Winapp2.ini Posted January 6, 2012 Author Share Posted January 6, 2012 They look like log files and database files to me, which are usually okay to delete. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Miroku4444 Posted January 6, 2012 Share Posted January 6, 2012 Try this. http://www.mydigital...-google-chrome/ I was wondering if you also have Firefox installed on the system. Firefox has a feature called 'caret browsing'. The main reason that Firefox has this feature is that you can select text with your keyboard. This feature could cause the curser blink. You can disable this feature. Type in "about:config" in the address bar and then type in "caret" in the filter box and simply double click to change the option from "true" to "false". Of course i have firefox, its my main browser. Just in case this is the cause, ill disable that feature. Don't use it anyway. Which one do i set to false?? Link to comment Share on other sites More sharing options...
JDPower Posted January 6, 2012 Share Posted January 6, 2012 Which one do i set to false?? http://www.lmgtfy.co...sing+in+firefox accessibility.browsewithcaret_shortcut.enabled Link to comment Share on other sites More sharing options...
Miroku4444 Posted January 7, 2012 Share Posted January 7, 2012 Caret browsing now disabled. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 7, 2012 Moderators Share Posted January 7, 2012 Caret browsing now disabled. lets us know if that fixed the issue ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Miroku4444 Posted January 7, 2012 Share Posted January 7, 2012 lets us know if that fixed the issue I doubt it will as this was an windows explorer(OS) issue and not with Firefox. I appreciate the suggestion though, so thanks. Ill try it later. Link to comment Share on other sites More sharing options...
siliconman01 Posted January 7, 2012 Share Posted January 7, 2012 Added FileKey32 and FileKey33 [TuneUp Utilities 2011/2012 Reg Defrag Cleanup*] LangSecRef=3024 Detect=HKCU\Software\TuneUp\Utilities\10.0 Detect2=HKCU\Software\TuneUp\Utilities\12.0 Default=False FileKey1=%WinDir%\System32\config|SECURITY_tureg_old FileKey2=%WinDir%\System32\config|SOFTWARE_tureg_old FileKey3=%WinDir%\System32\config|SYSTEM_tureg_old FileKey4=%WinDir%\System32\config|DEFAULT_tureg_new.LOG1 FileKey5=%WinDir%\System32\config|DEFAULT_tureg_new.LOG2 FileKey6=%WinDir%\System32\config|SAM_tureg_new.LOG1 FileKey7=%WinDir%\System32\config|SAM_tureg_new.LOG2 FileKey8=%WinDir%\System32\config|SECURITY_tureg_new.LOG1 FileKey9=%WinDir%\System32\config|SECURITY_tureg_new.LOG2 FileKey10=%WinDir%\System32\config|SOFTWARE_tureg_new.LOG1 FileKey11=%WinDir%\System32\config|SOFTWARE_tureg_new.LOG2 FileKey12=%WinDir%\System32\config|SYSTEM_tureg_new.LOG1 FileKey13=%WinDir%\System32\config|SYSTEM_tureg_new.LOG2 FileKey14=%WinDir%\System32\config|DEFAULT_tureg_old FileKey15=%WinDir%\System32\config|SAM_tureg_old FileKey16=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_old FileKey17=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG1 FileKey18=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG2 FileKey19=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_old FileKey20=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG1 FileKey21=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG2 Filekey22=%WinDir%\System32\config|COMPONENTS_tureg_old Filekey23=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG1 Filekey24=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG2 FileKey25=%LocalAppData%\Microsoft\Windows\|USRCLASS.DAT_tureg_old FileKey26=%UserProfile%|NTUSER.DAT_tureg_new.LOG1 FileKey27=%UserProfile%|NTUSER.DAT_tureg_new.LOG2 FileKey28=%UserProfile%|NTUSER.DAT_tureg_old FileKey29=%SystemDrive%\Boot\|BCD_tureg_new.LOG1 FileKey30=%SystemDrive%\Boot\|BCD_tureg_new.LOG2 FileKey31=%SystemDrive%\Boot\|BCD_tureg_old FileKey32=%LocalAppData%\Microsoft\Windows\|USRCLASS.DAT_tureg_new.LOG1 FileKey33=%LocalAppData%\Microsoft\Windows\|USRCLASS.DAT_tureg_new.LOG2 Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
nodles Posted January 7, 2012 Share Posted January 7, 2012 Added FileKey32 and FileKey33 Btw. I guess you could shorten this (and other) entries by using wildcards in the end (*-mark). In example: FileKey32=%LocalAppData%\Microsoft\Windows\|USRCLASS.DAT_tureg_new.LOG* FileKey1=%WinDir%\System32\config|SECURITY_tureg_old FileKey2=%WinDir%\System32\config|SOFTWARE_tureg_old FileKey3=%WinDir%\System32\config|SYSTEM_tureg_old FileKey4=%WinDir%\System32\config|DEFAULT_tureg_new.LOG* FileKey5=%WinDir%\System32\config|SAM_tureg_new.LOG* FileKey6=%WinDir%\System32\config|SECURITY_tureg_new.LOG* FileKey7=%WinDir%\System32\config|SOFTWARE_tureg_new.LOG* FileKey8=%WinDir%\System32\config|SYSTEM_tureg_new.LOG* FileKey9=%WinDir%\System32\config|DEFAULT_tureg_old FileKey10=%WinDir%\System32\config|SAM_tureg_old FileKey11=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_old FileKey12=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG* FileKey13=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_old FileKey14=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG* Filekey15=%WinDir%\System32\config|COMPONENTS_tureg_old Filekey16=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG* FileKey17=%LocalAppData%\Microsoft\Windows\|USRCLASS.DAT_tureg_old FileKey18=%UserProfile%|NTUSER.DAT_tureg_new.LOG* FileKey19=%UserProfile%|NTUSER.DAT_tureg_old FileKey20=%SystemDrive%\Boot\|BCD_tureg_new.LOG* FileKey21=%SystemDrive%\Boot\|BCD_tureg_old FileKey22=%LocalAppData%\Microsoft\Windows\|USRCLASS.DAT_tureg_new.LOG* That's 11 (unnecessary) FileKeys less. Link to comment Share on other sites More sharing options...
