back_track Posted August 1, 2012 Share Posted August 1, 2012 update for jdownloader [JDownloader .junique*] LangSecRef=3022 DetectFile1=%UserProfile%\.jd_home\ Detect=HKLM\Software\JDownloader Default=False FileKey1=%ProgramFiles%\JDownloader\.junique|*.* [JDownloader Backup*] LangSecRef=3022 DetectFile1=%UserProfile%\.jd_home\ Detect=HKLM\Software\JDownloader Default=False FileKey1=%ProgramFiles%\JDownloader\backup|*.* [JDownloader Capatchas*] LangSecRef=3022 DetectFile1=%UserProfile%\.jd_home\ Detect=HKLM\Software\JDownloader Default=False FileKey1=%ProgramFiles%\JDownloader\captchas|*.* FileKey2=%ProgramFiles%\JDownloader\tmp\linksave|*.* [JDownloader Config*] LangSecRef=3022 DetectFile1=%UserProfile%\.jd_home\ Detect=HKLM\Software\JDownloader Default=False FileKey1=%ProgramFiles%\JDownloader\config|*.* [JDownloader DLC*] LangSecRef=3022 DetectFile1=%UserProfile%\.jd_home\ Detect=HKLM\Software\JDownloader Default=False FileKey1=%ProgramFiles%\JDownloader\container|*.* [JDownloader Downloads*] LangSecRef=3022 DetectFile1=%UserProfile%\.jd_home\ Detect=HKLM\Software\JDownloader Default=False FileKey1=%ProgramFiles%\JDownloader\downloads|*.* [JDownloader Logs*] LangSecRef=3022 DetectFile1=%UserProfile%\.jd_home\ Detect=HKLM\Software\JDownloader Default=False FileKey1=%ProgramFiles%\JDownloader|*.log FileKey2=%ProgramFiles%\JDownloader|*.lck FileKey3=%UserProfile%\.jd_home|*.log FileKey4=%UserProfile%\.jd_home|*.lck FileKey5=%UserProfile%\.jd_home\logs|*.0 [VirtualBox logs *] LangSecRef=3024 DetectFile=%UserProfile%\.VirtualBox\ Default=False FileKey1=%UserProfile%\.VirtualBox\|VBoxSVC.log.* FileKey2=%UserProfile%\.VirtualBox\|VBoxSVC.* FileKey3=%UserProfile%\.VirtualBox\|*.log FileKey4=%UserProfile%\VirtualBox VMs\liveboot\Logs|*.log [FlashGot*] LangSecRef=3026 SpecialDetect=DET_MOZILLA DetectFile=%AppData%\Mozilla\Firefox\Profiles\*\FlashGot.exe Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\FlashGot.log FileKey2=%AppData%\Mozilla\Firefox\Profiles\*\FlashGot.log.bak* Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 1, 2012 Author Share Posted August 1, 2012 Thanks much! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Homy Posted August 1, 2012 Share Posted August 1, 2012 I made an addition for Gretech GomPlayer. Sorry for the Crosspost, I replied to someone else and then found I should post here perhaps. http://forum.piriform.com/index.php?showtopic=28948 Link to comment Share on other sites More sharing options...
nolme Posted August 2, 2012 Share Posted August 2, 2012 Hi, I'll post here various folders I've noticed that wasn't cleaned by CCleaner accros multiple versions. Maybe some of those are already managed. C:\Program Files\Lenovo\System Update\session See : http://forums.lenovo...-p/90544/page/2 "You must keep system, temp, QuestResponse.xml and updates.ser, or else System Update won't start. You can safely delete all other directories." Size : 2.2 GB for me. C:\Windows\SoftwareDistribution\Download Contain Windows update temp folder. Size : 800 MB C:\Program Files\Google\Update\Download Google update folder Size : 22 MB %CURRENT_USER%\Application Data\Easeware\DriverEasy\drivers\*.* The driver updater DriverEasy (www.drivereasy.com) download updates. Size : 130 MB %CURRENT_USER%\Application Data\Easeware\DriverEasy\updates\*.* New software version are stored here Size : 5 MB Vincent Link to comment Share on other sites More sharing options...
