Coffee4Joe Posted January 26, 2012 Share Posted January 26, 2012 I agree it should be left out. I should of put "But definatly not for daily cleaning." in bright red bold font Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 26, 2012 Moderators Share Posted January 26, 2012 yes I believe we two three are of the same mind on that, but sadly the question is brought up for one or the other every 3 or so pages ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 26, 2012 Author Share Posted January 26, 2012 And with 59 pages of posts.. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
pook1y7985 Posted January 27, 2012 Share Posted January 27, 2012 Looking at the above. I agree with adding a warning message to the below. It should be pointed out this file is used by Windows to do a normal built in defrag as welll. Some sits I have found do not recommend removing this file from your system as it may not be recreated. You might want to think about either removing completely or putting a Use with Caution message or only periodically as its only one ini [Defragmentation List*] LangSecRef=3025 DetectFile=%WinDir% Default=False FileKey1=%WinDir%\Prefetch|Layout.ini Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 27, 2012 Author Share Posted January 27, 2012 Sounds dangerous, is it the sort of thing you guys think should be removed? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 27, 2012 Moderators Share Posted January 27, 2012 i vote yes ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
pook1y7985 Posted January 27, 2012 Share Posted January 27, 2012 Modified Entry I noticed that the one FileKey Entry is cleaned now by default so I removed it. [MalwareBytes Anti Malware Logs*] LangSecRef=3024 Detect=HKCU\Software\Malwarebytes' Anti-Malware Default=False FileKey1=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.* Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 27, 2012 Author Share Posted January 27, 2012 Whoops. I didn't do my usual scan for true defaults, that's my bad . winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted January 27, 2012 Share Posted January 27, 2012 Modified Entry I noticed that the one FileKey Entry is cleaned now by default so I removed it. [MalwareBytes Anti Malware Logs*] LangSecRef=3024 Detect=HKCU\Software\Malwarebytes' Anti-Malware Default=False FileKey1=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.* I would prefer that you not remove FileKey2 from this code because the built in code for MalwareBytes removes the quarantined items. I leave that one unchecked because I do not like removing quarantined security items as a normal cleaning element. I would like this cleaning element clean all logs on its own. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted January 27, 2012 Share Posted January 27, 2012 [Defragmentation List*] LangSecRef=3025 DetectFile=%WinDir% Default=False FileKey1=%WinDir%\Prefetch|Layout.ini The above entry negates part of the features of Perfectdisk in that it prevents Perfectdisk from aligning programs so that the system will boot faster. I recommend that this entry before or a warning message be inserted. It may also negatively affect other third party defraggers (I do not know this for fact, but it may). The link below further explains how Perfectdisk interfaces with Layout.ini. http://superuser.com...agement-options Suggested Warning message: [Defragmentation List*] LangSecRef=3025 Warning=DO NOT use if your system has PerfectDisk defragging software. DetectFile=%WinDir% Default=False FileKey1=%WinDir%\Prefetch|Layout.ini First time I saw this entry in R-Wipe&Clean few years back. East-Tec Eraser has it in their program for the last few years. I always have PerfectDisk on my system. Right now I have PerfectDisk 12.5 Pro. I also have R-Wipe&Clean that always removes this file, never had any issue. BTW this file is not a part of PerfectDisk program. It also keeps information about the programs were removed from the system until it got recreated again. http://www.pcreview....i-t2176963.html Windows recreate this file after restarting the system as long as Superfetch (Vista-7) service is running. In case if you delete old one and need to recreate a fresh one right away here is a code: http://answers.micro...e2-b6110691580c http://social.techne...83-8c6c8a450289 Link to comment Share on other sites More sharing options...
