Moderators Andavari Posted August 22, 2012 Moderators Share Posted August 22, 2012 Updated (added RegKey1): [Paint.NET More*] LangSecRef=3021 Detect=HKCU\Software\Paint.NET Default=False FileKey1=%LocalAppData%\Paint.NET|*.*|RECURSE RegKey1=HKCU\Software\Paint.NET|LastFileDialogDirectory Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 22, 2012 Author Share Posted August 22, 2012 Thanks Andavari (and you're the 2000th reply in the thread, isn't that special!) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
jonjonjon Posted August 23, 2012 Share Posted August 23, 2012 why would one consider app specific settings as junk, they must be manually set so who would want them cleaned every time ccleaner, or any time, ran no. its keeps a list of every program you have run under those keys. a side effect of deleting them is it will also remove the app-specific settings. maybe you should install it and look before commenting. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 23, 2012 Author Share Posted August 23, 2012 No need to be rude; I understood what it does, but your original post was slightly ambiguous. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
rohk Posted August 23, 2012 Share Posted August 23, 2012 Entries for Adblock Lite addon (a fork of the Adblock Plus): [Adblock Lite Backups*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\adblocklite|patterns-backup*.ini [Pale Moon - Adblock Lite Backups*] LangSecRef=3026 Detect=HKLM\Software\Mozilla\Pale Moon DetectFile=%ProgramFiles%\Pale Moon\palemoon.exe Default=False FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*\adblocklite|patterns-backup*.ini Edit: should these detect the folder of the the addon instead? It isn't that commonly used compared to the Plus version. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 23, 2012 Moderators Share Posted August 23, 2012 Thanks Andavari (and you're the 2000th reply in the thread, isn't that special!) Thanks. My mom has always said I was "special", but I don't think she meant it in a nice way. Link to comment Share on other sites More sharing options...
FreddeVries Posted August 24, 2012 Share Posted August 24, 2012 [sun Java Cache*] LangSecRef=3022 DetectOS=6.0 Detect=HKLM\SOFTWARE\JavaSoft\Java Runtime Environment Default=False FileKey1=%LocalLowAppData%\Sun\Java\Deployment\SystemCache|*.*|RECURSE FileKey2=%WinDir%\System32\SystemProfile\AppData\LocalLow\Sun\Java\Development\Cache|*.*|RECURSE FileKey3=%WinDir%\SysWOW64\SystemProfile\AppData\LocalLow\Sun\Java\Development\Cache|*.*|RECURSE Removed original FileKey1 (FileKey1=%LocalLowAppData%\Sun\Java\Deployment\cache|*.*|RECURSE) because it is already in winapp.ini (FileKey1=%appdata%\Sun\Java\Deployment\cache|*.*|RECURSE) Link to comment Share on other sites More sharing options...
nodles Posted August 24, 2012 Share Posted August 24, 2012 [sun Java Cache*] LangSecRef=3022 DetectOS=6.0 Detect=HKLM\SOFTWARE\JavaSoft\Java Runtime Environment Default=False FileKey1=%LocalLowAppData%\Sun\Java\Deployment\SystemCache|*.*|RECURSE FileKey2=%WinDir%\System32\SystemProfile\AppData\LocalLow\Sun\Java\Development\Cache|*.*|RECURSE FileKey3=%WinDir%\SysWOW64\SystemProfile\AppData\LocalLow\Sun\Java\Development\Cache|*.*|RECURSE Removed original FileKey1 (FileKey1=%LocalLowAppData%\Sun\Java\Deployment\cache|*.*|RECURSE) because it is already in winapp.ini (FileKey1=%appdata%\Sun\Java\Deployment\cache|*.*|RECURSE) Those are different paths? %appdata% = C:\Users\username\AppData\Roaming %LocalLowAppData% (which didn't work when typed to run, but works in CCleaner) = C:\Users\username\AppData\LocalLow Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 24, 2012 Author Share Posted August 24, 2012 [educated guess with emphasis on guess]I think it never materialized because each ini file is formatted differently[/EDWEOG] late response here, but my understanding is ini's are all formatted the same way, that being [Header] ItemOne=Value That's how it worked when I used to script in mIRC Scripting Language for funsies, and how CCleaner uses it, and numerous other programs I've seen. I may be wrong though. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 24, 2012 Author Share Posted August 24, 2012 Updated! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
amckern Posted August 25, 2012 Share Posted August 25, 2012 Just a question - what will the "Windows XP System Profile*" clean? Link to comment Share on other sites More sharing options...
siliconman01 Posted August 25, 2012 Share Posted August 25, 2012 DetectOS corrected in "Windows XP System Profile" so that this cleaner does not display on non-XP systems. [Windows XP System Profile*] LangSecRef=3025 DetectOS=|5.1 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%windir%\system32\config\systemprofile\Cookies|*.*|RECURSE FileKey2=%windir%\system32\config\systemprofile\IETldCache|*.*|RECURSE FileKey3=%windir%\system32\config\systemprofile\Local Settings\History|*.*|RECURSE FileKey4=%windir%\system32\config\systemprofile\Local Settings\Temp|*.*|RECURSE FileKey5=%windir%\system32\config\systemprofile\Local Settings\Temporary Internet Files|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted August 25, 2012 Share Posted August 25, 2012 You forgot to modify this one: http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=219285 Link to comment Share on other sites More sharing options...