Alan_B Posted August 2, 2012 Share Posted August 2, 2012 %CURRENT_USER%\Application Data\Easeware\DriverEasy\updates\*.* What is %CURRENT_USER% ? I am not aware of it and CMD.EXE fails to recognize it as a variable, and it does not seem to be used in WinApp2.ini. %APPDATA% is fully recognised and is used in WinApp2.ini. Is "%APPDATA%\" the same as "%CURRENT_USER%\Application Data\" ? Link to comment Share on other sites More sharing options...
nolme Posted August 2, 2012 Share Posted August 2, 2012 %APPDATA% is fully recognised and is used in WinApp2.ini. Is "%APPDATA%\" the same as "%CURRENT_USER%\Application Data\" ? Yes it is. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 2, 2012 Author Share Posted August 2, 2012 C:\Windows\SoftwareDistribution\Download Contain Windows update temp folder. Size : 800 MB no C:\Program Files\Google\Update\Download Google update folder Size : 22 MB I don't see this directory, but I do have one in %LocalAppData% winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nolme Posted August 3, 2012 Share Posted August 3, 2012 C:\Windows\SoftwareDistribution\Download : Depends on your computer. On a fresh Windows Vista installation, it may be huge. For Google, Maybe they have changed it. Can't we add both of them ? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 3, 2012 Moderators Share Posted August 3, 2012 C:\Windows\SoftwareDistribution\Download : Depends on your computer. On a fresh Windows Vista installation, it may be huge. this has been previously discussed to death, Microsoft states that that area should not be cleaned ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 3, 2012 Author Share Posted August 3, 2012 If users want to clean it on their own, they can. I've done it without ill-effect, Winapp2.ini gets hundreds of thousands of downloads a month, most likely many of those don't understand the implications, and they'll come here asking about it. Probably just too much of a headache. I'll add the ProgramFiles directory to the Google Update entry winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
rohk Posted August 4, 2012 Share Posted August 4, 2012 My entries for Nokia Suite. [Nokia Suite Installer Cache*] LangSecRef=3021 DetectFile=%CommonAppData%\NokiaInstallerCache Default=False FileKey1=%CommonAppData%\NokiaInstallerCache\PackageCache|*.*|RECURSE FileKey2=%CommonAppData%\NokiaInstallerCache\ProductCache|*.log|RECURSE [Nokia Suite Updater Cache*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Nokia\Nokia Suite Warning=This will remove Nokia phone firmwares, applications and all other files stored by Nokia Suite Updater. Files will be re-downloaded when updating phone next time. Default=False FileKey1=%CommonAppData%\Nokia\Nokia Suite\NOSSU2|*.*|RECURSE ExcludeKey1=FILE|%CommonAppData%\Nokia\Nokia Suite\NOSSU2\Flash|*.* ExcludeKey2=FILE|%CommonAppData%\Nokia\Nokia Suite\NOSSU2\usergroups.cfg Tested on vista. Locations on Xp should be the same according to nokia forums. Edit: Both entries had own problems. Edited them and now repair install and uninstall works, as well as the updater. Should have tested more before posting! Entry for old Nokia Software Updater 3, which is not anymore available by nokia as it is included in the new Nokia Suite. By google search, it can be still downloaded and used. [Nokia Software Updater 3 Cache*] LangSecRef=3021 Detect=HKCU\Software\Nokia\NSU3 Warning=This will remove Nokia phone firmwares, applications and all other files stored by Nokia Software Updater. Files will be re-downloaded when updating phone next time. Default=False FileKey1=%LocalAppData%\Nokia\NSU3\NOSSU2|*.*|RECURSE ExcludeKey1=FILE|%LocalAppData%\Nokia\NSU3\NOSSU2\Flash|*.* ExcludeKey2=FILE|%LocalAppData%\Nokia\NSU3\NOSSU2\usergroups.cfg Also I had files stored on my system by older version of Nokia Software Updater (~200mb) which paths are not used on newer versions. Found older version also by google, but it couldn't be used anymore. Updating to new version or closing the program were the only options available. [Nokia Software Updater Cache - Old Versions*] LangSecRef=3021 DetectFile1=%CommonAppData%\Nokia\Nokia Service Layer\A DetectFile2=%CommonProgramFiles%\Nokia\Service Layer\A Warning=This will remove all files stored by old version of Nokia Software Updater, which is no longer supported or available. Default=False FileKey1=%CommonAppData%\Nokia\Nokia Service Layer\A|*.*|REMOVESELF FileKey2=%CommonProgramFiles%\Nokia\Service Layer\A|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 4, 2012 Moderators Share Posted August 4, 2012 New: [metapad*] LangSecRef=3021 Detect=HKCU\Software\metapad Default=False RegKey1=HKCU\Software\metapad|szLastDirectory Link to comment Share on other sites More sharing options...
