Winapp2.ini 0 Posted July 26, 2012 Author Share Posted July 26, 2012 Yeah, I was hoping someone would come along and help repair it, but I dont think anyone uses the macromedia versions of flash player anymore, so probably good to remove edit: sorry about those missed entries, got a little sloppy in my excitement for the huge update winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
SMalik 0 Posted July 26, 2012 Share Posted July 26, 2012 MODIFIED ENTRY Removed Filekey8 (FileKey8=%AppData%\OpenOffice.org2\user\registry\data\org\openoffice\Office|Common.xcu) Renamed Filekey8, 9 and replaced '/' with '|'. [OpenOffice.org*] LangSecRef=3021 Detect1=HKLM\SOFTWARE\OpenOffice.org Detect2=HKLM\SOFTWARE\Wow6432Node\OpenOffice.org Default=False FileKey1=%AppData%\OpenOffice.org\*\user\config\imagecache|*.* FileKey2=%AppData%\OpenOffice.org\*\user\registry\cache|*.* FileKey3=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Common.xcu FileKey4=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Views.xcu FileKey5=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Writer.xcu FileKey6=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu FileKey7=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Store.xcu FileKey8=%AppData%\OpenOffice.org\*\user|registrymodifications.xcu FileKey9=%AppData%\OpenOffice.org\*\user|registration.xml Link to post Share on other sites
Winapp2.ini 0 Posted July 26, 2012 Author Share Posted July 26, 2012 Thanks! winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Coffee4Joe 0 Posted July 26, 2012 Share Posted July 26, 2012 Found a couple older entries that haven't made it into winapp2.ini yet. http://forum.pirifor...ndpost&p=210165 [ThumbCacheToDelete*] LangSecRef=3025 DetectFile=%LocalAppData%\Microsoft\Windows\Explorer Default=False FileKey1=%LocalAppData%\Microsoft\Windows\Explorer\ThumbCacheToDelete|*.*|REMOVESELF & http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=209480 [NetworkService Temps*] LangSecRef=3025 DetectFile1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp Default=False FileKey1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp|*.txt Link to post Share on other sites
Winapp2.ini 0 Posted July 26, 2012 Author Share Posted July 26, 2012 Included in CCleaner: [Thumbnail Cache] ID=1029 LangSecRef=3002 LangRef=3131 DetectOS=6.0 Default=true SpecialKey1=N_EX_THUMBNAIL_CACHE FileKey1=%LocalAppData%\Microsoft\Windows\Explorer|thumbcache_*.db FileKey2=%LocalAppData%\Microsoft\Windows\Explorer\ThumbCacheToDelete|thm*.tmp winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Coffee4Joe 0 Posted July 26, 2012 Share Posted July 26, 2012 Included in CCleaner: [Thumbnail Cache] ID=1029 LangSecRef=3002 LangRef=3131 DetectOS=6.0 Default=true SpecialKey1=N_EX_THUMBNAIL_CACHE FileKey1=%LocalAppData%\Microsoft\Windows\Explorer|thumbcache_*.db FileKey2=%LocalAppData%\Microsoft\Windows\Explorer\ThumbCacheToDelete|thm*.tmp Yay! I had searched the built in's too, guess I left in the |*.*| No wonder my search didn't match anything or it hid from me Link to post Share on other sites
Winapp2.ini 0 Posted July 26, 2012 Author Share Posted July 26, 2012 Slightly different entry, but same effect winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
CSGalloway 0 Posted July 26, 2012 Share Posted July 26, 2012 The current winapp2.ini now shows Mozolla/FireFox even though I don't have either installed. I exported the HKCU\Software\Mozolla key and here it is. REGEDIT4 [HKEY_CURRENT_USER\Software\Mozilla] [HKEY_CURRENT_USER\Software\Mozilla\Firefox] [HKEY_CURRENT_USER\Software\Mozilla\Firefox\Extensions] "smartwebprinting@hp.com"="C:\\Program Files\\HP\\Digital Imaging\\Smart Web Printing\\MozillaAddOn3" Not sure how else CCleaner is identifing Mozilla/Firefox but willing to help track this down... Link to post Share on other sites
