CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
here's something I've been missing for ages:
(deletes all dialog history including searches (find function) in winrar)
working code, please add this:
[WinRAR Dialog History*]
LangSecRef=3024
Detect=HKCU\Software\WinRAR\DialogEditHistory
Default=False
RegKey1=HKCU\Software\WinRAR\DialogEditHistory
have been trying to do a code that deletes all subfolders separately instead of deleting the entire DIalogEditHistory key for almost 1 hour now...
tried stuff like
RegKey1=HKCU\Software\WinRAR\DialogEditHistory|*.*|REMOVESELF|ArcName|FindArcNames|FindNames
RegKey1=HKCU\Software\WinRAR\DialogEditHistory|*.*|RECURSE|ArcName|FindArcNames|FindNames
and all that stuff with a slash on the end, just like this:
RegKey1=HKCU\Software\WinRAR\DialogEditHistory\|*.*|RECURSE
RegKey1=HKCU\Software\WinRAR\DialogEditHistory\|*.*|REMOVESELF
etc.
even tried using * instead of *.*, because that would make sense, as *.* usually stand for filename.extension since at least 1981, and regkeys don't have any extensions.
but nothing works! dammit! I'm already tearing my hair out...
so I hope you'll just accept my code from above which is the only one that's working at all. thanks
Thanks!
Share this post
Link to post
As is, it's removing the key and subkeys on win7 and just the subkeys in winxp for me. With it just recreating the Key and subkeys of Exts when I open a ext type.
After changing it to RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer|FileExts it regenerated the whole entire list :o
edit. the |FileExts didn't work. The list was regenerated when I task killed explorer and restarted it.
Maybe it can't be removed :o
Share this post
Link to post
[Cached File Extensions*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts
I recommend that this code be removed from WinApp2.ini. On doing a manual removal of this key, several of my programs no long recognized their file associations. Outlook also lost the fact that it was the default email client. The FileExts key does start to regenerate itself, but it does require some manual intervention (as stated above) during this regeneration. I don't think this is something that WinApp2.ini should invoke on users.
Note: I had manually backed up the FileExts key before manually removing it.
Share this post
Link to post
Or just add warning message to it?
I think removal would be the better option, for the very limited functionality the entry provides it's not worth the hassle (IMO)
Share this post
Link to post
Yeah, it seems like it'd cause more problems than it's worth, and doesn't actually appear to do anything beneficial.
Share this post
Link to post
LangSecRef=3025
Default=False
siliconman01, you always scare people here. :) I am a registered user of R-Wipe&Clean and East-Tec Eraser since these programs are out. Both the programs have an option to remove Cached File Extensions. I always use this option on 2 diff. machines (Win 7 32-bit and 64-bit), never had a problem.
BTW it is just a 'CACHED' copy of user's File Extensions.
Share this post
Link to post
Code to kill and then restart Explorer.exe. You need to kill and restart explorer.exe to remove Tray Notification cache after running CCleaner.
@echo off
taskkill /f /IM explorer.exe
start explorer.exe
exit
Share this post
Link to post
@echo off
start explorer.exe
exit
How about
@echo off
cd C:\Program Files\CCleaner\
ccleaner.exe /AUTO
explorer.exe
Share this post
Link to post
@echo off
start explorer.exe
exit
Would you not get the same result by rebooting the P.C., which also kills and restarts explorer.exe (and much more) ?
Why would you want CCleaner to take special action if the cache is destined for oblivion at the end of the day ?
Share this post
Link to post
How about
@echo off
ccleaner.exe /AUTO
explorer.exe
Even better.
Share this post
Link to post
Yes, I agree. I am sorry I tried my best but, I couldn't make it work.
Share this post
Link to post
Updated :)
I will update the winsys/winapp combo a little later, for now the main winapp2.ini has been updated though.
Share this post
Link to post
Updated :)
Thank you. Don't know if you missed the posts listed below.
http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=209608
http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=209727
Share this post
Link to post
MODIFIED ENTRY
[Corel VideoStudio Pro X4*]
LangSecRef=3023
DetectFile=%ProgramFiles%\Corel\Corel VideoStudio Pro X4\vstudio.exe
Default=False
FileKey1=%AppData%\Corel\Messages|*.*|RECURSE
FileKey2=%AppData%\Ulead Systems\Corel VideoStudio Pro\14.0\en-US|VS_Pro.log
ExcludeKey1=FILE|%AppData%\Corel\Messages|*.policy
RegKey1=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\HerRFL
RegKey2=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\Library Manager|Latest Export Folder
RegKey3=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\Preference|Working Folder
RegKey4=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\14.0\VIO\Recent Dir
Share this post
Link to post
I suggest the following warning message be added in the code below:
[MS Management Console More*]
LangSecRef=3025
DetectFile=%AppData%\Microsoft\MMC
Warning=This resets the window size of Task Scheduler and Event Viewer back to the default size.
Default=False
FileKey1=%AppData%\Microsoft\MMC|*.*
Share this post
Link to post
Side project: I'm trying to move more entries over to Detect= from DetectFile, if you guys see any that can be moved, drop a correction here :)
Share this post
Link to post
The two codes below show up on Windows 7 systems. An OS detect needs to be included.
[Windows XP MUICache*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\ShellNoRoam\
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\ShellNoRoam\MUICache
[Windows XP ShellBags*]
LangSecRef=3025
Warning=This will delete window size, window position and view setting of all folders.
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU
RegKey2=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags
Share this post
Link to post
You have missed some of my modified entries:
[Avira AntiVir Logs*]
LangSecRef=3024
DetectFile1=%CommonAppData%\Avira
Default=False
FileKey1=%CommonAppData%\Avira\AntiVir Desktop\LOGFILES|*.*
FileKey2=%ProgramFiles%\Avira\AntiVir Desktop\APPDATA\LOGFILES|*.*
Added FileKey2.
[star Wars: The Old Republic*]
LangSecRef=3021
DetectFile1=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic
Default=False
FileKey1=%Documents%|Install STAR WARS The Old Republic.log
FileKey2=%LocalAppData%\SWTOR\CrashDump\swtor|*.*
FileKey3=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\betatest\retailclient\Temp|*.log
FileKey4=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\logs|*.log
FileKey5=%ProgramFiles%\Electronic Arts\BioWare\Star Wars-The Old Republic\swtor\retailclient\swtor\logs|*.log
FileKey6=%UserProfile%\Documents|Uninstall STAR WARS The Old Republic.log
Modified & added FileKeys.
[uTorrent More*]
LangSecRef=3022
DetectFile=%ProgramFiles%\uTorrent\uTorrent.exe
Default=False
FileKey1=%AppData%\utorrent|*.log
FileKey2=%AppData%\uTorrent\ie|*.tmp
FileKey3=%ProgramFiles%\uTorrent|*.tmp
Added FileKey2.
Share this post
Link to post
Yup, and it's correct if I remember right. Now at work so can't check and might have cleaned that already.
Share this post
Link to post
I only mention it because (as above) many entries people submit use %UserProfile%\Documents instead of just %Documents% :)
Share this post
Link to post
Ah ok, but %Documents% is shorter! :D Just checked, don't have the file anymore.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
