SMalik 0 Posted May 15, 2011 Share Posted May 15, 2011 Someone here posted this entry. Please think adding this in next release of Winapp2.ini. [Windows System Profile*] LangSecRef=3025 DetectFile=%WinDir%\system32\config\systemprofile Default=False FileKey1=%WinDir%\system32\config\systemprofile\Local Settings\Temp|*.*|RECURSE FileKey2=%WinDir%\system32\config\systemprofile\Local Settings\Temporary Internet Files|*.*|RECURSE FileKey3=%WinDir%\system32\config\systemprofile\Cookies|*.*|RECURSE It seems that .NET updates leave huge log files at those locations, could you please add those lines bellow. Thank you! Link to post Share on other sites
siliconman01 0 Posted May 16, 2011 Share Posted May 16, 2011 [McAfee Logs*] LangSecRef=3021 DetectFile=%CommonAppData%\McAfee\MCLOGS Default=False FileKey1=%CommonAppData%\McAfee\MCLOGS|*.log|RECURSE FileKey2=%CommonAppData%\McAfee\MCLOGS\CoreTech|*.*|RECURSE I have tested this modified entry on Windows 7 32-bit and 64-bit systems. I have McAfee Internet Security 2011 on both the systems. For some reason so many uninstalled programs empty folders were residing in the location listed here: C:\ProgramData\McAfee\MCLOGS\CoreTech After removing all the subfolders from the location listed above, everything was fine. I restarted the systems and all the needed subfolders were recreated. Please help me to figure out Norton Quarantine files location. In my opinion, removal of quarantined items for Security Programs such as McAfee, MBAM, SAS, NIS, etc., should be separate and unique entries in Winapp2.ini and Winapp.ini. That will allow CCleaner users to "purposely/intentionally" clean out quarantined items. If quarantined item removal is part of a general cleanup entry, users may not be aware that quarantined items are being deleted and could get into trouble if a security program false positive occurs and quarantines a good file. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
Winapp2.ini 0 Posted May 16, 2011 Author Share Posted May 16, 2011 Some people are of the opinion that quarentine files shouldn't be cleaned with CCleaner. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
siliconman01 0 Posted May 16, 2011 Share Posted May 16, 2011 Some people are of the opinion that quarentine files shouldn't be cleaned with CCleaner. I share that opinion too. However, if that is not the accepted "rule", then I recommend that they be a separate unique entry....only to clean out quarantine files. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
Moderators hazelnut 5 Posted May 16, 2011 Moderators Share Posted May 16, 2011 I think that the cleaning (deletion) of quarantined items should only be done through the av/malware app itself. CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
Winapp2.ini 0 Posted May 16, 2011 Author Share Posted May 16, 2011 I would add rules for quarantines but some AV programs really hate when you touch their belongings and start bugging out. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
SMalik 0 Posted May 16, 2011 Share Posted May 16, 2011 Thank you for all the suggestions. Actually I can't even find the location where Norton stores quarantines and related logs. Even after removing Recent History it does not remove the quarantines from the system. McAfee has an option where I can look and remove the quarantines and related logs. I have 7-Zip v9.20 on my system and CCleaner does not remove all the traces of 7-Zip. I am listing another path that need to be added into 7-Zip entry. HKCU\Software\7-Zip\Extraction|PathHistory Link to post Share on other sites
SMalik 0 Posted May 16, 2011 Share Posted May 16, 2011 NEW ENTRY [7-Zip More*] LangSecRef=3024 Detect=HKCU\Software\7-Zip Default=False RegKey1=HKCU\Software\7-Zip\Extraction|PathHistory Another More* here. Link to post Share on other sites
Winapp2.ini 0 Posted May 16, 2011 Author Share Posted May 16, 2011 Thanks winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Andavari 1 Posted May 17, 2011 Moderators Share Posted May 17, 2011 New addition submission, tested on Windows XP (SP3), needs testing on other OSes though. It's for the free Clementine music player. [Clementine*] ; Cleans the Network Cache LangSecRef=3023 Detect=HKCU\Software\Clementine Default=False FileKey1=%userprofile%\.config\Clementine\networkcache\http|*.cache| Link to post Share on other sites