Moderators Nergal 0 Posted July 26, 2012 Moderators Share Posted July 26, 2012 Not for inclusion to The File but for CSGalloway's above post (I use this, see warning) [Firefox/Mozilla leftovers*] LangSecRef=3026 Default=False Warning=Only use if you use Portable Firefox and it improperly closed, This will remove ALL Mozilla Registry entries Detect=HKCU\Software\Mozilla\ DetectFile1=%AppData%\Mozilla\ DetectFile2=%LocalAppData%\Mozilla\ FileKey1=%AppData%\Mozilla|*.*|REMOVESELF FileKey2=%LocalAppData%\Mozilla|*.*|REMOVESELF RegKey1=HKCU\Software\Mozilla\ ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
CSGalloway 0 Posted July 27, 2012 Share Posted July 27, 2012 Thanks Nergal. Wondered if there is another regkey that could be used to detect Firefox? As the one I have is used by HP printing online.... which I would like to lkeave aloine Link to post Share on other sites
Moderators Nergal 0 Posted July 27, 2012 Moderators Share Posted July 27, 2012 Have we tried using SpecialDetect=DET_MOZILLA in winapp2? Though this may still not fix your issue as that key could indeed be included in the Special Detect ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Winapp2.ini 0 Posted July 27, 2012 Author Share Posted July 27, 2012 wow, actually I have not. It never occured to me. o.0 my testing shows that this works. It would probably work for other SpecialDetects too. goody! winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Winapp2.ini 0 Posted July 27, 2012 Author Share Posted July 27, 2012 These entries were suggested: some of them are okay, i wonder about some others [spybot S&D History**] LangSecRef=3024 DetectFile=%ProgramFiles%\Spybot – Search & Destroy Default=False FileKey1=%CommonAppData%\Spybot – Search & Destroy\Backups\|*.*|RECURSE FileKey2=%CommonAppData%\Spybot – Search & Destroy\Recovery\|*.*|RECURSE FileKey3=%CommonAppData%\Spybot – Search & Destroy\Snapshots\|*.*|RECURSE FileKey4=%CommonAppData%\Spybot – Search & Destroy\Snapshots2\|*.*|RECURSE [Office Recent**] LangSecRef=3021 DetectFile=%ProgramFiles%\Microsoft Office Default=False FileKey1=%AppData%\Microsoft\Office\Niedawny\|*.lnk [MKS_Vir Skaner Online**] LangSecRef=3024 DetectFile=%ProgramFiles%\SkanerOnline Default=False FileKey1=%ProgramFiles%\SkanerOnline\Raporty\|*.* FileKey2=%ProgramFiles%\SkanerOnline\tmp\|*.* FileKey3=%SystemDrive%\|*.cpp.log [Windows XP dllcache**] LangSecRef=3025 DetectFile=%WinDir%\system32\dllcache Default=False FileKey1=%WinDir%\system32\dllcache|*.*|RECURSE [Windows MSI $PatchCache$**] LangSecRef=3025 DetectFile=%WinDir%\Installer\$PatchCache$ Default=False FileKey1=%WinDir%\Installer\$PatchCache$|*.*|REMOVESELF [Win XP updates old folders**] LangSecRef=3025 DetectFile=%WinDir%\SoftwareDistribution Default=False FileKey1=%WinDir%\$hf_mig$|*.*|REMOVESELF FileKey2=%WinDir%\$NtServicePackUninstall$|*.*|REMOVESELF FileKey3=%WinDir%\ServicePackFiles|*.*|REMOVESELF FileKey4=%WinDir%\ie8|*.*|REMOVESELF FileKey5=%WinDir%\ie8updates|*.*|REMOVESELF [Office MSOCache folder**] LangSecRef=3021 DetectFile=%ProgramFiles%\Microsoft Office Default=False FileKey1=%SystemDrive%\MSOCache|*.*|REMOVESELF winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
siliconman01 0 Posted July 27, 2012 Share Posted July 27, 2012 I do not recommend adding [Office MSOCache folder**]. Removing this folder causes the user to have to insert the MS Office DVD each time a MS hotfix for Office is issued/installed via Windows Update. The other option would be to insert a warning message telling the user of the consequences of removing this folder. In [Win XP updates old folders**], removing the $hf_mig$ is not recommended by Microsoft. This folder contains hotfix info and should not be removed. http://answers.microsoft.com/en-us/windows/forum/windows_xp-performance/how-to-delete-unused-files-under-cwindows/8ddd45a9-b748-4a5f-8475-ce00214be510 I do not recommend adding [Windows XP dllcache*] http://www.pcreview.co.uk/forums/can-delete-system32-dllcache-folder-content-t3887555.html http://support.microsoft.com/kb/222193 Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
