Winapp2.ini additions
Winapp2.ini
previous name for this entry were using "Windows" but based on suggestion, the "Windows" were removed so that the result page will show [Windows - Error Reporting More*] instead of [Windows - Windows Error Reporting More*]
and usually entries that complement default cc's cleaning rule will have "more" so i think we don't need to change the name
I agree, but there are some entries that have "Windows" in it. There is no CCleaner default rule for this. They have an entry with the name "Memory Dump".
EDIT
You're right, there is a built-in rule for this. I'm sorry. I think we should keep the same name.
Link to comment
  • Moderators
New:
[Zemana AntiMalware (Reports)*]
LangSecRef=3024
Detect1=HKCU\Software\Zemana\AntiMalware
Detect2=HKLM\Software\Zemana\AntiMalware
Default=False
FileKey1=%LocalAppData%\Zemana\Zemana AntiMalware\reports|*.txt
Link to comment
under system, Windows Error Reporting
the dump location are used by WER
as for entries that have "Windows" in it, some entries should have "Windows" to avoid confusion and it's up to the @ROCKNROLL whether to follow that naming scheme or not
Link to comment
I agree. I think "Windows" can be removed from [Windows Error Reporting More*], [Windows Installer Temps*], [Windows Memory Leak Detection*], [Windows System Profile*] and [Windows Tracing*].
Link to comment
Updated: https://github.com/MoscaDotTo/Winapp2/commit/b0a91971be469b26030d37c375e5bdeeb6a81066
I will keep the current version scheme then.
As for the Memory Dumps rule, that is only for the non-CCleaner version of Winapp2. Years ago, there was a cleaner for Winapp2 for cleaning memory dumps, until it was added to CCleaner. That is why it is in the Removed entries file.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
Revised Entry
Changed name from [Windows Backup*] to [Windows Backup Logs*] and corrected the Detect.
LangSecRef=3025
Detect=HKLM\Software\Microsoft\Windows
Default=False
FileKey1=%WinDir%\Logs\WindowsBackup|*.etl
Link to comment
 [AIMP 4*]
LangSecRef=3023
DetectFile=%ProgramFiles%\AIMP\AIMP.exe
Default=False
Warning=This will delete AIMP's auto profile and program backup. Make sure your AIMP running properly before using this entry
FileKey1=%AppData%\AIMP|*.bak
Filekey2=%ProgramFiles%\AIMP\!Backup|*.*|REMOVESELF
- add FK2 - delete auto backup of profile and program
[PnaclTranslation Cache*]
LangSecRef=3029
SpecialDetect=DET_CHROME
Default=False
FileKey1=%LocalAppData%\Google\Chrome\User Data\PnaclTranslationCache|*.*
[Auslogics Disk Defrag Professional*]
LangSecRef=3024
Detect1=HKLM\SOFTWARE\Auslogics\Disk Defrag Professional
Detect2=HKLM\SOFTWARE\WOW6432Node\Auslogics\Disk Defrag Professional
Default=False
FileKey1=%CommonAppData%\Auslogics\Disk Defrag Professional\*\Logs|*.*|RECURSE
FileKey2=%CommonAppData%\Auslogics\Disk Defrag Professional\*\Reports|*.*|RECURSE
FileKey3=%ProgramFiles%\Auslogics\Disk Defrag Professional|ndefrg.log
- fix filekey3
is there any reason why we should delete PendingFileRenameOperations@RK1? https://technet.microsoft.com/en-us/library/cc960241.aspx
i noticed the problem with this entry using WhyReboot software after updating 7-zip where older context menu dll file doesn't get replaced with the newer dll
i think we need to remove RK1 and rename to [AppCompactCache*]
[session Manager*]
LangSecRef=3025
Default=False
FileKey1=%WinDir%\AppCompat\Programs|*.txt;*.xml
FileKey2=%WinDir%\AppCompat\Programs\Install|*.txt;*.xml
RegKey1=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager|PendingFileRenameOperations
RegKey2=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\AppCompatCache|AppCompatCache
RegKey3=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\AppCompatCache|CacheMainSdb
RegKey4=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\AppCompatCache|SdbTime
Link to comment
[session Manager*]
LangSecRef=3025
Default=False
This could contain information about programs that were once on the system and now are not. There are two other known privacy eraser programs that have included this into their programs. My suggestion is, open some portable apps then remove it from the system completely, and purge from the Recycle bin. Then, uninstall a few programs from the system and then view the "AppCompatCache" value and you will see for yourself.
Link to comment
AppCompatCache work like Perfetch, i know that after i google-d it but what about RegKeg1?
deleting PendingFileRenameOperations will create problem like i've mentioned above
Link to comment
I agree with you. RegKey1 should be excluded.
