somespirit 0 Posted April 23, 2012 Share Posted April 23, 2012 next will delete Windows update files downloaded from microsoft via Windows Update, they are saved here - C:\Windows\SoftwareDistribution\Download - it is like cache for them, once they are installed it is safe to be removed [Windows Update Cache Downloads*] LangSecRef=3025 DetectFile=%WinDir%\SoftwareDistribution\Download\ Default=False FileKey1=%WinDir%\SoftwareDistribution\Download|*.*|RECURSE Warning=Working on all Win ............ Link to post Share on other sites
Moderators Nergal 0 Posted April 24, 2012 Moderators Share Posted April 24, 2012 next will delete Windows update files downloaded from microsoft via Windows Update, they are saved here - C:\Windows\SoftwareDistribution\Download - it is like cache for them, once they are installed it is safe to be removed this is for - Vista, Win 7, Win 2008 [Windows Update Cache Downloads*] LangSecRef=3025 DetectFile=%WinDir%\SoftwareDistribution\Download\ Default=False FileKey1=%WinDir%\SoftwareDistribution\Download|*.*|RECURSE Warning=only Vista, Win 7, Win 2008 no not considered safe to remove, not to be added to public ini. issue much discussed already. Link to post Share on other sites
somespirit 0 Posted April 24, 2012 Share Posted April 24, 2012 Delete Windows update files Warning If you delete the folder for each update, the corresponding Windows update cannot be uninstalled. Consider the effect that this will have on the computer before you delete the Windows update files. To delete Windows update files, follow these steps: Delete only those %Windir%/$NtUninstallKB number$ folders that were created more than a month ago as backup files for Windows updates. Do not delete those that were created within the last 30 days. To delete the download cache for Windows updates, delete all the folders in the %Windir%\SoftwareDistribution\download folder that were created more than 10 days ago. Delete the following log files in the %Windir% folder:kb*.log setup*.log setup*.old setuplog.txt winnt32.log set*.tmp Source - http://support.microsoft.com/kb/956324 it is perfectly safe to remove all files in that folder .......as microsoft says Link to post Share on other sites
Alan_B 0 Posted April 24, 2012 Share Posted April 24, 2012 It seems inconsistent that you give a link specific to Windows XP in support of an entry that warns :- Warning=only Vista, Win 7, Win 2008 Link to post Share on other sites
Winapp2.ini 0 Posted April 24, 2012 Author Share Posted April 24, 2012 Software Distribution folder has been discussed a lot, but generally not considered OK to remove because a lot of people don't understand the effects. Link to post Share on other sites
somespirit 0 Posted April 24, 2012 Share Posted April 24, 2012 It seems inconsistent that you give a link specific to Windows XP in support of an entry that warns :- Warning=only Vista, Win 7, Win 2008 i have made a little changes in my post: Warning=Working on all Win ............ Link to post Share on other sites
Winapp2.ini 0 Posted April 25, 2012 Author Share Posted April 25, 2012 Updated Link to post Share on other sites
nodles 0 Posted April 25, 2012 Share Posted April 25, 2012 Updated Great, thanks! Link to post Share on other sites
Moderators Nergal 0 Posted April 25, 2012 Moderators Share Posted April 25, 2012 Is [Windows System Profile*] LangSecRef=3025 DetectFile=%WinDir%\system32\config\systemprofile Default=False FileKey1=%WinDir%\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE FileKey2=%WinDir%\system32\config\systemprofile\AppData\Local\Temp|*.*|RECURSE FileKey3=%WinDir%\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies|*.*|RECURSE FileKey4=%WinDir%\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\IETldCache|*.*|RECURSE FileKey5=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE FileKey6=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies|*.*|RECURSE FileKey7=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\IETldCache|*.*|RECURSE Correct as is or does it need DetectFile2=%WinDir%\SysWOW64\config\systemprofile\ Link to post Share on other sites
