Winapp2.ini 0 Posted May 26, 2011 Author Share Posted May 26, 2011 Out now! winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
ricktendo64 0 Posted May 26, 2011 Share Posted May 26, 2011 Thanks...heres one Resource Hacker (setup) the .GID file is created if you launch the HLP file [Resource Hacker*] LangSecRef=3024 DetectFile="%ProgramFiles%\Resource Hacker\ResHacker.exe" Default=False FileKey1=%ProgramFiles%\Resource Hacker|ResHacker.ini FileKey2=%ProgramFiles%\Resource Hacker|reshacker.GID Link to post Share on other sites
aqua 0 Posted May 27, 2011 Share Posted May 27, 2011 ok have a question,, i use sandboxie and ie8,after downloading latest winapi i saw in ccleaner another option in applications section-internet explorer more* i check,,clean everything and open ie8,it idn't connect to the net,and then got a popout from sandboxie SBIE1308 program verclsid.exe cannot start due to restrictions" now when untickin this"internet explorer more...i get connection to the net..but the nag remain i have to close SB. and everytime i open ie8 i get this nag from SB... Still having the same problem with this new file Link to post Share on other sites
Tom AZ 0 Posted May 27, 2011 Share Posted May 27, 2011 What exactly gets cleaned with "Windows System Profile?" Are they all temp files? Also, what about the "Cached Fonts" and "Cached DGI+Fonts?" Link to post Share on other sites
CSGalloway 0 Posted May 27, 2011 Share Posted May 27, 2011 To TOM AZ : Just right click on each opf the ones you mentioned and select Analyze - that will show you what is deleted. To winapp2.ini: I see several occurnaces of the full pathnames like c:\documents and settings\all users\application data\ - be nice to globally change that to %allusersprofile%\application data\ and similar for the ones that have %whatever% appreviations. The following entry needs to be changed for Multi-Edit 2008 11.04 that I submitted a few weeks ago. [Multi-Edit 2008 11.04*] LangSecref=3021 Detect=HKCU\Software\Multi Edit Software\Multi-Edit\11.0 Default=False FileKey1=%appdata%\Multi Edit Software\Multi-Edit\11\Config.04\Tmp|*.* Is there a way toi remove all the registry entries under HKCU\Software\Piriform\CCleaner that start with "(app)" ?? - it would be helpful when there is a winapp2.ini entry that is renamed so the old name is not needed any more. Link to post Share on other sites
Winapp2.ini 0 Posted May 27, 2011 Author Share Posted May 27, 2011 Ah.. I don't know. You could delete them all I suppose but that'd delete your current CCleaner settings. The same issue is in CCleaner.ini whereby old entries remain with their options. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
SMalik 0 Posted May 30, 2011 Share Posted May 30, 2011 Some programs leave Temp files, Temporary Internet files or cookies in Windows System Profile also. Windows system stores caches of fonts and GDI+ fonts installed in the system. By deleting and wiping these caches, you do not remove the fonts or GDI+ fonts, only their cached copies. What exactly gets cleaned with "Windows System Profile?" Are they all temp files? Also, what about the "Cached Fonts" and "Cached DGI+Fonts?" Link to post Share on other sites
SMalik 0 Posted May 30, 2011 Share Posted May 30, 2011 NEW ENTRY Some applications contain the Qt modules, the paths to which can be left in system after removing these applications. [stored Qt Modules Paths*] LangSecRef=3021 Detect=HKCU\Software\Trolltech Default=False RegKey1=HKCU\Software\Trolltech Link to post Share on other sites
