Winapp2.ini Posted September 1, 2010 Author Share Posted September 1, 2010 [*Microsoft Windows Game Statistics] LangSecRef=3025 DetectOS=6.0 DetectFile=%localappdata%\Microsoft Games\ Default=False FileKey1=%localappdata%\Microsoft Games\Chess Titans\|ChessTitans.xml FileKey2=%localappdata%\Microsoft Games\Chess Titans\|ChessTitans.xml.bak FileKey3=%localappdata%\Microsoft Games\FreeCell\|FreeCellSettings.xml FileKey4=%localappdata%\Microsoft Games\FreeCell\|FreeCellSettings.xml.bak FileKey5=%localappdata%\Microsoft Games\Hearts\|HeartsSettings.xml FileKey6=%localappdata%\Microsoft Games\Hearts\|HearsSettings.xml FileKey7=%localappdata%\Microsoft Games\Mahjong Titans\|MahjongTitans.xml FileKey8=%localappdata%\Microsoft Games\Mahjong Titans\|MahJongTitansStats.xml FileKey9=%localappdata%\Microsoft Games\Mahjong Titans\|MahjongTitansStats.xml.bak FileKey10=%localappdata%\Microsoft Games\Minesweeper\|MinesweeperSettings.xml FileKey11=%localappdata%\Microsoft Games\Minesweeper\|MinesweeperSettings.xml.bak FileKey12=%localappdata%\Microsoft Games\Purble Place\|ComfyCakesScoresAndSettings.xml FileKey13=%localappdata%\Microsoft Games\Purble Place\|ComfyCakesScoresAndSettings.xml.bak FileKey14=%localappdata%\Microsoft Games\Purble Place\|ConcentrationScoresAndSettings.xml FileKey15=%localappdata%\Microsoft Games\Purble Place\|ConcentrationScoresAndSettings.xml.bak FileKey16=%localappdata%\Microsoft Games\Purble Place\|PurblePlaceSettings.xml FileKey17=%localappdata%\Microsoft Games\Purble Place\|PurblePlaceSettings.xml.bak FileKey18=%localappdata%\Microsoft Games\Purble Place\|PurbleShopScoresAndSettings.xml FileKey19=%localappdata%\Microsoft Games\Purble Place\|PurbleShopScoresAndSettings.xml.bak FileKey20=%localappdata%\Microsoft Games\Solitaire\|SolitaireSettings.xml FileKey21=%localappdata%\Microsoft Games\Solitaire\|SolitaireSettings.xml.bak FileKey22=%localappdata%\Microsoft Games\Spider Solitaire\|SpiderSolitaireSettings.xml FileKey23=%localappdata%\Microsoft Games\Spider Solitaire\|SpiderSolitaireSettings.xml.bak I had to play ALL the games but I did it. I will post a revision without SRWare Iron and with this revised entry winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
metalj Posted September 1, 2010 Share Posted September 1, 2010 You don't have to add extra FileKeys with %ProgramFiles(x86)% When CCleaner detects 64bit it points %ProgramFiles% to the right direction (in this case C:\ProgramFiles(x86)\) It's just like %LocalAppData%, CCleaner will automatically point it to %userprofile%\local settings\application data\ on Windows XP. Piriform Software User Guides Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 1, 2010 Author Share Posted September 1, 2010 I'll be a sad panda if Ccleaner did this by default and this was a waste of time, but oh well what can you do. Are you certain of that? Because to me that would imply we wouldn't need work arounds for default entries like Sun Java for vista/7 winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 3, 2010 Author Share Posted September 3, 2010 You don't have to add extra FileKeys with %ProgramFiles(x86)% When CCleaner detects 64bit it points %ProgramFiles% to the right direction (in this case C:\ProgramFiles(x86)\) It's just like %LocalAppData%, CCleaner will automatically point it to %userprofile%\local settings\application data\ on Windows XP. Aww I just tested this with few rules and it seems you are right, which is somewhat disheartening. Would it make sense then, to remove all the added things? At the very least I did add/update some entries I suppose winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
ishan_rulz Posted September 3, 2010 Share Posted September 3, 2010 Sticky this; edit the original Winapp2.ini thread. Simplicity is hard. Link to comment Share on other sites More sharing options...