Winapp2.ini 0 Posted April 25, 2012 Author Share Posted April 25, 2012 Shouldn't, since 64bit systems have that folder too Link to post Share on other sites
ricktendo64 0 Posted April 25, 2012 Share Posted April 25, 2012 (edited) Thanks for the update, I just wanna point out that this will break .net4 uninstall [Microsoft.NET Cache*] LangSecRef=3025 Detect=HKLM\SOFTWARE\Microsoft\.NETFramework Default=False FileKey1=%WinDir%\Microsoft.NET\Framework\v4.0.30319\SetupCache|*.*|RECURSE FileKey2=%WinDir%\Microsoft.NET\Framework64\v4.0.30319\SetupCache|*.*|RECURSE You can fix uninstall by deleting the uninstall entries for setup.exe in SetupCache and unhide the uninstall entries of the MSI's FileKey3=%WinDir%\Microsoft.NET\NETFXRepair* RegKey1=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft .NET Framework 4 Client Profile RegKey2=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft .NET Framework 4 Extended ; Client x64 RegKey3=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{F5B09CFD-F0B2-36AF-8DF4-1DF6B63FC7B4}\SystemComponent ; Client x86 RegKey4=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3C3901C5-3455-3E0A-A214-0B093A5070A6}\SystemComponent ; Extended x64 RegKey5=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{8E34682C-8118-31F1-BC4C-98CD9675E1C2}\SystemComponent ; Extended x86 RegKey6=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0A0CADCF-78DA-33C4-A350-CD51849B9702}\SystemComponent BTW I make a slim/updated .net4 installer with the setup stuff removed if anyone does not like the setup junk Edit: added NETFXRepair* (this is only used by setup.exe) and fixed RegKey's Edited April 26, 2012 by ricktendo64 : Members will have to find another way to access Ricktendo's .net installer Link to post Share on other sites
Moderators Andavari 1 Posted April 26, 2012 Moderators Share Posted April 26, 2012 (edited) I've been using this for awhile with no ill effects, however it needs testing by other people: [Microsoft Security Essentials (Old Definitions)]* Edit: Warning: I've found out using these with BleachBit will purge even new definitions if MSE is turned off. While this worked good with the previous version of MSE, it causes MSE v4 to re-download new definitions even though they already exist, so I've removed the cleaning routine. If anyone is using it in winapp2.ini I'd recommend removing it from it. Edited April 30, 2012 by Andavari Link to post Share on other sites
nodles 0 Posted April 26, 2012 Share Posted April 26, 2012 Why the first entry is in comments? ;[Macromedia Flashplayer*] ;LangSecRef=3023 ;Detect=HKCU\Software\Macromedia\FlashPlayer ;Default=False ;RegKey1=HKCU\Software\Macromedia\FlashPlayer|RecentMovie* Link to post Share on other sites
Winapp2.ini 0 Posted April 26, 2012 Author Share Posted April 26, 2012 I commented it out last version because it was is invalid and I was hoping someone would fix it for me Link to post Share on other sites
drazen11 0 Posted April 26, 2012 Share Posted April 26, 2012 Which entry in winapp2.ini delete the sound level in Windows 7 Volume Mixer? I set a system sound level to 25% and constantly becomes restored to 100%! Link to post Share on other sites
ProPaan 0 Posted April 26, 2012 Share Posted April 26, 2012 I've been using this for awhile with no ill effects, however it needs testing by other people: [Microsoft Security Essentials (Old Definitions)]* for me it's not causing problems Link to post Share on other sites
drazen11 0 Posted April 26, 2012 Share Posted April 26, 2012 Which entry in winapp2.ini delete the sound level in Windows 7 Volume Mixer? I set a system sound level to 25% and constantly becomes restored to 100%! [internet Explorer More*] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Internet Explorer Default=False FileKey1=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE FileKey2=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey3=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey4=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey5=%LocalAppData%\Microsoft\Internet Explorer|brndlog.txt FileKey6=%LocalAppData%\Microsoft\Internet Explorer|brndlog.bak FileKey7=%AppData%\Microsoft\Internet Explorer|brndlog.bak FileKey8=%AppData%\Microsoft\Internet Explorer|brndlog.txt RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey5=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey6=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete marked regkey4 remove sound level settings in Windows 7 Volume Mixer (reset all to master volume level, i prefer for system sound level to be 25% of master sound level)... please edit this rule Link to post Share on other sites