FreddeVries Posted August 5, 2012 Share Posted August 5, 2012 @rohk %CommonAppData% is an entry that only works in W7 and not in XP. To make it work in XP (and Vista?) you need to rework these entries. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 5, 2012 Moderators Share Posted August 5, 2012 %CommonAppData% is an entry that only works in W7 and not in XP. To make it work in XP (and Vista?) you need to rework these entries. In CCleaner it does not matter as it will properly know where to look, otherwise on my XP system dozens of cleaners I've made wouldn't even work: %CommonAppData% = The All User Profile Link to comment Share on other sites More sharing options...
rohk Posted August 5, 2012 Share Posted August 5, 2012 The environment path %ProgramData% works only in vista/7, and not it Xp. But in DetectFile paths section it is stated that, %CommonAppData%Windows XP: C:\Documents and Settings\All Users\Application Data Windows Vista/7: C:\ProgramData This was just what I needed for my entries. Isn't this the right way to use the %CommonAppData%? Btw here are all the paths for windows xp: nokia installer cache C:\documents and settings\All users\Application Data\NokiaInstallerCache nokia suite updater C:\Documents and Settings\All Users\Application Data\Nokia\Nokia Suite\NOSSU2 nokia software updater 3 C:\Documents and Settings\<USERNAME>\Local Settings\Application Data\Nokia\NSU3\NOSSU2 old nokia software updater C:\Documents and Settings\All Users\Application Data\Nokia\Nokia Service Layer\A C:\Program Files\Common Files\Nokia\Service Layer\A Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 5, 2012 Author Share Posted August 5, 2012 As Andavari said, %CommonAppData% is properly handled by CCleaner when used on different systems. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted August 8, 2012 Share Posted August 8, 2012 MODIFIED ENTRY [Freemake Video Downloader More*] LangSecRef=3022 Detect=HKCU\Software\Freemake\FreemakeVideoDownloader Default=False FileKey1=%ProgramFiles%\Freemake\Freemake Video Downloader|*.log FileKey2=%Program Files (x86)%\Freemake\Freemake Video Downloader|*.log FileKey3=%Documents%\Freemake\FreemakeVideoDownloader|fvd.bin FileKey4=%Documents%\Freemake\FreemakeVideoDownloader\History\Thumbnails|*.* FileKey5=%Documents%\Freemake\FreemakeVideoDownloader\History|*.xml Link to comment Share on other sites More sharing options...
CSGalloway Posted August 12, 2012 Share Posted August 12, 2012 I search my hard drive for *.bak and *.tmp files and would like help in creating Winapp2.ini entries to remove them please. C:\Documents and Settings\All Users\Application Data\Microsoft\OFFICE\DATA\OPA11.BAK C:\Documents and Settings\Charles\Application Data\Microsoft\File Transfer Manager\ftmTransferList.txt.bak C:\Documents and Settings\Charles\Local Settings\jv16PT_temp.tmp C:\Documents and Settings\Charles\Local Settings\Temp\DIO4.tmp C:\Documents and Settings\Charles\Local Settings\Temp\DIO9.tmp C:\Documents and Settings\Charles\Local Settings\Temp\MAR1.tmp C:\Documents and Settings\Charles\Local Settings\Temp\MAR2.tmp C:\Documents and Settings\Charles\Local Settings\Temp\REG1A0.tmp C:\Documents and Settings\Charles\Local Settings\Temp\REG1A1.tmp C:\Documents and Settings\Charles\Local Settings\Temp\REG19A.tmp C:\Documents and Settings\Charles\Local Settings\Temp\REG19B.tmp C:\Documents and Settings\Charles\Local Settings\Temp\REG19C.tmp C:\Documents and Settings\Charles\Local Settings\Temp\REG19E.tmp C:\Documents and Settings\Charles\Local Settings\Temp\REG19F.tmp C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.tmp C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.tmp C:\Program Files\Google\GoogleToolbarNotifier\GooA32.tmp C:\Program Files\Google\GoogleToolbarNotifier\5.7.6406.1642\gthA2B.tmp C:\Program Files\Google\GoogleToolbarNotifier\5.7.6406.1642\gtnA2A.tmp C:\Program Files\Google\GoogleToolbarNotifier\5.7.6406.1642\swgA29.tmp C:\Program Files\Google\GoogleToolbarNotifier\5.7.7018.1622\gthA2E.tmp C:\Program Files\Google\GoogleToolbarNotifier\5.7.7018.1622\gtnA2D.tmp C:\Program Files\Google\GoogleToolbarNotifier\5.7.7018.1622\swgA2C.tmp C:\Program Files\Google\GoogleToolbarNotifier\5.7.7227.1100\gthA31.tmp C:\Program Files\Google\GoogleToolbarNotifier\5.7.7227.1100\gtnA30.tmp C:\Program Files\Google\GoogleToolbarNotifier\5.7.7227.1100\swgA2F.tmp C:\Program Files\Secunia\PSI\RCX3CA.tmp C:\Program Files\TuneXP\docs\hardware.html.bak C:\Program Files\TuneXP\docs\memoryfs.html.bak C:\Program Files\Yahoo!