nodles Posted April 29, 2012 Share Posted April 29, 2012 NEW ENTRY: [Tweaking.com Windows Repair*] LangSecRef=3024 DetectFile=%SystemDrive%\Tweaking.com_Windows_Repair_Logs Default=False FileKey1=%SystemDrive%\Tweaking.com_Windows_Repair_Logs|*.* Link to comment Share on other sites More sharing options...
nodles Posted April 29, 2012 Share Posted April 29, 2012 NEW ENTRY: [installShield Installation Information*] LangSecRef=3024 DetectFile=%ProgramFiles%\InstallShield Installation Information Default=False FileKey1=%ProgramFiles%\InstallShield Installation Information|*.log|RECURSE Link to comment Share on other sites More sharing options...
Hav0c Posted April 29, 2012 Share Posted April 29, 2012 NEW ENTRY: [ESET NOD32 Antivirus*] LangSecRef=3021 Detect=HKLM\SOFTWARE\ESET\ESET Security Default=False FileKey1=%CommonAppData%\ESET\ESET NOD32 Antivirus\updfiles|*.*|RECURSE FileKey2=%CommonAppData%\ESET\ESET NOD32 Antivirus\Logs|*.*|RECURSE FileKey3=%CommonAppData%\ESET\ESET NOD32 Antivirus\Oldfiles|*.*|RECURSE NOTE: don't know if this should come with a warning as ESET stated You should be able to delete the folder updfiles but I would recommend to do this in safe mode for the antivirus package alternatively if you wish to delete the updfiles folder for ESET Remote Administrator then remeber to stop the ERA service. Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to comment Share on other sites More sharing options...
siliconman01 Posted May 1, 2012 Share Posted May 1, 2012 New Entry: [spywareBlaster Update File*] LangSecRef=3024 DetectFile=%ProgramFiles%\SpywareBlaster\sbautoupdate.exe Default=False Warning=This deletes SWB program updater file spywareblasterupgrade_latest.exe which is no longer needed once a SWB program version update occurs. FileKey1=%ProgramFiles%\SpywareBlaster\|spywareblasterupgrade_latest.exe This is for security program SpywareBlaster, licensed version with automatic updates. File spywareblasterupgrade_latest.exe is generated when a new SWB version is automatically downloaded and installed. Once the upgrade occurs the file is no longer needed. (See the forum discussion at the link below.) Although it is supposed to be automatically removed on the next reboot, the file is left hanging on my Windows 7 SP1 x64 and x86 Professional systems. So I assume that others have a similar unneccessary file. http://www.wildersse...ad.php?t=323061 Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
2nd base Posted May 2, 2012 Share Posted May 2, 2012 [Windows Live Movie Maker Recent List*] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Windows Live\Movie Maker Default=False RegKey1=HKCU\Software\Microsoft\Windows Live\Movie Maker\Recent should be tested more to make sure it rebuilds the recent key after clearing. via www.windowsmoviemakers.net/Forums/ShowPost.aspx?PostID=251089 and http://answers.micro...5e-39c413188ed0 Program has rebuilt the list. Thanks again. Link to comment Share on other sites More sharing options...
Berntsson Posted May 2, 2012 Share Posted May 2, 2012 I hope I'm in the right section... I'd like to request an addition, or instructions on how to add the following registry key(s). These keys list all the network adapters that have been installed on a machine. On XP they also list the connection information of the access points connected to. On Win7 those connections are in a folder that can be wiped using CCleaner's custom folder/file option. It is: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WZCSVC\Parameters\Interfaces\[interface Guid] The folder is: C:\ProgramData\Microsoft\Wlansvc\Profiles\Interfaces\[interface Guid] The registry key appears in several other places, but I'm not a registry expert...but it is always the same (WZCSVC\Parameters, etc...) Just looking at deleting the Guid's, leaving the main key. Deleting these does no permanent harm, the adapter gets re-created on boot, but I think it's a good privacy measure to delete them. http://www.iccyber.o...P_Eric_Rowe.pdf This is another key: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\Tcpip\Parameters\Interfaces I haven't tested if deleting these Guid's causes a problem or not. Thanks Link to comment Share on other sites More sharing options...