ricktendo64 0 Posted June 4, 2011 Share Posted June 4, 2011 Remote Desktop Connection (more cleaning entries) http://support.microsoft.com/kb/312169 [Remote Desktop Connection*] LangSecRef=3025 DetectFile=%WinDir%\System32\mstsc.exe Default=False FileKey1=%Documents%|*.rdp RegKey1=HKCU\Software\Microsoft\Terminal Server Client\Default|MRU0 RegKey2=HKCU\Software\Microsoft\Terminal Server Client\Default|MRU1 RegKey3=HKCU\Software\Microsoft\Terminal Server Client\Default|MRU2 RegKey4=HKCU\Software\Microsoft\Terminal Server Client\Default|MRU3 RegKey5=HKCU\Software\Microsoft\Terminal Server Client\Default|MRU4 RegKey6=HKCU\Software\Microsoft\Terminal Server Client\Default|MRU5 RegKey7=HKCU\Software\Microsoft\Terminal Server Client\Default|MRU6 RegKey8=HKCU\Software\Microsoft\Terminal Server Client\Default|MRU7 RegKey9=HKCU\Software\Microsoft\Terminal Server Client\Default|MRU8 RegKey10=HKCU\Software\Microsoft\Terminal Server Client\Default|MRU9 I extracted the VBS from the MSI "Fix it" installer, this is what it does/looks like Option Explicit On Error Resume Next Const HKEY_CURRENT_USER = &H80000001 Const strKeyPath = "Software\Microsoft\Terminal Server Client\Default" Const strComputer = "." Const REG_SZ = 1 Dim objReg , arrValueNames , arrValueTypes Dim i Set objReg=GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & strComputer & "\root\default:StdRegProv") objReg.EnumValues HKEY_CURRENT_USER, strKeyPath , arrValueNames, arrValueTypes If Not IsNull(arrValueNames) Then For i=0 To UBound(arrValueNames) If arrValueTypes(i) = REG_SZ And InStr(arrValueNames(i),"MRU") = 1 Then objReg.DeleteValue HKEY_CURRENT_USER,strKeyPath,arrValueNames(i) End If Next End If Dim objShell : Set objShell = CreateObject("WScript.Shell") Dim objFSO : Set objFSO = CreateObject("Scripting.FileSystemObject") Dim strPathDefault strPathDefault = objShell.ExpandEnvironmentStrings("%USERPROFILE%") If Not IsNull(strPathDefault) Then If objFSO.FileExists(strPathDefault & "\Documents\Default.rdp") Then objFSO.DeleteFile(strPathDefault & "\Documents\Default.rdp") End If If objFSO.FileExists(strPathDefault & "\My Documents\Default.rdp") Then objFSO.DeleteFile(strPathDefault & "\My Documents\Default.rdp") End If End If Function MyVBScriptCA() If (Err.Number=0) Then 'return success MyVBScriptCA = 1 Else 'return cancel MyVBScriptCA = 2 End If End Function Link to post Share on other sites
Winapp2.ini 0 Posted June 5, 2011 Author Share Posted June 5, 2011 I'd like to push the next version out on June 7th, so as per your requests I'm letting you all know winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
MVE 0 Posted June 6, 2011 Share Posted June 6, 2011 [Microsoft Security Essentials*] LangSecRef=3024 DetectFile=%ProgramData%\Microsoft\Microsoft Antimalware Default=False FileKey1=%ProgramData%\Microsoft\Microsoft Antimalware\LocalCopy|*.*|RECURSE Link to post Share on other sites
ricktendo64 0 Posted June 7, 2011 Share Posted June 7, 2011 Anyway of NOT deleting the .INI file to preserve settings, only editing it to remove MRU stuff example UniExtract.ini [uniExtract Preferences] globalprefs=1 history=1 appendext=1 removetemp=1 removedupe=1 warnexecute=1 debugdir=%temp% [File History] 0=C:\Users\Ricardo\Desktop\wpi.msi 3=F:\Microsoft\Drivers\Se7en\INF_allOS_9.1.1.1014_PV.exe 5=F:\Microsoft\Drivers\Se7en\INF_allOS_9.1.2.1008_PV.exe 6=C:\Users\Ricardo\Downloads\wintv7setup.exe 7=C:\Users\Ricardo\Documents\Projects\dotNETMaker\dotNETfx\DNF11\netfx.msi 8=C:\Users\Ricardo\Desktop\Seven Remix XP 2.41.exe 9=C:\Users\Ricardo\Downloads\EP0000156866.exe 2=F:\Microsoft\Drivers\Se7en\INF_allOS_9.2.0.1021_PV.exe 1=F:\wpi\Install\SkypeSetup.msi 4=F:\Microsoft\Drivers\Se7en\INF_allOS_9.1.2.1007_PV.exe [Directory History] 0=C:\Users\Ricardo\Desktop\wpi 3=F:\Microsoft\Drivers\Se7en\INF_allOS_9.1.1.1014_PV 5=F:\Microsoft\Drivers\Se7en\INF_allOS_9.1.2.1008_PV 6=C:\Users\Ricardo\Downloads\wintv7setup 7=C:\Users\Ricardo\Documents\Projects\dotNETMaker\dotNETfx\DNF11\netfx 