Winapp2.ini 0 Posted December 23, 2010 Author Share Posted December 23, 2010 [Yahoo Messenger Cache*] LangSecRef=3022 DetectFile=%ProgramFiles%\Yahoo!\Messenger\ Default=False FileKey1=%ProgramFiles%\Yahoo!\Messenger\Cache|*.*|RECURSE FileKey2=%ProgramFiles%\Yahoo!\Messenger\IMVCache|*.*|RECURSE [Yahoo Messenger Logs*] LangSecRef=3022 DetectFile=%ProgramFiles%\Yahoo!\Messenger\ Default=False FileKey1=%ProgramFiles%\Yahoo!\Messenger|ypager.log FileKey2=%ProgramFiles%\Yahoo!\Messenger\Logs|*.* [Yahoo Messenger Profiles*] LangSecRef=3022 DetectFile=%ProgramFiles%\Yahoo!\Messenger\ Warning=This will also delete your saved chat histories. Default=False FileKey1=%ProgramFiles%\Yahoo!\Messenger\Profiles|*.*|RECURSE [Yahoo Messenger Profiles Registry Key*] ;uses its cleaning path as a detect path as well. LangSecRef=3022 Detect=HKCU\Software\Yahoo\Profiles Default=False RegKey1=HKCU\Software\Yahoo\Profiles better? Link to post Share on other sites
back_track 0 Posted December 23, 2010 Share Posted December 23, 2010 [MediaphorAG Intaller*] LangSecRef=3024 DetectFile=C:\MediaphorAG Default=False FileKey1=C:\MediaphorAG|*.*|REMOVESELF It s create from some Inatallers from loadblog Link to post Share on other sites
Winapp2.ini 0 Posted December 23, 2010 Author Share Posted December 23, 2010 [MediaphorAG Intaller*] LangSecRef=3024 DetectFile=C:\MediaphorAG Default=False FileKey1=C:\MediaphorAG|*.*|REMOVESELF It s create from some Inatallers from loadblog Is it always at the root of your system drive? Would [MediaphorAG Intaller*] LangSecRef=3024 DetectFile=%SystemDrive%\MediaphorAG Default=False FileKey1=%SystemDrive%\MediaphorAG|*.*|REMOVESELF work as well? Link to post Share on other sites
Winapp2.ini 0 Posted December 24, 2010 Author Share Posted December 24, 2010 Forgot to push the update for CCleaner3.02 Changes in the first post Download here: http://ompldr.org/vNnBhNg/winapp2.ini Link to post Share on other sites
CSGalloway 0 Posted December 24, 2010 Share Posted December 24, 2010 Looks good but the "also" can be removed from the warning= for [Yahoo Messenger Profiles*] ----------------------------- [Yahoo Messenger Cache*] LangSecRef=3022 DetectFile=%ProgramFiles%\Yahoo!\Messenger\ Default=False FileKey1=%ProgramFiles%\Yahoo!\Messenger\Cache|*.*|RECURSE FileKey2=%ProgramFiles%\Yahoo!\Messenger\IMVCache|*.*|RECURSE [Yahoo Messenger Logs*] LangSecRef=3022 DetectFile=%ProgramFiles%\Yahoo!\Messenger\ Default=False FileKey1=%ProgramFiles%\Yahoo!\Messenger|ypager.log FileKey2=%ProgramFiles%\Yahoo!\Messenger\Logs|*.* [Yahoo Messenger Profiles*] LangSecRef=3022 DetectFile=%ProgramFiles%\Yahoo!\Messenger\ Warning=This will also delete your saved chat histories. Default=False FileKey1=%ProgramFiles%\Yahoo!\Messenger\Profiles|*.*|RECURSE [Yahoo Messenger Profiles Registry Key*] ;uses its cleaning path as a detect path as well. LangSecRef=3022 Detect=HKCU\Software\Yahoo\Profiles Default=False RegKey1=HKCU\Software\Yahoo\Profiles better? Link to post Share on other sites
back_track 0 Posted December 24, 2010 Share Posted December 24, 2010 Is it always at the root of your system drive? Would [MediaphorAG Intaller*] LangSecRef=3024 DetectFile=%SystemDrive%\MediaphorAG Default=False FileKey1=%SystemDrive%\MediaphorAG|*.*|REMOVESELF work as well? yes but I d change that: LangSecRef=3021 Link to post Share on other sites
Miroku4444 0 Posted December 25, 2010 Share Posted December 25, 2010 Could someone make some entry's for Opera, which include Website Icons(the built-in one doesn't work), VPS, and thumbnails. The files are located here: I have them listed in my include list in the options section, but it would be nice to delete them when i want, not everytime i run ccleaner. Link to post Share on other sites