SMalik Posted January 27, 2012 Share Posted January 27, 2012 I think we should change the LangSecRef of the entry listed below to bring the CCleaner's Freemake Video Downloader entry and this one in the same category. [Freemake Video Downloader More*] LangSecRef=3022 Detect=HKCU\Software\Freemake\FreemakeVideoDownloader Default=False FileKey1=%ProgramFiles%\Freemake\Freemake Video Downloader|trace.log FileKey2=%Documents%\Freemake\FreemakeVideoDownloader|fvd.bin FileKey3=%Documents%\Freemake\FreemakeVideoDownloader\History\Thumbnails|*.* FileKey4=%Documents%\Freemake\FreemakeVideoDownloader\History|*.xml Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 27, 2012 Author Share Posted January 27, 2012 I think we should change the LangSecRef of the entry listed below to bring the CCleaner's Freemake Video Downloader entry and this one in the same category. [Freemake Video Downloader More*] LangSecRef=3022 Detect=HKCU\Software\Freemake\FreemakeVideoDownloader Default=False FileKey1=%ProgramFiles%\Freemake\Freemake Video Downloader|trace.log FileKey2=%Documents%\Freemake\FreemakeVideoDownloader|fvd.bin FileKey3=%Documents%\Freemake\FreemakeVideoDownloader\History\Thumbnails|*.* FileKey4=%Documents%\Freemake\FreemakeVideoDownloader\History|*.xml Will do, thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted January 27, 2012 Share Posted January 27, 2012 I have Norton Internet Security 2012 on my system. There is problem with the entry listed below. Each time I use this entry I start getting an error. Some of the log files at that location shouldn't be deleted. I am attaching few snapshots of the error with this message. [Norton Installer Logs*] LangSecRef=3021 DetectFile=%CommonAppData%\NortonInstaller\Logs Default=False FileKey1=%CommonAppData%\NortonInstaller\Logs|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
SMalik Posted January 27, 2012 Share Posted January 27, 2012 MODIFIED ENTRY Added highlighted lines. [FastStone Capture*] LangSecRef=3024 DetectFile1=%AppData%\FastStone\FSC DetectFile2=%ProgramFiles%\FastStone Capture\FSCapture.exe Default=False FileKey1=%LocalAppData%\FastStone\FSC\EditWith|*.* FileKey2=%LocalAppData%\FastStone\FSC|*.db FileKey3=%AppData%\FastStone\FSC|*.bak FileKey4=%AppData%\FastStone\FSC|*.db RegKey1=HKCU\Software\FastStone\APP.FSRecorder\Global|_GrbId RegKey2=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastClipPlayed RegKey3=HKCU\Software\FastStone\APP.FSRecorder\Global|_LastRecordingFileName Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 27, 2012 Author Share Posted January 27, 2012 Thanks Saad, and thanks for pointing out the norton problem winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
ProPaan Posted January 27, 2012 Share Posted January 27, 2012 hi, im new here, i just want to say that Aimp 3 Profile folder is not in "ProgramFiles\AIMP3\Profile", is it in "AppData/Roaming/AIMP3", it was in ProgramFiles for AIMP2. And aimp have 2 utilities "advanced tag editor" and "Audio Library" maybe add them too files are "AIMP3ate.bak" and "AIMP3lib.bak" the are also in "AppData/Roaming/AIMP3" and i know many users still using aimp2, maybe add it too DetectFile=%ProgramFiles%\AIMP2\AIMP2.exe FileKey1=%ProgramFiles%\AIMP2\!Backup|*.zip FileKey2=%ProgramFiles%\AIMP2\Profile|AIMP2.bak sorry for bad english Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 27, 2012 Author Share Posted January 27, 2012 Thanks, will do. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted January 27, 2012 Share Posted January 27, 2012 NEW ENTRY [batman: Arkham City*] LangSecRef=3021 DetectFile=%Documents%\WB Games\Batman Arkham City\BmGame\Logs Default=False FileKey1=%Documents%\WB Games\Batman Arkham City\BmGame\Logs|*.* MODIFIED ENTRIES [MS IE6 Installation Temps*] LangSecRef=3025 DetectFile=%SystemDrive%\msdownld.tmp DetectFile2=%WinDir%|msdownld.tmp Default=False FileKey1=%SystemDrive%|msdownld.tmp FileKey2=%WinDir%|msdownld.tmp Added DetectFile2 & FileKey2. [ATI/AMD Graphics Driver Install Files*] LangSecRef=3024 Detect=HKLM\Software\Ati Technologies\Install\ATI Catalyst Install Manager Default=False FileKey1=%SystemDrive%\ATI|*.*|REMOVESELF FileKey2=%SystemDrive%\AMD|*.*|REMOVESELF Changed FileKey2's RECURSE to REMOVESELF. