Winapp2.ini Posted March 18, 2012 Author Share Posted March 18, 2012 Also truth. The built-in entry is also Default=False! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted March 18, 2012 Share Posted March 18, 2012 Also truth. The built-in entry is also Default=False! Yup... Probably should rename [Macromedia Shockwave 8*] to [Adobe ShockWave 8*] and [Macromedia Shockwave 9*] to [Adobe ShockWave 9*] also. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 18, 2012 Author Share Posted March 18, 2012 I think they were originally kept Macromedia because that's how they're built into CCleaner. I'd have to check if this is still the case though. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Baud Posted March 18, 2012 Share Posted March 18, 2012 Hello, this is my 1st post int his forum, just for a little problem: I cannot download winapp2.ini as a file (Win7 SP1 x64 up to date, IE9): if I click on the download link, a new page opens in IE that shows the contents of the file . So I have to select all, copy and paste in notepad, and save to winapp2.ini. In Win XP SP3 up to date and IE8, the file downloads as it should. Can someone help me to locate the problem? Thank you. Baud. Link to comment Share on other sites More sharing options...
JDPower Posted March 18, 2012 Share Posted March 18, 2012 Hello, this is my 1st post int his forum, just for a little problem: I cannot download winapp2.ini as a file (Win7 SP1 x64 up to date, IE9): if I click on the download link, a new page opens in IE that shows the contents of the file . So I have to select all, copy and paste in notepad, and save to winapp2.ini. In Win XP SP3 up to date and IE8, the file downloads as it should. Can someone help me to locate the problem? Thank you. Baud. Have you tried right clicking and save or "Save target as" or "Save as" (or however whatever browser you're using words it) Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 18, 2012 Author Share Posted March 18, 2012 Clicking the link for me (Also up to date Win7 x64) in IE9 tries to download file. I am not brought to the page. Sounds like a setting issue. The same thing happens in IE10 on Windows 8. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Baud Posted March 18, 2012 Share Posted March 18, 2012 Have you tried right clicking and save or "Save target as" or "Save as" (or however whatever browser you're using words it) This solves the problem; thank you so much! Clicking the link for me (Also up to date Win7 x64) in IE9 tries to download file. I am not brought to the page. Sounds like a setting issue. The same thing happens in IE10 on Windows 8. I will have a look at some settings, thanks. Link to comment Share on other sites More sharing options...
SMalik Posted March 19, 2012 Share Posted March 19, 2012 MODIFIED ENTRY http://forum.pirifor...ndpost&p=211472 Modified RegKey1 as it is diff. in Snagit 11. [snagit 11*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\Snagit\11 Default=False Warning=This will delete the backups of the captures that you have performed with Snagit 11. FileKey1=%LocalAppData%\TechSmith\Snagit|*.bin FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.* FileKey4=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf FileKey5=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAG FileKey6=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAGundo FileKey7=%LocalAppData%\TechSmith\Snagit\Thumbnails|*.* RegKey1=HKCU\Software\TechSmith\Snagit\11|CaptureCount RegKey2=HKCU\Software\TechSmith\Snagit\11\SnagitEditor\Recent File List Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 19, 2012 Author Share Posted March 19, 2012 Thanks saad! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Baud Posted March 19, 2012 Share Posted March 19, 2012 Clicking the link for me (Also up to date Win7 x64) in IE9 tries to download file. I am not brought to the page. Sounds like a setting issue. The same thing happens in IE10 on Windows 8. I will have a look at some settings, thanks. The download of winapp2.ini file works fine in Google Chrome; so I guess there must be some specific IE9 setting preventing the download; I'll try googling further more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 19, 2012 Author Share Posted March 19, 2012 Try resetting your Advanced Options in IE9 winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted March 19, 2012 Share Posted March 19, 2012 [/color][/b] The download of winapp2.ini file works fine in Google Chrome; so I guess there must be some specific IE9 setting preventing the download; I'll try googling further more. That has always been the default action in Firefox for me, I always have to right click>save to download the ini file from the direct download, always have done as long as I can remember. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 19, 2012 Author Share Posted March 19, 2012 Strange. That was the case for me for a while, but it seemed to change randomly. http://ompldr.org/l20dtnn1s-winapp2.ini (the old hosting) 20 Nov 2010 05:39:06 open in browser (like a .txt) 21 Nov 2010 18:52:36 opens a download prompt winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
ProPaan Posted March 20, 2012 Share Posted March 20, 2012 add line [MS Security Client*] LangSecRef=3025 DetectFile=%ProgramFiles%\Microsoft Security Client\msseces.exe Default=False FileKey1=%ProgramFiles%\Microsoft Security Client\Backup|*.*|RECURSE FileKey2=%CommonAppData%\Microsoft\Microsoft Security Client\Support|*.log FileKey3=%CommonAppData%\Microsoft\Microsoft Antimalware\Support|*.log FileKey4=%CommonAppData%\Microsoft\Microsoft Antimalware\Definition Updates\Backup|*.*|RECURSE FileKey5=%CommonAppData%\Microsoft\Microsoft Antimalware\Scans\History|*.*|RECURSE Link to comment Share on other sites More sharing options...