TheWebAtom 0 Posted December 25, 2010 Share Posted December 25, 2010 Something like this? [More Opera*] LangSecRef=3022 Detect=HKLM\SOFTWARE\Opera Software Default=False FileKey1=%appdata%\Opera\Opera\icons|*.*| FileKey2=%appdata%\Opera\Opera\thumbnails|*.*| FileKey3=%appdata%\Opera\Opera\vps|*.*| I haven't got Opera installed, so I can't confirm if it works. Link to post Share on other sites
Miroku4444 0 Posted December 25, 2010 Share Posted December 25, 2010 Something like this? [More Opera*] LangSecRef=3022 Detect=HKLM\SOFTWARE\Opera Software Default=False FileKey1=%appdata%\Opera\Opera\icons|*.*| FileKey2=%appdata%\Opera\Opera\thumbnails|*.*| FileKey3=%appdata%\Opera\Opera\vps|*.*| I haven't got Opera installed, so I can't confirm if it works. Tested it and it didn't work. Shouldn't the words local setting be in there for it to work? Link to post Share on other sites
TheWebAtom 0 Posted December 25, 2010 Share Posted December 25, 2010 Tested it and it didn't work. Shouldn't the words local setting be in there for it to work? Probably, as I said - it was just me quickly typing something up while checking my email/ Link to post Share on other sites
Winapp2.ini 0 Posted December 25, 2010 Author Share Posted December 25, 2010 just replace the %appdata% with %localappdata% Link to post Share on other sites
Miroku4444 0 Posted December 26, 2010 Share Posted December 26, 2010 just replace the %appdata% with %localappdata% Its working, but its not deleting sub-folders. Link to post Share on other sites
Winapp2.ini 0 Posted December 26, 2010 Author Share Posted December 26, 2010 If you want it to delete everything in the folder, and all the subfolders, use |*.*|REMOVESELF If you just want it to remove the contents of the subdirs, use |*.*|RECURSE Link to post Share on other sites
Miroku4444 0 Posted December 26, 2010 Share Posted December 26, 2010 If you want it to delete everything in the folder, and all the subfolders, use |*.*|REMOVESELF If you just want it to remove the contents of the subdirs, use |*.*|RECURSE Thanks a million, they both work perfectly!! Here they are to be added to the next winapp2.ini version. I added one for temporary_downloads. [More Opera*] LangSecRef=3022 Detect=HKLM\SOFTWARE\Opera Software Default=False FileKey1=%localappdata%\Opera\Opera\icons|*.*|RECURSE FileKey2=%localappdata%\Opera\Opera\thumbnails|*.*|RECURSE FileKey3=%localappdata%\Opera\Opera\vps|*.*|RECURSE FileKey4=%localappdata%\Opera\Opera\temporary_downloads|*.*|RECURSE [More Opera*] LangSecRef=3022 Detect=HKLM\SOFTWARE\Opera Software Default=False FileKey1=%localappdata%\Opera\Opera\icons|*.*|REMOVESELF FileKey2=%localappdata%\Opera\Opera\thumbnails|*.*|REMOVESELF FileKey3=%localappdata%\Opera\Opera\vps|*.*|REMOVESELF FileKey4=%localappdata%\Opera\Opera\temporary_downloads|*.*|REMOVESELF Link to post Share on other sites
CSGalloway 0 Posted December 27, 2010 Share Posted December 27, 2010 Hi. The following files can be safely removed for users of AVG10. I have also let MrG know... C:\Documents and Settings\All Users\Application Data\AVG10\IDS\config\internalList.zip.bak C:\Documents and Settings\All Users\Application Data\AVG10\IDS\config\quarantinedList.zip.bak C:\Documents and Settings\All Users\Application Data\AVG10\IDS\config\userList.zip.bak C:\Documents and Settings\All Users\Application Data\AVG10\IDS\profile\globalLoadable.bak C:\Documents and Settings\All Users\Application Data\AVG10\Temp\file9514.tmp Thanks. Link to post Share on other sites
