Winapp2.ini additions
Winapp2.ini
MODIFIED ENTRY
Removed: DetectFile1=%AppData%\FastStone\FSC
There is no need to have this line.
[FastStone Capture*]
LangSecRef=3024
DetectFile=%ProgramFiles%\FastStone Capture\FSCapture.exe
Default=False
FileKey1=%LocalAppData%\FastStone\FSC\EditWith|*.*
FileKey2=%LocalAppData%\FastStone\FSC|*.db
FileKey3=%AppData%\FastStone\FSC|*.bak
FileKey4=%AppData%\FastStone\FSC|*.db
RegKey1=HKCU\Software\FastStone\APP.FSRecorder\Global|_GrbId
RegKey2=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastClipPlayed
RegKey3=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastRecordingFileName
Link to comment
MODIFIED ENTRY
[Cached WPF Fonts*]
LangSecRef=3025
DetectFile=%windir%\ServiceProfiles\LocalService\AppData\Local
Default=False
FileKey1=%windir%\ServiceProfiles\LocalService\AppData\Local|*.dat
ExcludeKey1=FILE|%windir%\ServiceProfiles\LocalService\AppData\Local|lastalive0.dat
ExcludeKey2=FILE|%windir%\ServiceProfiles\LocalService\AppData\Local|lastalive1.dat
There are always cached copies of WPF fonts for all the user accounts with their SID (Security IDentifier). Please look at the snapshot in the previous post.
http://forum.pirifor...ndpost&p=209414
Link to comment
  • Moderators
All the lines are valid in the entry listed below. I don't know why Nergal is asking to change it.
[Windows Media Center*]
LangSecRef=3023
DetectFile=%WinDir%\ehome\ehshell.exe
Default=False
FileKey1=%CommonAppData%\Microsoft\eHome\logs|*.*
FileKey2=%LocalAppData%\Microsoft\eHome|playlistcache.db
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center\MRU\SettingsMRU
Because it already exists in Default CCleaner with the top two filekeys, only not the regkey (see below))
[Windows Media Center]
ID=2278
LangSecRef=3023
DetectFile=%windir%\ehome\ehshell.exe
Default=True
Link to comment
ID=2278
LangSecRef=3023
Default=True
ic. Thank you. :)
Link to comment
entries[/s] entry are is in red)
[Windows Media Player]
ID=2033
LangSecRef=3023
Detect=HKCU\Software\Microsoft\MediaPlayer\Player
Default=True
RegKey1=HKCU\Software\Microsoft\MediaPlayer\Player\RecentFileList
RegKey2=HKCU\Software\Microsoft\MediaPlayer\Player\RecentURLList
RegKey3=HKCU\Software\Microsoft\MediaPlayer\Preferences|LastPlayList
RegKey4=HKCU\Software\Microsoft\MediaPlayer\Preferences|LastPlayListIndex
RegKey5=HKCU\Software\Microsoft\MediaPlayer\Player\Settings|SaveAsDir
RegKey6=HKCU\Software\Microsoft\MediaPlayer\AutoComplete\MediaEdit
RegKey7=HKCU\Software\Microsoft\MediaPlayer\Radio\MRUList
FileKey1=%LocalAppData%\Microsoft\Media Player|lastplayed.wpl
FileKey2=%LocalAppData%\Microsoft\Media Player|cacheentry*.*|RECURSE
Ok so only one redundant (also see my real player edit above :D)
Ahhhhh. The use of the word breakouts confused me. I am currently home with no computers so i can't make changes till Sunday
accessing the forums from my thunderbolt is no easy task, i must say
Link to comment
Found a typo that causes a problem with trim.bat. The name of the following entry has no trailing asterisk (*). Can you rename these 2 entries, please?
[spybot Search & Destroy Updates] to [spybot Search and Destroy Updates*]
[spybot Hosts Backups*] to [spybot Search and Destroy Hosts Backups*]
Link to comment
I would prefer the long names - just for better matching with the name of the built-in entry.
Here are two more entries without an asterisk. Found thanks to the latest Trim_x.bat from Alan_B.
[Eset Online Scanner]
[uTorrent Bar Logs]
We should change the LangSecRef of the following entry:
[FileZilla FTP Client Temps*]
LangSecRef=3022
Thanks!
Link to comment
NEW ENTRY
[CyberLink PowerDirector 10*]
LangSecRef=3023
DetectFile=%ProgramFiles%\CyberLink\PowerDirector10\PDR10.exe
Default=False
FileKey1=%AppData%\CyberLink\MediaCache|*.*
FileKey2=%AppData%\CyberLink\PowerDirector\10.0|Recentfiles.ini
RegKey1=HKCU\Software\CyberLink\Hanuman\Waveform
RegKey2=HKCU\Software\CyberLink\MediaCache5\Data5
RegKey3=HKCU\Software\CyberLink\MediaCache5\Thumbnail5
Link to comment
I recommend that [HostsMan*] be changed to:
[HostsMan's HostsServer (Log)*]
And I would like to see the following added:
[TrojanHunter (Debug Logs)*]
LangSecRef=3024
Detect=HKCU\Software\TrojanHunter
Default=False
FileKey1=%ProgramFiles%\TrojanHunter *\|Debug.log
FileKey2=%ProgramFiles%\TrojanHunter *\|DebugLog.txt
[DisplayFusion (Setup File & Log)*]
Warning=This removes the DisplayFusionSetup.exe file and DisplayFusionSetup.log generated during the installation of DisplayFusion.  Both are unneeded after the installation is completed.