Alan_B Posted January 7, 2012 Share Posted January 7, 2012 Is the [WLSetup Logs*] entry sensible ? It starts with [WLSetup Logs*] LangSecRef=3022 DetectFile=%LocalAppData%\Microsoft\WLSetup\Logs\ Default=False FileKey1=%LocalAppData%\Microsoft\WLSetup\Logs|*.log|REMOVESELF First of all this is volatile/intermittent detection. If it appears and you clean the REMOVESELF should remove the "DetectFile=..." trigger, and hitting the Function F5 key will cause CC to refresh and the check-box will not appear again. Secondly it seems to me that it attempts to remove *.log files but avoid removing "brother/sister" files with other extensions BUT THEN it tries to REMOVESELF the parent folder, and if it succeeds there will be no home for future "brother/sister" files. A bit like an evil step-mother, don't evict the children, but when they go out change the locks quick Link to comment Share on other sites More sharing options...
nodles Posted January 7, 2012 Share Posted January 7, 2012 Not sure whose entry that is (maybe mine? ), but it's ok if you remove the "REMOVESELF"-command. Which "other extensions" do you mean? Link to comment Share on other sites More sharing options...
nodles Posted January 7, 2012 Share Posted January 7, 2012 Possibly new entries for Spybot S&D: http://forum.piriform.com/index.php?showtopic=34859 Link to comment Share on other sites More sharing options...
SMalik Posted January 7, 2012 Share Posted January 7, 2012 MODIFIED ENTRY http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=207593 [internet Explorer More*] LangSecRef=3022 DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe Default=False RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey5=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey6=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.* FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF FileKey4=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE FileKey5=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey6=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey7=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE Added: RegKey6=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete Moved into alphabet order: RegKey4=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 7, 2012 Moderators Share Posted January 7, 2012 saad I think we should wait on the ie more entry until Miroku4444's issue is resolved, since it is mostly your entry, I believe, I wonder if you could give him some aid in it ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 7, 2012 Author Share Posted January 7, 2012 Is the [WLSetup Logs*] entry sensible ? It starts with [WLSetup Logs*] LangSecRef=3022 DetectFile=%LocalAppData%\Microsoft\WLSetup\Logs\ Default=False FileKey1=%LocalAppData%\Microsoft\WLSetup\Logs|*.log|REMOVESELF First of all this is volatile/intermittent detection. If it appears and you clean the REMOVESELF should remove the "DetectFile=..." trigger, and hitting the Function F5 key will cause CC to refresh and the check-box will not appear again. Secondly it seems to me that it attempts to remove *.log files but avoid removing "brother/sister" files with other extensions BUT THEN it tries to REMOVESELF the parent folder, and if it succeeds there will be no home for future "brother/sister" files. A bit like an evil step-mother, don't evict the children, but when they go out change the locks quick Possibly. No future files are generated until a WLSetup is run again though, but I think you're right. Some entries are designed for applications that are portable, but WL is not portable so I think the removeself can be changed to |*.*|RECURSE winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted January 7, 2012 Share Posted January 7, 2012 saad I think we should wait on the ie more entry until Miroku4444's issue is resolved, since it is mostly your entry, I believe, I wonder if you could give him some aid in it That issue has nothing to do with Internet Explorer More entry. I think that issue is with Adobe FlashPlayer or Shockwave Player. I think he should uninstall both the programs and re-install. http://forum.pirifor...ndpost&p=208487 What exactly Internet Explorer More entry removes. http://forum.pirifor...ndpost&p=192469 Some of them are included into CCleaner now. Link to comment Share on other sites More sharing options...