nodles Posted March 21, 2012 Share Posted March 21, 2012 (edited) NEW ENTRIES [Magicka*] LangSecRef=3021 DetectFile=%ProgramFiles%\Steam\steamapps\common\magicka Default=False FileKey1=%ProgramFiles%\Steam\steamapps\common\magicka|errorReport*.txt [Alien Swarm*] LangSecRef=3021 DetectFile=%ProgramFiles%\Steam\steamapps\common\alien swarm\swarm Default=False FileKey1=%ProgramFiles%\Steam\steamapps\common\alien swarm\swarm|tilegen_log.txt MODIFIED ENTRY [internet Explorer More*] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Internet Explorer Default=False FileKey1=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE FileKey2=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey3=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey4=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey5=%LocalAppData%\Microsoft\Internet Explorer|brndlog.txt FileKey6=%LocalAppData%\Microsoft\Internet Explorer|brndlog.bak RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey5=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey6=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete Added FileKey5 & FileKey6. Edit. Correct; Added FK5+FK6 Edited March 22, 2012 by nodles Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 21, 2012 Author Share Posted March 21, 2012 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
pook1y7985 Posted March 22, 2012 Share Posted March 22, 2012 New Entry [Join.Me Logs*] LangSecRef=3022 Detect=HKCU\Software\join.me Default=False FileKey1=%LocalAppData%\join.me|*.log Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 22, 2012 Author Share Posted March 22, 2012 Sidenote: currently at 797 entries, hoping to make it to 800 for the next release winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted March 22, 2012 Share Posted March 22, 2012 Added FK5+FK6 Are those entries definitely right? If so you might want to add an additional two lines as the two brndlog files are in appdata on my system (WinXP, IE8), not localappdata. Link to comment Share on other sites More sharing options...
siliconman01 Posted March 22, 2012 Share Posted March 22, 2012 You could add these entries for jv16 PowerTools 2012 which is in Release Candidate testing state at the present time. [jv16 PowerTools 2012 Backup Files*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools 2012\jv16PT.exe Default=False FileKey1=%ProgramFiles%\jv16 PowerTools 2012\Backups|*.*|RECURSE| FileKey2=%ProgramFiles%\jv16 PowerTools 2012\Settings|UserActionLog.txt Excludekey1=FILE|%ProgramFiles%\jv16 PowerTools 2012\Backups|License.xbin_backup and add DetectFile4 to the existing code below. [jv16 PowerTools*] LangSecRef=3024 DetectFile1=%ProgramFiles%\jv16 PowerTools 2009\jv16PT.exe DetectFile2=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exe DetectFile3=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe DetectFile4=%ProgramFiles%\jv16 PowerTools 2012\jv16PT.exe Default=False FileKey1=%UserProfile%|NTUSER.DAT.bak_* FileKey2=%UserProfile%|NTUSER.DAT.bak_*.* FileKey4=%LocalAppData%\Microsoft\Windows|UsrClass.dat.bak_* FileKey5=%LocalAppData%\Microsoft\Windows|UsrClass.dat.bak_*.* FileKey7=%WinDir%\system32\config|Default.bak_* FileKey8=%WinDir%\system32\config|Default.bak_*.* FileKey10=%WinDir%\system32\config|software.bak_*.* FileKey12=%WinDir%\system32\config|software.bak_* FileKey13=%WinDir%\system32\config|system.bak_* FileKey14=%WinDir%\system32\config|system.bak_*.* FileKey16=%WinDir%\System32\config|SAM.bak_* FileKey17=%WinDir%\System32\config|SAM.bak_*.* FileKey19=%WinDir%\System32\config|COMPONENTS.bak_* FileKey20=%WinDir%\System32\config|COMPONENTS.bak_*.* FileKey22=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT.bak_* FileKey23=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT.bak_*.* FileKey25=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT.bak_* FileKey26=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT.bak_*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
nodles Posted March 22, 2012 Share Posted March 22, 2012 Are those entries definitely right? If so you might want to add an additional two lines as the two brndlog files are in appdata on my system (WinXP, IE8), not localappdata. Yes. I've those files only in %LocalAppData%\Microsoft\Internet Explorer. Don't know about XP, using Win7 64bit and I've "uninstalled" IE. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 22, 2012 Author Share Posted March 22, 2012 I'll add in those two file keys then winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
joedf Posted March 22, 2012 Share Posted March 22, 2012 Great project! but, there's a problem with the "FastStone Capture*" entry: It somehow deletes your software registration, I had to register again. If there is no fix for the moment, maybe you should atleast add: Warning=This may deleted your software Registration! -joedf Link to comment Share on other sites More sharing options...
joedf Posted March 22, 2012 Share Posted March 22, 2012 Sorry, about the triple post! It was an accident!!! (Internet temporary lag, so i spam the post button! ) please don't hurt me... PS TWAS AN ACCIDENT! Link to comment Share on other sites More sharing options...
Moderators DennisD Posted March 22, 2012 Moderators Share Posted March 22, 2012 What triple post? No worries joedf, I cleaned them up. Link to comment Share on other sites More sharing options...