w33d3r 0 Posted December 27, 2010 Share Posted December 27, 2010 Winapp2.ini - Didn't CCleaner used to recognise if a user has Microsoft Silverlight installed? (well, I say if, more like who hasn't the way MS force feed it via windows update) Just tried the current version of CCleaner with your most up to date ini and nothing seems to come up on any lists. Anyway, if not, I believe the following could be added [silverlight] LangSecRef=3022 Detect=HKLM\SOFTWARE\Microsoft\Silverlight Default=True FileKey1=%userprofile%\AppData\LocalLow\Microsoft\Silverlight|*.*|RECURSE For cleaning out MS LSOs (Local Shared Objects), similar to Adobe's Link to post Share on other sites
Eastman 0 Posted December 27, 2010 Share Posted December 27, 2010 Ahh, good to know - I use AVG Link to post Share on other sites
knightkiller 0 Posted December 28, 2010 Share Posted December 28, 2010 Borland Delphi 7 and CodeGear RAD Studio 2009 [borland Delphi 7*] LangSecRef=3024 Detect=HKCU\Software\Borland\Delphi\7.0 Default=False RegKey1=HKCU\Software\Borland\Delphi\7.0\Closed Files RegKey2=HKCU\Software\Borland\Delphi\7.0\Closed Projects KegKey3=HKCU\Software\Borland\Delphi\7.0\Session [CodeGear RAD Studio 2009*] LangSecRef=3024 Detect=HKCU\Software\CodeGear\BDS\6.0 Default=False RegKey1=HKCU\Software\CodeGear\BDS\6.0\Closed Files RegKey2=HKCU\Software\CodeGear\BDS\6.0\Closed Projects KegKey3=HKCU\Software\CodeGear\BDS\6.0\Session Link to post Share on other sites
Moderators Nergal 0 Posted December 28, 2010 Moderators Share Posted December 28, 2010 Winapp2.ini - Didn't CCleaner used to recognise if a user has Microsoft Silverlight installed? (well, I say if, more like who hasn't the way MS force feed it via windows update) Just tried the current version of CCleaner with your most up to date ini and nothing seems to come up on any lists. Anyway, if not, I believe the following could be added [silverlight] LangSecRef=3022 Detect=HKLM\SOFTWARE\Microsoft\Silverlight Default=True FileKey1=%userprofile%\AppData\LocalLow\Microsoft\Silverlight|*.*|RECURSE For cleaning out MS LSOs (Local Shared Objects), similar to Adobe's Silverlight is now detected by CCleaner without Winapp2 (as of the latest version) [Microsoft Silverlight] ID=2169 LangSecRef=3023 DetectFile=%LocalAppData%\Microsoft\Silverlight\is DetectFile2=%LocalLowAppData%\Microsoft\Silverlight\is Default=True FileKey1=%LocalAppData%\Microsoft\Silverlight\is|*.*|RECURSE FileKey2=%LocalLowAppData%\Microsoft\Silverlight\is|*.*|RECURSE ExcludeKey1=FILE|%LocalAppData%\Microsoft\Silverlight\is\*\|disabled.dat ExcludeKey2=FILE|%LocalLowAppData%\Microsoft\Silverlight\is\*\|disabled.dat the issue I see here with what you posted was you didn't have the excludekey thus deleted the entire is directory thus when you updated winapp2 and ccleaner it no longer saw anything Link to post Share on other sites
w33d3r 0 Posted December 29, 2010 Share Posted December 29, 2010 the issue I see here with what you posted was you didn't have the excludekey thus deleted the entire is directory thus when you updated winapp2 and ccleaner it no longer saw anything Aah, I see my bad, thank you. Edit: Erm, just checked, Version 3.02.1343 CCleaner, downloaded a fresh version of the latest winapp2.ini linked in the OP (without any meddling by myself) - CCleaner is not listing Microsoft Silverlight for cleanout anywhere OS = Win 7 x 32 Link to post Share on other sites