FreddeVries 0 Posted July 27, 2012 Share Posted July 27, 2012 [Kingsoft Office*] LangSecRef=3021 Detect=HKCU\SOFTWARE\Kingsoft Default=False FileKey1=%AppData%\Kingsoft\office6\backup|*.* FileKey2=%AppData%\Kingsoft\office6\update\log|*.log FileKey3=%AppData%\Kingsoft\office6|*.bak FileKey4=%LocalAppData%\Kingsoft\et\cache\http|* FileKey5=%LocalAppData%\Kingsoft\et\cache\https|* FileKey6=%LocalAppData%\Kingsoft\wps\cache\http|* FileKey7=%LocalAppData%\Kingsoft\wps\cache\https|* FileKey8=%Programfiles%\Kingsoft\Kingsoft Office\office6|update.log FileKey9=%Programfiles%\Kingsoft\Kingsoft Office\office6|Readme.txt FileKey10=%Programfiles%\Kingsoft\Kingsoft Office\office6|License.txt Link to post Share on other sites
Moderators Andavari 1 Posted July 27, 2012 Moderators Share Posted July 27, 2012 (edited) These entries were suggested: some of them are okay, i wonder about some others These are not safe!!!: [Windows XP dllcache**] LangSecRef=3025 DetectFile=%WinDir%\system32\dllcache Default=False FileKey1=%WinDir%\system32\dllcache|*.*|RECURSE [Win XP updates old folders**] LangSecRef=3025 DetectFile=%WinDir%\SoftwareDistribution Default=False FileKey1=%WinDir%\$hf_mig$|*.*|REMOVESELF FileKey2=%WinDir%\$NtServicePackUninstall$|*.*|REMOVESELF FileKey3=%WinDir%\ServicePackFiles|*.*|REMOVESELF FileKey4=%WinDir%\ie8|*.*|REMOVESELF FileKey5=%WinDir%\ie8updates|*.*|REMOVESELF To remove MSOCache all one has to do is open Disk Cleanup which is built right into Windows and it will properly remove it from the system so there's no registry data pointing to the folder. Doing it this way I wouldn't: [Office MSOCache folder**] LangSecRef=3021 DetectFile=%ProgramFiles%\Microsoft Office Default=False FileKey1=%SystemDrive%\MSOCache|*.*|REMOVESELF This is a hidden folder with the attributes hidden and system ("HS") on it, and I don't think it's safe to remove it. It's full of read-only .DLL files, etc., and many of the files with no extensions in that folder are also some sort of program or something: [Windows MSI $PatchCache$**] LangSecRef=3025 DetectFile=%WinDir%\Installer\$PatchCache$ Default=False FileKey1=%WinDir%\Installer\$PatchCache$|*.*|REMOVESELF Hmm, I wonder if whoever submitted them just needs to buy a bigger hard disk! Removing those folders would reclaim an absolutely hellish amount of free hard disk space. _______________________ Edit 2: According to Microsoft (http://support.microsoft.com/kb/329260) this is safe to remove, so if someone wants to use it I made a cleaner just for it which will only work on WinXP (OS v5.1) and without all that other unsafe stuff: [XP NtServicePackUninstall*] LangSecRef=3025 DetectOS=5.1 DetectFile=%windir%\$NtServicePackUninstall$ Default=False Warning=After removing the $NtServicePackUninstall$ folder you will not be able to uninstall the service pack. FileKey1=%windir%\$NtServicePackUninstall$|*.*|REMOVESELF I think most of this has been in winapp2.ini before though, and was removed for reasons I suppose! Edited July 27, 2012 by Andavari Updated info Link to post Share on other sites
Moderators Andavari 1 Posted July 27, 2012 Moderators Share Posted July 27, 2012 It would be very nice if the Mozilla Firefox cleaners could be grouped together in the winapp2.ini file somehow, trying to find them when they're all over the place is difficult. Grouped example with a Starts/Ends indication: ; Mozilla Firefox - Starts [Adblock Plus Backups*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\adblockplus|patterns-backup*.ini [bookmark Backups*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\bookmarkbackups|*.json ; Mozilla Firefox - Ends ------------------------------------------- Many updates for the Mozilla Firefox cleaners. After a clean install of Mozilla Firefox 14.0.1 and not seeing winapp2.ini cleaners working for it I found Firefox didn't create the "HKCU\Software\Mozilla\Firefox" registry key which so many of the winapp2.ini cleaners rely upon for detection. So wanting to more thoroughly cleanse Firefox, I've replaced the detections with: SpecialDetect=DET_MOZILLA The updates: ; Mozilla Firefox - Starts [Adblock Plus Backups*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\adblockplus|patterns-backup*.ini [bookmark Backups*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\bookmarkbackups|*.json [Corrupt SQLites*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles|*.corrupt|RECURSE [Crash Reports*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Crash Reports|*.