CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
Modified Entry:  [belarc Advisor*]
Added FileKey13
[Belarc Advisor*]
LangSecRef=3024
Detect=HKCU\Software\Belarc
Default=False
FileKey1=%LocalAppData%\VirtualStore\Program Files*\Belarc\Advisor\System|Progress.Log
FileKey2=%LocalAppData%\VirtualStore\Program Files*\Belarc\Advisor\System\Security\BelNotify|BelNotify.log;History.log;HistoryHF.log
FileKey3=%LocalAppData%\VirtualStore\Program Files*\Belarc\Advisor\System\Tmp|*.*
FileKey4=%LocalAppData%\VirtualStore\Program Files*\Belarc\BelArcAdvisor\System|Progress.Log
FileKey5=%LocalAppData%\VirtualStore\Program Files*\Belarc\BelArcAdvisor\System\Security\BelNotify|BelNotify.log;History.log;HistoryHF.log
FileKey6=%LocalAppData%\VirtualStore\Program Files*\Belarc\BelArcAdvisor\System\Tmp|*.*
FileKey7=%ProgramFiles%\Belarc\Advisor\System|Progress.Log
FileKey8=%ProgramFiles%\Belarc\Advisor\System\Security\BelNotify|BelNotify.log;History.log;HistoryHF.log
FileKey9=%ProgramFiles%\Belarc\Advisor\System\Tmp|*.*
FileKey10=%ProgramFiles%\Belarc\BelArcAdvisor\System|Progress.Log
FileKey11=%ProgramFiles%\Belarc\BelArcAdvisor\System\Security\BelNotify|BelNotify.log;History.log;HistoryHF.log
FileKey12=%ProgramFiles%\Belarc\BelArcAdvisor\System\Tmp|*.*
FileKey13=%ProgramFiles%\Belarc\BelarcAdvisor\|install.log
Share this post
Link to post
A bit offtopic but i need help.
I want creat a bat file for downloading the last winapp2.ini from github but voldemord cant do this at the moment.
So i creat a bat script with wget
@echo off
echo Download winapp2.ini from Github
ping /n 1 raw.githubusercontent.com
if errorlevel 1 goto NOC
echo online
del winapp2.ini
::Bug: One Text without spaces
::curl.exe -o Winapp2.ini -A "Mozilla/5.0 (iPhone; U; CPU like Mac OS X; en) AppleWebKit/420+ (KHTML, like Gecko) Version/3.0 Mobile/1A543a Safari/419.3" -G "https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp2.ini"
wget.exe -c --output-document=Winapp2.ini "https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp2.ini"
goto end
:NOC
echo no connection
:end
ccleaner.exe
So the problem is that downloading unformated all in 1 line ccleaner haven't problems with it, but I (for manuel reading).
OK i can use notepad++ but the normal dont work right....
THX
Share this post
Link to post
I use JPSoft's TCMD and convert the line endings. The line that does the line ending conversation is the TPIPE ( http://www.datamystic.com/textpipe.html )
echo.
if not isdir "C:\TCMD\WinApp2_Ini\" md /s "C:\TCMD\WinApp2_Ini\"
copy "https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp2.ini" C:\TCMD\WinApp2_Ini\Winapp2_Unix.ini
echo.
rem convet UNIX to ASCII
TPIPE /input=C:\TCMD\WinApp2_Ini\Winapp2_Unix.ini /eol=0,2,0 /output=C:\TCMD\WinApp2_Ini\Winapp2_Ansii.ini
echo.
copy "C:\TCMD\WinApp2_Ini\Winapp2_Ansii.ini" + "%UserProfile%\Desktop\Galloway Desktop\INI_001\custom.ini" "%ProgramFiles%\CCleaner\Winapp2.ini"
echo.
Share this post
Link to post
echo.
echo.
echo.
echo.
THX for the informartion.
I found a free programm for it ;-)
@echo off
:: Programms:
:: http://gnuwin32.sourceforge.net/packages/wget.htm
:: https://curl.haxx.se/download.html
:: http://waterlan.home.xs4all.nl/dos2unix.html
echo online
del winapp2.ini
unix2dos.exe Winapp2.ini
goto end
:NOC
echo no connection
:end
ccleaner.exe
Share this post
Link to post
Duplicate entry:
[Yahoo! Messenger Desktop App Cache*]
LangSecRef=3022
Detect=HKCU\Software\Yahoo\Messenger
DetectFile=%LocalAppData%\yahoomessenger
Default=False
FileKey1=%AppData%\Yahoo Messenger\Cache|*.*
LangSecRef=3022
Default=False
Edit: A similar diction of the name "Yahoo" would be nice. (All "Yahoo" or all "Yahoo!" ?)