APMichael Posted August 25, 2012 Share Posted August 25, 2012 (edited) Thanks for the update. But you accidentally missed following posts/entries again. Is it possible that you release a "hotfix" update, please? Missed posts: - #1824 (2 new entries: [Xmarks Sync Log*], [HTC Sync*]) - #1875 (2 modified entries: [Apple Installer Cache*], [DivX Player*]) - #1879 (new entry: [NetworkService Temps*]) - #1926 (modified "JDownloader" entries) - #1942 (modified entry: [Freemake Video Downloader More*]) - #1959 (modified entry: [Config.msi Folder*]) - #1960 (3 new entries: [Emsisoft HiJackFree*], [ultraDefrag Portable (Log)*], [Windows ESENT Process (MRU)*]) Modified entry: [FlashGot*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*|FlashGot.log FileKey2=%AppData%\Mozilla\Firefox\Profiles\*|FlashGot.log.bak* Modified entry: [spybot Search and Destroy History*] LangSecRef=3024 Detect=HKLM\Software\Safer Networking Limited\SpybotSnD Default=False FileKey1=%CommonAppData%\Spybot – Search & Destroy\Backups|*.*|RECURSE FileKey2=%CommonAppData%\Spybot – Search & Destroy\Recovery|*.*|RECURSE FileKey3=%CommonAppData%\Spybot – Search & Destroy\Snapshots|*.*|RECURSE FileKey4=%CommonAppData%\Spybot – Search & Destroy\Snapshots2|*.*|RECURSE Rename suggestion: - Please rename [TuneUp XP*] to [TuneXP*]. Missing blank lines: - Above the entry [Windows Audio/Video (Stats)*] is a blank line missing. - Above the entry [WinHasher*] is a blank line missing. Edited August 25, 2012 by APMichael Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 25, 2012 Moderators Share Posted August 25, 2012 late response here, but my understanding is ini's are all formatted the same way, that being [Header] ItemOne=Value That's how I've always seen INI and CFG files formatted when they're following "standards." I know many of us would like to have the ability for CCleaner to remove MRU items, etc., from INI and CFG settings files. One workaround I've did previously but it would have to be tested by someone using a particular software that uses INI or CFG is to make all your settings you want for that particular software, then manually remove any MRU items, and finally set the INI/CFG file to read-only. Note that some software will ignore the read-only attribute and update it anyways, while others may complain, freeze, or even crash. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 25, 2012 Moderators Share Posted August 25, 2012 DetectOS corrected in "Windows XP System Profile" so that this cleaner does not display on non-XP systems. Arrh, I missed putting in that stupid Pipe symbol. Good catch. Just a question - what will the "Windows XP System Profile*" clean? It cleans everything in these folders: C:\Windows\system32\config\systemprofile\Cookies C:\Windows\system32\config\systemprofile\IETldCache C:\Windows\system32\config\systemprofile\Local Settings\History C:\Windows\system32\config\systemprofile\Local Settings\Temp C:\Windows\system32\config\systemprofile\Local Settings\Temporary Internet Files Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 25, 2012 Author Share Posted August 25, 2012 - #1942 (modified entry: [Freemake Video Downloader More*]) The change proposed there will have no effect, having %ProgramFiles% and %ProgramFiles(x86)% is redundant (as we learned many, many moons ago) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted August 26, 2012 Share Posted August 26, 2012 Thank you for your reply. I just listed the missed posts and didn't check them for mistakes, sorry! Maybe saad2011 can tell us why he added this FileKey. Link to comment Share on other sites More sharing options...
rohk Posted August 26, 2012 Share Posted August 26, 2012 [Nexus Mod Manager Trace Logs*] LangSecRef=3021 DetectFile=%Documents%\Nexus Mod Manager Default=False FileKey1=%Documents%\Nexus Mod Manager|TraceLog*.txt Tested on xp. Couldn't find any reg key for detection. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 26, 2012 Author Share Posted August 26, 2012 Thanks! I wont be adding http://forum.piriform.com/index.php?showtopic=32310&st=1920&p=218865entry218865 because it re-adds DetectFiles i previously removed, unless for some reason, the registry keys are not always created. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted August 27, 2012 Share Posted August 27, 2012 Thank you for your reply. I just listed the missed posts and didn't check them for mistakes, sorry! Maybe saad2011 can tell us why he added this FileKey. It was a mistake. Link to comment Share on other sites More sharing options...
SMalik Posted August 27, 2012 Share Posted August 27, 2012 New Entry [PowerISO More*] LangSecRef=3024 Detect=HKCU\Software\PowerISO Default=False FileKey1=%AppData%\PowerISO\Upgrade|*.*|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 27, 2012 Author Share Posted August 27, 2012 Thanks saad! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted August 27, 2012 Share Posted August 27, 2012 @saad2011: Thanks for your reply. New entry: [APC PowerChute Personal Edition*] LangSecRef=3024 Detect=HKCU\Software\APC\PowerChute Personal Edition Default=False FileKey1=%ProgramFiles%\APC\PowerChute Personal Edition|PCPELog.txt FileKey2=%WinDir%\System32|PCPELog.txt FileKey3=%WinDir%\SysWOW64|PCPELog.txt Link to comment Share on other sites More sharing options...
ricktendo64 Posted August 28, 2012 Share Posted August 28, 2012 New entry: [AIDA64 Reports*] LangSecRef=3021 Detect=HKCU\Software\FinalWire\AIDA64 Default=False FileKey1=%Documents%\AIDA64 Reports|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