*|RECURSE [Downloads*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%Documents%\Downloads|*.*|RECURSE [extensions.log*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*|extensions.log [Lock Files*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*|*.lock [Maintenance Service Logs*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%CommonAppData%\Mozilla\logs|*.* [Recovered File Fragments*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%ProgramFiles%\Mozilla|*.chk|RECURSE [Thumbnails*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\thumbnails|*.*|RECURSE [updates*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%LocalAppData%\Mozilla\Firefox\Mozilla Firefox\updates|*.*|RECURSE [webappsstore.sqlite*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*|webappsstore.sqlite ; Mozilla Firefox - Ends Link to post Share on other sites
CSGalloway 0 Posted July 27, 2012 Share Posted July 27, 2012 Have we tried using SpecialDetect=DET_MOZILLA in winapp2? Though this may still not fix your issue as that key could indeed be included in the Special Detect So to use this would I remove the Detect and Detectfile lines for the Mozolla/Firefox sections? ?What other SpecialDetect lines are available? Link to post Share on other sites
Moderators Andavari 1 Posted July 27, 2012 Moderators Share Posted July 27, 2012 So to use this would I remove the Detect and Detectfile lines for the Mozolla/Firefox sections? ?What other SpecialDetect lines are available? If you look at those Firefox cleaners in my post just above yours all I have is the SpecialDetect listed, it's what CCleaner does by default with its embedded INI files. Link to post Share on other sites
Moderators Nergal 0 Posted July 27, 2012 Moderators Share Posted July 27, 2012 [Office Recent**] LangSecRef=3021 DetectFile=%ProgramFiles%\Microsoft Office Default=False FileKey1=%AppData%\Microsoft\Office\Niedawny\|*.lnk I don't think this is valid as I believe "Niedawny" is a person's name (also I don't have any think like that in that folder what version of office is it supposed to be for?) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Winapp2.ini 0 Posted July 27, 2012 Author Share Posted July 27, 2012 I know FileKey3=%WinDir%\ServicePackFiles|*.*|REMOVESELF is cleaned by the cleanmgr function in windows. As for ;firefox entries, the file is sorted alphabetically by Alan's script winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Andavari 1 Posted July 27, 2012 Moderators Share Posted July 27, 2012 I don't think this is valid as I believe "Niedawny" is a person's name (also I don't have any think like that in that folder what version of office is it supposed to be for?) Probably not valid because just like you I don't have that folder with Office 2003 (v11.0). Link to post Share on other sites
Moderators Andavari 1 Posted July 27, 2012 Moderators Share Posted July 27, 2012 I know FileKey3=%WinDir%\ServicePackFiles|*.*|REMOVESELF is cleaned by the cleanmgr function in windows. That's the safe way of properly removing it! Manually deleting it or using CCleaner delete it may cause issues, because on Microsoft's website they state do not delete it or move it. Link to post Share on other sites
Winapp2.ini 0 Posted July 27, 2012 Author Share Posted July 27, 2012 ah, alright then. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
CSGalloway 0 Posted July 27, 2012 Share Posted July 27, 2012 Wonder when the new winapp2.ini will be released? So many false detections for Mozolla / Firefox it would be nice to have the fix in the orginal... Link to post Share on other sites