\Messenger\Cache\9G0IMTf7KSnOtr1pRkveNQ--.ProfileMap.dat.tmp C:\RECYCLER\S-1-5-21-1202660629-854245398-1801674531-1003\Dc1.bak C:\RECYCLER\S-1-5-21-1202660629-854245398-1801674531-1003\Dc2.bak C:\WINDOWS\msdownld.tmp C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP2A.tmp C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP6B.tmp C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP14.tmp C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP74D.tmp C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP80.tmp C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP113A.tmp C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP229.tmp C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP349.tmp C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAPDB.tmp C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAPF21.tmp C:\WINDOWS\pchealth\helpctr\Config\Cache\Professional_32_1033.dat.bak C:\WINDOWS\system32\REN72.tmp C:\WINDOWS\system32\wuapi.dll.wusetup.139324421.bak C:\WINDOWS\system32\wuauclt.exe.wusetup.139325171.bak C:\WINDOWS\system32\wuaueng.dll.wusetup.139325937.bak C:\WINDOWS\system32\NtmsData\NTMSDATA.BAK Thanks in advance Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 12, 2012 Moderators Share Posted August 12, 2012 @ CSGalloway If you delete this file, you WILL have to reinstall Microsoft Office: C:\Documents and Settings\All Users\Application Data\Microsoft\OFFICE\DATA\OPA11.BAK CCleaner should already be deleting stuff in here by default (make sure you have enabled/ticked in the large Cleaner button: Windows->System->Temporary Files): C:\Documents and Settings\Charles\Local Settings\Temp\ I also have this file, but have no ideal if it's safe to remove or not, which is why I've left it alone on my system, more noteworthy many disk cleaning tools that religiously target the .BAK extension don't even offer to clean it: C:\WINDOWS\system32\NtmsData\NTMSDATA.BAK Link to comment Share on other sites More sharing options...
CSGalloway Posted August 12, 2012 Share Posted August 12, 2012 @ CSGalloway If you delete this file, you WILL have to reinstall Microsoft Office: C:\Documents and Settings\All Users\Application Data\Microsoft\OFFICE\DATA\OPA11.BAK CCleaner should already be deleting stuff in here by default (make sure you have enabled/ticked in the large Cleaner button: Windows->System->Temporary Files): C:\Documents and Settings\Charles\Local Settings\Temp\ I also have this file, but have no ideal if it's safe to remove or not, which is why I've left it alone on my system, more noteworthy many disk cleaning tools that religiously target the .BAK extension don't even offer to clean it: C:\WINDOWS\system32\NtmsData\NTMSDATA.BAK re: OPA11.BAK I have Microsfot Ofice Standard Edition 2003 - not sure if this file can be removed or not. re: NTMSDATA.BAK look at http://www.google.com/search?sourceid=navclient&aq=f&oq=NTMSDATA.BAK&ie=UTF-8&rlz=1T4GGHP_enUS442US442&q=NTMSDATA.BAK&gs_upl=0l0l0l2000lllllllllll0&aqi=g-K1 Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 12, 2012 Moderators Share Posted August 12, 2012 re: OPA11.BAK I have Microsfot Ofice Standard Edition 2003 - not sure if this file can be removed or not. Like I've already stated if you delete it then Microsoft Office is going to need reinstalled, no way around that as I've been there and done that in the past which is why in EasyCleaner I have it ignored. re: NTMSDATA.BAK look at http://www.google.co...lllll0&aqi=g-K1 That Google search doesn't tell me much though. It isn't some piece of malware on my system as most of those search results seem to think. Possibly just some junk file created by Windows, and looking at it in a hex editor doesn't reveal much either. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 12, 2012 Moderators Share Posted August 12, 2012 I'm not convinced that ntmsdata.bak is safe for regular cleaning but only in extreme cases such as http://support.microsoft.com/default.aspx?scid=kb;EN-US;235032 ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 13, 2012 Moderators Share Posted August 13, 2012 On my system NTMSDATA.BAK is identical to the regular one without an extension "NTMSDATA", they have matching MD5 / SHA-1 checksums. That and AVG Free and MBAM find nothing wrong with it and neither does Jotti or VirSCAN.org. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 13, 2012 Author Share Posted August 13, 2012 I'm hoping to do an update in the next 24 hours, just a heads up winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 13, 2012 Moderators Share Posted August 13, 2012 After being annoyed by the Notepad window size which wouldn't remember my settings I came up with this new cleaning entry: [MS Notepad*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Notepad Default=False Warning=If Notepad stops remembering your window size settings using this cleaner will reset it back to the original Windows default size. RegKey1=HKCU\Software\Microsoft\Notepad|iWindowPosDX RegKey2=HKCU\Software\Microsoft\Notepad|iWindowPosDY RegKey3=HKCU\Software\Microsoft\Notepad|iWindowPosX RegKey4=HKCU\Software\Microsoft\Notepad|iWindowPosY Link to comment Share on other sites More sharing options...
