19=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_old
FileKey20=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_new.LOG1
FileKey21=%WinDir%\ServiceProfiles\NetworkService\|NTUSER.DAT_tureg_new.LOG2
Filekey22=%WinDir%\System32\config\|COMPONENTS_tureg_old
Filekey23=%WinDir%\System32\config\|COMPONENTS_tureg_new.LOG1
Filekey24=%WinDir%\System32\config\|COMPONENTS_tureg_new.LOG2
FileKey25=%USERPROFILE%\AppData\Local\Microsoft\Windows|USRCLASS.DAT_tureg_old
FileKey26=%USERPROFILE%\|NTUSER.DAT_tureg_new.LOG1
FileKey27=%USERPROFILE%\|NTUSER.DAT_tureg_new.LOG2
FileKey28=%USERPROFILE%\|NTUSER.DAT_tureg_old
FileKey29=C:\Boot\|BCD_tureg_new.LOG1
FileKey30=C:\Boot\|BCD_tureg_new.LOG2
FileKey31=C:\Boot\|BCD_tureg_old
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD21, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
[secunia PSI*]
LangSecRef=3021
DetectFile=%ProgramFiles%\Secunia\PSIsua.exe
Detect=HKCU\Software\Secunia\PSI
Default=False
FileKey1=%ProgramFiles%SecuniaPSI|sualog.txt
FileKey2=%ProgramFiles%SecuniaPSI|psialog.txt
FileKey3=%ProgramFiles%\Secunia\PSI|psialog.txt2
FileKey1 and 2 are missing 2 \ (Each) should be
FileKey1=%ProgramFiles%\Secunia\PSI|sualog.txt
FileKey2=%ProgramFiles%\Secunia\PSI|psialog.txt
In addition to the correction noted above, add a backslash after "PSI" on the "DetectFile" line:
DetectFile=%ProgramFiles%\Secunia\PSI\sua.exe
Link to comment
I install many of my programs (D:\) on a separate drive from my OS drive(C:\) does CCleaner still automatically detect and clean the programs correctly? What about if I have the folder it is installed into named in a non-default way?
If I install MalwareBytes' Anti-Malware in the following location will the program be cleaned correctly by CCleaner: E:\Programs\Securty\Scanners\MB Anti-Malware
I am running CCleaner portable 3.11 on Microsoft Windows 7 Professional 64.
Link to comment
CCleaner will only find them if you have them installed to the same path as %ProgramFiles% or if it has a registry detection path.
You can help us fill out more registry detection paths (preferred over env var paths such as %ProgramFiles%) if there are any programs not detected. :)
Link to comment
A brief thanks to all who've contributed and worked to main this file, especially the host and thread starter. It's really a great thing that CCleaner's "customization feature" is being used like so. With CCleaner and this file I see absolutely no need for anything else. I used to run several other apps and settled in on this one as the .ini file grew; and as Piriform made changes to CCleaner over the years. CCleaner has been easy to use and has worked well for some time. Good enough to recommend to others and some small businesses that I support from time to time.
Having said all that, I could probably put together some entries, or copy/paste the ones I've done. But they are for some technical engineering simulations and apps and I'm not sure that's what's needed here??
Also, I have not read all the docs yet, but is it possible for CCleaner to run a batch file? Or execute something of my own making? Either as part of the cleaning process or like a command on exiting CCleaner proper. A simple y/n would suffice - I'll figure it all out later.
Link to comment
Created two new entries
[GradeKeeper Recent Files/Assignments*]
LangSecRef=3021
Detect=HKCU\Software\Gradekeeper
FileKey1=%userprofile%\AppData\Roaming\Gradekeeper|*.*
[OpenDNS Updater Logs*]
LangSecRef=3021
warning=You must exit OpenDNS Updater in the System Tray to clear log files
Detect=HKCU\Software\OpenDNS Updater
FileKey1=%userprofile%\AppData\Roaming\OpenDNS Updater|*.txt
Added new Line to existing in Red
[LogMeIn*]
LangSecRef=3022
DetectFile=%ProgramFiles%\Logmein\x86\LogMeIn.exe
Default=False
FileKey1=%ProgramFiles%\Logmein|LMI*.log
FileKey2=%ProgramData%\Logmein|LMI*.log
Link to comment
Another one I have added , also saw this on other Piriform forums as a recommendation . I personal had 500mb of cache that was all created over a year ago.
