Alan_B Posted November 28, 2011 Share Posted November 28, 2011 New version of CCleaner just came out, when will Winapp2.ini? No hurries/worries, just asking. I see absolutely no urgency. The new version cleans more stuff with zero impact on what WinApp2.ini achieves, and the only possible improvement to WinApp2.ini is to remove any odd items which are now cleaned by the new version. Since 99% of all Winapp2.ini users are happy to accept that at least 90% of WinApp2.ini is useless bloat because they only have 10% of the applications installed, an extra 1% on top of 90% is not a priority. Link to comment Share on other sites More sharing options...
nodles Posted November 28, 2011 Share Posted November 28, 2011 Well, I always like an update, doesn't matter to what (especially to CCleaner + Winapp2.ini). And like I said, no hurries, just curious. Don't really get your point there / point for that post. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 28, 2011 Author Share Posted November 28, 2011 It's coming in just a few minutes. No worries winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 28, 2011 Author Share Posted November 28, 2011 Updated Let me know if anything is incorrect, errors tend to slip in winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted November 28, 2011 Share Posted November 28, 2011 Thanks! That was quick. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 28, 2011 Moderators Share Posted November 28, 2011 Nodles, can you tell us a bit about what scm logs are and when we might want/need them kept? [Quicken Deluxe 2012 (logs)*] LangSecRef=3021 DetectFile=%ProgramFiles%\Quicken\qw.exe Default=False Filekey1=%AppData%\Intuit\Quicken\Log\|*.txt FileKey2=%AppData%\Intuit\Quicken\Log\|*.log Filekey3=%CommonAppData%\Intuit\Quicken\Log\|*.log Filekey4=%CommonAppData%\Intuit\Quicken\Log\installer|*.*|RECURSE Excludekey1=FILE|%CommonAppData%\Intuit\Quicken\Log\installer\|*.htm looks to me as if it is valid for all quicken years and builds not just 2012 deluxe. it Detects and cleans things for Quicken 2011 Home and Business) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
nodles Posted November 28, 2011 Share Posted November 28, 2011 More info about SCM: http://www.geoffchap.../events/wpp.htm and http://social.techne...a-9d713b7fa402/ and http://msdn.microsoft.com/en-us/library/windows/desktop/ms685150%28v=vs.85%29.aspx Though, I haven't had any issues with that entry (not yet atleast), cleaned a few PC's with it ticked (Win7). And like always, as I guess you already know, you should always be (more) careful with Winapp2.ini, 'cause it's a custom config/file. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 28, 2011 Moderators Share Posted November 28, 2011 Cool, sounds safe nuff to clean for me (those links were what I was looking for, thanks) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
ricktendo64 Posted November 29, 2011 Share Posted November 29, 2011 One typo is you have this duplicated (the second is supposed to be VideoStudio) [Corel PaintShop Pro X4 More*] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel PaintShop Pro X4\Corel PaintShop Pro.exe Default=False FileKey1=%LocalAppData%\Corel PaintShop Pro\14.0\Database|*.db FileKey2=%AppData%\Corel\Messages|*.*|RECURSE Excludekey1=FILE|%AppData%\Corel\Messages|*.policy [Corel PaintShop Pro X4 More*] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel PaintShop Pro X4\Corel PaintShop Pro.exe Default=False FileKey1=%LocalAppData%\Corel PaintShop Pro\14.0\Database|*.db FileKey2=%AppData%\Corel\Messages|*.*|RECURSE Excludekey1=FILE|%AppData%\Corel\Messages|*.policy Link to comment Share on other sites More sharing options...
