CCleaner Community Forums
Winapp2.ini additions
Winapp2.ini
Guest Keatah
Duplicate set of entries? Which can I get rid of?
[Adobe Flash Install Logs*]
LangSecRef=3023
DetectFile1=%WinDir%\System32\Macromed\Flash
DetectFile2=%WinDir%\SysWOW64\Macromed\Flash
Default=False
FileKey1=%WinDir%\System32\Macromed\Flash|FlashInstall.log
FileKey2=%WinDir%\SysWOW64\Macromed\Flash|FlashInstall.log
AND
LangSecRef=3023
DetectFile=%WinDir%\System32\Macromed\Flash|FlashInstall.log
Default=False
Link to comment
  • Moderators
Yes this has been discussed and will be fixed in next version. Go ahead and remove the second one (as it is covered by the first one)
Link to comment
  • Moderators
Just kidding
Link to comment
MODIFIED ENTRIES
[Freemake Video Downloader*]
LangSecRef=3023
Detect=HKCU\Software\Freemake\FreemakeVideoDownloader
Default=False
FileKey1=%ProgramFiles%\Freemake\Freemake Video Downloader|trace.log
FileKey2=%CommonAppData%\Freemake\FreemakeVideoDownloader|*.txt
FileKey3=%Documents%\Freemake\FreemakeVideoDownloader|fvd.bin
FileKey4=%Documents%\Freemake\FreemakeVideoDownloader\History\Thumbnails|*.*
FileKey5=%Documents%\Freemake\FreemakeVideoDownloader\History|*.xml
[Freemake Audio Converter*]
LangSecRef=3023
Detect=HKCU\Software\Freemake\FreemakeAudioConverter
Default=False
FileKey1=%CommonAppData%\Freemake\FreemakeAudioConverter|*.txt
[Freemake Video Converter*]
LangSecRef=3023
Detect=HKCU\Software\Freemake\FreemakeVideoConverter
Default=False
FileKey1=%CommonAppData%\Freemake\FreemakeVideoConverter|*.txt
Link to comment
These are out of place alphabetically,
[Any Video Converter*]
LangSecRef=3023
Detect=HKCU\Software\AnvSoft\Any Video Converter
Default=False
FileKey1=%appdata%\AnvSoft\Any Video Converter|*.db
FileKey2=%appdata%\AnvSoft\Any Video Converter|*.log
[AnvSoft Any Audio Converter (Logs)*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\AnvSoft\Any Audio Converter|*.log
[AnvSoft Any DVD Converter (Database)*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\AnvSoft\Any DVD Converter Professional|*.db
[AnvSoft Any DVD Converter (Logs)*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\AnvSoft\Any DVD Converter Professional|*.log
[AnvSoft Any Video Converter (Database)*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\AnvSoft\Any Video Converter|*.db
[AnvSoft Any Video Converter (Logs)*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\AnvSoft\Any Video Converter|*.log
[Crash Reports*]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\FireFox\Crash Reports\
Default=False
FileKey1=%AppData%\Mozilla\FireFox\Crash Reports\pending|*.*
FileKey2=%AppData%\Mozilla\FireFox\Crash Reports\submitted|*.*
FileKey3=%AppData%\Mozilla\FireFox\Crash Reports|*.*
[Dump Files*]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\Firefox
Default=False
FileKey1=%AppData%\Mozilla|*.dmp|RECURSE
[Firefox Updates*]
LangSecRef=3026
DetectFile=%LocalAppData%\Mozilla\Firefox
Default=False
FileKey1=%LocalAppData%\Mozilla\Firefox\Mozilla Firefox\updates|*.*|RECURSE
[TestPilot Error Logs*]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\FireFox\Profiles
Default=False
FileKey1=%AppData%\Mozilla\FireFox\Profiles|TestPilotErrorLog.*|RECURSE
[Thunderbird Install Log*]
LangSecRef=3026
DetectFile=%ProgramFiles%\Mozilla Thunderbird\install.log
Default=False
FileKey1=%ProgramFiles%\Mozilla Thunderbird|install.log
Link to comment
  • Moderators
Miroku4444 you need to be a little better about reading the thread, or at least the most recent entries. Three times (before you) it was reported about the double Flash Install and three time before you an answer was given. At LEAST 1 of those time IS ON THIS PAGE of the thread. Come'on'son http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=208192
Link to comment
Miroku4444 you need to be a little better about reading the thread, or at least the most recent entries. Three times (before you) it was reported about the double Flash Install and three time before you an answer was given. At LEAST 1 of those time IS ON THIS PAGE of the thread. Come'on'son http://forum.pirifor...ndpost&p=208192
I apologize, should have looked a little. Was a Long day.