LangSecRef=3024
Detect=HKCU\Software\Binary Fortress Software\DisplayFusion
Default=False
FileKey1=%AppData%\DisplayFusion|DisplayFusionSetup.log
FileKey2=%AppData%\DisplayFusion|DisplayFusionSetup.exe
[DisplayFusion (Auto Backups)*]
Warning=This removes the DisplayFusion auto backups of the Program's settings.  This settings backup file is automatically created when a new version of DisplayFusion is installed. The folder is located at %SystemDrive%\User\My Documents\DisplayFusion Backups
LangSecRef=3024
Default=False
FileKey1=%UserProfile%\My Documents\DisplayFusion Backups\|*.*
[Logitech Setpoint 6 (Logs)*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Logitech\SetPointG\SetPointII.exe
Default=False
FileKey1=%AppData%\Logishrd\sp6_Log\|*.*|REMOVESELF
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD21, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
New Entries
[AVG AntiVirus 2012 Installer*]
LangSecRef=3024
DetectFile=%CommonAppData%\AVG2012
Default=False
FileKey1=%CommonAppData%\AVG2012\SetupBackup|*.*
[AVG AntiVirus 10 Installer*]
LangSecRef=3024
DetectFile=%CommonAppData%\AVG10
Default=False
FileKey1=%CommonAppData%\AVG10\SetupBackup|*.*
[AVG AntiVirus 9 Installer*]
LangSecRef=3024
DetectFile=%CommonAppData%\AVG9
Default=False
FileKey1=%CommonAppData%\AVG9\SetupBackup|*.*
stumbled apon this http://forums.avg.co...=show&id=161669
%CommonAppData%\AVG2012\update is already cleaned by CCleaner
That forum post is for avg2010 but the locations for avg9 - 2012 are the same
Link to comment
  • Moderators
OT: it's easy on my webOS ;)
Link to comment
NEW ENTRY
[CyberLink PhotoDirector 3*]
LangSecRef=3023
DetectFile=%ProgramFiles%\CyberLink\PhotoDirector3\PhotoDirector3.exe
Default=False
FileKey1=%LocalAppData%\Cyberlink\PhotoDirector\3.0|*.cache
FileKey2=%USERPROFILE%\Pictures\PhotoDirector\3.0\*|*.*|RECURSE
ExcludeKey1=FILE|%USERPROFILE%\Pictures\PhotoDirector\3.0\*|*.phd
Link to comment
@Nergal
@WinApp2.ini
Did you know that when your mobile gives you internet access,
Websites and their advertisers may know more than your IP address ?
Apparently O2 also hand out your phone number.
http://www.thinkbroadband.com/news/4990-o2-shares-your-mobile-phone-number-with-every-website-you-visit.html
Link to comment
  • Moderators
Yup my phone also has a hosts update patch to block things
This is a superset to Ad Blocker. It blocks ads, tracking etc.If you find that this breaks an app for you, try uninstalling it and using Ad Blocker instead. WARNING: Only install Max Blocker OR Ad Blocker, not both. Failure to heed this will result in Santa putting you on the naughty list.
Link to comment
New entries (more info)
[Adobe Customization Wizard 8*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Customization Wizard 8
Default=False
RegKey1=HKCU\Software\Adobe\Adobe Customization Wizard 8\Recent File List
[Adobe Customization Wizard 9*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Customization Wizard 9
Default=False
RegKey1=HKCU\Software\Adobe\Adobe Customization Wizard 9\Recent File List
[Adobe Customization Wizard X*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Customization Wizard X
Default=False
RegKey1=HKCU\Software\Adobe\Adobe Customization Wizard X\Recent File List
Link to comment
And could a user of iTunes test the following entry, please? If iTunes doesn't want to download its installer again, we can add this entry to the winapp2.ini also.
[Apple Installer Cache*]
LangSecRef=3023
DetectFile=%CommonAppData%\Apple Computer
Default=False
FileKey1=%CommonAppData%\Apple Computer\Installer Cache\*|*.*
FileKey2=%CommonAppData%\Apple\Installer Cache\*|*.*
I could test this entry on a friends PC with Windows 7 (x64) and latest iTunes 10.5.3 (x64). We used CC with the entry and started iTunes again: Absolutely nothing happened, no error message or repair-installer appeared and no re-download of the installer started. I think the entry is safe.
Link to comment
Is this a "kosher legal" entry I found in Winapp2.ini ?
[icon Cache*]
LangSecRef=3025
Default=False
FileKey1=%LocalAppData%|IconCache.db
I think all the other 742 entries have at least one Detect line.
I would have expected every entry to have a Detect file or reg key.
My next version of Trim_x was depending on it - yet another bug-fix :(
This omission is not expressly permitted in the documentation I have seen,
therefore each time CCleaner.exe is updated it may lose the capability to clean the Icon Cache.
Alan
Link to comment
I haven't had any issues with removing these
Link to comment
Register a new account
Sign in
Important Information