siliconman01 Posted May 3, 2012 Share Posted May 3, 2012 Non-functioning Belarc* needs to be modified to the following code: [belarc*] LangSecRef=3024 Detect=HKCU\Software\Belarc Default=False FileKey1=%ProgramFiles%\Belarc\Advisor\|INSTALL.Log FileKey2=%ProgramFiles%\Belarc\Advisor\System\|Progress.Log FileKey3=%ProgramFiles%\Belarc\Advisor\System\Tmp\|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 3, 2012 Author Share Posted May 3, 2012 thanks winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 3, 2012 Moderators Share Posted May 3, 2012 This is another key: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\Tcpip\Parameters\Interfaces I haven't tested if deleting these Guid's causes a problem or not. That's where your default Gateway, etc., reside to use the Internet, and I'd think wiping out the whole thing would possibly cause issues. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 3, 2012 Moderators Share Posted May 3, 2012 I haven't tested if deleting these Guid's causes a problem or not. Quick Reminder to EVERYBODY, please do not submit untested entries. Thanks MGMT ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 3, 2012 Author Share Posted May 3, 2012 Thanks, MGMT! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 3, 2012 Moderators Share Posted May 3, 2012 Actually as I left out the comma I believe I may have been thanking http://en.wikipedia....thyltransferase LOL MGMT has also been shown to be a useful tool increasing gene therapy efficiency. By using a two component vector consisting of a transgene of interest and MGMT, in vivo drug selection can be utilized to select for successfully transduced cells ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
APMichael Posted May 4, 2012 Share Posted May 4, 2012 I'm back from my vacation. Thanks for the update. Following two suggestions are missed: Please change the following entry, because RegKey2 and 3 are included in winapp.ini of CCleaner now: [Windows Media Player (MediaGuide)*] LangSecRef=3023 Detect=HKCU\Software\Microsoft\MediaPlayer Default=True RegKey1=HKCU\Software\Microsoft\MediaPlayer\Preferences|CurrentBackgroundScanFolder RegKey2=HKCU\Software\Microsoft\MediaPlayer\Services\MediaGuide|CachedIconPath RegKey3=HKCU\Software\Microsoft\MediaPlayer\Services\MediaGuide|CachedLargeLogoPath I think you can remove the following entry, because RegKey and FileKey are included in winapp.ini of CCleaner (for Office 2003, 2007 and 2010): [MS Office Temp Files*] LangSecRef=3021 Detect=HKCU\Software\Microsoft\Office Default=False RegKey1=HKCU\Software\Microsoft\Office\Common|FontBmpCache FileKey1=%AppData%\Microsoft\Office|*.tmp|RECURSE And between the entries [Windows Log Files More*] and [Windows Mail*] is no blank line. Link to comment Share on other sites More sharing options...
nodles Posted May 5, 2012 Share Posted May 5, 2012 NEW ENTRY: [TomTom*] LangSecRef=3021 Detect=HKCU\Software\TomTom Default=False FileKey1=%AppData%\TomTom\HOME\Profiles\*|Log.txt Link to comment Share on other sites More sharing options...