8=C:\Users\Ricardo\Desktop\Seven Remix XP 2.41 9=C:\Users\Ricardo\Downloads\EP0000156866 2=F:\Microsoft\Drivers\Se7en\INF_allOS_9.2.0.1021_PV 1=F:\wpi\Install\SkypeSetup 4=F:\Microsoft\Drivers\Se7en\INF_allOS_9.1.2.1007_PV Code could go something like [universal Extractor*] LangSecRef=3021 DetectFile=%ProgramFiles%\Universal Extractor\UniExtract.exe Default=False ; This will delete all that is present under a ini section FileKey1=%ProgramFiles%\Universal Extractor|UniExtract.ini|File History,* ; This will delete only a specified value (8=*) FileKey2=%ProgramFiles%\Universal Extractor|UniExtract.ini|Directory History,8 Its just a rough example to show you what I mean, you guys may know better how to code winapp2.ini We are working on adding support to clean various types of document/content. INI files will be one of them! Coming soon! Any progress on this front? Link to post Share on other sites
Winapp2.ini 0 Posted June 7, 2011 Author Share Posted June 7, 2011 It hasn't been mentioned again. I'm still hoping one day that there will be wildcard folder support. Maybe one day.. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
ricktendo64 0 Posted June 7, 2011 Share Posted June 7, 2011 I was referring to editing INI files [sections] Now that you mention it wildcard registry support would also be nice (like in the case of the MRU* I found/added to Remote Desktop Connection) Link to post Share on other sites
Winapp2.ini 0 Posted June 7, 2011 Author Share Posted June 7, 2011 It'd be great if all of these things could be added, it'd really boost up the strength and capabilities of CCleaner. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Winapp2.ini 0 Posted June 7, 2011 Author Share Posted June 7, 2011 Updated winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
ricktendo64 0 Posted June 8, 2011 Share Posted June 8, 2011 Is this missing a backslash after %CommonAppData%? [AOL 9.6*] Default=False DetectFile=%CommonAppData%AOL\C_AOL Desktop 9.6 LangSecRef=3022 FileKey1=%CommonAppData%AOL\C_AOL Desktop 9.6\spool|*.tmp FileKey2=%CommonAppData%AOL\C_AOL Desktop 9.6\bart|*.*|RECURSE BTW I just checked in official CCleaner INI and the new registry entries I added to Remote Desktop Connection are not needed [Remote Desktop]ID=2063 LangSecRef=3025 Detect=HKCU\Software\Microsoft\Terminal Server Client Default=True FileKey1=%localappdata%\Microsoft\Terminal Server Client\Cache|*.* RegKey1=HKCU\Software\Microsoft\Terminal Server Client\Default ExcludeKey1=REG|HKCU\Software\Microsoft\Terminal Server Client\Default\AddIns Link to post Share on other sites
CSGalloway 0 Posted June 8, 2011 Share Posted June 8, 2011 [AOL 9.6*] Default=False DetectFile=%CommonAppData%AOL\C_AOL Desktop 9.6 LangSecRef=3022 FileKey1=%CommonAppData%AOL\C_AOL Desktop 9.6\spool|*.tmp FileKey2=%CommonAppData%AOL\C_AOL Desktop 9.6\bart|*.*|RECURSE should be [AOL 9.6*] Default=False DetectFile=%CommonAppData%\AOL\C_AOL Desktop 9.6 LangSecRef=3022 FileKey1=%CommonAppData%\AOL\C_AOL Desktop 9.6\spool|*.tmp FileKey2=%CommonAppData%\AOL\C_AOL Desktop 9.6\bart|*.*|RECURSE Link to post Share on other sites
Akin 0 Posted June 12, 2011 Share Posted June 12, 2011 Star Trek Online ( http://www.startrekonline.com/ ) Install location can be determined by reading [HKEY_CURRENT_USER\Software\Cryptic\Star Trek Online] "InstallLocation"="c:\\program files (x86)\\steam\\steamapps\\common\\star trek online" (as an example) I will use (installdir) to reference the path from the registry key above. You can safely erase the files located in the following locations: (installdir)\Star Trek Online\Live\cache (to be clear, this would be c:\program files (x86)\steam\steamapps\common\star trek online\Star Trek Online\Live\cache) (installdir)\Star Trek Online\PlayTest\cache (I suggest a checkbox for "Star Trek Online Cache") (installdir)\Star Trek Online\Live\logs\GameClient (installdir)\Star Trek Online\Playtest\logs\GameClient (I suggest a checkbox for "Star Trek Online Logs") Clearing these directories can easily free up 25-50 MB or more of space. The game will simply regenerate the files as needed, so they are perfectly safe to erase. EDIT: Note: For users not using Steam, the game installation path is "c:\users\public\games\cryptic studios\Star Trek Online" instead. Link to post Share on other sites