Coffee4Joe Posted January 8, 2012 Share Posted January 8, 2012 New Entry [CamStudio*] LangSecRef=3023 DetectFile=%ProgramFiles%\CamStudio\ Default=False FileKey1=%ProgramFiles%\CamStudio|CamLayout.ini FileKey2=%ProgramFiles%\CamStudio|CamShapes.ini FileKey3=%ProgramFiles%\CamStudio|Camdata.ini After some more testing this entire entry can be left out. Cleaning Camdata.ini will cause the program to crash unless you open/close then reopen it Cleaning CamShapes.ini will wipe the annotaions list CamLayout.ini saves settings on close Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 11, 2012 Author Share Posted January 11, 2012 Next update moves a lot of entries around to more appropirate categories. Post any changes you think would be appropriate All games are moving to Applications, for example. Since they're currently spread between all of the different sections. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted January 11, 2012 Share Posted January 11, 2012 I think we should move "FileKey" before the "RegKey" in entries. I have tried some other privacy eraser programs and that is how they have their entries. For example: [internet Explorer More*] LangSecRef=3022 DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe Default=False FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.* FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF FileKey4=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE FileKey5=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey6=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey7=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey5=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey6=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 11, 2012 Author Share Posted January 11, 2012 (edited) I've just gone through and finished doing that, thanks for the idea, Saad. Linearization! Edited January 11, 2012 by Winapp2.ini winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Alan_B Posted January 11, 2012 Share Posted January 11, 2012 RegKey6=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete ??????????????????????????????????????????????????????? That surprises me. I naturally assumed that ...\PendingDelete signified :- Failed to promptly delete at the time ; On Microsoft's ToDo list ; Should get done on the next Reboot, or failing that the next Patch Tuesday, or failing that the next Operating System Service Pack. I would be concerned that if the flag was removed then Windows might forget to delete what was pending. Do these ...\PendingDelete flags get forgotten and left behind after the relevant delete ? Or is Microsoft better at promising than it is at performing requisite deletions ? Link to comment Share on other sites More sharing options...
SMalik Posted January 12, 2012 Share Posted January 12, 2012 ??????????????????????????????????????????????????????? That surprises me. I naturally assumed that ...\PendingDelete signified :- Failed to promptly delete at the time ; On Microsoft's ToDo list ; Should get done on the next Reboot, or failing that the next Patch Tuesday, or failing that the next Operating System Service Pack. I would be concerned that if the flag was removed then Windows might forget to delete what was pending. Do these ...\PendingDelete flags get forgotten and left behind after the relevant delete ? Or is Microsoft better at promising than it is at performing requisite deletions ? It is related to the FileKey4. Last Active directory files traces in registry. FileKey4=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted January 12, 2012 Share Posted January 12, 2012 I doubt it will as this was an windows explorer(OS) issue and not with Firefox. I appreciate the suggestion though, so thanks. Ill try it later. Could you please replace the Internet Explorer More entry with the one listed here and try it. I don't have a XP system to try it. [internet Explorer More*] LangSecRef=3022 DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe Default=False FileKey1=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE FileKey2=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.* FileKey3=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey4=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU RegKey4=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey5=HKCU\Software\Microsoft\Internet Explorer\PageSetup RegKey6=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete Basically I have provided this entry but, someone added the lines listed below into this entry. FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.* FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 12, 2012 Author Share Posted January 12, 2012 The next update will come sometime by sunday, lots of organizational changes (LangSecRef movements, ordering of FileKeys before RegKeys, etc.) but there are enough changes to whats cleaned to warrant it I think winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted January 12, 2012 Share Posted January 12, 2012 MODIFIED ENTRY [FastStone Capture*] LangSecRef=3023 DetectFile=%Program Files%\FastStone Capture\FSCapture.exe Default=False FileKey1=%LocalAppData%\FastStone\FSC\EditWith|*.* FileKey2=%AppData%\FastStone\FSC|*.bak RegKey1=HKCU\Software\FastStone\APP.FSRecorder\Global|_GrbId RegKey2=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastClipPlayed RegKey3=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastRecordingFileName I have edited this post. Added: HKCU\Software\FastStone\APP.FSRecorder\Global|_GrbId Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 12, 2012 Author Share Posted January 12, 2012 Thanks saad! I created a custom skin for winapp2.ini editing in Notepad++ http://dl.dropbox.com/u/14823386/winapp2.xml import it from the language maker select langauge winapp from the language list. It works on a dark background Here's my view http://dl.dropbox.com/u/14823386/2012-01-12_140500.png Just thought I'd share it for anyone else who'd like to use it. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