nodles Posted May 6, 2012 Share Posted May 6, 2012 MODIFIED ENTRIES: [batman: Arkham City*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Warner Bros\Batman Arkham City Default=False FileKey1=%Documents%\WB Games\Batman Arkham City\BmGame\Logs|*.* <-Changed DetectFile to Detect. [battlefield 3*] LangSecRef=3021 Detect=HKLM\SOFTWARE\EA Games\Battlefield 3 Default=False FileKey1=%ProgramFiles%\Origin Games\Battlefield 3\__Installer|InstallLog.txt <-Changed DetectFile to Detect. [League of Legends*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Riot Games\League of Legends Default=False FileKey1=%HomeDrive%\Riot Games\League of Legends\rads|*.log* FileKey2=%HomeDrive%\Riot Games\League of Legends\rads\solutions\lol_game_client_sln\releases\0*\deploy|*.log FileKey3=%HomeDrive%\Riot Games\League of Legends\rads\solutions\lol_game_client_sln\releases\0*\deploy|*.txt FileKey4=%HomeDrive%\Riot Games\League of Legends\rads\projects\lol_air_client\releases\0*\deploy\logs|*.log FileKey5=%HomeDrive%\Riot Games\League of Legends\rads\projects\lol_launcher\releases\0*\deploy|*.log FileKey6=%HomeDrive%\Riot Games\League of Legends\rads\projects\lol_launcher\releases\0*\deploy\temp|*.tmp FileKey7=%HomeDrive%\Riot Games\League of Legends\Logs|*.txt|RECURSE FileKey8=%UserProfile%\riotsGamesLogs|*.log <-Changed entry name & changed DetectFile to Detect. Merged with entry [Riot Games Logs*] which can be removed. [Origin*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Origin Default=False FileKey1=%CommonAppData%\Origin\Logs|*.* FileKey2=%CommonAppData%\Origin\DownloadCache|*.*|RECURSE FileKey3=%CommonAppData%\Origin\AvatarsCache|*.*|RECURSE FileKey4=%LocalAppData%\Origin\Web Cache|*.*|RECURSE FileKey5=%SystemDrive%|shared.log <-Changed DetectFile to Detect. [star Wars: The Old Republic*] LangSecRef=3021 Detect=HKLM\SOFTWARE\BioWare\Star Wars-The Old Republic Default=False FileKey1=%Documents%|Install STAR WARS The Old Republic.log FileKey2=%LocalAppData%\SWTOR\CrashDump\swtor|*.* FileKey3=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\betatest\retailclient\Temp|*.log FileKey4=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\logs|*.log FileKey5=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\swtor\retailclient\swtor\logs|*.log FileKey6=%Documents%|Uninstall STAR WARS The Old Republic.log FileKey7=%ProgramFiles%\Origin Games\Star Wars - The Old Republic\swtor\retailclient\swtor\logs|*.* FileKey8=%ProgramFiles%\Origin Games\Star Wars - The Old Republic\logs|*.* FileKey9=%ProgramFiles%\Origin Games\Star Wars - The Old Republic\__Installer|InstallLog.txt <-Changed DetectFile to Detect. [Windows Live Messenger Chat History*] LangSecRef=3022 Detect=HKLM\SOFTWARE\Microsoft\Windows Live\Messenger Warning=Removes Windows Live Messenger chat history! Default=False FileKey1=%Documents%\My Received Files\*\History|*.* <-Changed DetectFile to Detect. [Windows Live Messenger More*] LangSecRef=3022 Detect=HKLM\SOFTWARE\Microsoft\Windows Live\Messenger Warning=After running this, you will not be able to uninstall Windows Live Essentials components without downloading the installer again. Default=False FileKey1=%LocalAppData%\Microsoft\Messenger|*.uccapilog|RECURSE FileKey2=%LocalAppData%\Microsoft\Messenger|*.bak|RECURSE FileKey3=%LocalAppData%\Microsoft\Messenger|*.txt|RECURSE FileKey4=%LocalAppData%\Microsoft\Windows Live Contacts|*.log|RECURSE FileKey5=%LocalAppData%\Microsoft\Windows Live Contacts|*.jrs|RECURSE FileKey6=%LocalAppData%\Microsoft\Windows Live|*.log|RECURSE FileKey7=%LocalAppData%\Microsoft\Windows Live|*.jrs|RECURSE FileKey8=%CommonProgramFiles%\Windows Live\.cache|*.*|RECURSE FileKey9=%LocalLowAppData%\Microsoft\Windows Live\Setup|*.*|REMOVESELF FileKey10=%LocalAppData%\Microsoft\Windows Live|*.sqm|RECURSE FileKey11=%LocalAppData%\Microsoft\Windows Live Contacts\*\*\*\Backup|*.*|RECURSE FileKey12=%ProgramFiles%\Windows Live\Messenger|*.bak|RECURSE FileKey13=%WinDir%\System32\config\systemprofile\Documents|wlidsvctrace*.txt <-Changed DetectFile to Detect. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 6, 2012 Author Share Posted May 6, 2012 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Coffee4Joe Posted May 6, 2012 Share Posted May 6, 2012 Modified Added FileKey2 after snapshot 12w18a, single player will run as a local server [Minecraft*] LangSecRef=3021 DetectFile=%AppData%\.minecraft Default=False FileKey1=%AppData%\.minecraft\stats|*.old FileKey2=%AppData%\.minecraft\server|server.log Link to comment Share on other sites More sharing options...