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 27, 2012 Author Share Posted January 27, 2012 *** NEW *** Click here for Winapp2.ini for use with Winsys2.ini winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted January 27, 2012 Share Posted January 27, 2012 Will try, btw missing URL in new Winapp2.ini "This is a special winapp2.ini made for use with its sister file Winsys.ini, you can find Winsys.ini here:" Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 27, 2012 Moderators Share Posted January 27, 2012 [Windows Error Reporting More*] LangSecRef=3025 DetectFile=%WinDir% Default=False RegKey1=HKU\S-1-5-18\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation FileKey1=%WinDir%\System32\config\systemprofile\AppData\Local\CrashDumps|*.dmp this needs to move to winsys2 as Windows Error Reporting is in the Windows tab ( LangSecRef=3003 ) From Winapp2 Remove [Windows Media Center*] LangSecRef=3023 DetectFile=%WinDir%\ehome\ehshell.exe Default=False FileKey1=%CommonAppData%\Microsoft\eHome\logs|*.* FileKey2=%LocalAppData%\Microsoft\eHome|playlistcache.db RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center\MRU\SettingsMRU replace with [Windows Media Center More*] LangSecRef=3023 DetectFile=%WinDir%\ehome\ehshell.exe Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center\MRU\SettingsMRU the Windows Media Player break outs replicate a lot of the default windows media player entry, perhaps a warning to Uncheck Windows Media Player or items may be deleted even if one of the breakout is unchecked Both Real Player Trimmer and Realplayer converter only clean realplayer 12 (i.e. realplayer 15 uses HKCU\Software\RealNetworks\RealConverter\15.0\Preferences and HKCU\Software\RealNetworks\RealTrimmer\15.0\Preferences ) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 27, 2012 Author Share Posted January 27, 2012 the Windows Media Player break outs replicate a lot of the default windows media player entry, perhaps a warning to Uncheck Windows Media Player or items may be deleted even if one of the breakout is unchecked ...? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 27, 2012 Author Share Posted January 27, 2012 Will try, btw missing URL in new Winapp2.ini "This is a special winapp2.ini made for use with its sister file Winsys.ini, you can find Winsys.ini here:" Oops, fixed that. Forgot to re-upload it after making the bit.ly link winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 27, 2012 Moderators Share Posted January 27, 2012 ... ? From default Clean (the redundant entries entry are is in red) [Windows Media Player] ID=2033 LangSecRef=3023 Detect=HKCU\Software\Microsoft\MediaPlayer\Player Default=True RegKey1=HKCU\Software\Microsoft\MediaPlayer\Player\RecentFileList RegKey2=HKCU\Software\Microsoft\MediaPlayer\Player\RecentURLList RegKey3=HKCU\Software\Microsoft\MediaPlayer\Preferences|LastPlayList RegKey4=HKCU\Software\Microsoft\MediaPlayer\Preferences|LastPlayListIndex RegKey5=HKCU\Software\Microsoft\MediaPlayer\Player\Settings|SaveAsDir RegKey6=HKCU\Software\Microsoft\MediaPlayer\AutoComplete\MediaEdit RegKey7=HKCU\Software\Microsoft\MediaPlayer\Radio\MRUList FileKey1=%LocalAppData%\Microsoft\Media Player|lastplayed.wpl FileKey2=%LocalAppData%\Microsoft\Media Player|cacheentry*.*|RECURSE Ok so only one redundant (also see my real player edit above ) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted January 27, 2012 Share Posted January 27, 2012 MODIFIED ENTRIES Added highlighted lines as Nergal suggested. [RealPlayer Converter*] LangSecRef=3023 DetectFile=%ProgramFiles%\Real\RealPlayer\realconverter.exe Default=False RegKey1=HKCU\Software\RealNetworks\RealJukebox\1.0\Preferences\WatchFolders RegKey2=HKCU\Software\RealNetworks\RealConverter\12.0\Preferences\BrowsePath RegKey3=HKCU\Software\RealNetworks\RealConverter\12.0\Preferences\DestinationPath RegKey4=HKCU\Software\RealNetworks\RealConverter\15.0\Preferences\BrowsePath RegKey5=HKCU\Software\RealNetworks\RealConverter\15.0\Preferences\DestinationPath [RealPlayer Trimmer*] LangSecRef=3023 DetectFile=%ProgramFiles%\Real\RealPlayer\realtrimmer.exe Default=False RegKey1=HKCU\Software\RealNetworks\RealTrimmer\12.0\Preferences\BrowsePath RegKey2=HKCU\Software\RealNetworks\RealTrimmer\15.0\Preferences\BrowsePath All the lines are valid in the entry listed below. I don't know why Nergal is asking to change it. [Windows Media Center*] LangSecRef=3023 DetectFile=%WinDir%\ehome\ehshell.exe Default=False FileKey1=%CommonAppData%\Microsoft\eHome\logs|*.* FileKey2=%LocalAppData%\Microsoft\eHome|playlistcache.db RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center\MRU\SettingsMRU Link to comment Share on other sites More sharing options...
