Winapp2.ini additions
Winapp2.ini
NEW / MISSED ENTRIES
[Adobe Acrobat More*]
LangSecRef=3021
DetectFile1=%LocalAppData%\Adobe\Acrobat
Default=False
FileKey1=%LocalAppData%\Adobe\Acrobat\*\Updater|*.log
FileKey2=%LocalAppData%\Adobe\Acrobat\*\Cache|*.lst
[Firefox Install Log*]
LangSecRef=3022
DetectFile=%ProgramFiles%\Mozilla Firefox
Default=False
FileKey1=%ProgramFiles%\Mozilla Firefox|install.log
[JavaRa Log*]
LangSecRef=3024
DetectFile=%HomeDrive%\JavaRa.log
Default=False
FileKey1=%HomeDrive%|JavaRa.log
[HandBrake Logs*]
LangSecRef=3023
DetectFile=%AppData%\HandBrake\logs
Default=False
FileKey1=%AppData%\HandBrake\logs|*.txt
[iWisoft Free Video Converter Logs*]
LangSecRef=3023
DetectFile=%ProgramFiles%\iWisoft Free Video Converter
Default=False
FileKey1=%ProgramFiles%\iWisoft Free Video Converter|VideoConverter.log
[Osmos Logs*]
LangSecRef=3021
DetectFile=%UserProfile%\Documents\Osmos
Default=False
FileKey1=%UserProfile%\Documents\Osmos|osmos.log
[Windows Panther Logs*]
LangSecRef=3025
DetectFile1=%WinDir%\Panther
Default=False
FileKey1=%WinDir%\Panther|*.log
[Windows ServiceProfiles\NetworkService Temps*]
LangSecRef=3025
DetectFile1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp
Default=False
FileKey1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp|*.txt
[Windows Update Cache*]
LangSecRef=3025
DetectFile=%WinDir%\SoftwareDistribution\Download
Default=False
FileKey1=%WinDir%\SoftwareDistribution\Download|*.*|RECURSE
Link to comment
MODIFIED ENTRIES
Merge these
[batman Arkham Asylum*]
LangSecRef=3021
DetectFile=%Documents%\Eidos\Batman Arkham Asylum\
Default=False
FileKey1=%Documents%\Eidos\Batman Arkham Asylum\BmGame|*.log|RECURSE
[batman: Arkham Asylum GOTY Logs*]
LangSecRef=3023
DetectFile=%UserProfile%\Documents\Square Enix\Batman Arkham Asylum GOTY\BmGame\Logs
Default=False
FileKey1=%UserProfile%\Documents\Square Enix\Batman Arkham Asylum GOTY\BmGame\Logs|Launch.log
to
[batman: Arkham Asylum*]
LangSecRef=3021
DetectFile2=%UserProfile%\Documents\Square Enix\Batman Arkham Asylum GOTY
Default=False
FileKey2=%UserProfile%\Documents\Square Enix\Batman Arkham Asylum GOTY\BmGame\Logs|Launch.log
More modified entries:
[Avira AntiVir Logs*]
LangSecRef=3024
DetectFile1=%CommonAppData%\Avira
Default=False
FileKey1=%CommonAppData%\Avira\AntiVir Desktop\LOGFILES|*.*
FileKey2=%ProgramFiles%\Avira\AntiVir Desktop\APPDATA\LOGFILES|*.*
[iTunes Logs*]
LangSecRef=3023
DetectFile=%ProgramFiles%\iTunes\iTunes.exe
Default=False
FileKey1=%AppData%\Apple Computer\Logs|*.*|RECURSE
FileKey2=%WinDir%\system32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log|RECURSE
[star Wars: The Old Republic*]
LangSecRef=3021
DetectFile1=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic
Default=False
FileKey1=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\betatest\retailclient\Temp|*.log
FileKey2=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\logs|*.log
FileKey3=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\swtor\retailclient\swtor\logs|*.log
FileKey4=%Documents%|Install STAR WARS The Old Republic.log
FileKey5=%LocalAppData%\SWTOR\CrashDump\swtor|*.*
FileKey6=%UserProfile%\Documents|Uninstall STAR WARS The Old Republic.log
[steam More*]
LangSecRef=3021
Detect=HKCU\Software\Valve\Steam
Default=False
FileKey1=%ProgramFiles%\Valve\Steam\SteamLogs|*.log
FileKey2=%ProgramFiles%\Valve\Steam|Steam.log
FileKey3=%ProgramFiles%\Steam|*.log|RECURSE
FileKey4=%ProgramFiles%\Steam\logs|*.txt
[uTorrent More*]
LangSecRef=3022
DetectFile=%ProgramFiles%\uTorrent\uTorrent.exe
Default=False
FileKey1=%AppData%\utorrent|*.log
FileKey2=%AppData%\uTorrent\ie|*.tmp
FileKey3=%ProgramFiles%\uTorrent|*.tmp
Link to comment
LangSecRef=3025
Default=False
Already built in ;)
LangSecRef=3025
Default=False
Rather controversial.