[MoveNetworks Media Player Cache*]
LangSecRef=3023
Detect=HKCU\Software\MoveNetworks
Default=False
FileKey1=%userprofile%\AppData\LocalLow\Move Networks\QMCache00|*.*
Link to comment
MODIFIED ENTRY
[Tipard Total Media Converter*]
LangSecRef=3023
Detect=HKCU\Software\Tipard Studio\Tipard Total Media Converter
Default=False
RegKey1=HKCU\Software\Tipard Studio\Tipard Total Media Converter\Edit|LastVideoFilePath
NEW ENTRIES
[Corel PaintShop Pro X4*]
LangSecRef=3023
DetectFile=%ProgramFiles%\Corel\Corel PaintShop Pro X4\Corel PaintShop Pro.exe
Default=False
FileKey1=%LocalAppData%\Corel PaintShop Pro\14.0\Database|*.db
FileKey2=%AppData%\Corel\Messages|*.*|RECURSE
Excludekey1=FILE|%AppData%\Corel\Messages|*.policy
[Corel VideoStudio Pro X4*]
LangSecRef=3023
DetectFile=%ProgramFiles%\Corel\Corel VideoStudio Pro X4\vstudio.exe
Default=False
FileKey1=%AppData%\Corel\Messages|*.*|RECURSE
FileKey2=%AppData%\Ulead Systems\Corel VideoStudio Pro\14.0\en-US|VS_PRO.log
[Nero Video 11*]
LangSecRef=3023
DetectFile=%ProgramFiles%\Nero\Nero 11\Nero Vision\NeroVision.exe
Default=False
FileKey1=%AppData%\Nero\Nero 11\Nero Vision\Log|*.*
FileKey2=%AppData%\Nero\Nero 11\Nero Vision\NVFACache|*.*
FileKey3=%AppData%\Nero\Nero 11\Nero Vision|*.txt
FileKey4=%AppData%\Nero\Nero 11\Nero Vision|*.bin
FileKey5=%AppData%\Nero\Nero 11\Nero3D|*.log
Link to comment
Change required for TuneUp Utilities 2012.
[TuneUp Utilities*]
LangSecRef=3024
Default=False
FileKey1=%AppData%\TuneUp Software\TuneUp Utilities\Backups|*.rcb
FileKey2=%AppData%\TuneUp Software\TU2011\Backups|*.rcb
FileKey3=%AppData%\TuneUp Software\TU2012\Backups|*.rcb
For TuneUp Utilities 2012 Registry Defrag Cleanup
[TuneUp Utilities 2012 Reg Defrag Cleanup*]
LangSecRef=3024
Detect=HKCU\Software\TuneUp\Utilities\12.0
Default=False
or you could combine TuneUp 2011 and TuneUp 2012
[TuneUp Utilities 2011/2012 Reg Defrag Cleanup*]
LangSecRef=3024
Detect2=HKCU\Software\TuneUp\Utilities\12.0
Default=False
Link to comment
[bing Dynamic CCleaner fix*]
LangSecRef=3023
DetectFile=%LocalAppData%\Microsoft\Windows\Themes\BingDynamic1.theme
Default=False
Warning=New download and delt only the rss file
FileKey1=%LocalAppData%\Microsoft\Feeds|http~c~f~fthemeserver~dmicrosoft~dcom~fdefault~daspx~mp=Bing&c=Desktop&m=en-US~.feed-ms
[Paramount Dynamic CCleaner fix*]
LangSecRef=3023
DetectFile=%LocalAppData%\Microsoft\Windows\Themes\ParamountDynamic.theme
Default=False
FileKey1=%LocalAppData%\Microsoft\Feeds|http~c~f~fthemeserver~dmicrosoft~dcom~fdefault~daspx~mp=Paramount&c=Dynamic&m=en-US~
Link to comment
MODIFIED ENTRIES
[Nero Video 11*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\Nero\Nero 11\Nero Vision|*.log
FileKey2=%AppData%\Nero\Nero 11\Nero Vision\Log|*.*
FileKey3=%AppData%\Nero\Nero 11\Nero Vision\NVFACache|*.*
FileKey4=%AppData%\Nero\Nero 11\Nero Vision|*.txt
FileKey5=%AppData%\Nero\Nero 11\Nero Vision|*.bin
FileKey6=%AppData%\Nero\Nero 11\Nero3D|*.log
[Windows Media Center*]
LangSecRef=3023
DetectFile=%CommonAppData%\Microsoft\eHome
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center\MRU\SettingsMRU
FileKey1=%CommonAppData%\Microsoft\eHome\logs|*.*
FileKey2=%LocalAppData%\Microsoft\eHome|playlistcache.db
Link to comment
  • Moderators
the narwhal bacons at midnight !
:blink:
Link to comment
Register a new account
Sign in
Important Information