Winapp2.ini 0 Posted December 29, 2010 Author Share Posted December 29, 2010 ExcludeKey1=FILE|%LocalAppData%\Microsoft\Silverlight\is\*\|disabled.dat ExcludeKey2=FILE|%LocalLowAppData%\Microsoft\Silverlight\is\*\|disabled.dat[/code] Is that some wildcard folder support? Alas, seems tis not so. Link to post Share on other sites
tehloxely 0 Posted December 29, 2010 Share Posted December 29, 2010 I see that uTorrent is added. Is there a way to clean old .torrent files in the "..\AppData\Roaming\uTorrent" as well? I don't know if there is a way to check if uTorrent is using or not, that's the only issue. Link to post Share on other sites
TheWebAtom 0 Posted December 29, 2010 Share Posted December 29, 2010 I see that uTorrent is added. Is there a way to clean old .torrent files in the "..\AppData\Roaming\uTorrent" as well? I don't know if there is a way to check if uTorrent is using or not, that's the only issue. Hahahah! I lost about 15 torrents trying to do this. I really don't recommend anyone follow in my failed footsteps. The only way I can think to do this is with some sort of VBScript, then call it from CCleaner. See psuedo code*: Imports DotNetUtils Dim u As New VBUtils If u.ProcessRunning(uTorrent.exe) = True Then '//Check if uTorrent is running. This is so it prevents deletion of torrents in use. For Each torrent As String In System.Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData) & \Roaming\uTorrent, *.* If System.IO.Path.GetExtension(torrent) = ".torrent" Then '//Make sure the file extension is .torrent If u.FileInUse(torrent) = False Then '//Check whether uTorrent is using the file. Try My.Computer.FileSystem.DeleteFile(torrent) Catch ex As Exception MessageBox.Show("Could not delete file.) End If Next End If *Well, .NET code actually - I've never actually had the need to write VBScript before. Anyone wanting to try the above code will need the DotNetUtils DLL. Link to post Share on other sites
Moderators Nergal 0 Posted December 30, 2010 Moderators Share Posted December 30, 2010 Adobe Acrobat 9.0 (should work with Acrobat 9 Standard, Acrobat 9 Pro and Acrobat 9 Pro Extended). [Adobe Acrobat 9.0 Most Recent Files*] LangSecRef=3021 Detect=HKCU\Software\Adobe\Adobe Acrobat\9.0 Default=False RegKey1=HKCU\Software\Adobe\Adobe Acrobat\9.0\AVGeneral\cRecentFiles Link to post Share on other sites
Winapp2.ini 0 Posted December 30, 2010 Author Share Posted December 30, 2010 Hahahah! I lost about 15 torrents trying to do this. I really don't recommend anyone follow in my failed footsteps. The only way I can think to do this is with some sort of VBScript, then call it from CCleaner. See psuedo code*: Imports DotNetUtils Dim u As New VBUtils If u.ProcessRunning(uTorrent.exe) = True Then '//Check if uTorrent is running. This is so it prevents deletion of torrents in use. For Each torrent As String In System.Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData) & \Roaming\uTorrent, *.* If System.IO.Path.GetExtension(torrent) = ".torrent" Then '//Make sure the file extension is .torrent If u.FileInUse(torrent) = False Then '//Check whether uTorrent is using the file. Try My.Computer.FileSystem.DeleteFile(torrent) Catch ex As Exception MessageBox.Show("Could not delete file.) End If Next End If *Well, .NET code actually - I've never actually had the need to write VBScript before. Anyone wanting to try the above code will need the DotNetUtils DLL. I also tried this a while ago, while running ?Torrent, however I only use analyze when testing new entries, and that was enough for me to see it doesn't work. I wonder why ?Torrent doesn't lock its "in use" torrent files. Link to post Share on other sites
