Winapp2.ini additions
Winapp2.ini
Awesome
One more thing I forgot to mention and I do not know how he gets that figure.  Just below the version number, there is this:
; Notes
; # of entries: 2,579
Unless he can tell us, my suggestion would be to eliminate that count until a correct number of entries count can be placed within the file
Since each entry must start with [ then just count the number of "[" in the file...
which for "Version: v5.24.161210" is 2,549
Link to comment
Awesome
; Notes
APMichael mentioned a way to do this with Notepad++ some time ago: https://forum.piriform.com/index.php?showtopic=32310&p=276966
He also mentioned Trim.bat also counts the number of entries.
Robert just counted the number of entries manually himself and Notepad++ comes up with the same. Sometimes I forget to update that number.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
Nice work guys.  I just ran the TRIM.BAT and id does come up with 2578
CREATING FALSE/TRUE VARIANTS #_ZAP_WINAPP2.INI + #_DEBUG_ZAP_WINAPP2.INI
14:32:13.74 - 14:32:05.92 = 7820 mSec   = Counted 2578 Configuration blocks
Link to comment
CCleaner 5.25 can't recognize winapp2.ini although I put it in %Program Files%\CCleaner\ folder.
I have reinstalled CCleaner but it resolves nothing.
Any idea of workarounds?
Will it recognize the INI file if you run it as a portable?
@ ROCKNROLL -  Since v5.25 has been released, maybe update the INI version to match the new release with any updates, this way you do not have to update the INI file until a new version of Ccleaner is released.
Link to comment
When you open CCleaner and select "Cleaner" on the left icon bar and then the "Applications" tab, there are no items with an * showing up in the list?  If there are, you have to check mark the ones you want to use.
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD21, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
No.
There is no asterisk (*) items in Cleaner tab.
I have been using winapp2.ini since a long time. But, Since the newest version (v5.25), I can't see the asterisk items anymore.
I installed 5.25 in overwrite mode. I tried to reinstall it (clean uninstall then install it again), but it can't resolve the problem.
Siliconman01, does it still work for you using v5.25 in your computer?
Link to comment
Yes, it (CCleaner v5.25.5902 + the latest winapp2.ini) is working fine for me on all of my computers which are all Windows 10 x64 Pro and different hardware platforms.
Zip your winapp2.ini and attach it to a post here so I can take a look at it.  I assume that you use "trim.bat" to reduce the size of the big winapp2.ini to match your system, eh ?  You didn't accidentally put it in your C:\program files\CCleaner as winapp2.txt, did you?
Link to comment
I copy-paste the filename here: Winapp2.ini
Where is the attachment feature here, BTW?
But, for temporary, I could provide its SHA-1 checksum for you: f1f6539ffe5ddfaa684f1985f17d0b78a7bdff60
No, I DON'T trim it.
File size: 5.65 MB (5,932,876 bytes)
File size on disk: 5.66 MB (5,935,104 bytes)
Link to comment
Here the file.
The file you posted is not winapp2.ini.  It looks like you downloaded the wrong file github.
You need to download the RAW version of winapp2.ini from https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp2.ini
I have attached a pic that shows the beginning of the proper winapp2.ini file.
Once the html page opens showing the winapp2.ini file, do a <select all><copy>.  Then open Notepad and paste winapp2.ini into a blank Notepad page.  Save the Notepad document as Winapp2.ini into the CCleaner folder
Link to comment
Just the first of a regular stream I suspect, finding the file is not straightforward on GitHub. And even then you can't download it cos of the formatting, you have to copy and paste :unsure:
Link to comment
  • Moderators
Remind me the problem with downloading that necessitates the copy/paste
Link to comment
Today I re-uploaded the Winapp2 file, which should fix the formatting issue. Can you please try out the new file and see if it still happens. This file was re-uploaded through plain text, so it is best not to use any rich text editors, like Wordpad. Notepad or Notepad++ works best.
Link to comment
Still no line breaks viewing with Notepad
Link to comment
  • Moderators
Link to comment
No that is for git, which is a version control system: https://git-scm.com/
Anyways, I think the issue is more related to this: http://superuser.com/questions/362087/notepad-ignoring-linebreaks and https://github.com/zeroclipboard/ZeroClipboard/issues/222  A user mentioned the /n would break line breaks in Notepad and there are many entries that have that in it. This doesn't happen in Wordpad or Notepad++ right?
Link to comment
Yes Notepad++ works fine.
We have also discuss these Problem and found a workaround ;-)
Posts 5853-5856.
THX for the informartion.
I found a free programm for it ;-)
@echo off
:: Programms:
:: http://gnuwin32.sourceforge.net/packages/wget.htm
:: https://curl.haxx.se/download.html
:: http://waterlan.home.xs4all.nl/dos2unix.html
echo Download winapp2.ini from Github
ping /n 1 raw.githubusercontent.com
if errorlevel 1 goto NOC
echo online
del winapp2.ini
::curl.exe -o Winapp2.ini -A "Mozilla/5.0 (iPhone; U; CPU like Mac OS X; en) AppleWebKit/420+ (KHTML, like Gecko) Version/3.0 Mobile/1A543a Safari/419.3" -G "https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp2.ini"
wget.exe -c --output-document=Winapp2.ini "https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp2.ini"
unix2dos.exe Winapp2.ini
goto end
:NOC
echo no connection
:end
ccleaner.exe
Link to comment
@echo off
:: Programms:
echo online
del winapp2.ini
goto end
:NOC
echo no connection
:end
ccleaner.exe
The problem with this is that it executes unix2dos.exe Winapp2.ini but does not check to see if unix2dos.exe exists on the system to make the conversion.
Link to comment
  • 2 weeks later...
  • 2 weeks later...
Modified Entries:
[Google Crash Reports*]>[Chrome Crash Reports*]
-  Changed name from [Google Crash Reports*]  to [Chrome Crash Reports*]
-  Changed LangSecRef=3022 to LangSecRef=3029
-  Changed Detect to SpecialDetect=DET_CHROME
-  Added FileKey2
LangSecRef=3029
Default=False
FileKey1=%LocalAppData%\Google\CrashReports|*.*
FileKey2=%LocalAppData%\Google\Chrome\User Data\Crashpad\reports|*.*
[Google Update*]>[Chrome Update*]
-  Changed name from [Google Update*] to [Chrome Updates*]
[Chrome Update*]
LangSecRef=3029
Default=False
FileKey1=%LocalAppData%\Google\Update\Download|*.*|RECURSE
FileKey2=%LocalAppData%\Google\Update\Install|*.*|RECURSE
FileKey3=%LocalAppData%\Google\Update\Offline|*.*|RECURSE
FileKey4=%LocalAppData%\VirtualStore\Program Files*\Google\Update\Download|*.*|RECURSE
FileKey5=%LocalAppData%\VirtualStore\Program Files*\Google\Update\Install|*.*|RECURSE
FileKey6=%LocalAppData%\VirtualStore\Program Files*\Google\Update\Offline|*.*|RECURSE
FileKey7=%ProgramFiles%\Google\Update\Download|*.*|RECURSE
FileKey8=%ProgramFiles%\Google\Update\Install|*.*|RECURSE
FileKey9=%ProgramFiles%\Google\Update\Offline|*.*|RECURSE
Link to comment
Register a new account
Sign in
Important Information