Winapp2.ini 0 Posted June 13, 2011 Author Share Posted June 13, 2011 Will this work? [star Trek Online Cache*] LangSecRef=3022 DetectFile=%ProgramFiles%\Steam\Steamapps\common\Star Trek Online Default=False FileKey1=%ProgramFiles%\Steam\Steamapps\Common\Star Trek Online\Live\Cache|*.* FileKey2=%ProgramFiles%\Steam\Steamapps\Common\Star Trek Online\PlayTest\Cache|*.* [star Trek Online Logs*] LangSecRef=3022 DetectFile=%ProgramFiles%\Steam\Steamapps\common\Star Trek Online Default=False FileKey1=%ProgramFiles%\Steam\Steamapps\Common\Star Trek Online\Live\Logs\GameClient|*.* FileKey2=%ProgramFiles%\Steam\Steamapps\Common\Star Trek Online\Playtest\Logs\GameClient|*.* winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Akin 0 Posted June 14, 2011 Share Posted June 14, 2011 Looks good to me, thank you. Link to post Share on other sites
SMalik 0 Posted June 15, 2011 Share Posted June 15, 2011 CORRECTED ENTRIES I have added the Detect paths. [MS Clip Organizer*] LangSecRef=3021 DetectFile=%AppData%\Microsoft\Clip Organizer Default=False FileKey1=%AppData%\Microsoft\Clip Organizer|mstore14.mgc [MS Management Console More*] LangSecRef=3025 DetectFile=%AppData%\Microsoft\MMC Default=False FileKey1=%AppData%\Microsoft\MMC|*.* [MS Office Saved CEIP data*] LangSecRef=3021 DetectFile=%AppData%\Microsoft\UProof Default=False FileKey1=%AppData%\Microsoft\UProof|*.bin FileKey2=%AppData%\Microsoft\UProof|*.DIC FileKey3=%AppData%\Microsoft\UProof|*.XML [MS Office UnsavedFiles*] LangSecRef=3021 DetectFile=%LocalAppData%\Microsoft\Office\UnsavedFiles Default=False FileKey1=%LocalAppData%\Microsoft\Office\UnsavedFiles|*.* [MS UserScanProfiles*] LangSecRef=3025 DetectFile=%LocalAppData%\Microsoft\UserScanProfiles Default=False FileKey1=%LocalAppData%\Microsoft\UserScanProfiles|*.* Link to post Share on other sites
haloxx 0 Posted June 15, 2011 Share Posted June 15, 2011 NEW ENTRY Lotus Notes Cache: If deleted the software starts faster. No disadvantage in program usage. It works with Lotus Notes 7 - 8.5 [Lotus Notes Cache] LangSecRef=3021 DetectFile=%ProgramFiles%\IBM\Lotus\Notes\Data\Cache.NDK Default=False FileKey1=%ProgramFiles%\IBM\Lotus\Notes\Data|Cache.NDK Link to post Share on other sites
Winapp2.ini 0 Posted June 15, 2011 Author Share Posted June 15, 2011 Thanks winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Akin 0 Posted June 15, 2011 Share Posted June 15, 2011 This will add support for Champions Online: http://www.champions-online.com/ [Champions Online Cache*] LangSecRef=3022 DetectFile=%ProgramFiles%\Steam\Steamapps\common\Champions Online Default=False FileKey1=%ProgramFiles%\Steam\Steamapps\Common\Champions Online\Live\Cache|*.* FileKey2=%ProgramFiles%\Steam\Steamapps\Common\Champions Online\PlayTest\Cache|*.* [Champions Online Logs*] LangSecRef=3022 DetectFile=%ProgramFiles%\Steam\Steamapps\common\Champions Online Default=False FileKey1=%ProgramFiles%\Steam\Steamapps\Common\Champions Online\Live\Logs\GameClient|*.* FileKey2=%ProgramFiles%\Steam\Steamapps\Common\Champions Online\Playtest\Logs\GameClient|*.* EDIT: Note: For users not using Steam, the game installation path is "c:\users\public\games\cryptic studios\Champions Online" instead. Link to post Share on other sites
