Winapp2.ini additions
Winapp2.ini
Here is a little "cosmetic" change, because this was the only entry for Firefox using %ProgramFiles% for detection.
[Extensions Logs*]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\Firefox
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*|extensions.log
The next entry has two detection lines. I think the first one (DetectFile) is enough because the entry gets detected regardless if the second one (Detect) matches or not.
[secunia PSI*]
LangSecRef=3021
DetectFile=%ProgramFiles%\Secunia\PSI\psi.exe
Detect=HKCU\Software\Secunia\PSI
Default=False
FileKey1=%ProgramFiles%\secunia\PSI|sualog.txt
FileKey2=%ProgramFiles%\Secunia\PSI|psialog.txt
FileKey3=%ProgramFiles%\Secunia\PSI|psialog.txt2
And I have a question about the following entry. Are you really sure this is for "MS Customer Experience Improvement Program"? Because the file "Custom.DIC" saves your own additions to the office dictionary (for the spell checker). And until now I didn't find a suspect file in the folder "UProof".
[MS Office Saved CEIP data*]
LangSecRef=3021
DetectFile=%AppData%\Microsoft\UProof
Default=False
FileKey1=%AppData%\Microsoft\UProof|*.bin
FileKey2=%AppData%\Microsoft\UProof|*.DIC
FileKey3=%AppData%\Microsoft\UProof|*.XML
Link to comment
Quote
LangSecRef=3021
Default=False
Personally I do not checkmark this code because I use Office 2007 and Office 2010. As stated, this code clears out the Custom.dic which is undesirable to me for Outlook and other Office programs.
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD21, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
@ siliconman01 & Winapp2.ini: Thanks for your replies.
Here are some more changes and new entries. The first 2 are just cosmetic changes. Can you rename them please?
[MalwareBytes' Anti-Malware 1.50 (Logs)*] to [Malwarebytes Anti Malware Logs*]
[VLC media player More*] to [VLC Media Player More*]
This is a new entry:
[DVBViewer*]
LangSecRef=3023
DetectFile=%CommonAppData%\CMUV\DVBViewer
Default=False
FileKey1=%CommonAppData%\CMUV\DVBViewer|*.bak
FileKey2=%CommonAppData%\CMUV\DVBViewer|*.log
The following entries are suggestions only. I'm not sure if they are good for all. I'm using a small SSD and therefore searched for unnecessary setup files. It would be great if other users could check and test them.
Adobe Reader X: The only ill effect is that a repair installation doesn't work anymore. But the uninstaller still works.
[Adobe Reader 10.0 Setup Files*]
LangSecRef=3021
DetectFile=%CommonAppData%\Adobe\Acrobat\10.0
Warning=This will prevent a repair installation. You have to download the installer for a reinstallation.
Default=False
FileKey1=%CommonAppData%\Adobe\ARM\Reader_10.*|*.*|REMOVESELF
FileKey2=%CommonAppData%\Adobe\Setup\{AC76BA86-7AD7-*-7B44-AA1000000001}|*.*|REMOVESELF
Citrix Web Client: No errors occurred. Uninstaller still works.
[Citrix Online Plug-in Web Setup Files*]
LangSecRef=3021
DetectFile=%CommonAppData%\Citrix\Citrix Online Plug-in - Web
Default=False
FileKey1=%CommonAppData%\Citrix\Citrix Online Plug-in - Web|*.msi
FileKey2=%CommonAppData%\Citrix\Citrix Online Plug-in - Web|*.cab
FileKey3=%CommonAppData%\Citrix\Citrix Online Plug-in - Web|eula*.rtf
JavaRE 7: No errors occurred. Uninstaller still works.
[sun Java Setup Files*]
LangSecRef=3022
DetectFile=%LocalLowAppData%\Sun\Java
Default=False
FileKey1=%LocalLowAppData%\Sun\Java\jre*|*.*|REMOVESELF
Apple Installer: Changed this one a little bit. QuickTime shows no error after deletion. Uninstallers still work. Can somebody test it with latest iTunes please?
[Apple Installer Cache*]
LangSecRef=3023
DetectFile=%CommonAppData%\Apple Computer
Default=False
FileKey1=%CommonAppData%\Apple Computer\Installer Cache\*|*.*
FileKey2=%CommonAppData%\Apple\Installer Cache\*|*.*
DVBViewer: It's not possible to modify the installation anymore. Uninstaller still works.
[DVBViewer Setup Files*]
LangSecRef=3023
DetectFile=%ProgramFiles%\DVBViewer
Warning=This will prevent a modify installation. You have to download the installer to modify the installation.
Default=False
FileKey1=%ProgramFiles%\DVBViewer\setup|*.*
FileKey2=%ProgramFiles%\DVBViewer\Transponders|*.*
Malwarebytes' Anti-Malware: No errors occurred. Uninstaller still works.
[Malwarebytes Anti Malware Setup File*]
LangSecRef=3024
DetectFile=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware
Default=False
FileKey1=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware|mbam-setup.exe
All entries are tested on Windows 7 x64.
Edit: Correction of typos. Thanks to JDPower.
Edited by APMichael
Link to comment
If we're talking cosmetic surely it should be "Malwarebytes Anti-Malware" not "Malwarebytes' Anti-Malware" ;)
No, for this case "Malwarebytes' Anti-Malware" is correct, because the built-in entry of CC is written exactly like this. The program files folder is labeled "Malwarebytes' Anti-Malware" also.
Edit: Big sorry, you are right! CCleaners entry is written "Malwarebytes Anti Malware" (also no hyphen "-"). Shame on me. :( And thanks for your good eyes. :)
Ok, then the entries should be renamed from
[Malwarebytes' Anti-Malware Setup File*] to [Malwarebytes Anti Malware Setup File*]
I will correct those typos in my post above.
Link to comment
You're right the file 'Custom.DIC' saves your own additions to the office dictionary. Other two lines are valid.
Link to comment
NEW ENTRIES
[Cached WPF Fonts*]
LangSecRef=3025
DetectFile=%windir%\ServiceProfiles\LocalService\AppData\Local
Default=False
FileKey1=%windir%\ServiceProfiles\LocalService\AppData\Local|FontCache3.0.0.0.dat
http://forum.pirifor...79
[Defragmentation List*]
LangSecRef=3025
DetectFile=%WinDir%
Default=False
FileKey1=%WinDir%\Prefetch|Layout.ini
Link to comment
I believe wiping .pf files from Prefetch directory is completely safe. The problem is only when ReadyBoot directory and its contents (.fx files) are wiped from Prefetch directory without restarting the system. I think we should have an entry to wipe .pf files since CCleaner's Old Prefetch data entry doesn't work on Windows Vista and 7.
Link to comment
I can confirm this, now. Today I get a pop-up window with the "Customer Experience Improvement Program" and those files were generated. This is the modified entry:
[MS Office Saved CEIP Data*]
LangSecRef=3021
Default=False
FileKey2=%AppData%\Microsoft\UProof|*.XML
Link to comment
I made a mistake by adding .DIC into that entry. Otherwise the entry is valid. Thank you for confirming.
Link to comment
I have seen 3 different sorts of DetectFiles within WinApp2.ini,
are they all legal and do they all do the same in every situation ?
1. Many with a trailing backslash such as
DetectFile=%AppData%\DriverCure\
2. Many without a trailing backslash such as
DetectFile=%LocalAppData%\Innovative Solutions\DriverMax
3. At least one with a trailing dot such as
DetectFile=%AppData%\dvdcss\.
Regards
Alan
Link to comment
Register a new account
Sign in
Important Information