Alan_B Posted September 3, 2010 Share Posted September 3, 2010 Aww I just tested this with few rules and it seems you are right, which is somewhat disheartening. Would it make sense then, to remove all the added things? At the very least I did add/update some entries I suppose If your recent test on a FEW RULES shows that a they are redundant, it neither proves nor disproves the value of other rules. Windows 7, and also presumable Vista, has BLACK HOLES where data disappears over the Event Horizon. All the rules are broken. Abandon hope all ye who enter ! ! ! I have just posted information on this problem at :- http://forum.piriform.com/index.php?showtopic=29618 Alan Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 3, 2010 Author Share Posted September 3, 2010 This is true, I did not check every single path, so I can't assume ccleaner automagically does this for every entry. I suspect things pointing to locallowappdata wouldn't be compatible with windows xp, for example. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 3, 2010 Author Share Posted September 3, 2010 I will do some additional testing with one of my windows xp boxes, I suspect that some of the paths at the very least have altered, but I don't know. Aside from that, heres an updated version (with added filekeys still there) http://omploader.org/vNWZndQ/winapp2.ini winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
212eta Posted September 3, 2010 Share Posted September 3, 2010 [icon Cache] LangSecRef=3002 Default=true FileKey1=%userprofile%\Local Settings\Application Data|IconCache.db FileKey2=%LocalAppData%|IconCache.db *** Correction *** [icon Cache] LangSecRef=3025 Default=true FileKey1=%userprofile%\Local Settings\Application Data|IconCache.db FileKey2=%LocalAppData%|IconCache.db So that it will be added under the Tab Applications>Windows and Not under the Tab Applications>Windows Explorer (since it can Not go under the Tab Windows>Windows Explorer - where it normally belongs). Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 4, 2010 Author Share Posted September 4, 2010 It does not. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
212eta Posted September 4, 2010 Share Posted September 4, 2010 It does not.Then, you can make the above Correction (3002=>3025) so that the respective Icon Cache entrylooks like: [icon Cache] LangSecRef=3025 Default=true FileKey1=%userprofile%\Local Settings\Application Data|IconCache.db FileKey2=%LocalAppData%|IconCache.db Thank you for your hard work! Link to comment Share on other sites More sharing options...
Sailback Posted September 4, 2010 Share Posted September 4, 2010 Nice work Winapp2.ini. This just jumped out to me, though. [*CleanMyPC Registry Cleaner (Backups)] LangSecRef=3024 DectectFile=%ProgramFiles%\CleanMyPC\Registry Cleaner\rcleaner.exe DetectFile=%ProgramFiles(x86)%\CleanMyPC\Registry Cleaner\rcleaner.exe Default=True FileKey1=%ProgramFiles%\CleanMyPC\Registry Cleaner\UndoCenter|*.* FileKey2=%ProgramFiles(x86)%\CleanMyPC\Registry Cleaner\rcleaner.exe FileKey2 will not give the desired result I think. FileKey2=%ProgramFiles(x86)%\CleanMyPC\Registry Cleaner\rcleaner.exe Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 6, 2010 Author Share Posted September 6, 2010 Nice work Winapp2.ini. This just jumped out to me, though. [*CleanMyPC Registry Cleaner (Backups)] LangSecRef=3024 DectectFile=%ProgramFiles%\CleanMyPC\Registry Cleaner\rcleaner.exe DetectFile=%ProgramFiles(x86)%\CleanMyPC\Registry Cleaner\rcleaner.exe Default=True FileKey1=%ProgramFiles%\CleanMyPC\Registry Cleaner\UndoCenter|*.* FileKey2=%ProgramFiles(x86)%\CleanMyPC\Registry Cleaner\rcleaner.exe FileKey2 will not give the desired result I think. FileKey2=%ProgramFiles(x86)%\CleanMyPC\Registry Cleaner\rcleaner.exe I know I said I didn't check most of the entries, but judging by the detect file, that on is REALLY bad. Someone dun goof'd I've fixed it in my copy, I'm still testing some stuff though. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 11, 2010 Author Share Posted September 11, 2010 Updated: http://ompldr.org/vNWk5Mg/winapp2.ini winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 11, 2010 Moderators Share Posted September 11, 2010 Cool, checked and merged with mine and good to go thanks I like some of the new adds too (P.s. For next one you can remove realplayer sp it's = to winapp.ini and also the second * on quicktime for vista and seven 1) no longer needs cache new winapp.ini does that correct now 2) doesn't need extra * ) again, Winapp2.ini thanks so much for your work you're awesome. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 13, 2010 Author Share Posted September 13, 2010 Updated: http://ompldr.org/vNWl4aQ/winapp2.ini changes in the first post. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Woundman Posted September 19, 2010 Share Posted September 19, 2010 Updated: http://ompldr.org/vNWl4aQ/winapp2.ini changes in the first post. Hey Winapp2.ini, I've been trying to figure out how to make a Winapp2.ini for Pale Moon. Is it possible? Thanks! Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 26, 2010 Author Share Posted September 26, 2010 new: http://ompldr.org/vNW41Yg/winapp2.ini winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 27, 2010 Moderators Share Posted September 27, 2010 As of CCleaner 2.36.1233: Quicktime for Vista and 7 can be removed These lines can be removed from winapp2 MS Office Picture Manager FileKey1=%LocalAppData%\Microsoft\OIS|OIScatalog.cag FileKey2=%LocalAppData%\Microsoft\OIS\thumbnails|*.* (however the rest on the entry is still valid i think. . . unless %localappdata = %userprofile%\local settings\application data\ then entire entry can be removed) Cheers ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 27, 2010 Author Share Posted September 27, 2010 I've removed those two entries, the changes will be reflected in the next post . winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 29, 2010 Moderators Share Posted September 29, 2010 Also Malwarebytes is double listed (winapp.ini and winapp2.ini) I'm not sure how the new detect programfiles64 works in ccleaner's winapp.ini (if they have to listed the two versions. so I'm going to put both the winapp2 and winapp version below and let us figure out what to do Winapp2 [Malwarebytes' Anti Malware*] LangSecRef=3024 DetectFile=%ProgramFiles%\Malwarebytes' Anti-Malware\mbam.exe DetectFile=%ProgramFiles(x86)%\Malwarebytes' Anti-Malware\mbam.exe Default=False FileKey1=%appdata%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.txt FileKey2=%appdata%\Malwarebytes\Malwarebytes' Anti-Malware\Quarantine|*.* Winapp [Malwarebytes Anti Malware] ID=2162 LangSecRef=3024 DetectFile=%ProgramFiles%\Malwarebytes' Anti-Malware\mbam.exe Default=False FileKey1=%appdata%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.txt FileKey2=%appdata%\Malwarebytes\Malwarebytes' Anti-Malware\Quarantine|*.* the difference being your's listed (x86) Also: any objections for me to change thread title and sticky in now that winapp2.ini (the user and the file) are up and rolling? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 29, 2010 Author Share Posted September 29, 2010 No objections, I'm very curious as to what %Programfiles32/64% do but haven't gotten around to testing them just yet. I will do so soon (and remove that malware bytes entry since I guess it was just added in the new version? ) Added support for Paint Shop Pro X3, VLC Media Player, MediaMonkey, Winamp, Malwarebytes Anti Malware, Avast! Antivirus and WinPatrol. looks like my VLC is obsolete too (/feels special it was included officially, since I wrote it ) I have to look but I think some of the other things are in winapp2.ini also -Removed VLC -Removed Malwarebytes -Reoved Avast! -Removed Winamp -Removed WinPatrol -Removed both Quicktime entries -Removed FTP accounts wooh! http://ompldr.org/vNW9oZw/winapp2.ini Glad to know the Devs are watching for frequently requested applications EDIT: I'm actually going to go through the list to check for more things that are now obsolete (I really dont notice a lot due to the lack of the required detect! ) Expect another update within a day or two winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 29, 2010 Moderators Share Posted September 29, 2010 Also of note it seems many entries were moved to default=false (setting it to not clean until noticed by the cccleaner user). Safe I think for many, good choice ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 30, 2010 Author Share Posted September 30, 2010 Yes I did that in the previous update, since I felt it should be up to the end user. Sorry to do a double update but this version removes more obsolete entries http://ompldr.org/vNW9qdw/winapp2.ini winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted September 30, 2010 Share Posted September 30, 2010 Yes I did that in the previous update, since I felt it should be up to the end user. Sorry to do a double update but this version removes more obsolete entries http://ompldr.org/vNW9qdw/winapp2.ini Malwarebytes is still part of the update download above. [Malwarebytes' Anti Malware*]LangSecRef=3024 DetectFile=%ProgramFiles%\Malwarebytes' Anti-Malware\mbam.exe DetectFile=%ProgramFiles(x86)%\Malwarebytes' Anti-Malware\mbam.exe Default=False FileKey1=%appdata%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.txt FileKey2=%appdata%\Malwarebytes\Malwarebytes' Anti-Malware\Quarantine|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