SMalik 0 Posted May 17, 2011 Share Posted May 17, 2011 NEW ENTRIES [Microsoft Clip Organizer*] LangSecRef=3025 Default=False FileKey1=%AppData%\Microsoft\Clip Organizer|mstore14.mgc [Windows Defender More*] LangSecRef=3025 Default=False FileKey1=%CommonAppData%\Microsoft\Windows Defender\Support|*.log Link to post Share on other sites
siliconman01 0 Posted May 18, 2011 Share Posted May 18, 2011 Raxco PerfectDisk 12 (Now in Release Candidate phase) [PerfectDisk 12*] LangSecRef=3024 Detect=HKCU\Software\Raxco\PerfectDisk\12.0 Default=False FileKey1=%CommonAppData%\Raxco\PerfectDisk\12.0|*.log FileKey2=%CommonAppData%\Raxco\PerfectDisk\12.0|PDBootLog Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
CCUser003 0 Posted May 18, 2011 Share Posted May 18, 2011 Hi, Can anyone tell me if they have a "ready to use" winapp2.ini for clearing the data that Microsoft Office 2010, particularly Office Outlook 2010 logs --- I am specifically referring to the "last entry looked up" in the "Find" box for Contacts. Thanks Link to post Share on other sites
SMalik 0 Posted May 20, 2011 Share Posted May 20, 2011 MODIFIED ENTRIES Please replace Microsoft Clip Organizer with MS Clip Organizer and MS Office 2010 UnsavedFiles with MS Office UnsavedFiles. Also I have corrected the LangSecRef for the entries listed here. [MS Clip Organizer*] LangSecRef=3021 Default=False FileKey1=%AppData%\Microsoft\Clip Organizer|mstore14.mgc [MS Office UnsavedFiles*] LangSecRef=3021 Default=False FileKey1=%LocalAppData%\Microsoft\Office\UnsavedFiles|*.* [Windows Defender More*] LangSecRef=3024 Default=False FileKey1=%CommonAppData%\Microsoft\Windows Defender\Support|*.log Link to post Share on other sites
CCUser003 0 Posted May 20, 2011 Share Posted May 20, 2011 Hi, Can anyone tell me if they have a "ready to use" winapp2.ini for clearing the data that Microsoft Office 2010, particularly Office Outlook 2010 logs --- I am specifically referring to the "last entry looked up" in the "Find" box for Contacts. Thanks OK, Here is what needs to be done: The registry key data for here need to be deleted: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\profile_name\0a0d020000000000c000000000000046\101f0446 Can someone take 30 seconds to write the code I need to insert int he winapp2.ini file to do this? Thanks Link to post Share on other sites
Winapp2.ini 0 Posted May 20, 2011 Author Share Posted May 20, 2011 I really don't know that this will work for anyone but you, but here. [MS Office 10*] LangSecRef=3021 Detect=HKCU\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\Profile_name\0a0d020000000000c000000000000046 Default=False RegKey1=HKCU\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\profile_name\0a0d020000000000c000000000000046|101f0446 winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
SMalik 0 Posted May 20, 2011 Share Posted May 20, 2011 NEW ENTRY [WinASO Registry Optimizer (Backups)*] LangSecRef=3024 DetectFile=%ProgramFiles%\WinASO\Registry Optimizer\RegOpt.exe Default=False FileKey1=%ProgramFiles%\WinASO\Registry Optimizer\backup|*.*|RECURSE Is there a time every month when you release Winapp2.ini file? If you start announcing the release date for the next Winapp2.ini, then we will try to post all the suggestions together before the latest Winapp2.ini release day. Link to post Share on other sites
Winapp2.ini 0 Posted May 20, 2011 Author Share Posted May 20, 2011 I typically put out the next version when I feel there's been enough changes made. I always update after a CCleaner version is released. I think I will hold off an update for may until CCleaner 3.07 is out. If you guys want a designated release schedule, I could accommodate that. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
siliconman01 0 Posted May 21, 2011 Share Posted May 21, 2011 I typically put out the next version when I feel there's been enough changes made. I always update after a CCleaner version is released. I think I will hold off an update for may until CCleaner 3.07 is out. If you guys want a designated release schedule, I could accommodate that. Your current update practice is fine with me. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
