Winapp2.ini additions
Winapp2.ini
Why are you detecting what you are deleting. This seems unclean
you need to detect a file or entry that will stay in existence not what you are cleaning
Typo or something, I guess, but you should check what I suggested:
[Adobe Flash Install Logs*]
LangSecRef=3023
DetectFile1=%WinDir%\System32\Macromed\Flash
DetectFile2=%WinDir%\SysWOW64\Macromed\Flash
Default=False
FileKey1=%WinDir%\System32\Macromed\Flash|FlashInstall.log
FileKey2=%WinDir%\SysWOW64\Macromed\Flash|FlashInstall.log
Btw. now over 1000 replies in this thread. :D
Link to comment
Don't know if it's supposed to but [internet Explorer More*] causes slow loading and high cpu usage when viewing image thumbnails
This entry has nothing to do with that issue. This entry is completely safe.
Link to comment
MODIFIED ENTRY
[Windows Update Logs*]
LangSecRef=3025
DetectFile=%WinDir%\SoftwareDistribution
Default=False
FileKey1=%WinDir%\SoftwareDistribution\DataStore\Logs|*.*
FileKey2=%WinDir%\SoftwareDistribution|ReportingEvents.log
Link to comment
I thought X-Chat 2 already had an entry but I can't seem to find it
New Entry
[X-Chat 2*]
LangSecRef=3022
DetectFile=%userprofile%\AppData\Roaming\X-Chat 2
Default=False
FileKey1=%userprofile%\AppData\Roaming\X-Chat 2\xchatlogs|*.*|REMOVESELF
FileKey2=%userprofile%\AppData\Roaming\X-Chat 2\scrollback|*.*|REMOVESELF
Cleans the logs and the scrollback if enabled in X-Chat 2
Link to comment
  • Moderators
extra space or End of Line Character at the end of:
[Audio/Video (Stats)*] (FileKey)
[Paint.NET More*] (FileKey)
Proposed changes
__________________________________________________________________________________________________________________________
[Any Video Converter*] Change to [AnvSoft Any Video Converter*] in order to 1) not cause confusion with, little a, "any video converter" and 2) fit with the "AnvSoft Any Audio" entries
I also notice that the [MS Office Word More*] entry has been changed to recursivly clean the entire appdata folder for word. This includes
listgal.dat which is used for custom multilevel lists http://office.microsoft.com/en-us/word-help/create-a-multilevel-list-HA010065017.aspx#BM2
and the Startup folder http://office.microsoft.com/en-us/word-help/load-or-unload-a-template-or-add-in-program-HA010105537.aspx#BM3
both of these seem likely to (while rarely) be used without the user knowing that they use them and thus cleaning would cause issues. I propose a roleback to
Warning=This will delete the temp files created by Microsoft Word
LangSecRef=3021
Detect=HKCU\Software\Microsoft\Office\Word
Default=False
FileKey1=%AppData%\Microsoft\Word|*.wbk
FileKey2=%AppData%\Microsoft\Word|*.as$
FileKey3=%Documents%|~*.doc|RECURSE
______________________________________________________________________________________________________________________________
Link to comment
  • Moderators
Good catch Rick I missed that one in looking. The second entry can be removed as it is combined with the 64bit entry
Link to comment
This leftover code needs to be removed from the latest version.
LangSecRef=3023
DetectFile=%WinDir%\System32\Macromed\Flash|FlashInstall.log
Default=False
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD21, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
You have removed the highlighted line from the entry listed below. This was a valid path,
iPhone creates crash logs (Diagnostics & Usage Data) and after syncing iPhone with iTunes, it transfers all the crash logs to computer.
[iTunes Logs*]
LangSecRef=3023
DetectFile=%ProgramFiles%\iTunes\iTunes.exe
Default=False
FileKey1=%AppData%\Apple Computer\Logs|*.crash|RECURSE
FileKey2=%AppData%\Apple Computer\Logs|*.log|RECURSE
FileKey3=%WinDir%\system32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log|RECURSE
You also ignored all other entries that I posted few days before.