Share this post
Link to post
Duplicate entry:
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
That's funny, Thought i fixed that already. Hmm.. looks like I fixed it in one but not the other. It's fixed now: https://github.com/MoscaDotTo/Winapp2/commit/4b28df2153733887815492cafb2602510e8687a1
According to CSGalloway, they are not called Yahoo! anymore, it is just Yahoo. Those other entries from Yahoo may need to be fixed as all the FileKeys point at the old name still.
Share this post
Link to post
1 Fix and some new lines for NV
https://github.com/MoscaDotTo/Winapp2/pull/55/files
https://github.com/MoscaDotTo/Winapp2/compare/master...TZocker:patch-8
reorganisation and
Filekey=%LocalAppData%\NVIDIA Corporation\NvNode|*.log;*.bak
Filekey=%LocalAppData%\NVIDIA Corporation\NvTelemetry|*.log;*.bak
Filekey=%LocalAppData%\NVIDIA Corporation\NvVAD|*.log;*.bak
Filekey=%LocalAppData%\NVIDIA Corporation\NVIDIA Share\CefCache|*.log;*.bak
But I have one extra line but more testing is needed
Filekey14=%LocalAppData%\NVIDIA Corporation\NVIDIA GeForce Experience\CefCache|*.*
Share this post
Link to post
How do you see what entry is being altered on GitHub? It cuts off the first part in change links like above, is there anyway to make it show the the lines above so you can see what entry the change actually applies to?
Share this post
Link to post
 I checked the Help | About and the EXE file properties and both just show Yahoo.  Not Yahoo!.  I am not sure if the old Yahoo Messenger is still available.  So my vote would be to keep the old entries as is...
Share this post
Link to post
there https://github.com/MoscaDotTo/Winapp2/compare/master...TZocker:patch-8
and this entries
use strg F after = ;-)
Share this post
Link to post
Revised Entries
[AutoPlay Devices*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Warning=This will clear out devices and drives from AutoPlay that you've connected to your computer.
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers\KnownDevices
Changed Warning from "This will clear out all default autoplay options for devices and drives you've connected to your computer!" to "This will clear out devices and drives from AutoPlay that you've connected to your computer."
[CD/DVD Burn Cache*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning
Default=False
Warning=This will wipe all files that are waiting to be burned to a CD/DVD/BD drive.
FileKey1=%LocalAppData%\Microsoft\CD Burning|*.*
FileKey2=%LocalAppData%\Microsoft\Windows\Burn|*.*|RECURSE
Changed Warning from "This option will wipe all files that are waiting to be burned to a CD/DVD/BRD" to "This will wipe all files that are waiting to be burned to a CD/DVD/BD drive."
Share this post
Link to post
and this entries
Nope, you lost me.
When I click the change links like that, this is what I see. How do I tell what program entry it is that has been edited so I can copy to the right place in my winapp2 file?: q9Hb0fy.jpg
Share this post
Link to post
Nope, you lost me.
Take my post above this one for example. If you click on the link and look to the left, you should see the line numbers, like 3780, 3781, 3782, etc. Along there, you should see a weird looking thing with arrows pointing up and down in it. Click that and it will expand the text.
Share this post
Link to post
I'd already done that in the screenshot I posted (hence no arrow showing), was the first thing I tried. Clicking it in the patch posts doesn't work. It does work for the below post, but not for the patch posts :huh: (tried in FF, IE and chrome in case a browser specific issue)
Share this post
Link to post
Sry, i lost you. xd
Its
[NVIDIA Logs*]
Share this post
Link to post
Sry, i lost you. xd
Its
[NVIDIA Logs*]
I worked that out by copying the first line, then searching the full file for it. Just thought there might be an easier way. Presume it's a GitHub bug/quirk
Share this post
Link to post
I don't understand issue 60. Issue 61 I think depends on the program but (other than lots of work, see below) I see no issue with it.
This should however be done as a community effort, if someone sees 3 versions of a program taking up lines x-y, then they can submit it as a pull changing lines x-y
Share this post
Link to post
Issue 60 is pretty much saying to go over the removed entries and update them, if needed, as most of them have been in their for years and haven't been looked at in a long time.
The idea of issue 61 is to combine entries where the only real difference is the year or number of programs, like AVG 2013-2015 and Snagit 9-11. I mean is there ever a time where someone would want to clean one year but not the other year?
Share this post
Link to post
I guess I'm confused on "removed entries" is someone keeping a log of removed entries? My initial understanding of the move to git is that removed entries are easily seen (red minuses)
Edit
Ohhhhh
There's a separate ini for removed entries....but why? :lol: usually, removed are done because either integration with ccleaner default or dangerous to use
Share this post
Link to post
Register a new account
Sign in