nodles 0 Posted April 26, 2012 Share Posted April 26, 2012 Not sure if it needs editing; you could edit/exclude it from your cleaning settings though.. Link to post Share on other sites
Winapp2.ini 0 Posted April 27, 2012 Author Share Posted April 27, 2012 RegKey4=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore That's what causes that? This has been driving me insane! Also is unrelated to Internet Explorer O_o.. Link to post Share on other sites
Moderators Nergal 0 Posted April 27, 2012 Moderators Share Posted April 27, 2012 Yeah, I was wondering why that was there when he mentioned it. Link to post Share on other sites
Coffee4Joe 0 Posted April 27, 2012 Share Posted April 27, 2012 RegKey4=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore That's what causes that? This has been driving me insane! Also is unrelated to Internet Explorer O_o.. Should be a separate entry? Audio\PolicyConfig [Audio Policy Config Cache*] LangSecRef=3025 Warning=May Reset user set Volume levels. Detect=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio Default=False RegKey1=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore Doesn't reset the volume levels when cleared for me. Wonder if it depends on the Audio driver? I have WIn7 Pro and a realtek audio driver. and a soundmax integrated driver on a laptop. Link to post Share on other sites
2nd base 0 Posted April 28, 2012 Share Posted April 28, 2012 Any chance of adding Windows live movie maker recent projects added? I can't seem to do remove these easily. At least I can't find where to look, i should say. Link to post Share on other sites
Coffee4Joe 0 Posted April 28, 2012 Share Posted April 28, 2012 Any chance of adding Windows live movie maker recent projects added? I can't seem to do remove these easily. At least I can't find where to look, i should say. [Windows Live Movie Maker Recent List*] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Windows Live\Movie Maker Default=False RegKey1=HKCU\Software\Microsoft\Windows Live\Movie Maker\Recent should be tested more to make sure it rebuilds the recent key after clearing. via www.windowsmoviemakers.net/Forums/ShowPost.aspx?PostID=251089 and http://answers.micro...5e-39c413188ed0 Link to post Share on other sites
2nd base 0 Posted April 28, 2012 Share Posted April 28, 2012 [Windows Live Movie Maker Recent List*] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Windows Live\Movie Maker Default=False RegKey1=HKCU\Software\Microsoft\Windows Live\Movie Maker\Recent should be tested more to make sure it rebuilds the recent key after clearing. via www.windowsmoviemakers.net/Forums/ShowPost.aspx?PostID=251089 and http://answers.micro...5e-39c413188ed0 Thank you. Darned if it wasn't simple. I was looking in the windows folder in the reg. Didn't rebuild though. I made two quick ones and nothing was remembered from the program. I make a lot of movies from baseball games though so who knows. It may eventually start another list after a reboot. I haven't rebooted yet. Link to post Share on other sites
nodles 0 Posted April 29, 2012 Share Posted April 29, 2012 NEW ENTRIES: [Creative Installation Information*] LangSecRef=3021 DetectFile=%ProgramFiles%\Creative Installation Information Default=False FileKey1=%ProgramFiles%\Creative Installation Information|*.log|RECURSE [Windows Live Messenger Chat History*] LangSecRef=3022 DetectFile=%Documents%\My Received Files Warning=Removes Windows Live Messenger chat history! Default=False FileKey1=%Documents%\My Received Files\*\History|*.* This works only on english WLM versions/installations. Link to post Share on other sites