I am listing all those entries here again.
MODIFIED ENTRIES
I have removed the RegKey6 line from the InternetExplorer More entry as it is not part of InternetExplorer.
RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached
I have made a new entry for this and that is listed below.
LangSecRef=3022
DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe
Default=False
RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache
RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache
RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU
RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup
RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore
FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.*
FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat
FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF
FileKey4=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE
FileKey5=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.*
FileKey6=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey7=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE
[MS Office Temp Files*]
LangSecRef=3021
DetectFile=%AppData%\Microsoft\Office
Default=False
RegKey1=HKCU\Software\Microsoft\Office\Common|FontBmpCache
FileKey1=%AppData%\Microsoft\Office|*.tmp|RECURSE
[Roxio Temp Files*]
LangSecRef=3021
DetectFile=%AppData%\Roxio
Default=False
FileKey1=%LocalAppData%|rx_audio.Cache
FileKey2=%LocalAppData%|rx_image32.Cache
FileKey3=%AppData%\Roxio\Dragon\3.x\DiscInfoCache|*.tmp
FileKey4=%AppData%\Roxio Burn\Temp|*.*|RECURSE
NEW ENTRIES
[Cached File Extensions*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\
[Cached Shell Extensions*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached
[DivX Plus Player*]
LangSecRef=3023
DetectFile=%ProgramFiles%\DivX\DivX Plus Player\DivX Plus Player.exe
Default=False
RegKey1=HKCU\Software\DivX\Settings\Player\PlayerState|LastOpenFileLocation
RegKey2=HKCU\Software\DivX\Settings\TransferWizard|LastBrwosedDir
RegKey3=HKCU\Software\DivX\Settings\Converter|lastBrowseDir
RegKey4=HKCU\Software\DivX\Settings\Converter|outputDir
[Windows Error Reporting More*]
LangSecRef=3025
DetectFile=%Windir%
Default=False
RegKey1=HKU\S-1-5-18\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation
FileKey1=%WinDir%\System32\config\systemprofile\AppData\Local\CrashDumps|*.dmp
[WMP MediaGuide*]
LangSecRef=3023
DetectFile=%ProgramFiles%\Windows Media Player\wmplayer.exe
Default=False
RegKey1=HKCU\Software\Microsoft\MediaPlayer\Preferences|CurrentBackgroundScanFolder
RegKey2=HKCU\Software\Microsoft\MediaPlayer\Services\MediaGuide|CachedIconPath
RegKey3=HKCU\Software\Microsoft\MediaPlayer\Services\MediaGuide|CachedLargeLogoPath
Link to comment
Wow! I looked at some of the entries here. You guys should pat yourselves on the back for being total slaves for the rest of us.
I can't believe the amount of effort you all put into updating things.
Thanks, thanks, thanks, thanks, thanks, thanks, thanks!
Link to comment
Proposed changes
listgal.dat which is used for custom multilevel lists http://office.micros...065017.aspx#BM2
and the Startup folder http://office.micros...105537.aspx#BM3
LangSecRef=3021
Default=False
I think we should exclude only STARTUP folder and listgal.dat file. This location can store shortcuts of the Word templates separately and sometimes in a folder (diff. name each time).
LangSecRef=3021
Default=False
FileKey1=%AppData%\Microsoft\Word|*.*|RECURSE
FileKey2=%Documents%|~*.doc|RECURSE
Excludekey1=FILE|%AppData%\Microsoft\Word\STARTUP\|*.*
Excludekey2=FILE|%AppData%\Microsoft\Word\|listgal.dat
Link to comment
Thank you. At least someone here appreciates. :)
I put a lot of effort into doing that. Creating a system image. Installing and testing the programs. Making the entries and then rolling the system back. :)
Link to comment
Register a new account
Sign in
Important Information