CSGalloway 0 Posted May 22, 2011 Share Posted May 22, 2011 Add: [Multi-Edit 2008 11.04*] LangSecref=3021 Detect=HKCU\Software\Multi Edit Software\Multi-Edit\11.0 Default=False FileKey1=%appdata%\Multi Edit Software\Multi-Edit\11\Config.04\Tmp\*.* [ACDSee 6.0 Standard Registry*] Default=False Detect=HKCU\Software\ACD Systems\ACDSee 6.0 LangSecref=3023 RegKey1=HKU\S-1-5-21-1202660629-854245398-1801674531-1003\Software\ACD Systems\ACDSee\60|HistMCFDestFolder RegKey2=HKU\S-1-5-21-1202660629-854245398-1801674531-1003\Software\ACD Systems\ACDSee\60|HistPaths RegKey3=HKU\S-1-5-21-1202660629-854245398-1801674531-1003\Software\ACD Systems\ACDSee\60|LastOptionPageName RegKey4=HKU\S-1-5-21-1202660629-854245398-1801674531-1003\Software\ACD Systems\ACDSee\60|OpenFolder RegKey5=HKU\S-1-5-21-1202660629-854245398-1801674531-1003\Software\ACD Systems\ACDSee\60\PrintOptions\OutputContactSheet|ContactSheetFN RegKey6=HKU\S-1-5-21-1202660629-854245398-1801674531-1003\Software\ACD Systems\ACDSee\60\PrintOptions\OutputContactSheet|ImageMapFN [AOL 9.6*] Default=False DetectFile=C:\Documents and Settings\All Users\Application Data\AOL\C_AOL Desktop 9.6 LangSecRef=3022 FileKey1=C:\Documents and Settings\All Users\Application Data\AOL\C_AOL Desktop 9.6\spool|*.tmp FileKey2=C:\Documents and Settings\All Users\Application Data\AOL\C_AOL Desktop 9.6\bart|*.*|RECURSE Change: [ACDSee 6.0 Standard*] to: [ACDSee 6.0 Standard Database*] Link to post Share on other sites
SMalik 0 Posted May 22, 2011 Share Posted May 22, 2011 To have a designated time schedule is better that way we can submit all the entries at once instead of posting every day. It is up to you. NEW ENTRY MS Office Saved Customer Experience Improvement Program data [MS Office Saved CEIP data*] LangSecRef=3021 Default=False FileKey1=%AppData%\Microsoft\UProof|*.bin FileKey2=%AppData%\Microsoft\UProof|*.DIC FileKey3=%AppData%\Microsoft\UProof|*.XML Is there a way that I can make an entry to scan for *.sqm files? The SQM file basically contains header data and Datapoints. Please replace MS Office 2010 UnsavedFiles entry with MS Office UnsavedFiles as it is good for Office 2007 also. I have posted this entry in my last post. I typically put out the next version when I feel there's been enough changes made. I always update after a CCleaner version is released. I think I will hold off an update for may until CCleaner 3.07 is out. If you guys want a designated release schedule, I could accommodate that. Link to post Share on other sites
CCUser003 0 Posted May 23, 2011 Share Posted May 23, 2011 I really don't know that this will work for anyone but you, but here. [MS Office 10*] LangSecRef=3021 Detect=HKCU\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\Profile_name\0a0d020000000000c000000000000046 Default=False RegKey1=HKCU\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\profile_name\0a0d020000000000c000000000000046|101f0446 Hey, Thanks for helping.. It didn't work! I tried this one: [MS Office 14*] LangSecRef=3021 Detect=HKCU\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\Outlook\0a0d020000000000c000000000000046\101f0446 Default=False RegKey1=HKCU\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\Outlook\0a0d020000000000c000000000000046\101f0446 | Basically, what I need done is everything in the 101f0446 key (all the values) need to be deleted. I double checked the value of the registry, and correct it slightly... but it is still not deleting. What am I doing wrong? Link to post Share on other sites
Winapp2.ini 0 Posted May 23, 2011 Author Share Posted May 23, 2011 make it |101f0446 instead of 101f0446 | winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
MVE 0 Posted May 24, 2011 Share Posted May 24, 2011 [HTC Home Apis*] LangSecRef=3021 DetectFile=%ProgramFiles%\HTC Home Default=False FileKey1=%ProgramFiles%\HTC Home\log|*.*|RECURSE Link to post Share on other sites
ricktendo64 0 Posted May 26, 2011 Share Posted May 26, 2011 Will there be a update today Link to post Share on other sites