Hav0c Posted May 7, 2012 Share Posted May 7, 2012 MODIFIED ENTRIES: <-Changed DetectFile to Detect. [Tracks Eraser Pro Log*] LangSecRef=3024 Detect=HKLM\Software\Acesoft\tracks eraser pro Default=False FileKey1=%ProgramFiles%\Acesoft\Tracks Eraser Pro|te.log <-Changed DetectFile to Detect. [K-Lite Codec Pack Install Log*] LangSecRef=3023 Detect=HKLM\Software\KLCodecPack Default=False FileKey1=%ProgramFiles%\K-Lite Codec Pack|install.log <-Changed DetectFile to Detect. [WinASO Registry Optimizer (Backups)*] LangSecRef=3024 Detect=HKLM\Software\WinASO\Registry Optimizer Default=False FileKey1=%ProgramFiles%\WinASO\Registry Optimizer\backup|*.*|RECURSE <-Changed DetectFile to Detect. [spybot Search and Destroy Hosts Backups*] LangSecRef=3024 Detect=HKLM\Software\Safer Networking Limited\SpybotSnD Default=False FileKey1=%WinDir%\System32\drivers\etc|hosts.*.backup <-Changed DetectFile to Detect. [spybot Search And Destroy Updates*] LangSecRef=3024 Detect=HKLM\Software\Safer Networking Limited\SpybotSnD Default=False FileKey1=%ProgramFiles%\Spybot - Search & Destroy\Updates|*.zip Question: Does changing DetectFile to Detect make such a huge difference that all has to be Detect ? Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to comment Share on other sites More sharing options...
nodles Posted May 7, 2012 Share Posted May 7, 2012 Question: Does changing DetectFile to Detect make such a huge difference that all has to be Detect ? Thanks again, Joe! Sidenote: I did some actual testing today and although the difference is extremely small, there is a small difference in running a blank clean with Registry detections. (Using Alan_B's script to time a CCleaner.exe /AUTO run, which counts running time as well, there was about a 30ms difference on my machine. Slower machines may see better/worse speeds.) CCleaner/Winapp2.ini loads a bit faster with Detect (using registry). Link to comment Share on other sites More sharing options...
nodles Posted May 7, 2012 Share Posted May 7, 2012 Should we merge all Comodo entries into one? [Comodo Crash Dumps*] LangSecRef=3024 DetectFile=%CommonAppData%\Comodo Default=False FileKey1=%CommonAppData%\Comodo\CisDumps|*.* [Comodo Temps*] LangSecRef=3024 DetectFile=%CommonAppData%\Comodo Default=False FileKey1=%CommonAppData%\Comodo\Installer|*.* FileKey2=%CommonAppData%\Comodo Downloader|*.* [Comodo Update Temps*] LangSecRef=3024 DetectFile1=%ProgramFiles%\COMODO\COMODO Internet Security DetectFile2=%LocalAppData%\Temp\Comodo\Firewall Pro\Data\TempFiles Default=False FileKey1=%ProgramFiles%\COMODO\COMODO Internet Security|*.tmp FileKey2=%LocalAppData%\Temp\Comodo\Firewall Pro\Data\TempFiles|*.* [CSC Cache*] LangSecRef=3023 DetectFile=%AppData%\ComodoGroup\CSC Default=False FileKey1=%AppData%\ComodoGroup\CSC\Cache|*.* Here's the merged entry with Detect instead of DetectFile: [Comodo*] LangSecRef=3024 Detect=HKCU\Software\ComodoGroup Default=False FileKey1=%AppData%\ComodoGroup\CSC\Cache|*.* FileKey2=%CommonAppData%\Comodo Downloader|*.* FileKey3=%CommonAppData%\Comodo\CisDumps|*.* FileKey4=%CommonAppData%\Comodo\Installer|*.* FileKey5=%LocalAppData%\Temp\Comodo\Firewall Pro\Data\TempFiles|*.* FileKey6=%ProgramFiles%\COMODO\COMODO Internet Security|*.tmp Link to comment Share on other sites More sharing options...