Whoops/Thanks! on the rest :)
Link to comment
NEW / MISSED ENTRIES:
[Adobe My Digital Editions Import Logs*]
LangSecRef=3026
DetectFile=%UserProfile%\Documents\My Digital Editions
Default=False
FileKey1=%UserProfile%\Documents\My Digital Editions|import.log
[Windows Live Setup Logs*]
LangSecRef=3025
DetectFile1=%ProgramData%\Microsoft\WLSetup
Default=False
FileKey1=%ProgramData%\Microsoft\WLSetup\CabLogs|Logs.CAB
FileKey2=%ProgramData%\Microsoft\WLSetup\Logs|*.log
Link to comment
Just wondering have you given a thought to creating the Winsys2.ini file to separate out some of the many Windows related cleaning tasks? I see the only change you would need is to change the SecRef. I also see that it doesn't require you to use detection in the Winsys2 file which could increase loading speed. I am impressed that there are now well over 700 hundred entries added!!
New Entry
[user Default Download Directory *]
LangSecRef=3025
Detect Paths:%UserProfile%\Downloads
Default=False
FileKey1=%UserProfile%\Downloads|*.*|RECURSE
Link to comment
  • Moderators
i've done that for my personal ccleaner
(change.txt to .ini)winsys2 .txt
Link to comment
LangSecRef=3026
Default=False
LangSecRef=3025
Default=False
in winapp2:
[WLSetup Logs*]
LangSecRef=3022
DetectFile=%LocalAppData%\Microsoft\WLSetup\Logs\
Default=False
FileKey1=%LocalAppData%\Microsoft\WLSetup\Logs|*.*|RECURSE
FileKey2=%CommonAppData%\Microsoft\WLSetup\Logs|*.*|RECURSE
FileKey3=%LocalAppData%\Microsoft\WLSetup\Cablogs|*.*|RECURSE
FileKey4=%CommonAppData%\Microsoft\WLSetup\Cablobs|*.*|RECURSE
Due for a renaming, certainly. I will rename it for the next iteration.
Link to comment
[Defragmentation List*]
LangSecRef=3025
DetectFile=%WinDir%
Default=False
FileKey1=%WinDir%\Prefetch|Layout.ini
The above entry negates part of the features of Perfectdisk in that it prevents Perfectdisk from aligning programs so that the system will boot faster. I recommend that this entry before or a warning message be inserted. It may also negatively affect other third party defraggers (I do not know this for fact, but it may). The link below further explains how Perfectdisk interfaces with Layout.ini.
http://superuser.com...agement-options
Suggested Warning message:
LangSecRef=3025
Warning=DO NOT use if your system has PerfectDisk defragging software.
DetectFile=%WinDir%
Default=False
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD21, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
Thanks for the update!
Missed entry:
[bookmark Backups*]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\Firefox
Warning=This will delete all bookmark backups. Make sure to backup them manually.
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\bookmarkbackups|*.json
New entries:
[3ware 3DM2*]
LangSecRef=3024
DetectFile=%CommonAppData%\3ware
Default=False
FileKey1=%CommonAppData%\3ware|tw_mgmt.log
[Dyn Updater*]
LangSecRef=3022
DetectFile=%CommonAppData%\Dyn\Updater
Default=False
FileKey1=%CommonAppData%\Dyn\Updater|dyndns.log
And could a user of iTunes test the following entry, please? If iTunes doesn't want to download its installer again, we can add this entry to the winapp2.ini also.
[Apple Installer Cache*]
LangSecRef=3023
DetectFile=%CommonAppData%\Apple Computer
Default=False
FileKey1=%CommonAppData%\Apple Computer\Installer Cache\*|*.*
FileKey2=%CommonAppData%\Apple\Installer Cache\*|*.*
Link to comment
The bookmark backups get deleted after a week or so, is it worth it to delete them with CCleaner?
IMHO it is worth. Before I make a new disk image I'd like to have a clean system (without those 6 backup files per user account).
DITTO!....but it it has to do with Firefox, it should have a Firefox heading vs [bookmark Backups*] heading....same as [Extensions Logs*], [Crash Reports*] and [Dump Files*]
Link to comment
  • Moderators
No don't change it, they are all confused about what headinbg means
The Firefox entries don't need to say firefox because they are grouped together under firefox
Like this (but in your mind replace safari with firefox)
Link to comment
  • Moderators
/me blinks
/me shouts
"the priority is the look and feel of ccleaner program not the vainity of having the ini "look pretty"!!!"
/me shakes a fist at a cloud "get off m'lawn"
Link to comment
LangSecRef=3025
Default=False
I've always treated these the same as prefetch, I clean it maybe once a month, But definatly not for daily cleaning.
Link to comment
  • Moderators
I'd really rather that not go into the public template it causes too many issues for too many regular ccleaner users, as I've said before you can add it to your own if you want (personal discretion and all) but i think it is asking for trouble in the public file.
Link to comment
:lol:
That's how I've been treating the prefetch and softwaredistro folders.
Link to comment
Register a new account
Sign in
Important Information