Link to comment
Distributed [Windows System Profile*] into separate entries. So please add these and remove [Windows System Profile*].
[systemprofile Cookies*]
LangSecRef=3022
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%WinDir%\System32\config\SystemProfile\Cookies|*.*|RECURSE
FileKey2=%WinDir%\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies|*.*|RECURSE
FileKey3=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies|*.*|RECURSE
[systemprofile History*]
LangSecRef=3022
Default=False
FileKey1=%WinDir%\System32\config\SystemProfile\History|*.*|RECURSE
FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History|*.*|RECURSE
FileKey3=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\History|*.*|RECURSE
[systemprofile Temporary Files*]
LangSecRef=3025
Default=False
FileKey1=%WinDir%\System32\config\SystemProfile\Local Settings\Temp|*.*|RECURSE
FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\Temp|*.*|RECURSE
FileKey3=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Temp|*.*|RECURSE
[systemprofile Temporary Internet Files*]
LangSecRef=3022
Default=False
FileKey1=%WinDir%\System32\config\SystemProfile\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
FileKey3=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
Link to comment
Revised Entry
Changed |REMOVESELF with |RECURSE
[NetworkService Cookies*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Cookies|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService.NT*\Cookies|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp\Cookies|*.*|RECURSE
FileKey4=%WinDir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Cookies|*.*|RECURSE
Link to comment
Revised Entry
Removed: HKLM\SYSTEM\CurrentControlSet\Control\Session Manager|PendingFileRenameOperations
[session Manager*]
LangSecRef=3025
Default=False
RegKey1=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\AppCompatCache|AppCompatCache
RegKey2=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\AppCompatCache|CacheMainSdb
RegKey3=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\AppCompatCache|SdbTime
Link to comment
Revised Entry
[session Manager*]
LangSecRef=3025
Default=False
why not change the name to AppCompactCache* ?
i think it is better to use that name rather than Session Manager
Link to comment
What is this entry about and why is it in the Windows Store Apps section?
I think it should be removed.
[Windows Retail Demo*]
DetectOS=10.0|
Section=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft
Default=False
FileKey1=%CommonAppData%\Microsoft\Windows\RetailDemo|*.*|REMOVESELF
Link to comment
DetectOS=10.0|
Section=3031
Default=False
https://github.com/MoscaDotTo/Winapp2/issues/20
https://github.com/MoscaDotTo/Winapp2/pull/21
Link to comment
DetectOS=10.0|
Section=3031
Default=False
This is from Windows 10 Insider Builds.  I would not remove it.
https://www.neowin.net/news/windows-10-has-a-secret-retail-demo-mode-with-a-new-app-and-video-loop
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD21, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
Revised Entry
Changed name from [NetworkService Temps*] to [NetworkService Temporary Files*] same like [LocalService Temporary Files*] and [systemprofile Temporary Files*].
LangSecRef=3025
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Temp|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService.NT*\Local Settings\Temp|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp|*.*|RECURSE
Link to comment
Do we really need the entries listed below. I cannot find those locations on Window 7, 8, 8.1 and 10. I checked a few other known privacy eraser programs and they don't have cleaning rules for the locations listed below.
[LocalService Cookies*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Cookies|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\LocalService.NT*\Cookies|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Temp\Cookies|*.*|REMOVESELF
FileKey4=%WinDir%\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Cookies|*.*|REMOVESELF
[LocalService History*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Local Settings\History|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\LocalService.NT*\Local Settings\History|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\History|*.*|RECURSE
[LocalService Temporary Internet Files*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\LocalService.NT*\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
LangSecRef=3022
Default=False
[NetworkService History*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\History|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService.NT*\Local Settings\History|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\History|*.*|RECURSE
[NetworkService Temporary Internet Files*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Content.IE5|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey3=%SystemDrive%\Documents and Settings\NetworkService.NT*\Local Settings\Content.IE5|*.*|RECURSE
FileKey4=%SystemDrive%\Documents and Settings\NetworkService.NT*\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey5=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
FileKey6=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Content.IE5|*.*|RECURSE
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
Link to comment
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
I have some of the locations on my Win10 system. My guess could be these are some old entries during 2000/XP times, as I see Content.IE5, which makes me think of Internet Explorer 5.
Link to comment
I think we should change Detect to DetectFile=CommonAppData%\Microsoft\Windows\RetailDemo and DetectOS=10.0| can be removed.
DetectOS=10.0|
Section=3025
Default=False
Link to comment
Same here, all of these exist on my Win7 laptop:
Becoming a regular occurrence in this thread - "This doesn't exist on MY system so should be removed from winapp2". Not that it bothers me as I hardly bother with the main file since the GitHub move, makes it a PITA to copy new entries.
Link to comment
Register a new account
Sign in
Important Information