nodles Posted May 7, 2012 Share Posted May 7, 2012 Same with Avira products (with other changes): [Avira More*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Avira Default=False FileKey1=%CommonAppData%\Avira|*.tmp|RECURSE FileKey2=%CommonAppData%\Avira|*.log|RECURSE FileKey3=%ProgramFiles%\Avira|*.tmp|RECURSE FileKey4=%ProgramFiles%\Avira|*.log|RECURSE FileKey5=%ProgramFiles%\Avira GmbH|*.log|RECURSE From: [AntiVir Personal 8*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Avira\AntiVir PersonalEdition Classic Default=False FileKey1=%CommonAppData%\Avira\AntiVir PersonalEdition Classic\BACKUP\FAILSAFE|*.tmp FileKey2=%CommonAppData%\Avira\AntiVir PersonalEdition Classic\LOGFILES|*.log FileKey3=%ProgramFiles%\Avira\AntiVir PersonalEdition Classic|*.tmp FileKey4=%ProgramFiles%\Avira\AntiVir PersonalEdition Classic\FAILSAFE|*.tmp [Avira AntiVir Logs*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Avira Default=False FileKey1=%ProgramFiles%\Avira\AntiVir Desktop\APPDATA\LOGFILES|*.* [Avira RootKit Detection*] LangSecRef=3024 DetectFile=%ProgramFiles%\Avira GmbH\Avira RootKit Detection\avirarkd.exe Default=False FileKey1=%ProgramFiles%\Avira GmbH\Avira RootKit Detection|*.log|RECURSE What do you think? Link to comment Share on other sites More sharing options...
nodles Posted May 7, 2012 Share Posted May 7, 2012 How about AMD/ATI? [AMD/ATI*] LangSecRef=3024 Detect=HKLM\Software\AMD Detect2=HKLM\Software\ATI Detect3=HKLM\Software\ATI Technologies Default=False FileKey1=%CommonAppData%\AMD\Fuel|*.txt FileKey2=%LocalAppData%\AMD\Fuel|ClientProxyLog*.* FileKey3=%LocalAppData%\ATI\ACE|*.txt FileKey4=%ProgramFiles%\AMD\OverDrive|*.log FileKey5=%ProgramFiles%\ATI\CIM\Reports|*.xml FileKey6=%ProgramFiles%\ATI Technologies|cccutil64.txt FileKey7=%SystemDrive%\ATI|*.*|REMOVESELF FileKey8=%SystemDrive%\AMD|*.*|REMOVESELF From: [ATI Technologies Log*] LangSecRef=3024 Detect=HKLM\Software\ATI Technologies\ Default=False FileKey1=%ProgramFiles%\ATI Technologies|cccutil64.txt [ATI/AMD Graphics Card Driver Install Logs*] LangSecRef=3024 Detect=HKLM\Software\Ati Technologies\Install\ATI Catalyst Install Manager Default=False FileKey1=%ProgramFiles%\ATI\CIM\Reports|*.xml [ATI/AMD Graphics Driver Install Files*] LangSecRef=3024 Detect=HKLM\Software\Ati Technologies\Install\ATI Catalyst Install Manager Default=False FileKey1=%SystemDrive%\ATI|*.*|REMOVESELF FileKey2=%SystemDrive%\AMD|*.*|REMOVESELF [AMD OverDrive*] LangSecRef=3024 DetectFile=%ProgramFiles%\AMD\OverDrive Default=False FileKey1=%ProgramFiles%\AMD\OverDrive|*.log [AMD ACE*] LangSecRef=3024 Detect=HKLM\Software\ATI\ACE Default=False FileKey1=%LocalAppData%\ATI\ACE|*.txt [AMD Fuel Logs*] LangSecRef=3024 Detect=HKLM\Software\AMD\Fuel Default=False FileKey1=%LocalAppData%\AMD\Fuel|ClientProxyLog*.* FileKey2=%CommonAppData%\AMD\Fuel|*.txt Link to comment Share on other sites More sharing options...
