Winapp2.ini additions
Winapp2.ini
Thanks saad!
I created a custom skin for winapp2.ini editing in Notepad++
http://dl.dropbox.co...386/winapp2.xml
import it from the language maker
select langauge winapp from the language list.
It works on a dark background
Here's my view
http://dl.dropbox.co...1-12_140500.png
Just thought I'd share it for anyone else who'd like to use it. :)
Very nice. Thank you. :)
Link to comment
Could you please replace the Internet Explorer More entry with the one listed here and try it. I don't have a XP system to try it.
[internet Explorer More*]
LangSecRef=3022
DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe
Default=False
FileKey1=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE
FileKey2=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.*
FileKey3=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey4=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE
RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache
RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache
RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU
RegKey4=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore
RegKey5=HKCU\Software\Microsoft\Internet Explorer\PageSetup
RegKey6=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete
Basically I have provided this entry but, someone added the lines listed below into this entry.
FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.*
FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat
FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF
Your awesome, this totally fixed it. Internet Explorer More* causes no more problems. I guess it was iconcache causing the problems?
Link to comment
The next version of Winapp2.ini will have at minimum 700 entries! A year ago, v.1.0.110108 had 449 entries!
two months before that,
; Version: v1.0 build 101104
had 344 entries. We're now more than double the number of entries in just 14 months, and that's not counting the many that have been removed (included in CCleaner) or combined into eachother over time.
Great job everyone, really :)
Link to comment
this is my first go so please try not to laugh too much :) i have tried and tested it and it works for me
[sABnzbd*]
LangSecRef=3021
DetectFile=%LocalAppData%\sabnzbd
Default=False
FileKey1=%LocalAppData%\sabnzbd\logs|sabnzbd.log
FileKey2=%LocalAppData%\sabnzbd\admin|history1.db
FileKey3=%LocalAppData%\sabnzbd\admin|totals9.sab
FileKey1 deletes log file
FileKey2 deletes download history
FileKey3 deletes total downloaded
or if its better to seperate these ?
win7 32bit
Link to comment
Updated! Changes in the first post (lots of them!)
Thank you very much. Everything looks fine. It must be a lot of work for you this time.
Could you please modify the entries listed below in the next release of Winapp2.ini file.
There were two DetectFiles in this entry. I think one detectfile is sufficient. Also added another RegKey..
[FastStone Capture*]
LangSecRef=3024
DetectFile=%Program Files%\FastStone Capture\FSCapture.exe
Default=False
FileKey1=%LocalAppData%\FastStone\FSC\EditWith|*.*
FileKey2=%AppData%\FastStone\FSC|*.bak
RegKey1=HKCU\Software\FastStone\APP.FSRecorder\Global|_GrbId
RegKey2=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastClipPlayed
RegKey3=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastRecordingFileName
LangSecRef=3022
Default=False
Removed the lines listed below since Miroku4444 was having an issue after removing these files.
http://forum.pirifor...ndpost&p=208851
Link to comment
NEW ENTRIES
[iTunes Cache*]
LangSecRef=3023
DetectFile=%ProgramFiles%\iTunes\iTunes.exe
Default=False
FileKey1=%LocalAppData%\Apple Computer\iTunes|Cache.db
[CyberLink Install Temps*]
LangSecRef=3023
DetectFile=%CommonAppData%\install_clap
Default=False
FileKey1=%CommonAppData%\install_clap|*.*|REMOVESELF
[TEMP folder*]
LangSecRef=3025
DetectFile=%CommonAppData%\TEMP
Default=False
FileKey1=%CommonAppData%\TEMP|*.*|RECURSE
The TEMP folder entry is good for Windows Vista and Windows 7. CyberLink programs leave some temporary installation files here.
Link to comment
Passing this along from the bleachbit forums
Modified
[batman Arkham Asylum*]
LangSecRef=3021
DetectFile=%Documents%\Eidos\Batman Arkham Asylum\
Default=False
FileKey1=%Documents%\Eidos\Batman Arkham Asylum\BmGame|*.log|RECURSE
It was "Detect=%Documents%\Eidos\Batman Arkham Asylum\"
As detect it was causing an error in bleachbit.
Link to comment
Thanks for this very useful "winapp2.ini" file. I think a few entries need a warning message:
[Remote Desktop Connection More*]
Warning=This will reset all Remote Desktop Connection settings.
[Windows 7 ShellBags*] and [Windows XP ShellBags*]
Warning=This will delete window size, window position and view setting of all folders.
Maybe you can include them in the next release.
Link to comment
  • Moderators
Thanks for this very useful "winapp2.ini" file. I think a few entries need a warning message: [Remote Desktop Connection More*] Warning=This will reset all Remote Desktop Connection settings. [Windows 7 ShellBags*] and [Windows XP ShellBags*] Warning=This will delete window size, window position and view setting of all folders. Maybe you can include them in the next release.
+1
Link to comment
I wrote some new entries (my first ones):
[bookmark Backups*]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\Firefox
Warning=This will delete all bookmark backups. Make sure to backup them manually.
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\bookmarkbackups|*.json
[ElsterFormular*]
LangSecRef=3021
DetectFile=%ProgramFiles%\ElsterFormular
Default=False
FileKey1=%AppData%\elsterformular\eric\log|*.log
FileKey2=%AppData%\elsterformular\eric\tmp|*.*
FileKey3=%AppData%\elsterformular\pica\log|*.log
FileKey4=%AppData%\elsterformular\pluginmanager\tmp|*.*
FileKey5=%LocalAppData%\.elfohilfe|*.*|REMOVESELF
[MS Office Help Cache*]
LangSecRef=3021
DetectFile=%CommonAppData%\Microsoft Help
Default=False
FileKey1=%LocalAppData%\Microsoft Help|*.*
[brother Printer Debug Logs*]
LangSecRef=3024
DetectFile=%CommonAppData%\Brother\BrLog
Default=False
FileKey1=%CommonAppData%\Brother\BrLog|*.log
They work flawless on my system (Windows 7 x64).
Maybe you can add these too: http://forum.pirifor...ndpost&p=208541
Link to comment
  • Moderators
[MS Office Help Cache*]LangSecRef=3021DetectFile=%CommonAppData%\Microsoft HelpDefault=FalseFileKey1=%LocalAppData%\Microsoft Help|*.*
Ilike this entry I didn't even know I had that one, thanks (thus far no ill effects)
Link to comment
  • Moderators
Arg, those entries with strange unix encoding. Windows Notepad doesn't like it! D:.
I've fixed them though, near as I can tell. I did a search for them.
what is this in reply to? (if it was to my post above, that's not the ini that's the forum software)
Link to comment
CORRECTED ENTRY
[iTunes Logs*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\Apple Computer\Logs|*.crash|RECURSE
FileKey2=%AppData%\Apple Computer\Logs|*.log|RECURSE
FileKey3=%WinDir%\system32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log|RECURSE
Corrected the highlighted area from *.* to *.log|RECURSE
It used be like this.
Link to comment
Thanks! The only effect I recognize is that the help window needs a little bit longer to show up. But I use the help windows very rarely, so this doesn't bother me.
Link to comment
Register a new account
Sign in
Important Information