I'll edit my post.
Is that 64 in this entry a reference to 64-bit. If so can i remove it if i dont have a 64-bit system? Or just leave it alone?
LangSecRef=3023
Default=False
Link to comment
You're welcome Winapp2 :)
MODIFIED ENTRY
http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=207593
[Cached File Extensions*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts
Link to comment
I cleaned up the first post a little, put the disclaimer in a spoiler and moved the trimming down below the download links with the other spoiler stuff (excluding the disclaimer)
Basically the information on the current file is front and center.
I also added an Adf.ly link as an alternative. I'll basically just donate whatever comes from that to CCleaner. The direct link is still up since it'd be unfair to force people to use the adfly one.
(Hope that's okay!)
Link to comment
  • Moderators
I'm ok with it, let's see what the other Mods and the Admins have to say
Link to comment
Hey guys, im having a problem with one of the entry's. Its called *internet explorer more. When i have it checked and run CCleaner, it then will cause my cursor to flicker. When im browsing thru folders on my PC, the cursor flickers rapidly. If i reboot, and then uncheck *internet explorer more, everything works fine with no problems.
Link to comment
I use this on Windows 7, no problem at all.
Details about this entry.
http://forum.pirifor...ndpost&p=192469
Link to comment
I have that option permanently ticked too and have had no problem (WinXP). Perhaps a video card issue? Are you using any custom cursors or something like that? Just guessing really, not sure how that entry could cause that :huh:
Link to comment
  • Moderators
RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache
RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache
RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU
RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup
RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore
RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached
FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.*
FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat
FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF
FileKey4=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE
FileKey5=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.*
FileKey6=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey7=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE
I have to agree None of these seem like they would cause this issue (maybe iconcache folder and/or iconcache.dat but I doubt it)
Link to comment
Nope, no custom cursors. No big deal as i dont use ie much, and that entry didn't seem to do that much. If i need to do it, i can run it before i shut down, then when i boot back up it will be gone.
Try this.
http://www.mydigital...-google-chrome/
I was wondering if you also have Firefox installed on the system. Firefox has a feature called 'caret browsing'. The main reason that Firefox has this feature is that you can select text with your keyboard. This feature could cause the curser blink.
You can disable this feature. Type in "about:config" in the address bar and then type in "caret" in the filter box and simply double click to change the option from "true" to "false".
Link to comment
This reply is supposed to be for http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=179 , regarding Western Digital Smartware. The following files were flagged by CCleaner, but I'm cautious to delete them. Does anyone know if these are really OK to get rid of?
D:\Documents and Settings\All Users\Application Data\Western Digital\WD SmartWare\WDFME.log 361 KB
D:\Documents and Settings\All Users\Application Data\Western Digital\WDFME\configuration.xml 1 KB
D:\Documents and Settings\All Users\Application Data\Western Digital\WDFME\Settings.db3 24 KB
D:\Documents and Settings\All Users\Application Data\Western Digital\WDFME\Settings.db3-journal 5 KB
D:\Documents and Settings\All Users\Application Data\Western Digital\WDFME\temp.db3 0 KB
D:\Documents and Settings\All Users\Application Data\Western Digital\WDFME\Volume0b1d568a9bb311dd896c806d6172696f.db3 2,415 KB
D:\Documents and Settings\All Users\Application Data\Western Digital\WDFME\Volume0b1d568b9bb311dd896c806d6172696f.db3 1,368 KB
D:\Documents and Settings\All Users\Application Data\Western Digital\WDFME\Volume0b1d568b9bb311dd896c806d6172696f.db3-journal 19 KB
D:\Documents and Settings\All Users\Application Data\Western Digital\WDFME\Volume214060c47bd711e0a6f2002170a455d3.db3 3,704 KB
D:\Documents and Settings\All Users\Application Data\Western Digital\WDFME\Volume56b37cd2ccd211e0b64d002170a455d3.db3 15 KB
Link to comment
Register a new account
Sign in
