CCleaner Community Forums
Winapp2.ini additions
Winapp2.ini
The only way to add a detectfile would be to detectfile iconcache.db, which would also upset trim_x.bat :(
Actually several years ago, before CCleaner advanced from series 2.* to 3.*,
I found that this would work for me, and it should be good to Iconcache also :-
DetectFile=C:\
Trim_x.bat thus far has not been concerned by the absence of a detect.
My upcoming version is more rigorous and the absence caused a "Volatile" alert which was easily fixed.
I have a concern that if CCleaner.exe code expects a detect,
then in the absence of a detect its behavior is undefined,
and that is NEVER a good thing.
At any time in the future a code revision might refrain from deleting what has not been detected.
Link to comment
I haven't had any issues with removing these
Thanks for testing! :)
Actually several years ago, before CCleaner advanced from series 2.* to 3.*, I found that this would work for me, and it should be good to Iconcache also :-
DetectFile=C:\
Or maybe this detection line?
DetectFile=%LocalAppData%
Link to comment
[Apple Installer Cache*]
LangSecRef=3023
DetectFile=%CommonAppData%\Apple Computer
Default=False
FileKey1=%CommonAppData%\Apple Computer\Installer Cache\*|*.*
FileKey2=%CommonAppData%\Apple\Installer Cache\*|*.*
I did get a warning in the event viewer after launching Apple Software Updater if I removed the Installer Cache folder also. But the entry as is it works without trouble.
Link to comment
Is there a way to get the DetectFile to point to %AppData%\Mozilla\FireFox\Profiles\unique numbers and letters .default\ ?
for this:
[AdBockPlus backups*]
LangSecRef=3026
Warning=This will remove all filter backups
DetectFile=%AppData%\Mozilla\FireFox\Profiles
Default=False
FileKey1=%AppData%\Mozilla\FireFox\Profiles\*\adblockplus|patterns-backup*.ini
not really a submitted entry as it'd show up weather or not they have the ABP extension installed
Link to comment
  • Moderators
Your Trim_X Bat file is really helpful!! I just tried and it really improves loading. As the entry list keeps growing it will become more and more helpful. Keep up the Good.
It's Actually @Alan_B's .bat
Link to comment
Right, that's why the entry doesn't remove the folders and deletes the setup files only. If you remove the folders also, there will appear an error message or a repair installation (e.g. QuickTime).
Link to comment
A couple new ones
[NirSoft RegScanner Backups*]
LangSecRef=3024
DetectFile=%ProgramFiles%\NirSoft\RegScanner
Warning=This will remove all backups and reports made by RedScanner. If you backed up elsewhere these are safe to remove.
Default=False
FileKey1=%ProgramFiles%\NirSoft\RegScanner|report.html
FileKey2=%ProgramFiles%\NirSoft\RegScanner|*.bak
[bleachBit Error Reproting Log*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Bleachbit
Default=False
FileKey1=%ProgramFiles%\BleachBit|bleachbit.exe.log
Link to comment
NEW ENTRY
[MountPoints2*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2
http://www.ehow.com/how_8541638_delete-mountpoints2-regedit.html
The entry listed below is not working. Can someone take a look at this and tell me what I did wrong?
[Cached File Extensions*]
LangSecRef=3025
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts
Link to comment
LangSecRef=3025
Default=False
It's in the in the winapp2.ini list already. I kept editing, hitting f5 and waiting for the check box to appear with no luck then noticed it was listed twice :blink:
Link to comment
Yes, it is in Winapp2.ini already. I have provided this entry and its not working. :)
Link to comment
A bonus with my Trim_? bat is that duplicated entries are detected and counted / warned as "Repetition Anomalies"
(though Trim_10 dropped the word Repetition to fit the display in the window size of a Laptop
Link to comment
LangSecRef=3025
Default=False
The above is "detected" but does not clean on either Windows 7 SP1 x64 Professional or Windows 7 SP1 x86 Professional. I do not see anything invalid in the RegKey1 code :wacko:
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti:   Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
here's something I've been missing for ages:
(deletes all dialog history including searches (find function) in winrar)
working code, please add this:
[WinRAR Dialog History*]
LangSecRef=3024
Detect=HKCU\Software\WinRAR\DialogEditHistory
Default=False
RegKey1=HKCU\Software\WinRAR\DialogEditHistory
have been trying to do a code that deletes all subfolders separately instead of deleting the entire DIalogEditHistory key for almost 1 hour now...
tried stuff like
RegKey1=HKCU\Software\WinRAR\DialogEditHistory|*.*|REMOVESELF|ArcName|FindArcNames|FindNames
RegKey1=HKCU\Software\WinRAR\DialogEditHistory|*.*|RECURSE|ArcName|FindArcNames|FindNames
and all that stuff with a slash on the end, just like this:
RegKey1=HKCU\Software\WinRAR\DialogEditHistory\|*.*|RECURSE
RegKey1=HKCU\Software\WinRAR\DialogEditHistory\|*.*|REMOVESELF
etc.
even tried using * instead of *.*, because that would make sense, as *.* usually stand for filename.extension since at least 1981, and regkeys don't have any extensions.
but nothing works! dammit! I'm already tearing my hair out...
so I hope you'll just accept my code from above which is the only one that's working at all. thanks
Link to comment
It is functioning fine. The way you have it set to clean removes all values in the Fileexts key, but not subkeys (folders)
Try
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer|FileExts
The above modification does not work either. I'm wondering if its because Explorer.exe is running continuously.
Link to comment
LangSecRef=3025
Default=False
As is, it's removing the key and subkeys on win7 and just the subkeys in winxp for me. With it just recreating the Key and subkeys of Exts when I open a ext type.
After changing it to RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer|FileExts it regenerated the whole entire list :o
edit. the |FileExts didn't work. The list was regenerated when I task killed explorer and restarted it.
Edited by Coffee4Joe
Link to comment
Register a new account
Sign in
Important Information