SMalik Posted November 29, 2011 Share Posted November 29, 2011 Some of the entries are listed as: [Adobe Distiller Cache*]LangSecRef=3021DetectFile=%AppData%\Adobe\Acrobat\Distiller 10Default=FalseFileKey1=%AppData%\Adobe\Acrobat\Distiller 10\Cache|*.*|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 29, 2011 Author Share Posted November 29, 2011 @saad - Weird, it looks fine in my editor (Notepad++) but looks completely wrong in regular notepad. I'll fix that. @rick I'll fix that and release with the above fix as well. Oops. edit: @saad - The problem seems to have been a completely invisible character that should have been a line break character in each line. Weird. It probably happened to everything modified in this update. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted November 29, 2011 Share Posted November 29, 2011 @saad - Weird, it looks fine in my editor (Notepad++) but looks completely wrong in regular notepad. I'll fix that. @rick I'll fix that and release with the above fix as well. Oops. edit: @saad - The problem seems to have been a completely invisible character that should have been a line break character in each line. Weird. It probably happened to everything modified in this update. You're right the problem is with the modified entries. The latest version of CCleaner has no support for RealPlayer 15. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 29, 2011 Author Share Posted November 29, 2011 It should be fixed up now. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted November 29, 2011 Share Posted November 29, 2011 It should be fixed up now. [Corel VideoStudio Pro X4*] is still the same. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 29, 2011 Author Share Posted November 29, 2011 It's now [Corel PaintShop Pro X4 More*] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel PaintShop Pro X4\Corel PaintShop Pro.exe Default=False FileKey1=%LocalAppData%\Corel PaintShop Pro\14.0\Database|*.db FileKey2=%AppData%\Corel\Messages|*.*|RECURSE Excludekey1=FILE|%AppData%\Corel\Messages|*.policy [Corel VideoStudio Pro X4*] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel VideoStudio Pro X4\vstudio.exe Default=False FileKey1=%AppData%\Corel\Messages|*.*|RECURSE FileKey2=%AppData%\Ulead Systems\Corel VideoStudio Pro\14.0\en-US|VS_PRO.log Excludekey1=FILE|%AppData%\Corel\Messages|*.policy Wasn't that how it was supposed to be? Before there were two paintshop pro X4 winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
ricktendo64 Posted November 29, 2011 Share Posted November 29, 2011 Yep [Corel VideoStudio Pro X4* More] LangSecRef=3023 DetectFile=%ProgramFiles%\Corel\Corel VideoStudio Pro X4\vstudio.exe Default=False FileKey1=%AppData%\Corel\Messages|*.*|RECURSE FileKey2=%AppData%\Ulead Systems\Corel VideoStudio Pro\14.0\en-US|VS_PRO.log Excludekey1=FILE|%AppData%\Corel\Messages|*.policy Link to comment Share on other sites More sharing options...
Miroku4444 Posted November 29, 2011 Share Posted November 29, 2011 [since 99% of all Winapp2.ini users are happy to accept that at least 90% of WinApp2.ini is useless bloat because they only have 10% of the applications installed,an extra 1% on top of 90% is not a priority. Exactly. I have a custom WinApp2.ini with only the entry's that apply to the programs i have. I would never use the full WinApp2.ini. Wouldn't make sense. I use the full WinApp2.ini as a sort of reference library. Link to comment Share on other sites More sharing options...
Guest Keatah Posted November 29, 2011 Share Posted November 29, 2011 Does anyone know where CCleaner checks for installed programs? What part of the registry? I assume CCleaner does indeed look to see what is installed and offers to clean only what you have registered? Link to comment Share on other sites More sharing options...
nodles Posted November 29, 2011 Share Posted November 29, 2011 CCleaner or Winapp2.ini? The program uses either program paths or registry entries; eg. file/folder/program path: DetectFile=%ProgramFiles%\Safari\Safari.exe OR registry: Detect=HKCU\Software\Chromium Link to comment Share on other sites More sharing options...
Alan_B Posted November 29, 2011 Share Posted November 29, 2011 Exactly. I have a custom WinApp2.ini with only the entry's that apply to the programs i have. I would never use the full WinApp2.ini. Wouldn't make sense. I use the full WinApp2.ini as a sort of reference library. Me too, nice to know I am not alone Link to comment Share on other sites More sharing options...
nodles Posted November 29, 2011 Share Posted November 29, 2011 I use the whole & updated Winapp2.ini with my own additional entries to get everything cleaned, and for the other PC's I use it on (don't have to check all the programs installed etc). Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 29, 2011 Author Share Posted November 29, 2011 There was talk of making a batch file to create the winapp2.ini file relevant to your computer for you, but it never got put together. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Alan_B Posted November 29, 2011 Share Posted November 29, 2011 I have a batch that works - now fine tuning and fully testing. Perhaps ready for release next week. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 29, 2011 Author Share Posted November 29, 2011 Let me know if you need help testing winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted November 29, 2011 Moderators Share Posted November 29, 2011 @saad - Weird, it looks fine in my editor (Notepad++) but looks completely wrong in regular notepad. I'll fix that. Probably need to make sure the formatting is correct by using good ole Windows Notepad because more advanced text viewers/editors can fool you into thinking everything is ok when it isn't, I've been there and done that before! Link to comment Share on other sites More sharing options...
