CCleaner Community Forums
Winapp2.ini additions
I guess I'm confused on "removed entries" is someone keeping a log of removed entries? My initial understanding of the move to git is that removed entries are easily seen (red minuses) Edit Ohhhhh There's a separate ini for removed entries....but why? :lol: usually, removed are done because either integration with ccleaner default or dangerous to use
Book keeping, among some other uses for winapp2.ini that aren't kosher for this forum.
Link to post
Do you mean good uses for WinApp2.ini for the other cleaners that the file uses?  Or entries that are too dangerous for the general public?
Link to post
I don't think we're maintaining a 'dangerous entry' ini. I used to quite a long time ago, but it got almost no traffic so I stopped.
Link to post
A user once tried bringing this back to the Winapp2 GitHub page, but we all agreed not to use it as it was "unofficial".
Link to post
Analysis Complete - (0.473 secs)
1.92 KB to be removed. (Approximate size)
Secure file deletion enabled - Simple Overwrite (1 pass)
Details of files to be deleted (Note: No files have been deleted yet)
Utilities - Malwarebytes Anti-Malware    1 KB    1 files
Utilities - Malwarebytes Anti-Malware*    1 KB    1 files
C:\ProgramData\Malwarebytes\Malwarebytes Anti-Malware\Logs\protection-log-2016-11-27.xml    1 KB
The two utilities seem to be duplicated....
Link to post
Keep in mind that the Malwarebytes Anti-Malware cleaner code that is part of winapp.ini removes all files that have been quarantined by MBAM.  This could be hazardous if MBAM quarantined a false positive and then you run CCleaner...you would lose the quarantined file and could not restore the false positive file.  Particularly hazardous if you have MBAM to automatically quarantine files.
Link to post
New Entry:  [Ashampoo Burning Studio 18*]
LangSecRef=3024
Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18
Default=False
FileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 18\log|*.xml;*.txt
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Backup Project\BackupOptions|CustomLocation
RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\BDMV Disc Project\SelectBDMVFolder|BdmvPath
RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Browse Image Project\BrowseImageFile|ImagePath
RegKey5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Burn Image Project\SelectImage|ImagePath
RegKey8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Data Disc Project\DumpImage|ImagePath
RegKey10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\DVD-Video Disc Project\MoviesPage|Path
RegKey11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory
RegKey12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Logs
RegKey13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\tempFiles
RegKey14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Unknown Project
RegKey15=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey16=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey17=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
Link to post
Dunno if this is a bug with the winapp2 entry, or showing up a bug with CC, or just a quirk of my computer, but part of the "Internet Explorer More" entry keeps showing webcache folder cleaned, then when you run CC again, it shows it cleaning the exact same files again (same file sizes), even though it's supposedly just deleted them, and even though the folder it's cleaning is actually empty. So EVERY time I run CC I get the below result for the entry, even though there's nothing there :huh:
Link to post
  • Moderators
V01.log and WebCacheV01.dat are always locked by a svchost.exe process.
the others can be deleted but get re-created, definitely at each boot, maybe sooner.
all part of the brave new IE/Edge/Win10 new world I think.
are you Windows 10?
(apologies if none of that was news, may help others though)
Link to post
are you Windows 10?
They're not even there, the folder is empty, yet CCleaner is claiming to clean them (analyze shows nothing, cleaning repeatedly shows them in the results of what's just been cleaned). And just to pre-empt, yes, I have hidden and system files visible.
And no, not Win10, am on Win7 and it's IE11
Link to post
Modified Entry: [samsung Magician Logs*]
Added FileKey5 for Samsung Magician V5.0
[Samsung Magician Logs*]
LangSecRef=3021
Detect1=HKLM\Software\Samsung Magician
Detect2=HKLM\Software\Wow6432Node\Samsung Magician
Default=False
FileKey1=%LocalAppData%\VirtualStore\Program Files*\Samsung\Samsung Magician|*.log;*.txt|RECURSE
FileKey2=%LocalAppData%\VirtualStore\Program Files*\Samsung\Samsung Magician\Logs|*.*
FileKey3=%ProgramFiles%\Samsung Magician\Logs|*.*
FileKey4=%ProgramFiles%\Samsung\Samsung Magician\Logs|*.*
FileKey5=%ProgramFiles%\Samsung\Samsung Magician\Log|*.*
Link to post
Hi!
The entry for PowerDVD 16 deletes the 'cache' folder and 'EVO1.xml'. What's the intention of doing so?
(I use my own PowerDVD 16 rules for deleting privacy related data, e.g. the content of 'Caches'.)
Link to post
Why isn't the version number updated within the file?
The one I am currently using shows:
; Version: v5.21.160816
; Application Cleaning file
; Notes
; # of entries: 2,570
The one currently posted shows:
; Notes
; # of entries: 2,577
Link to post
LangSecRef=3021
Default=False
Please don't forget this entry for Winapp2.ini
Link to post
New Entry:  [Malwarebytes V3 Logs*]
-  Malwarebytes Version 3 combines and replaces Malwarebytes Anti-Malware, Anti-Exploit, and Anti-Ransomware.
LangSecRef=3024
Detect=HKCU\Software\Malwarebytes
Default=False
Warning=You must manually and temporarily turn off Malwarebytes "self-protection" to remove the logs.
FileKey1=%CommonAppData%\Malwarebytes\MBAMService|*.log;*.bak
FileKey2=%CommonAppData%\Malwarebytes\MBAMService\logs|*.*
Link to post
Updated: https://github.com/MoscaDotTo/Winapp2/commit/856ea0a45d587e6c433d98965fa413a2c6fbbd3b
Probably better to keep the old entries for awhile longer, because I heard v3 was pretty buggy, so people might stick with the old versions until v3 is more stable.
Yep!  It will be awhile before V3 is fully functional.  Was surprised that it got released so quickly during the beta testing cycle.
Link to post
Version number has not been updated
I usually leave that up to Robert, as I don't know what the proper version number is, as a rarely use CCleaner.
Link to post
 By looking at the version number in the file Version: v5.21.160816 that tells me it's for Ccleaner v5.21 and file release date of August 16, 2016
We are currently on v5.24.5839 and you updated the INI file on December 09,2016, so I would venture to say that internal version number should be v5.24.161209
So I would suggest you also make that change when updating the final INI file to be downloaded so there is a way for the users to keep track of which file they have.
Link to post
Awesome
One more thing I forgot to mention and I do not know how he gets that figure.  Just below the version number, there is this:
; Notes
; # of entries: 2,579
Unless he can tell us, my suggestion would be to eliminate that count until a correct number of entries count can be placed within the file
Link to post
Register a new account
Sign in