nodles Posted May 7, 2012 Share Posted May 7, 2012 MODIFIED / MERGED ENTRIES: Merged Adobe Flash entries to: [Adobe Flash More*] LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer Default=False FileKey1=%AppData%\Adobe\Flash Player\AssetCache|*.*|RECURSE FileKey2=%WinDir%\System32\Macromed\Flash|FlashInstall.log FileKey3=%WinDir%\SysWOW64\Macromed\Flash|FlashInstall.log From: [Adobe Flash Install Logs*] LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer Default=False FileKey1=%WinDir%\System32\Macromed\Flash|FlashInstall.log FileKey2=%WinDir%\SysWOW64\Macromed\Flash|FlashInstall.log [Adobe Flash Player Asset Cache*] LangSecRef=3023 Detect=HKCU\Software\Macromedia\FlashPlayer Default=False FileKey1=%AppData%\Adobe\Flash Player\AssetCache|*.*|RECURSE [Foxit Reader 5.0 More*] LangSecRef=3021 Detect=HKCU\Software\Foxit Software\Foxit Reader 5.0 Default=False RegKey1=HKCU\Software\Foxit Software\Foxit Reader 5.0\RecentFiles RegKey2=HKCU\Software\Foxit Software\Foxit Reader 5.0\Preferences\Others|csInitialOpenDir RegKey3=HKCU\Software\Foxit Software\Foxit Reader 5.0\Recent File List <-Added RegKey3. Apparently wildcards don't work with regkeys? Merged MBAM entries: [MalwareBytes Anti Malware More*] LangSecRef=3024 Detect=HKCU\Software\Malwarebytes' Anti-Malware Default=False FileKey1=%AppData%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.* FileKey2=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.* FileKey3=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware|mbam-setup.exe From: [MalwareBytes Anti Malware Logs*] LangSecRef=3024 Detect=HKCU\Software\Malwarebytes' Anti-Malware Default=False FileKey1=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.* FileKey2=%AppData%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.* [Malwarebytes Anti Malware Setup File*] LangSecRef=3024 Detect=HKCU\Software\Malwarebytes' Anti-Malware Default=False FileKey1=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware|mbam-setup.exe [Microsoft Standalone System Sweeper Tool*] LangSecRef=3024 Detect=HKCU\Software\Microsoft\Microsoft Standalone System Sweeper Tool DetectFile=%WinDir%\Windows Defender Offline\Support Default=False FileKey1=%CommonAppData%\Microsoft\Microsoft Standalone System Sweeper Tool\Support|*.log FileKey2=%WinDir%\Windows Defender Offline\Support|*.txt <-Changed DetectFile to Detect. [secunia PSI*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Secunia\PSI Detect2=HKCU\Software\Secunia\PSI Default=False FileKey1=%ProgramFiles%\secunia\PSI|sualog.txt FileKey2=%ProgramFiles%\Secunia\PSI|psialog.txt* <-Changed DetectFile to Detect. Removed FileKey3, added * to FileKey2. [search Everything*] LangSecRef=3024 DetectFile=%ProgramFiles%\Everything Default=False FileKey1=%ProgramFiles%\Everything|Errorlog.txt <-Changed entry title/name. Link to comment Share on other sites More sharing options...
siliconman01 Posted May 8, 2012 Share Posted May 8, 2012 You can change [Thumbsplus 8*] to [Thumbsplus 8/9*]. Thumbsplus 9 is almost out of beta and the cleanup is the same as Thumbsplus 8. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
pook1y7985 Posted May 9, 2012 Share Posted May 9, 2012 The only comments I have about combing entries are that I know some would prefer to keep the Malwarebytes Separate so they don't have to clean the Quarantine area(which is what the default CCleaner entry does) I think combining them makes sense to me as the list is growing ever longer. Perhaps use the Warning tag to list out what is being cleaned the combined entries so its more apparent what they will be removing. Just my two cents. Link to comment Share on other sites More sharing options...
